    3. Off Topic
    4. InfluxDB
    5. Influx DB unter bookworm installieren
      Thomas Braun Most Active @nobbiman last edited by Thomas Braun
      @nobbiman
      Ist doch drauf?
      Setting up influxdb (1.8.10-1)
      • N
        nobbiman @Thomas Braun last edited by
        @thomas-braun wo sollte ich das finden?
          @nobbiman
          ? Steht im LogFile doch drin. Danach hast du es, warum auch immer, ja wieder rausgeworfen.
          • N
            @thomas-braun Weil die Installation nicht klappte, wollte ich alles wieder blank ziehen und einen neuen Weg suchen, deshalb bin ich hier!
              @nobbiman
              Die hat schon geklappt.
              sudo apt update
              ls -lah /etc/apt/sources.list.d/
              sagt?
              • N
                @thomas-braun sagte in Influx DB unter bookworm installieren:
                sudo apt update
                pi@RasPi-ioBroker:~ $ sudo apt update
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:4 https://repos.influxdata.com/debian stable InRelease
                Get:5 https://repos.influxdata.com/debian stretch InRelease [7,048 B]
                Hit:6 https://apt.grafana.com stable InRelease
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
                Get:9 https://repos.influxdata.com/debian stretch/stable armhf Packages [3,639 B]
                Get:10 https://repos.influxdata.com/debian stretch/stable arm64 Packages [7,071 B]
                Err:8 http://archive.raspberrypi.com/debian bookworm InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                Fetched 17.8 kB in 2s (7,507 B/s)
                Reading package lists... Done
                Building dependency tree... Done
                All packages are up to date.
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                total 28K
                drwxr-xr-x 2 root root 4.0K Oct 30 21:43 .
                drwxr-xr-x 9 root root 4.0K Oct 31 13:19 ..
                -rw-r--r-- 1 root root   84 Oct 31 13:14 grafana.list
                -rw-r--r-- 1 root root  114 Oct 31 13:14 influxdata.list
                -rw-r--r-- 1 root root   55 Oct 31 13:19 influxdb.list
                -rw-r--r-- 1 root root  100 Oct 27 13:37 nodesource.list
                -rw-r--r-- 1 root root  191 Oct 10 05:37 raspi.list
                  @nobbiman
                  sudo rm /etc/apt/sources.list.d/influxdb.list
                  sudo apt update
                  apt policy influxdb*
                  • N
                    pi@RasPi-ioBroker:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
                    sudo apt update
                    Hit:5 https://apt.grafana.com stable InRelease
                    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
                    Err:7 http://archive.raspberrypi.com/debian bookworm InRelease
                    N: Unable to locate package influxdb.key
                    N: Couldn't find any package by glob 'influxdb.key'
                      @nobbiman
                      rm influxdb.key
                      sudo apt update
                      • N
                        rm influxdb.key
                        pi@RasPi-ioBroker:~ $ rm influxdb.key
                        sudo apt update
                        influxdb2-cli:
                          Installed: (none)
                          Candidate: 2.7.3-1
                          Version table:
                             2.7.3-1 500
                                500 https://repos.influxdata.com/debian stable/main arm64 Packages
                             2.7.1-2 500
                             2.6.1 500
                             2.6.0 500
                             2.5.0 500
                             2.4.0 500
                             2.3.0 500
                        influxdb-client:
                          Installed: (none)
                          Candidate: 1.6.7~rc0-1+b13
                          Version table:
                             1.6.7~rc0-1+b13 500
                        influxdb-dev:
                          Installed: (none)
                          Candidate: (none)
                          Version table:
                        influxdb2-client:
                          Installed: (none)
                          Candidate: 2.7.1-1
                          Version table:
                             2.7.1-1 500
                        influxdb:
                          Installed: (none)
                          Candidate: 1.8.10-1
                          Version table:
                             1.8.10-1 500
                                100 /var/lib/dpkg/status
                             1.6.7~rc0-1+b13 500
                        influxdb2:
                          Installed: (none)
                          Candidate: 2.7.3-1
                          Version table:
                             2.7.3-1 500
                             2.7.1-1 500
                             2.7.0-1 500
                             2.6.1-1 500
                             2.6.0-1 500
                             2.5.1-1 500
                             2.4.0-1 500
                             2.3.0-1 500
                             2.2.0 500
                          @nobbiman
                          Alles in der Auslage.
