    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
    • Rene R
      Rene R @Damrak2022 last edited by Rene R
      @damrak2022
      Kannst du mir vielleicht helfen ich bekomme es nicht am laufen was hast du bei dir in der .ini alles drin???
      Habe ne fritzbox 6490
      So läuft aber bekomme keine daten..
      (.venv) pi@raspberrypi:/opt/fritzinfluxdb $ python3 ./fritzinfluxdb.py
      2022-09-02 23:07:51,955 - INFO: Starting fritzinfluxdb v1.0.1 (2022-08-22)
      2022-09-02 23:07:51,957 - INFO: Done reading config files
      2022-09-02 23:07:52,011 - INFO: Successfully parsed config
      2022-09-02 23:07:52,024 - INFO: Connection to InfluxDB 1.8.10 established and database present
      2022-09-02 23:07:53,656 - INFO: Successfully established FritzBox TR-069 session
      2022-09-02 23:07:54,735 - INFO: Successfully established FritzBox Lua session
      2022-09-02 23:07:54,735 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritzbox) Model: FRITZ!Box 6490 Cable - FW: 7.29
      2022-09-02 23:07:54,741 - INFO: Starting main loop
      2022-09-02 23:07:55,460 - INFO: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
      2022-09-02 23:07:55,460 - INFO: Querying action 'GetInfo' will be disabled
      2022-09-02 23:07:55,474 - INFO: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
      2022-09-02 23:07:55,475 - INFO: Querying action 'GetStatisticsTotal' will be disabled
      2022-09-02 23:07:55,488 - INFO: Requested invalid action 'X_AVM-DE_GetDSLInfo' for service: WANDSLInterfaceConfig
      2022-09-02 23:07:55,488 - INFO: Querying action 'X_AVM-DE_GetDSLInfo' will be disabled
      2022-09-02 23:07:55,488 - INFO: All actions for service 'WANDSLInterfaceConfig' are unavailable. Disabling service.
      2022-09-02 23:07:55,544 - INFO: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
      2022-09-02 23:07:55,544 - INFO: Querying action 'GetInfo' will be disabled
      2022-09-02 23:07:55,545 - INFO: All actions for service 'WANPPPConnection:1' are unavailable. Disabling service.
      2022-09-02 23:08:19,603 - INFO: Unable to request FritzBox Lua service 'DSL Info'
      2022-09-02 23:08:19,603 - INFO: FritzBox Lua service 'DSL Info' will be disabled.
      Rene
      • framp
        framp @crunchip last edited by framp
        Unhandled python exception in init callback: OSError: fritzcollectd: Failed to connect to fritz.box", was mir sagt das mein FritzOS wohl zu neu ist.
        Ich hatte das Problem auch. Allerdings liegt es nicht an einer zu neuen FB sondern daran, dass der Connect etwas laenger dauert und fritzcollectd keinen Connect Retry hat. Den habe ich eingebaut und schon ist die Fehlermeldung weg :-). Der Fix steht ich hier in meinem Fork zur allgemeinen Verfuegung.
        Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
        Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
        Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
        Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
        Jan 28 23:53:28 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
        Jan 28 23:53:33 raspberrypi-bullseye-docker-64 collectd[547]: Initialization complete, entering read-loop.
        • I
          iobroJB @crunchip last edited by iobroJB
          @crunchip Hallo, ich antworte jetzt einfach mal Dir.
          Ich habe noch wenig Erfahrung mit iobroker und grafana,
          habe aber nach der obigen Anweisung hier und den weiteren Hilfen in diesem Beitrag, die Installationen denke ich richtig hinbekommen.
          Da das BeispielDashboard in obigen Beitrag nicht mehr aufrufbar ist, habe ich aus einem anderen Beitrag hier (ganz am Ende des Textes) das Dashboard hier importiert.
