    • Nashra
      @SBorg
      kannst Du mir sagen was da heute Nacht schiefgelaufen ist
      2023-10-01 01:02:12.184 - info: linux-control.0 (2530934) successful received data from Proxmox (192.168.1.13:22)
      2023-10-01 01:03:00.082 - error: javascript.0 (2529042) Error in callback: SyntaxError: Unexpected token o in JSON at position 1
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at JSON.parse ()
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at VorJahr (script.js.Wetter.Statistik-WS:417:24)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at Object.main (script.js.Wetter.Statistik-WS:158:4)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at listOnTimeout (node:internal/timers:569:17)
      2023-10-01 01:03:00.083 - error: javascript.0 (2529042) at processTimers (node:internal/timers:512:7)
      2023-10-01 01:04:00.048 - info: host.ioBroker instance system.adapter.weatherunderground.0 started with pid 841580
      Node 18.18.0
      Admin 6.10.1
      Javascript 7.1.4
      IOB 5.0.12
      Boronsbruder 1 Reply Last reply Reply Quote 0
      • Boronsbruder
        Boronsbruder @Nashra last edited by Boronsbruder
        @Nashra
        Ich würde behaupten, der Json den er vom Vorjahr parsen wollte, ist kein JSON (von der Formatierung), sondern ein Object?
        Meiner sah z.B. so aus:
        [{'Tiefstwert':2.1,'Hoechstwert':24.7,'Temp_Durchschnitt':12.14,'Max_Windboee':47.87,'Max_Regenmenge':19.304,'Regenmenge_Monat':60.51,'warme_Tage':9,'Sommertage':0,'heisse_Tage':0,'Frost_Tage':0,'kalte_Tage':0,'Eistage':0,'sehr_kalte_Tage':0}]
        • SBorg
          Jupp, alt bekanntes Problem. So wie es aktuell erstellt wird ist es auch kein ioB valides JSON. Das ist nur "hin- und zusammen gefrickelt" damit es "irgendwie" mit allem anderen funktioniert (zumindest mehr oder weniger).
          Plan: korrektes JSON erstellen, Konverter für die Alt-Datensätze erstellen, um sie in korrektes JSON umzuwandeln, Skripte ggf. anpassen
          Umsetzung: unbekannt, nicht in absehbarer Zeit meinerseits
          • Nashra
            Hi, sorry war 3 Tage im Krankenhaus, daher erst jetzt. Kein Problem @SBorg , wird ja trotzdem alles korrekt angezeigt.
            Also ganz in Ruhe irgendwann mal wenn Du Zeit hast.
            • SBorg
              SBorg Forum Testing Most Active @Nashra last edited by
              @nashra
              Hoffe alles wieder gut, auf jeden Fall gute Besserung.
              Also nie ? 🤘
              Hier "stapelt" nix mehr, das "türmt" sich schon, von wegen Arbeit und so...
              Prio hat jetzt aktuell meine Solaranlagenerweiterung, dann steht die Klima auf der ToDo und so weiter 😉
              • Nashra
                Nashra Most Active Forum Testing @SBorg last edited by
                @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                @nashra
                Also nie ? 🤘
                Na Na Na, so war das aber jetzt auch nicht gemeint 😀
                Ok, wichtiger. Dann mal ran...
                • V
                  viper4iob @Sugomojawe last edited by viper4iob
                  @sugomojawe said in [Linux Shell-Skript] WLAN-Wetterstation:
                  ich hätte da mal eine Frage. mein Vater hat mich mit dem ganzen Thema etwas angefixt. Er ist Amateurfunker und hat in seinem Hobbyraum eine ganze Station um Wetterbilder von Meteosat zu empfangen.
                  Aber zu meiner Frage, ich habe vor mir die Froggit HP1000SE PRO Display inkl. Innensensor + DP40 Aussen Temperatur/Luftfeuchte + DP80 Regensensor + DP300 Anemometer zu kaufen. Wie läuft das mit dem DP80 Regensensor? Der steht ja nicht in der Liste der Zusatzsensoren, wird der mit dem Display verbunden und dann so an ioBroker übermittelt oder wie kann ich mir das vorstellen?
                  Danke und liebe Grüße aus dem Westerwald
                  Michael
                  ich habe von Froggit die HP1000SE PRO Single Sensor Edition und zusätzlich einen zweiten Außentemperatursensor und einen Blitzdetektor.
                  In der Single Sensor Edition ist auch der DP80 enthalten und das funktioniert ohne Probleme, er sendet also seine Werte als "regulärer Sensor" und muss nicht als zusätzlicher Sensor hinzugefügt werden.
                  In der config habe ich bei folgenden Sensoren eine 1 stehen:
                  ANZAHL_WH31=1	#Außen Thermo-Hygrometer
                  ANZAHL_DP40=1	#zusätzliches Außen Thermo-Hygrometer
                  ANZAHL_DP50=1	#Innen Thermo-Hygrometer
                  ANZAHL_DP60=1	#Blitzdetektor
                  ANZAHL_DP300=1	#Anemometer und Lichtsensor
                  • Rene55
                    Rene55 @SBorg last edited by
                    @sborg Ich habe gestern (😖) festgestellt, dass die Werte von 0_userdata.0.Wetterstation.Info.Temp_Aussen_24h_max (und ähnliche) nicht da sind. Kannst du mir kurz einen Hinweis geben, wo da was falsch läuft, bzw. wann die von wem geschrieben werden? Ich blick gerade nicht mehr durch.
