    3. Off Topic
    4. InfluxDB
    5. Influx DB unter bookworm installieren
    • N
      nobbiman @Thomas Braun last edited by
      @thomas-braun sagte in Influx DB unter bookworm installieren:
      rm influxdb.key
      pi@RasPi-ioBroker:~ $ rm influxdb.key
      sudo apt update
      apt policy influxdb*
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
      Err:7 http://archive.raspberrypi.com/debian bookworm InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
      W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.3-1
        Version table:
           2.7.3-1 500
              500 https://repos.influxdata.com/debian stable/main arm64 Packages
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      influxdb-client:
        Installed: (none)
        Candidate: 1.6.7~rc0-1+b13
        Version table:
           1.6.7~rc0-1+b13 500
      influxdb-dev:
        Installed: (none)
        Candidate: (none)
        Version table:
      influxdb2-client:
        Installed: (none)
        Candidate: 2.7.1-1
        Version table:
           2.7.1-1 500
      influxdb:
        Installed: (none)
        Candidate: 1.8.10-1
        Version table:
           1.8.10-1 500
              100 /var/lib/dpkg/status
           1.6.7~rc0-1+b13 500
      influxdb2:
        Installed: (none)
        Candidate: 2.7.3-1
        Version table:
           2.7.3-1 500
           2.7.1-1 500
           2.7.0-1 500
           2.6.1-1 500
           2.6.0-1 500
           2.5.1-1 500
           2.4.0-1 500
           2.3.0-1 500
           2.2.0 500
        Thomas Braun Most Active @nobbiman last edited by
        @nobbiman
        Alles in der Auslage.
        Jetzt kannst du den Key für raspberry noch reinziehen.
        • N
          nobbiman @Thomas Braun last edited by nobbiman
          @thomas-braun Du sprichst in Rätseln, wahrscheinlich hast du schon bemerkt, dass ich kein Linux-Fan/-Freund/-Kenner bin. bitte sag mir, was ich zu tun habe, sprich den Key "reinziehen" kann
            @nobbiman
            wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
            sudo apt-key add raspberrypi.gpg.key
            rm raspberrypi.gpg.key
            Dann prüfen:
            sudo apt update
            • N
              pi@RasPi-ioBroker:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
              --2023-10-31 14:32:52--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
              Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 46.235.231.151, 46.235.231.145, 93.93.130.212, ...
              Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80... connected.
              HTTP request sent, awaiting response... 200 OK
              Length: 1719 (1.7K) [application/pgp-keys]
              Saving to: ‘raspberrypi.gpg.key’
              raspberrypi.gpg.key                                 100%[==================================================================================================================>]   1.68K  --.-KB/s    in 0.002s
              2023-10-31 14:32:52 (785 KB/s) - ‘raspberrypi.gpg.key’ saved [1719/1719]
              Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
              OK
              pi@RasPi-ioBroker:~ $ sudo apt update
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
              Wenn ich das mit meinem Geringwissen richtig interpretiere, sieht das gut aus, zumindest wurde offenbar der key für den raspberry gespeichert.
              Kann ich denn jetzt die erstgenannte influxdb-Installation erneut starten?
              Install lt. Hausautomation, s.o.
                @nobbiman
                sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                Dann halt die gewünschte Version von influxdb installieren. Ich würde die influxdb2 nehmen.
                • N
                  Ich verneige mich vor dir und deiner Hilfsbereitschaft, wahrscheinlich hätte ich das ohne Hilfe nicht hinbekommen - sag mir, wo ich dir einen Kaffee spendieren kann!
                  Aber noch eines: weißt du, ob ich vor der Installation mit
                  sudo apt-get install influxdb2
                  noch einen Key installieren muss? Ich frage, weil unter einer YT-Anleitung, ab 8:43 davon gesprochen wird.
                    Thomas Braun Most Active @nobbiman last edited by Thomas Braun
                    @nobbiman
                    Ich schau keine YT-Filmchen. Solltest du auch nicht, die wenigsten davon sind wirklich zu gebrauchen.
                    apt wird aber Meckern, wenn ein Key fehlen sollte. Es fehlt aber keiner, sonst hättest du da Meldungen analog zu der Meldung gesehen, die du jetzt ja angegangen bist.