          Leider zeigt Grafana keine Werte an, obwohl ich die vorhandene influxdb zugewiesen habe und auch den Wert für die FritzBox entsprechend ausgewählt habe.
          Habe ich noch etwas vergessen, übersehen oder falsch gemacht?
          Ich bitte um Eure Hilfe, danke.
          ? crunchip 2 Replies Last reply Reply Quote 0
            A Former User @iobroJB last edited by
            @iobrojb
            Moin,
            warum bist Du nicht nach dem offiziellen Installations Doku vorgegangen fritzinfluxdb?
            Benutzt Du influxDB V. 1.8 oder influxDB V.2.x?
            Welche Version setzt Du von fritzinfluxdb ein (Aktuell ist 1.2.1)
            Ist influxDB auch der korrekte Name der Datenbank, Zeig mal die zu fitzinfluxdb passende Konfiguration /opt/fritzinfluxdb/fritzinfluxdb.ini
            !!!Achtung!!! da können User und Passwort im Klartext stehen
            Installations Beispiel für Ubuntu, sieh obigen link
            sudo apt-get install python3-virtualenv
            cd /opt
            git clone https://github.com/bb-Ricardo/fritzinfluxdb.git
            cd fritzinfluxdb
            virtualenv -p python3 .venv
            . .venv/bin/activate
            pip3 install -r requirements.txt
            modify your configuration and test it
            ./fritzinfluxdb.py
            Wenn Du das ganze über systemd startest, was sagt dir
            # systemctl status fritzinfluxdb.service
            Bei mir sieht das so aus:
            [dp20eic@loki fritzinfluxdb]$ systemctl status fritzinfluxdb.service
            * fritzinfluxdb.service - Fritz to InfluxDB daemon
                 Loaded: loaded (/usr/lib/systemd/system/fritzinfluxdb.service; enabled; preset: disabled)
                 Active: active (running) since Wed 2023-02-01 17:11:39 CET; 3min 5s ago
               Main PID: 187969 (python)
                  Tasks: 1 (limit: 38366)
                 Memory: 34.4M
                 CGroup: /system.slice/fritzinfluxdb.service
                         `-187969 /opt/fritzinfluxdb/.venv/bin/python /opt/fritzinfluxdb/fritzinfluxdb.py -d
            Feb 01 17:11:40 loki fritzinfluxdb[187969]: INFO: Connection to InfluxDB 2.5.1 established and bucket is present
            Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Unknown FritzBox link type 'Ethernet'. Please report this link type as issue to the gi>
            Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox TR-069 session
            Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox Lua session
            Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 (>
            Feb 01 17:11:46 loki fritzinfluxdb[187969]: /opt/fritzinfluxdb/fritzinfluxdb.py:141: DeprecationWarning: There is no current event loop
            Feb 01 17:11:46 loki fritzinfluxdb[187969]:   loop = asyncio.get_event_loop()
            Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Starting main loop
            Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'DSL Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Lin>
            Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model L>
            Die original Dashboards liegen, wenn Du alles richtig gemacht hast unter den jeweiligen Ordnern für influx1 / influx2
            [dp20eic@loki ~]$ ls -la /opt/fritzinfluxdb/grafana/
            total 555
            drwxr-xr-x 4 root root      6 Jan 25 14:00 .
            drwxr-xr-x 7 root root     18 Jan 25 14:03 ..
            -rw-r--r-- 1 root root 356744 Jan 25 14:00 grafana_dashboard.png
            -rw-r--r-- 1 root root 164338 Jan 25 14:00 grafana_home-automation_dashboard.png
            drwxr-xr-x 2 root root      5 Jan 25 14:00 influx1_dashboards
            drwxr-xr-x 2 root root      6 Jan 25 14:00 influx2_dashboards
            !!!Achtung!!!
            fritzinfluxdb für influxDb V. 1.8 wird vom Developer nicht mehr weiter entwickelt.