                    • SBorg
                      SBorg Forum Testing Most Active @Rene55 last edited by
                      @rene55 Wird aus der InfluxDB gelesen.
                      Dazu nötig:
                      • loggen der Außentemperatur per Influx
                      • InfluxDB-Verbindung
                        • Bucket
                        • Token
                        • Organisation
                        • IP-Adresse und Port
                      Falls du also was an der InfluxDB geändert haben solltest...
                      Kleiner Test (auch im laufenden Betrieb) im Installationsverzeichnis stehen: ./wetterstation.sh --influx_test
                      • Rene55
                        Rene55 @SBorg last edited by Rene55
                        @sborg Danke, sowas hab ich gesucht. Ja, ich hatte eine andere Influx angebunden. Nach bestem Wissen sind alle Parameter richtig.
                        Bei dem Test bekomme ich jetzt:
                        ./wetterstation.sh: line 161: [: V3.2.0: unary operator expected
                        Testing InfluxDB... min/max Aussentemperatur 24h: °C °C
                        Hab nachgesehen: Alle Dateien haben intern die V3.2.0 stehen.
                        EDIT: Ich hab die .conf neu gemacht - der unary-Fehler ist weg, sonst unverändert keine Werte!
                        • Boronsbruder
                          Boronsbruder @Rene55 last edited by
                          @rene55
                          Schau mal
                          1. Ob Daten in der DB sind
                          2. Ins Log der DB, ob da nicht vielleicht der Zugriff durch das Skript zurückgwiesen wird
                          • Rene55
                            Rene55 @Boronsbruder last edited by Rene55
                            @boronsbruder Grundsätzlich sind Daten in der DB drin. _24h_max ist leer.
                            Log der DB??? Wo und wie?
                            • SBorg
                              @rene55 Weil wir es schon mal hatten, dein Token in der wetterstation.conf endet mit "==" ?
                              Da das Ganze URL basierend ist und ich noch nicht überall korrigiert habe, hast du ev. ein Sonderzeichen (auch Leerzeichen) im Bucket bzw. Organisation? Soweit ich mich noch erinnere ist die Organisation bei Influx auch case sensitiv.
                              Standardmäßig loggt InfluxDB ins syslog. Ich weiß aber nicht ob er da fehlende Rechte, User etc. pp. von Influx mit loggt.
                              Mach noch mal den Influx-Test von oben gefolgt von einem sudo dmesg|tail ob da was von Influx steht.
                              • Rene55
                                @sborg Das stimmt. Mein Token enden mit "==". Ich hab gerade den Befehl von oben nochmal ausgeführt und danach den dmesg gemacht dmesg: read kernel buffer failed: Operation not permitted.
                                Ich hatte extra ein Bucket für "weather" erstellt. Unter den meisten Einträgen sind Werte drin. Nur eben nicht bei den min/max-Werten.
                                • SBorg
                                  @rene55 Du hast als User kein Recht das syslog zu lesen (das ist die Fehlermeldung), deswegen der "sudo".
                                  Dann funktioniert eigentlich auch dein Influx-Zugriff (wahrscheinlicher ist aber das es genau die Werte sind die nicht aus der Influx kommen). Zumindest wenn alles funktionieren würde, müsste der Test Werte liefern. Der ließt einfach die Außentemperatur von 0:00 Uhr bis jetzt (oder 23:59 Uhr wenn es ein anderer Tag ist) und überlässt dann Influx den kleinsten/größten Wert zu ermitteln. Ich mache an der Stelle nichts als eine "simple" Influx-Abfrage.
                                  Mir fällt gerade noch was ein. Einen Alias nutzt du nicht beim loggen im ioB für die Außentemperatur?
                                  Ansonsten, siehst du einen Graphen in der InfluxDB-GUI wenn du die Außentemperatur abfragst?
                                  • Rene55
                                    Rene55 last edited by Rene55
                                    @sborg Oh, mag das der Fehler sein?
                                    Graph für "Aussentemperatur" ist da.
                                    • SBorg
                                      @rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                      Nö, das isser 🙂
                                      So kann er den DP unter Influx nicht abfragen.
                                      • Rene55
                                        @sborg Also Alias raus und nativ schreiben lassen! Oder gibt es noch eine Alternative (für mich)?
                                        • SBorg
                                          @rene55 Ich wollte das schon mal ändern, aber das Tagn unter dem Influx-Adapter läuft auch nicht so ganz wie es soll, dann hätte man darüber den Namen feststellen/selektieren können.
                                          Aktuell habe ich es halt über den kpl. Objektnamen lösen müssen. Beim Alias kann ich den Namen so wieder nicht auslesen (müsste aber IMO mittels der Rest-API funktionieren) und müsste dann wieder in der conf einen Parameter einfügen wie der Alias benannt wurde. Da sind eigentlich schon genug Parameter drin.
                                          Aber aktuell schlichtweg keine Zeit dafür und das ist nicht gerade mal in 5 Minuten gemacht (du kennst ja "mal schnell..." 😉 )
                                          • Rene55
                                            @sborg Nee lass mal. InfluxDB 3.0 steht ja auch noch ins Haus. Ich tüftel nochmal weiter - ich meld mich dann nochmal, wenn ich klüger bin (letzteres kann wohl dauern 🤔 )
                                            152
                                            5661
                                            3775793
