    3. Off Topic
    4. InfluxDB
    5. Influx DB unter bookworm installieren
    • N
      nobbiman last edited by
      Ich hänge mich mal hieran, das es mir seit 2 Tagen nicht gelingt Influxdb unter bookworm zu installieren:
      Was habe ich getan:
      Zunächst gem. o.a. Beschreibung die beiden Repos angelegt, dann gem. Beschreibung von hotspot_2 die Installation angestoßen.
      pi@RasPi-ioBroker:~ $ wget -q https://repos.influxdata.com/influxdata-archive_co        mpat.key
      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdat        a-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg        --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/nu        ll
      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://        repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/infl        uxdata.list
      rm influxdata-archive_compat.key
      influxdata-archive_compat.key: OK
      deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.        influxdata.com/debian stable main
      pi@RasPi-ioBroker:~ $ sudo apt-get install -y apt-transport-https
      sudo apt-get install -y software-properties-common wget
      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com st        able main" | sudo tee /etc/apt/sources.list.d/grafana.list
      Reading package lists... Done
      Building dependency tree... Done
      apt-transport-https is already the newest version (2.6.1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      software-properties-common is already the newest version (0.99.30-4).
      wget is already the newest version (1.21.3-1+b1).
      deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable m        ain
      pi@RasPi-ioBroker:~ $ sudo apt-get update
      sudo apt install -y influxdb
      Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
      Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
      Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Get:6 https://apt.grafana.com stable InRelease [5,984 B]
      Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
      Ign:8 https://repos.influxdata.com/debian bookworm InRelease
      Err:9 https://repos.influxdata.com/debian bookworm Release
        404  Not Found [IP: 99.86.4.4 443]
      Get:10 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6,123        B]
      Get:11 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6,155        B]
      Get:12 https://apt.grafana.com stable/main arm64 Packages [124 kB]
      Get:13 https://apt.grafana.com stable/main armhf Packages [106 kB]
      Err:7 http://archive.raspberrypi.com/debian bookworm InRelease
        The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 82B129927FA3303E
      E: The repository 'https://repos.influxdata.com/debian bookworm Release' does no        t have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disa        bled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration deta        ils.
      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: http://archive.raspb        errypi.com/debian bookworm InRelease: The following signatures couldn't be verif        ied because the public key is not available: NO_PUBKEY 82B129927FA3303E
      The following NEW packages will be installed:
        influxdb
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 50.7 MB of archives.
      After this operation, 148 MB of additional disk space will be used.
      Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb arm64 1.8.1        0-1 [50.7 MB]
      Fetched 50.7 MB in 11s (4,611 kB/s)
      Selecting previously unselected package influxdb.
      (Reading database ... 69131 files and directories currently installed.)
      Preparing to unpack .../influxdb_1.8.10-1_arm64.deb ...
      Unpacking influxdb (1.8.10-1) ...
      Setting up influxdb (1.8.10-1) ...
      Processing triggers for man-db (2.11.2-2) ...
      pi@RasPi-ioBroker:~ $ sudo systemctl unmask influxdb.service
      sudo systemctl start influxdb.service
      sudo systemctl enable influxdb.service
      Wo liegen denn hier die Fehler, die ich aus dem Meldungen mangels Kenntnissen nicht herauslesen, bzw. beseitigen kann?
      Hab mittlerweile versucht, die Installation zu löschen, da ich sie unter dem Port 8086 nicht erreichen kann.
      pi@RasPi-ioBroker:~ $ sudo apt-get autoremove influxdb
      The following packages will be REMOVED:
        influxdb
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 148 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 69156 files and directories currently installed.)
      Removing influxdb (1.8.10-1) ...
      Schaue ich mir mit htop an, was noch übrig gebleiben ist, finde ich noch Rest von influxdb
      /usr/bin/influxd -config /etc/influxdb/influxdb.conf
      Wie bekomme ich diese Reste weg und wie bewerkstelle ich eine erneute Insatllation?