                    • N
                      @thomas-braun Das sagt einer, der sich auskennt, dem Laien blieb eine intensive Einarbeitung in Linux, um ein Systemverständnis zu entwickeln. Eigentlich will ich nur mit dem später noch zu installierenden Grafan Daten aus dem ioBroker visualisieren. Das kostet mich genug Zeit.
                      Also, was ist mit dem Kaffee?
                        @nobbiman sagte in Influx DB unter bookworm installieren:
                        YT-Clips sind halt eine große Zeitverschwendung. In der Zeit, wir da noch ein tolles Intro läuft und die erste nervige Werbeunterbrechung mir auf den Zeiger geht hab ich da schon eine bessere und aktuellere Anleitung in Schriftform gefunden. Zuletzt mal eine (ungelogen!) 10 minütige längliche Anleitung mit allem nervigen Krams gesehen, in der eine Datei mittels Editor um zwei Einträge ergänzt wurde. Das ist in einem Wiki oder Forum maximal ein Zweizeiler.
                        Nicht erforderlich. Du kannst aber wenn du magst meiner Patentochter in Togo ein Taschengeld zukommen lassen.
                        • N
                          @thomas-braun OK, dann gehe ich mal auf die Suche, wenn ich Grafana installieren werde.
                          Tolle Idee mit der Patentochter, wie bekomme ich das Taschengeld nach Togo?
                          • werner2000x
                            werner2000x last edited by
                            Ich habe auch das Problem mit influx unter bookworm und folgende Fehlerausgabe:
                            sudo apt update
                            Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                            Hit:2 https://apt.grafana.com stable InRelease
                            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Err:5 https://repos.influxdata.com/debian stable InRelease
                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                              Thomas Braun Most Active @werner2000x last edited by
                              @werner2000x
                              Richte das influxdb-Repo neu ein:
                              https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                              werner2000x 1 Reply Last reply Reply Quote 0
                              • werner2000x
                                werner2000x @Thomas Braun last edited by
                                @thomas-braun Danke für den Link:
                                Nun habe ich noch folgenden Fehler bei der Installation von influx:
                                 rm influxdata-archive_compat.key
                                rm: cannot remove 'influxdata-archive_compat.key': No such file or directory
                                pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                  @werner2000x
                                  Und warum machst du es nicht wie es in meinem Link drin steht?
                                  Da ist es nämlich richtig, ohne apt-key.
                                  • werner2000x
                                    @thomas-braun Ja, Danke.
                                    Ich bekomme mit dem Befehl:
                                    sudo service influxdb Status
                                    influxdb: unrecognized service
                                    und in Grafana:
                                    Post "http://139.168.198.39:8086/query?db=iobroker&epoch=ms": dial tcp 139.168.198.39:8086: i/o timeout error reading influxDB
                                      @werner2000x
                                      Das heißt ja auch auf modernen Systemen
                                      systemctl status influxdb.service
                                      werner2000x 1 Reply Last reply Reply Quote 1
                                      • werner2000x
                                        werner2000x @Thomas Braun last edited by Homoran
                                        @thomas-braun Ja richtig, aber in grafana geht es nicht obwohl die instance ok meldet. Hier der status:
                                        Linux raspberrypi 6.6.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.47-1+rpt1 (2024-09-02) aarch64
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Tue Sep 17 20:40:37 2024 from 192.168.198.72
                                        pi@raspberrypi:~ $ systemctl status influxdb.service
                                        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                             Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enable>     Active: active (running) since Tue 2024-09-17 21:13:28 CEST; 36min ago
                                               Docs: https://docs.influxdata.com/influxdb/
                                            Process: 16923 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>   Main PID: 16924 (influxd)
                                              Tasks: 14 (limit: 4915)
                                                CPU: 50.711s
                                             CGroup: /system.slice/influxdb.service
                                                     └─16924 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                        Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:37 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>...skipping...
                                                CPU: 50.711s
                                             Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)        Active: active (running) since Tue 2024-09-17 21:13:28 CEST; 36min ago        Docs: https://docs.influxdata.com/influxdb/        Process: 16923 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)                                                            Main PID: 16924 (influxd)
                                                CPU: 50.711s
                                        Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:31 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:32 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:32 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:37 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:37 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>~
                                        lines 1-21/21 (END)
                                          @werner2000x
                                          Grafana und influxdb verwende ich nicht. Kann ich also nix genaues zu sagen.
                                          4476
