    4. Homekit Controller startet ständig neu, bis er gestoppt wird
      Thomas Braun Most Active @Homerunner last edited by
      @homerunner sagte in Homekit Controller startet ständig neu, bis er gestoppt wird:
      bei Putty kann ich zwar markieren, aber nicht kopieren.
      Ich hab zwar puTTY nicht im Einsatz, aber deine puTTY-Leidensgenossen bekommen das auch immer kopiert. Muss also grundsätzlich funktionieren.
                                v.2023-10-10
           Static hostname: iobroker
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Debian GNU/Linux 10 (buster)
                    Kernel: Linux 4.19.0-25-amd64
              Architecture: x86-64
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     2
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/local/bin/node             v18.18.2
                                /usr/local/bin/npm              9.8.1
                                /usr/local/bin/npx              9.8.1
                                /usr/local/bin/corepack         0.19.0
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        *** nodejs is NOT correctly installed ***
        Wrong installation path detected. This needs to be fixed.
        Please check
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        for more information on how to fix these errors.
        MEMORY:
        Mem:           3.0G        1.7G        637M        5.0M        703M        1.2G
        Swap:          3.1G        178M        2.9G
        Total:         6.1G        1.8G        3.5G
        Active iob-Instances:   23
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.16
                                admin                   6.12.1
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                4214
        States:                 3445
        Size of iob-Database:
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        6.1M    /opt/iobroker/iobroker-data/objects.json.migrated
        6.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.0M    /opt/iobroker/iobroker-data/states.jsonl
        620K    /opt/iobroker/iobroker-data/states.json.migrated
        620K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        === Mark text until here for copying ===
        iobroker@iobroker:~$ Mark until here for C&P
        [1] 12177
        -bash: Mark: Kommando nicht gefunden.
        v.2023-10-10
        Chassis: vm
        Virtualization: kvm
        -bash: P: Kommando nicht gefunden.
        [1]+ Exit 127 Mark until here for C
        Installation: kvm
        Kernel: x86_64
        Userland: amd64
        iobroker@iobroker:~$ ```
        v.2023-10-10
        Chassis: vm
        Virtualization: kvm
        Installation: kvm
        Kernel: x86_64
        Userland: amd64
        User-ID: 1000
        X-Server: false
        Please check
        MEMORY:
        total used free shared buff/cache available
        admin 6.12.1
        ioBroker Status: iobroker is running on this host.
        Objects type: jsonl
        States type: jsonl
        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 4214
        States: 3445
          buster
          Ist tot (Muss ersetzt werden) und nodejs (wie erwartet...) falsch installiert.
          iob nodejs-update
          (Evtl. zuvor iob fix ausführen.)
            @thomas-braun said in Homekit Controller startet ständig neu, bis er gestoppt wird:
            iob nodejs-update
            Alles gemacht:
                                    v.2023-10-10
                       Chassis: vm
                Virtualization: kvm
            Installation:           kvm
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                    /usr/bin/node           v18.18.2
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    /usr/bin/corepack       0.19.0
            MEMORY:
            Mem:           3.0G         89M        1.8G        5.0M        1.1G        2.7G
            Swap:          3.1G         17M        3.1G
            Total:         6.1G        107M        4.8G
            Active iob-Instances:   1
                                    admin                   6.12.1
            ioBroker Status:        iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects:                4214
            States:                 3247
            6.7M    /opt/iobroker/iobroker-data/objects.jsonl
            816K    /opt/iobroker/iobroker-data/states.jsonl
              Alles gemacht:
              Nö, Buster ist immer noch tot und muss ersetzt werden.
              Aber zumidest ist die Laufzeitumgebung jetzt auf Stand.
                Das heißt? Was muss ich tun?
                Wie gesagt, bin Anfänger...
                  Dein Betriebssystem neuinstallieren.
                  Startet der ioBroker denn nun wieder?
                  iob start
                    Das habe bereits gemacht, aber die Fehlermeldungen sind geblieben.
                      @homerunner
                      Dann gibt mal die Langfassung von
                      iob diag
                      bekannt.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                   Chassis: vm
                            Virtualization: kvm
                        model name      : Common KVM processor
                        Docker          : false
                        Virtualization  : kvm
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                         15:48:37 up 1 day, 20:38,  1 user,  load average: 0.06, 0.11, 0.08
                        CPU threads: 8
                        *** Time and Time Zones ***
                                       Local time: Wed 2023-11-01 15:48:37 CET
                                   Universal time: Wed 2023-11-01 14:48:37 UTC
                                         RTC time: Wed 2023-11-01 14:48:38
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        iobroker
                        /home/iobroker
                        iobroker tty dialout cdrom floppy audio dip video plugdev netdev lpadmin scanner
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           3.0G        1.4G        398M        5.0M        1.2G        1.4G
                        Swap:          3.1G         17M        3.1G
                        Total:         6.1G        1.4G        3.5G
                                 3002 M total memory
                                 1405 M used memory
                                 1815 M active memory
                                  450 M inactive memory
                                  398 M free memory
                                  247 M buffer memory
                                  951 M swap cache
                                 3069 M total swap
                                   17 M used swap
                                 3052 M free swap
                        *** FAILED SERVICES ***
                        0 loaded units listed. Pass --all to see loaded but inactive units, too.
                        To show all installed unit files use 'systemctl list-unit-files'.
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.5G     0  1.5G   0% /dev
                        tmpfs          tmpfs     301M  8.0M  293M   3% /run
                        /dev/sda1      ext4       29G  6.3G   21G  24% /
                        tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                        tmpfs          tmpfs     1.5G     0  1.5G   0% /sys/fs/cgroup
                        tmpfs          tmpfs     301M     0  301M   0% /run/user/1000
                        [Mon Oct 30 19:09:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        [Mon Oct 30 19:09:50 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                        TARGET        SOURCE    FSTYPE OPTIONS
                        /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                        `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                        /var:
                        896M    /var/
                        711M    /var/cache
                        692M    /var/cache/apt
                        631M    /var/cache/apt/archives
                        166M    /var/lib
                              Users in the 'systemd-journal' group can see all messages. Pass -q to
                              turn off this notice.