            VG
            Bernd
              crunchip Forum Testing Most Active @iobroJB last edited by
              @iobrojb sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
              Sind denn auch Daten in der Datenbank?
              Ich hatte das wie weiter oben geschrieben, per upnp Adapter laufen, der die Daten holte und die query's im Dashboard entsprechend angepasst.
              Nutze das allerdings seit rund 3 Jahren nicht mehr
                Maxtor62 @Guest last edited by Maxtor62
                @dp20eic
                hi, ist ein alter Thread aber ich versuch es trotzdem.
                Ich habe jetzt schon Proxmox LXC Container mit Debian 11 + 12, Ubuntu 22.04 + 23.04 versucht das Teil ans Laufen zu bringen.
                Auch mit nem Docker auf dem Synology NAS hab ich es versucht. Was soll ich sagen? Es klappt einfach nicht. Kann das an meiner Fritte liegen. Das ist die 7590 AX. Wäre super, wenn mir jemand noch n Tipp geben könnte. Hier die Logs dazu.
                (.venv) stefan@helper:/opt/fritzinfluxdb$ ./fritzinfluxdb.py
                2023-10-31 18:15:40,918 - INFO: Starting fritzinfluxdb v1.2.1 (2023-01-26)
                2023-10-31 18:15:40,918 - INFO: Done reading config files
                2023-10-31 18:15:40,938 - INFO: Successfully parsed config
                2023-10-31 18:15:40,940 - INFO: Connection to InfluxDB 2 established
                2023-10-31 18:15:46,412 - INFO: Successfully established FritzBox TR-069 session
                2023-10-31 18:15:47,135 - INFO: Successfully established FritzBox Lua session
                2023-10-31 18:15:47,136 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 AX (DSL) - FW: 7.                                     57
                2023-10-31 18:15:47,136 - INFO: Starting main loop
                2023-10-31 18:15:59,125 - INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Link type 'DSL'
                2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:16:24,525 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:16:30,767 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:35,802 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:40,870 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:45,920 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:50,991 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:16:56,016 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:17:03,083 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:08,623 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:14,134 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:19,203 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:24,889 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:30,976 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:33,338 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:17:33,339 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:17:36,381 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:41,420 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:46,463 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:51,571 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:17:56,971 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:02,262 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:18:07,437 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:17,150 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:22,474 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:29,000 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:35,006 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                2023-10-31 18:18:40,422 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:45,471 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:51,073 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                2023-10-31 18:18:56,581 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                ^C2023-10-31 18:19:01,953 - INFO: Received exit signal SIGINT...
                2023-10-31 18:19:01,954 - INFO: Cancelling 4 outstanding tasks
                2023-10-31 18:19:01,955 - INFO: Closed FritzBox TR-069 connection
                2023-10-31 18:19:01,955 - INFO: Closed FritzBox Lua connection
                2023-10-31 18:19:01,955 - INFO: Closed InfluxDB session
                2023-10-31 18:19:01,955 - INFO: Successfully shutdown fritzinfluxdb
                Die Datenbank wird kurz mit Daten gefüttert, die ich auch mit Grafana darstellen sehe, aber nach ca. einer Minute sind die Daten wieder weg, N/A.
                  A Former User @Maxtor62 last edited by
                  @maxtor62 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                  Moin,
                  wie ist die FritzBox eingerichtet, welchen User nutzt Du zum Login?
                  Die Einrichtung im LX Container hast Du nach Vorgabe wie auf der Github Seite gemacht, also auch fritzconnection und alle Python Module installiert?
                  Zeig mal die fritzinfluxdb.ini aber nimm vorher den User und das Passwort raus, oder x es aus
                  VG
                  Bernd
                    @dp20eic
                    hi sorry für meine Ungeduld. Hab halt schon so viel probiert.
                    Auf der Fritte hab ich extra ein User eingerichtet den ich dafür nehme. Hat alle Rechte.
