Influx DB unter bookworm installieren
sudo rm /etc/apt/sources.list.d/influxdb.list sudo apt update apt policy influxdb*
@thomas-braun sagte in Influx DB unter bookworm installieren:
pi@RasPi-ioBroker:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list sudo apt update apt policy influxdb* Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease Err:7 http://archive.raspberrypi.com/debian bookworm InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E W: Some index files failed to download. They have been ignored, or old ones used instead. N: Unable to locate package influxdb.key N: Couldn't find any package by glob 'influxdb.key'
rm influxdb.key sudo apt update apt policy influxdb*
rm influxdb.key
pi@RasPi-ioBroker:~ $ rm influxdb.key sudo apt update apt policy influxdb* Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease Err:7 http://archive.raspberrypi.com/debian bookworm InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E W: Some index files failed to download. They have been ignored, or old ones used instead. influxdb2-cli: Installed: (none) Candidate: 2.7.3-1 Version table: 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb-client: Installed: (none) Candidate: 1.6.7~rc0-1+b13 Version table: 1.6.7~rc0-1+b13 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages influxdb-dev: Installed: (none) Candidate: (none) Version table: influxdb2-client: Installed: (none) Candidate: 2.7.1-1 Version table: 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb: Installed: (none) Candidate: 1.8.10-1 Version table: 1.8.10-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status 1.6.7~rc0-1+b13 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages influxdb2: Installed: (none) Candidate: 2.7.3-1 Version table: 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages
@thomas-braun Du sprichst in Rätseln, wahrscheinlich hast du schon bemerkt, dass ich kein Linux-Fan/-Freund/-Kenner bin. bitte sag mir, was ich zu tun habe, sprich den Key "reinziehen" kann
wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key sudo apt-key add raspberrypi.gpg.key rm raspberrypi.gpg.key
Dann prüfen:
sudo apt update
rm raspberrypi.gpg.keypi@RasPi-ioBroker:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key sudo apt-key add raspberrypi.gpg.key rm raspberrypi.gpg.key --2023-10-31 14:32:52-- http://archive.raspberrypi.org/debian/raspberrypi.gpg.key Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 46.235.231.151, 46.235.231.145, 93.93.130.212, ... Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 1719 (1.7K) [application/pgp-keys] Saving to: ‘raspberrypi.gpg.key’ raspberrypi.gpg.key 100%[==================================================================================================================>] 1.68K --.-KB/s in 0.002s 2023-10-31 14:32:52 (785 KB/s) - ‘raspberrypi.gpg.key’ saved [1719/1719] Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)). OK
pi@RasPi-ioBroker:~ $ sudo apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://apt.grafana.com stable InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Wenn ich das mit meinem Geringwissen richtig interpretiere, sieht das gut aus, zumindest wurde offenbar der key für den raspberry gespeichert.
Kann ich denn jetzt die erstgenannte influxdb-Installation erneut starten?
Install lt. Hausautomation, s.o. -
sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
Dann halt die gewünschte Version von influxdb installieren. Ich würde die influxdb2 nehmen.
Ich verneige mich vor dir und deiner Hilfsbereitschaft, wahrscheinlich hätte ich das ohne Hilfe nicht hinbekommen - sag mir, wo ich dir einen Kaffee spendieren kann!
Aber noch eines: weißt du, ob ich vor der Installation mit
sudo apt-get install influxdb2
noch einen Key installieren muss? Ich frage, weil unter einer YT-Anleitung, ab 8:43 davon gesprochen wird.
Ich schau keine YT-Filmchen. Solltest du auch nicht, die wenigsten davon sind wirklich zu gebrauchen.
apt wird aber Meckern, wenn ein Key fehlen sollte. Es fehlt aber keiner, sonst hättest du da Meldungen analog zu der Meldung gesehen, die du jetzt ja angegangen bist.
@thomas-braun Das sagt einer, der sich auskennt, dem Laien blieb eine intensive Einarbeitung in Linux, um ein Systemverständnis zu entwickeln. Eigentlich will ich nur mit dem später noch zu installierenden Grafan Daten aus dem ioBroker visualisieren. Das kostet mich genug Zeit.
Also, was ist mit dem Kaffee? -
@nobbiman sagte in Influx DB unter bookworm installieren:
YT-Clips sind halt eine große Zeitverschwendung. In der Zeit, wir da noch ein tolles Intro läuft und die erste nervige Werbeunterbrechung mir auf den Zeiger geht hab ich da schon eine bessere und aktuellere Anleitung in Schriftform gefunden. Zuletzt mal eine (ungelogen!) 10 minütige längliche Anleitung mit allem nervigen Krams gesehen, in der eine Datei mittels Editor um zwei Einträge ergänzt wurde. Das ist in einem Wiki oder Forum maximal ein Zweizeiler.
Nicht erforderlich. Du kannst aber wenn du magst meiner Patentochter in Togo ein Taschengeld zukommen lassen.
@thomas-braun OK, dann gehe ich mal auf die Suche, wenn ich Grafana installieren werde.
Tolle Idee mit der Patentochter, wie bekomme ich das Taschengeld nach Togo? -
Ich habe auch das Problem mit influx unter bookworm und folgende Fehlerausgabe:
sudo apt update Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease Hit:2 https://apt.grafana.com stable InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Err:5 https://repos.influxdata.com/debian stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead.
Richte das influxdb-Repo neu ein:
https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
@thomas-braun Danke für den Link:
Nun habe ich noch folgenden Fehler bei der Installation von influx:
rm influxdata-archive_compat.key rm: cannot remove 'influxdata-archive_compat.key': No such file or directory pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add - Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Und warum machst du es nicht wie es in meinem Link drin steht?
Da ist es nämlich richtig, ohne apt-key. -
@thomas-braun Ja, Danke.
Ich bekomme mit dem Befehl:
sudo service influxdb Statusinfluxdb: unrecognized service
und in Grafana:
Post "http://139.168.198.39:8086/query?db=iobroker&epoch=ms": dial tcp 139.168.198.39:8086: i/o timeout error reading influxDB -