                        No journal files were opened due to insufficient permissions.
                        /opt/iobroker/backups:
                        32M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        341M    /opt/iobroker/iobroker-data/
                        216M    /opt/iobroker/iobroker-data/files
                        100M    /opt/iobroker/iobroker-data/backup-objects
                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                        9.3M    /opt/iobroker/iobroker-data/objects.jsonl
                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                        8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                100 /var/lib/dpkg/status
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             10.24.0~dfsg-1~deb10u3 500
                                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                             10.24.0~dfsg-1~deb10u1 500
                                500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.16
                        admin:          6.12.1
                        javascript:     7.1.4
                        Adapters from github:   0
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                          system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                        + system.adapter.mydlink.0                : mydlink               : iobroker                                 -  enabled
                        + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        + system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.12.0   , installed 6.12.1
                        Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
                        Adapter    "backitup"     : 2.8.1    , installed 2.8.7
                        Adapter    "deconz"       : 1.3.21   , installed 1.3.22
                        Adapter    "discovery"    : 3.1.0    , installed 3.2.0
                        Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.16
                        Adapter    "meross"       : 1.15.1   , installed 1.15.1
                        Adapter    "mydlink"      : 1.3.4    , installed 1.3.4
                        Adapter    "panasonic-comfort-cloud": 2.2.4, installed 2.2.4
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "web"          : 6.1.2    , installed 6.1.2
                        Adapter    "wled"         : 0.7.1    , installed 0.7.1
                        Adapter    "ws"           : 2.5.5    , installed 2.5.5
                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                        Adapter    "zigbee2mqtt"  : 2.13.3   , installed 2.13.3
                        Objects and States
                        Objects:        4214
                        States:         3459
                        Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                        Hit:2 http://phoscon.de/apt/deconz buster InRelease
                        Hit:3 http://ftp.de.debian.org/debian buster InRelease
                        Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11436      1/init
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       2104606    17991/io.jarvis.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14097      447/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1351999    3148/cupsd
                        tcp        0      0 0.0.0.0:44409           0.0.0.0:*               LISTEN      1000       2104641    18021/io.yahka.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2099756    17266/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2099749    17266/iobroker.js-c
                        tcp        0      0 127.0.0.1:39051         0.0.0.0:*               LISTEN      1000       2104722    18021/io.yahka.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          11444      1/init
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2102337    17285/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2104588    17976/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14099      447/sshd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1351998    3148/cupsd
                        udp        0      0 0.0.0.0:51504           0.0.0.0:*                           106        13971      384/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       2101736    17389/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       2101737    17389/io.tuya.0
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1352008    3149/cups-browsed
                        udp        0      0 192.168.178.115:5353    0.0.0.0:*                           1000       2103535    17961/io.mydlink.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       2102873    17927/io.wled.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13969      384/avahi-daemon: r
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2104373    17882/io.deconz.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13976      380/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11439      1/init
                        udp6       0      0 :::45791                :::*                                106        13972      384/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                106        13970      384/avahi-daemon: r
                        udp6       0      0 :::1900                 :::*                                1000       2104375    17882/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1000       2104374    17882/io.deconz.0
                        udp6       0      0 :::111                  :::*                                0          11449      1/init
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]: Error: undefined is not a valid state value
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Array.forEach (<anonymous>)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: Error: undefined is not a valid state value
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Array.forEach (<anonymous>)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
                        2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
                        2023-11-01 15:48:41.883  - error: host.iobroker instance system.adapter.homekit-controller.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-11-01 15:48:41.884  - info: host.iobroker Restart adapter system.adapter.homekit-controller.0 because enabled
                          @homerunner
                          Und die Einstellungen im Adapter sehen wie aus?
                            Homerunner @Thomas Braun last edited by
                            Kurios ist ja, unter Objekten sind Alle Geräte Grün.
                            In der Instanz zeigt er keine Geräte an, ist nur am suchen..Screenshot 2023-11-01 155636.png Screenshot 2023-11-01 145643.png Screenshot 2023-11-01 145643 - Kopie.png Screenshot 2023-11-01 155735.png Colored Text Here
                              @homerunner
                              Keine Ahnung wo es da hakt.
                                Trotzdem danke für deine Mühe.
                                Hast du einen Tipp, an wen ich mich noch wenden könnte?
                                  Bei GitHub ein Issue eröffnen.
                                    Ok, werde es versuchen.
                                    Ich habe noch eine Baustelle, weiß nicht, ob das auch dein Bereich ist.
                                    Du kennst bestimmt die WLED Garagentor Geschichte.
                                    Ich habe WLED seitig vorbereitet. Bei mir scheitert es an der Umsetzung der Signale vom Tor in ein Blockly zu schreiben. Ich habe ein Garagentoröffner von Meross und habe fogende Infos:Screenshot 2023-10-25 121031.png
                                      Wie und wo kann ich das machen?
                                        Thomas Braun Most Active @Homerunner last edited by Thomas Braun
                                        @homerunner
                                        Hier:
                                        https://github.com/Apollon77/ioBroker.homekit-controller
                                        Könnte aber das Ding sein:
                                        https://github.com/Apollon77/ioBroker.homekit-controller/issues/291
                                        Draygv2 created this issue in Apollon77/ioBroker.homekit-controller
                                        closed Instanz is terminating itself #291
                                          Danke, nun läuft wieder alles gut.
                                          875