        Thomas Braun Most Active @nobbiman last edited by Thomas Braun
        @nobbiman
        Ist doch drauf?
        • N
          nobbiman @Thomas Braun last edited by
          @thomas-braun wo sollte ich das finden?
            @nobbiman
            ? Steht im LogFile doch drin. Danach hast du es, warum auch immer, ja wieder rausgeworfen.
            • N
              @thomas-braun Weil die Installation nicht klappte, wollte ich alles wieder blank ziehen und einen neuen Weg suchen, deshalb bin ich hier!
                @nobbiman
                Die hat schon geklappt.
                sudo apt update
                ls -lah /etc/apt/sources.list.d/
                sagt?
                • N
                  @thomas-braun sagte in Influx DB unter bookworm installieren:
                  sudo apt update
                  pi@RasPi-ioBroker:~ $ sudo apt update
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Get:5 https://repos.influxdata.com/debian stretch InRelease [7,048 B]
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
                  Get:9 https://repos.influxdata.com/debian stretch/stable armhf Packages [3,639 B]
                  Get:10 https://repos.influxdata.com/debian stretch/stable arm64 Packages [7,071 B]
                  Err:8 http://archive.raspberrypi.com/debian bookworm InRelease
                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                  Fetched 17.8 kB in 2s (7,507 B/s)
                  All packages are up to date.
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                  W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  total 28K
                  drwxr-xr-x 2 root root 4.0K Oct 30 21:43 .
                  drwxr-xr-x 9 root root 4.0K Oct 31 13:19 ..
                  -rw-r--r-- 1 root root   84 Oct 31 13:14 grafana.list
                  -rw-r--r-- 1 root root  114 Oct 31 13:14 influxdata.list
                  -rw-r--r-- 1 root root   55 Oct 31 13:19 influxdb.list
                  -rw-r--r-- 1 root root  100 Oct 27 13:37 nodesource.list
                  -rw-r--r-- 1 root root  191 Oct 10 05:37 raspi.list
                    @nobbiman
                    sudo rm /etc/apt/sources.list.d/influxdb.list
                    sudo apt update
                    apt policy influxdb*
                    • N
                      pi@RasPi-ioBroker:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
                      sudo apt update
                      Hit:5 https://apt.grafana.com stable InRelease
                      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                      N: Unable to locate package influxdb.key
                      N: Couldn't find any package by glob 'influxdb.key'
                        @nobbiman
                        rm influxdb.key
                        sudo apt update
                        • N
                          rm influxdb.key
                          pi@RasPi-ioBroker:~ $ rm influxdb.key
                          sudo apt update
                          influxdb2-cli:
                            Installed: (none)
                            Candidate: 2.7.3-1
                            Version table:
                               2.7.3-1 500
                                  500 https://repos.influxdata.com/debian stable/main arm64 Packages
                               2.7.1-2 500
                               2.6.1 500
                               2.6.0 500
                               2.5.0 500
                               2.4.0 500
                               2.3.0 500
                          influxdb-client:
                            Installed: (none)
                            Candidate: 1.6.7~rc0-1+b13
                            Version table:
                               1.6.7~rc0-1+b13 500
                          influxdb-dev:
                            Installed: (none)
                            Candidate: (none)
                            Version table:
                          influxdb2-client:
                            Installed: (none)
                            Candidate: 2.7.1-1
                            Version table:
                               2.7.1-1 500
                          influxdb:
                            Installed: (none)
                            Candidate: 1.8.10-1
                            Version table:
                               1.8.10-1 500
                                  100 /var/lib/dpkg/status
                               1.6.7~rc0-1+b13 500
                          influxdb2:
                            Installed: (none)
                            Candidate: 2.7.3-1
                            Version table:
                               2.7.3-1 500
                               2.7.1-1 500
                               2.7.0-1 500
                               2.6.1-1 500
                               2.6.0-1 500
                               2.5.1-1 500
                               2.4.0-1 500
                               2.3.0-1 500
                               2.2.0 500
                            @nobbiman
                            Alles in der Auslage.