                    Die Einrichtung habe ich jedes Mal genau so wie Du oder auf Github beschrieben, gemacht.
                    Fritzconnection und alle Python Module installiert.
                    Hier die fritzinfluxdb.ini
                    [influxdb]
                    # requires a hostname or IP which points to your InfluxDB instance
                    hostname = 192.168.178.139
                    # define the port your InfluxDB instance is listening on
                    port = 8086
                    # weather TLS encryption is enabled or disabled
                    #tls_enabled = false
                    # set this to 'true' to enforces TLS certificate validation
                    #verify_tls = false
                    # set a measurement name which is used to write the data to InfluxDB
                    # If this is changed from the default then it also has to be changed
                    # from the default value during the Grafana dashboard installation
                    measurement_name = fritzbox
                    # The amount of days the data should be stored in InfluxDB.
                    # Older data will be deleted.
                    # Attention: THIS IS ONLY CONFIGURED ON NEW DB/BUCKET CREATION!
                    data_retention_days = 365
                    # define which InfluxDB version you are using
                    version = 2
                    ##### InfluxDB version 1.x options
                    # username and password to use to write data to InfluxDB
                    username =
                    password =
                    # defines the InfluxDB database to write the data to
                    # if the credentials permit to create databases then this
                    # will be created automatically
                    database =
                    ##### InfluxDB version 2.x options
                    # requires an InfluxDB API token with permissions to write to the desired bucket
                    token = RRoG5NJBBUqnql1OKaHuxo3d2xqz0YpA-2AOO-fviu1Ft5mpafJizebVkpiQdGxwdtQvDv3AUJvXWLMreSQ1NA==
                    # a valid InfluxDB organisation needs to be defined which is used during login
                    organisation = home
                    # defines the InfluxDB bucket to write the data to
                    # if the credentials permit to create buckets then this
                    bucket = fritzbox
                    ### [fritzbox]
                    ### Controls the parameters for connecting to your InfluxDB instance.
                    [fritzbox]
                    # changes the default FritzBox IP
                    # username and password to connect to the FritzBox
                    username = XXXX
                    password = XXXX
                    # Define the port the FritzBox is listening on
                    # change to 49443 if you use ssl
                    port = 49000
                    # weather TLS encryption is enabled or disabled (will set port to 49443 if port is undefined)
                    # set this to 'true' to enforces TLS certificate validation (only affects Lua sessions)
                    #verify_tls = false
                    # defines the InfluxDB measurement tag which is used
                    # to tag data from this FritzBox
                    #box_tag = fritz.box
                    # Define the FritzBox time zone. Used to convert dates/times from FritzBox to correct UTC Timestamp
                    timezone = Europe/Berlin
                    # the maximum of time in seconds which a connection to the FritzBox is allowed to take
                    connect_timeout = 30
                    # interval to request data from FritzBox in seconds
                    # the value CAN'T be lower then 10 seconds
                    request_interval = 30
                    # EOF
                    Danke und Grüße
                      Moin,
                      also da sehe ich erst einmal keine Klinke.
                      Ich habe mal nach dem im Log aufgeführten Fehler ha_alert im Source auf Github gesucht, das kommt wohl aus dem Bereich homeauto.py, jetzt kann ich damit aber auch nicht mehr anfangen, ob das jetzt an der FritzBox liegt, oder ob die Version 7.57 da für die AX eine Macke hat oder ob Du da vielleicht Geräte in Samrt Home eingerichtet hast und deswegen der Fehler kommt.
                      Warte einfach mal ab, was bb-Ricardo zu dem Fehler sagt.
                      VG
                      Bernd
                        @dp20eic
                        ok, danke für Deine Mühe. Im SmatHome hab ich nur Fritz Geräte über DECT eingerichtet, außer die drei Rollladen Motoren. Die sind von BoxControl, was auch über DECT läuft. Da sollte die Fritte ja kein Problem haben.
