HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt
pi@iobroker-pi:~ $ iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -bash: iob_diag:: Kommando nicht gefunden. pi@iobroker-pi:~ $ curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh pi@iobroker-pi:~ $
Keine Reaktion
Ich hatte das Ding vorhin schonmal gemacht.
da kam das hier bei raus======================= SUMMARY ======================= v.2023-10-25 Static hostname: iobroker-pi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 21 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.0 /usr/bin/node v18.18.0 npm ERR! code ENOSPC npm ERR! syscall write npm ERR! errno -28 npm ERR! nospc ENOSPC: no space left on device, write npm ERR! nospc There appears to be insufficient space on your system to finish. npm ERR! nospc Clear up some disk space and try again. npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-31T08_30_09_951Z-debug-0.log /usr/bin/npm npm ERR! code ENOSPC npm ERR! syscall write npm ERR! errno -28 npm ERR! nospc ENOSPC: no space left on device, write npm ERR! nospc There appears to be insufficient space on your system to finish. npm ERR! nospc Clear up some disk space and try again. npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-31T08_30_11_154Z-debug-0.log /usr/bin/npx /usr/bin/corepack 0.19.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 50M 3.4G 8.0M 443M 3.7G Swap: 12M 0B 12M Total: 3.9G 50M 3.4G Active iob-Instances: 0 ioBroker Core: js-controller admin ioBroker Status: Status admin and web instance: Objects: 0 States: 0 Size of iob-Database: 29M /opt/iobroker/iobroker-data/objects.jsonl 2.7M /opt/iobroker/iobroker-data/objects.json.migrated 2.7M /opt/iobroker/iobroker-data/objects.json.bak.migrated 88M /opt/iobroker/iobroker-data/states.jsonl 16K /opt/iobroker/iobroker-data/states.json.migrated 16K /opt/iobroker/iobroker-data/states.json.bak.migrated =================== END OF SUMMARY ====================
Der Datenträger ist voll. Und Buster tot.
Installier es neu unter Bookworm. 64Bit, kein Desktop.
habe wir hier dazu eine Anleitung ?Bookworm 64 bit kein Desktop - da verstehe ich leider nicht was du damit meinst.
Neuinstallation bedeutet dass die Skripts, Visus und Adaptereinistellungen alle weg sind ? Oder komm ich da noch irgendwie dran ?
@dellishelly sagte in HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt:
Du hast doch ein Backup.
Das spielst du ein, nachdem die aktuellste Version des Betriebssystems installiert wurde.https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
ich glaube ich steh leider auf dem Schlauch.
Also ich nehm mir ne neue SD Karte und folge 1:1 deiner Installationsanleitung ? Was ist hier mit Bookworm gemeint ?
Wie fahre ich dann fort ? wie bekomme ich das Backup von der alten Karte auf die neue ?
Backups liegen immer extern. Auf einem NAS oder einem externen Hoster. Ein Backup auf dem gleichen Datenträger nützt dir ja nix, wenn der einen Defekt hat.
Also hast du kein gescheites Backup? -
sudo apt clean
Danach solltest du wieder rein kommen.
sudo systemctl restart iobroker
vielleicht noch. Dann Backup ordentlich einrichten und mit dem Kram in ein aktuelles System umziehen.
pi@iobroker-pi:~ $ sudo apt clean -bash: /usr/bin/sudo: Input/output error pi@iobroker-pi:~ $
der Befehl klappt leider auch nicht glaub ich
----- War disconnected........ moment
pi@iobroker-pi:~ $ sudo apt clean pi@iobroker-pi:~ $ sudo su - root@iobroker-pi:~# apt clean root@iobroker-pi:~# sudo systemctl restart iobroker Failed to restart iobroker.service: Unit iobroker.service has a bad unit file setting. See system logs and 'systemctl status iobroker.service' for details. root@iobroker-pi:~#
root@iobroker-pi:~# ls -lah /opt/iobroker/backups/ insgesamt 401M drwxrwxr-x+ 2 iobroker iobroker 4,0K Okt 29 02:41 . drwxrwxr-x+ 7 iobroker iobroker 4,0K Okt 31 08:55 .. -rw-rwxr--+ 1 iobroker iobroker 42M Sep 21 02:41 iobroker_2023_09_21-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Sep 29 02:41 iobroker_2023_09_29-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 41M Okt 1 02:41 iobroker_2023_10_01-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Okt 5 02:41 iobroker_2023_10_05-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 40M Okt 9 02:41 iobroker_2023_10_09-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 37M Okt 13 02:41 iobroker_2023_10_13-02_40_13_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 40M Okt 17 02:41 iobroker_2023_10_17-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 41M Okt 21 02:41 iobroker_2023_10_21-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 40M Okt 25 02:41 iobroker_2023_10_25-02_40_11_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 40M Okt 29 02:41 iobroker_2023_10_29-02_40_11_backupiobroker.tar.gz root@iobroker-pi:~#
@thomas-braun said in HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt:
exit
df -hpi@iobroker-pi:~ $ df -h Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf /dev/root 15G 14G 653M 96% / devtmpfs 1,8G 0 1,8G 0% /dev tmpfs 1,9G 0 1,9G 0% /dev/shm tmpfs 1,9G 8,4M 1,9G 1% /run tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup /dev/mmcblk0p1 247M 50M 197M 21% /boot tmpfs 389M 0 389M 0% /run/user/1000 pi@iobroker-pi:~ $
ich lese grad nebenbei noch einen topic in dem der admin nicht erreichbar war....
Das Thema mqtt Logfile....
Ich glaube ich hab mir den Speicher mit debug Logfiles zugespamt... kann das sein ?
sudo ncdu /
/.. 3,1 GiB [##########] iobroker.2023-10-30.log 319,6 MiB [# ] iobroker.2023-10-24.log.gz 315,2 MiB [# ] iobroker.2023-10-23.log.gz 289,0 MiB [ ] iobroker.2023-10-25.log.gz 273,3 MiB [ ] iobroker.2023-10-28.log.gz 259,7 MiB [ ] iobroker.2023-10-29.log.gz 233,6 MiB [ ] iobroker.2023-10-27.log.gz 216,3 MiB [ ] iobroker.2023-10-26.log.gz 177,4 MiB [ ] iobroker.2023-10-30.log.gz 26,6 MiB [ ] iobroker.2023-10-31.log 4,0 KiB [ ] iobroker-audit.json @ 0,0 B [ ] iobroker.current.log
wie lösch ich das Moped ?
cd /opt/iobroker/logs > iobroker.2023-10-30.log
Und dann schaust du per
zless iobroker.2023-10-30.log.gz
in die Datei rein und guckst was da so ausgetickt ist.