                            Jetzt kannst du den Key für raspberry noch reinziehen.
                            • N
                              nobbiman @Thomas Braun last edited by nobbiman
                              @thomas-braun Du sprichst in Rätseln, wahrscheinlich hast du schon bemerkt, dass ich kein Linux-Fan/-Freund/-Kenner bin. bitte sag mir, was ich zu tun habe, sprich den Key "reinziehen" kann
                                @nobbiman
                                wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                                sudo apt-key add raspberrypi.gpg.key
                                rm raspberrypi.gpg.key
                                Dann prüfen:
                                sudo apt update
                                • N
                                  pi@RasPi-ioBroker:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                                  --2023-10-31 14:32:52--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                                  Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 46.235.231.151, 46.235.231.145, 93.93.130.212, ...
                                  Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80... connected.
                                  HTTP request sent, awaiting response... 200 OK
                                  Length: 1719 (1.7K) [application/pgp-keys]
                                  Saving to: ‘raspberrypi.gpg.key’
                                  raspberrypi.gpg.key                                 100%[==================================================================================================================>]   1.68K  --.-KB/s    in 0.002s
                                  2023-10-31 14:32:52 (785 KB/s) - ‘raspberrypi.gpg.key’ saved [1719/1719]
                                  Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                  OK
                                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                  W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                  Wenn ich das mit meinem Geringwissen richtig interpretiere, sieht das gut aus, zumindest wurde offenbar der key für den raspberry gespeichert.
                                  Kann ich denn jetzt die erstgenannte influxdb-Installation erneut starten?
                                  Install lt. Hausautomation, s.o.
                                    @nobbiman
                                    sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                                    Dann halt die gewünschte Version von influxdb installieren. Ich würde die influxdb2 nehmen.
                                    • N
                                      Ich verneige mich vor dir und deiner Hilfsbereitschaft, wahrscheinlich hätte ich das ohne Hilfe nicht hinbekommen - sag mir, wo ich dir einen Kaffee spendieren kann!
                                      Aber noch eines: weißt du, ob ich vor der Installation mit
                                      sudo apt-get install influxdb2
                                      noch einen Key installieren muss? Ich frage, weil unter einer YT-Anleitung, ab 8:43 davon gesprochen wird.
                                        @nobbiman
                                        Ich schau keine YT-Filmchen. Solltest du auch nicht, die wenigsten davon sind wirklich zu gebrauchen.
                                        apt wird aber Meckern, wenn ein Key fehlen sollte. Es fehlt aber keiner, sonst hättest du da Meldungen analog zu der Meldung gesehen, die du jetzt ja angegangen bist.
                                        • N
                                          @thomas-braun Das sagt einer, der sich auskennt, dem Laien blieb eine intensive Einarbeitung in Linux, um ein Systemverständnis zu entwickeln. Eigentlich will ich nur mit dem später noch zu installierenden Grafan Daten aus dem ioBroker visualisieren. Das kostet mich genug Zeit.
                                          Also, was ist mit dem Kaffee?
                                            @nobbiman sagte in Influx DB unter bookworm installieren:
                                            YT-Clips sind halt eine große Zeitverschwendung. In der Zeit, wir da noch ein tolles Intro läuft und die erste nervige Werbeunterbrechung mir auf den Zeiger geht hab ich da schon eine bessere und aktuellere Anleitung in Schriftform gefunden. Zuletzt mal eine (ungelogen!) 10 minütige längliche Anleitung mit allem nervigen Krams gesehen, in der eine Datei mittels Editor um zwei Einträge ergänzt wurde. Das ist in einem Wiki oder Forum maximal ein Zweizeiler.
                                            Nicht erforderlich. Du kannst aber wenn du magst meiner Patentochter in Togo ein Taschengeld zukommen lassen.
                                            4483