                        Ich werde mich in Geduld üben.
                        Stefan
                          Moin,
                          na dann kann es ja doch sein, dass da etwas nicht korrekt eingerichtet oder installiert ist. Du solltest mal gleich dein issuse auf Github mit allen Informationen erweitern, damit bb-Ricardo nicht erst noch nachfragen muss, verzögert dann ja nur zusätzlich.
                          VG
                          Bernd
                            @dp20eic
                            es ist unglaublich.
                            FritzBox boot tut gut.
                            Jetzt funktioniert alles.
                            Danke Dir noch mal.
                            Stefan
                              Danke Dir noch mal.
                              Moin,
                              bidde schön, ist aber nicht meine Verdienst, Du kannst Dich bei bb-Ricardo bedanken.
                              Und ja, mach mal, tut ein Boot gut 🙂
                              VG
                              Bernd
                                michihorn @crunchip last edited by
                                @crunchip Hallo hab mal mitgelesen, bei der Anleitung die Du empfohlen hast, scheitere ich schon bei sudo pip install fritzcollectd mit folgender Meldung:
                                error: externally-managed-environment
                                × This environment is externally managed
                                ╰─> To install Python packages system-wide, try apt install
                                    python3-xyz, where xyz is the package you are trying to
                                    install.
                                    If you wish to install a non-Debian-packaged Python package,
                                    create a virtual environment using python3 -m venv path/to/venv.
                                    Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                    sure you have python3-full installed.
                                    For more information visit http://rptl.io/venv
                                note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                hint: See PEP 668 for the detailed specification.
                                Hast du ne Ahnung was ich tun muss?
                                Michael
                                  crunchip Forum Testing Most Active @michihorn last edited by
                                  @michihorn hast du das befolgt?
                                  https://forum.iobroker.net/post/793557
                                    michihorn @crunchip last edited by michihorn
                                    @crunchip Ja habe ich, selbst mit "neu" aufgesetzter Maschine klappt es nicht
                                    habe es jetzt mal so versucht:
                                    pip install fritzcollectd --break-system-packages
                                    Ist durch gelaufen, brachte am Ende aber folgende Meldung:
                                      note: This error originates from a subprocess, and is likely not a problem with pip.
                                    error: legacy-install-failure
                                    × Encountered error while trying to install package.
                                    ╰─> lxml
                                    note: This is an issue with the package mentioned above, not pip.
                                    hint: See above for output from the failure.
                                    EDIT: So hat es geklappt:
                                    Quelle
                                    Eine TOP Anleitung zur Installation der Fritzbox Visualisierung findet man unter:
                                    Anleitung
                                    Keine Panik die Anleitung trägt den Titel "Fritz!Box Monitoring mit Raspberry Pi Zero W" funktioniert aber auch top bei neueren Versionen. Kleiner Tip, sollte mal die Installation von collectd schiefgehen, kann die Installation komplett mit "sudo apt-get purge --auto-remove collectd" gelöscht werden.
                                      @michihorn kann dir da aktuell nicht weiterhelfen, hab das schon lange nicht mehr laufen.
                                      • Sleepless135
                                        Sleepless135 last edited by
                                        Moin in die Runde,
                                        versuche mich gerade auch mal die Influx DB mit neuen Daten zu füttern.
                                        Mein kleines Problem ist das ich das Script nicht mal zum laufen bekomme.
                                        Traceback (most recent call last):
                                        File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 27, in <module>
                                        from fritzinfluxdb.classes.fritzbox.handler import FritzBoxHandler, FritzBoxLuaHandler
                                        File "/opt/fritzinfluxdb/fritzinfluxdb/classes/fritzbox/handler.py", line 13, in <module>
                                        import requests
                                        ModuleNotFoundError: No module named 'requests'
                                        Hat jemand eine Idee was ihm fehlt ?
                                        Gruß Tim
                                        144
                                        20498
