    2. English
    3. Development
    4. New Adapter - Soliscloud
      Schneider_Helmut @Trixx last edited by Schneider_Helmut
      @trixx
      I really appreciate your support. Your adapter will be very useful to Solis as people increasingly want to network systems. I can't understand why manufacturers don't make an effort to open up to common automation solutions and offer adapters themselves. For example, I have been looking for a wallbox for months where the manufacturer offers an IoBroker adapter with which I can start charging via IO-Broker and specify the charging current for the car myself.
      And I still did not find one.
      Trixx 1 Reply Last reply Reply Quote 0
      • Trixx
        Trixx @Schneider_Helmut last edited by Trixx
        The latest version on github is broken, I broke it while trying to fix something else...
        I'll try fixing this tonight.
        Edit; small fix. Already ok again
          Luapsi @Trixx last edited by
          @trixx
          I am also interested in the “Soliscloud” adapter.
          The installation was successful, unfortunately I can't get any further with the settings so that access to the SolisCloud is possible.
          No SolisCloud is displayed in the instances, but that's okay in the objects?
          I have already activated the Solis API.
          I have only recently started using ioBroker.
          Thk Sven
          Trixx Homoran 2 Replies Last reply Reply Quote 0
          • Trixx
            Trixx @Luapsi last edited by
            @luapsi
            Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
            From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
              Homoran Global Moderator Administrators @Luapsi last edited by
              @luapsi sagte in New Adapter - Soliscloud:
              that is the regular behavior by installing via github.
              The instance has to be added manually
                Luapsi @Homoran last edited by
                Hello, I just found it in the documentation.
                Thank you very much:)
                  @trixx sagte in New Adapter - Soliscloud:
                  battery_current_usage
                  hi @trixx,
                  The SolisCloud adapter also works for me. Thank you for your implementation.
                  As you requested, it would be great if these values ​​could be added:
                  from the Power Station List:
                  1. batteryTodayDischargeEnergy
                  2. batteryTodayChargeEnergy
                  3. homeLoadTodayEnergy
                  4. state
                  5. oneSelf
                  from the Inverter List:
                  1. eToday
                  2. etodayStr
                  3. state
                  Gerne teste ich für Dich!
                  • Trixx
                    @luapsi said in New Adapter - Soliscloud:
                    hi @trixx,
                    4. state
                    5. oneSelf
                    1. eToday
                    2. etodayStr
                    3. state
                    Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
                    I'll let you know once I have an update on this.
                    L 2 Replies Last reply Reply Quote 1
                      @trixx
                      hi @Trixx
                      thank you for taking the suggestions!
                      Here's a little addition!
                      In ioBroker, instances are assigned a category!
                      Would you be so kind as to put your instance in the “Energy” category?
                      Here is an excerpt from instances in this category
                      Thx Sven
                      • Trixx
                        @luapsi
                        I've just pushed a new version to github, I think it should include all requested additions 🙂
                        Regards,
                        Trixx
                          @trixx
                          Your performance is great, thank you very much.
                          I will test extensively and give you feedback.
                          I wish you a pleasant day
                            Luapsi @Trixx last edited by Luapsi
                            Hi @trixx,
                            all data fields are correct.
                            Thanks for the quick and professional work.
                            from the v1/api/InverterDetail:
                            1. familyLoadPower
                            2. familyLoadPowerStr
                            3. id inverter id
                            4. sn inverter sn
                            5. iAc1 AC current R
                            6. iAc2 AC current S
                            7. iAc3 AC current T
                            8. uAc1 AC voltage R
                            9. uAc2 AC voltage S
                            10. uAc3 AC voltage T
                            11. inverterTemperature
                            12. batteryPower
                            13. batterypowerStr
                            14. batteryPowerPec
                            15. batteryTodayChargeEnergy
                            16. batteryTodayChargeEnergyStr
                            17. batteryMonthChargeEnergy
                            18. batteryMonthChargeEnergyStr
                            19. batteryYearChargeEnergy
                            20. batteryYearChargeEnergyStr
                            21. batteryTotalChargeEnergy
                            22. batteryTotalChargeEnergyStr
                            23. batteryTodayDischargeEnergy
                            24. batteryTodayDischargeEnergyStr
                            25. batteryMonthDischargeEnergy
                            26. batteryMonthDischargeEnergyStr
                            27. batteryYearDischargeEnergy
                            28. batteryYearDischargeEnergyStr
                            29. batteryTotalDischargeEnergy
                            30. batteryTotalDischargeEnergyStr
                            another note about the data structure:
                            Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
                            • Power Station List (v1/api/userStationList)
                            • Power Station Detail (v1/api/stationDetail)
                            • Datalogger List (v1/api/collectorList)
                            • Data logger details (v1/api/collectorDetail)
                            Inverter List (v1/api/inverterList)
                            • Inverter details (v1/api/inverterDetail)
                              possible!
                            If I can support you here, please let me know.
                            Greetings from Saxony
                            PS: the app currently available from Solis cannot be used in this way.
                            • Trixx
                              @luapsi
                              I've pushed another version to github.
                              The values are split up between the inverter & station details, for the values I did have to switch some things.
                              The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
                              I still have a few more to add and need to adjust some units .
                              I'll try to get to those later today or later this week.
                              Regards,
                              Trixx
                                @trixx
                                Thank you for your enthusiasm and commitment!
                                For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
                                Let me know if there is any news.
                                Greetings Sven
                                  Luapsi @Luapsi last edited by Luapsi
                                  @Trixx
                                  The problem with the API is solved.
                                  An additional group is still needed 🙂
                                  Is it possible for you to integrate these?
                                  is needed to calculate data!
                                  Thank you very much in advance!
                                  from v1/api/epmDetail:
                                  1. state
                                  2. iAc1 Current U
                                  3. iAc2 Current V
                                  4. iAc3 Current W
                                  5. uAc1 Voltage U
                                  6. uAc2 Voltage V
                                  7. uAc3 Voltage W
                                  8. pAc1 Power U
                                  9. pAc2 Power V
                                  10. pAc3 Power W
                                  11. facMeter
                                  12. pEpmTotal
                                  13. pEpmTotalStr
                                  14. eTotalBuy
                                  15. eTotalBayStr
                                  16. eTotalSell
                                  17. etotalSellStr
                                  Thanks
                                  Trixx 2 Replies Last reply Reply Quote 0
                                  • Trixx
                                    @luapsi
                                    I'll see what I can do !
                                    • Trixx
                                      @luapsi
                                      Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
                                      I do have some IRL things to take care of this week, so it might be a few days before I get to this.
                                      Regards,
                                      Trixx
                                      • Trixx
                                        Trixx last edited by Trixx
                                        @luapsi
                                        Hi !
                                        Sorry for the long delay. I had some stuff going on that I needed to handle first...
                                        I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                                        Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                                        With that I should be able to map the values you requested.
                                        Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                                        Happy holidays !
                                        Regards,
                                        Trixx
                                        • M T
                                          M T @Schneider_Helmut last edited by
                                          Hallo
                                          Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                                          @schneider_helmut said in New Adapter - Soliscloud:
                                          @trixx
                                          Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                                          Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                                          mcm1957 M T 2 Replies Last reply Reply Quote 0
                                          • mcm1957
                                            mcm1957 @M T last edited by mcm1957
                                            @m-t said in New Adapter - Soliscloud:
                                            Hallo
                                            Können sie bitte einen Bild hochladen .........
                                            This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                                            M T 1 Reply Last reply Reply Quote 0
                                            57
                                            8524