                          Jetzt kannst du den Key für raspberry noch reinziehen.
                          • N
                            nobbiman @Thomas Braun last edited by nobbiman
                            @thomas-braun Du sprichst in Rätseln, wahrscheinlich hast du schon bemerkt, dass ich kein Linux-Fan/-Freund/-Kenner bin. bitte sag mir, was ich zu tun habe, sprich den Key "reinziehen" kann
                              @nobbiman
                              wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                              sudo apt-key add raspberrypi.gpg.key
                              rm raspberrypi.gpg.key
                              Dann prüfen:
                              sudo apt update
                              • N
                                pi@RasPi-ioBroker:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                                --2023-10-31 14:32:52--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                                Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 46.235.231.151, 46.235.231.145, 93.93.130.212, ...
                                Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80... connected.
                                HTTP request sent, awaiting response... 200 OK
                                Length: 1719 (1.7K) [application/pgp-keys]
                                Saving to: ‘raspberrypi.gpg.key’
                                raspberrypi.gpg.key                                 100%[==================================================================================================================>]   1.68K  --.-KB/s    in 0.002s
                                2023-10-31 14:32:52 (785 KB/s) - ‘raspberrypi.gpg.key’ saved [1719/1719]
                                Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                OK
                                Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:5 https://repos.influxdata.com/debian stable InRelease
                                W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                Wenn ich das mit meinem Geringwissen richtig interpretiere, sieht das gut aus, zumindest wurde offenbar der key für den raspberry gespeichert.
                                Kann ich denn jetzt die erstgenannte influxdb-Installation erneut starten?
                                Install lt. Hausautomation, s.o.
                                  @nobbiman
                                  sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                                  Dann halt die gewünschte Version von influxdb installieren. Ich würde die influxdb2 nehmen.
                                  • N
                                    Ich verneige mich vor dir und deiner Hilfsbereitschaft, wahrscheinlich hätte ich das ohne Hilfe nicht hinbekommen - sag mir, wo ich dir einen Kaffee spendieren kann!
                                    Aber noch eines: weißt du, ob ich vor der Installation mit
                                    sudo apt-get install influxdb2
                                    noch einen Key installieren muss? Ich frage, weil unter einer YT-Anleitung, ab 8:43 davon gesprochen wird.
                                      @nobbiman
                                      Ich schau keine YT-Filmchen. Solltest du auch nicht, die wenigsten davon sind wirklich zu gebrauchen.
                                      apt wird aber Meckern, wenn ein Key fehlen sollte. Es fehlt aber keiner, sonst hättest du da Meldungen analog zu der Meldung gesehen, die du jetzt ja angegangen bist.
                                      • N
                                        @thomas-braun Das sagt einer, der sich auskennt, dem Laien blieb eine intensive Einarbeitung in Linux, um ein Systemverständnis zu entwickeln. Eigentlich will ich nur mit dem später noch zu installierenden Grafan Daten aus dem ioBroker visualisieren. Das kostet mich genug Zeit.
                                        Also, was ist mit dem Kaffee?
                                          @nobbiman sagte in Influx DB unter bookworm installieren:
                                          YT-Clips sind halt eine große Zeitverschwendung. In der Zeit, wir da noch ein tolles Intro läuft und die erste nervige Werbeunterbrechung mir auf den Zeiger geht hab ich da schon eine bessere und aktuellere Anleitung in Schriftform gefunden. Zuletzt mal eine (ungelogen!) 10 minütige längliche Anleitung mit allem nervigen Krams gesehen, in der eine Datei mittels Editor um zwei Einträge ergänzt wurde. Das ist in einem Wiki oder Forum maximal ein Zweizeiler.
                                          Nicht erforderlich. Du kannst aber wenn du magst meiner Patentochter in Togo ein Taschengeld zukommen lassen.
                                          • N
                                            @thomas-braun OK, dann gehe ich mal auf die Suche, wenn ich Grafana installieren werde.
                                            Tolle Idee mit der Patentochter, wie bekomme ich das Taschengeld nach Togo?
                                            4483
