    3. Einsteigerfragen
    4. Installation
    5. Probleme bei 4.0.23 auf 5.0.12 [gelöst]
      GerdNutzinger @Thomas Braun last edited by
      DANKE !!💪 👌
      Alles passt jetzt !!
        Thomas Braun Most Active @GerdNutzinger last edited by
        @gerdnutzinger
        Abschlussdiagnose per Langfassung von
        iob diag
        bitte.
        G 2 Replies Last reply Reply Quote 0
          @thomas-braun sagte in Probleme bei 4.0.23 auf 5.0.12:
          iob diag
                                  v.2023-10-10
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               armhf
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          X-Server:               true
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                  /usr/bin/node           v18.18.2
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
          Recommended versions are nodejs 18.18.2 and npm 9.8.1
          MEMORY:
          Mem:            3.8G        945M        1.1G         34M        1.7G        2.7G
          Swap:            99M          0B         99M
          Total:          3.9G        945M        1.2G
          Active iob-Instances:   19
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.12
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                1296
          States:                 1180
          Size of iob-Database:
          6.3M    /opt/iobroker/iobroker-data/objects.jsonl
          2.7M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Icon name: computer
            Architecture: arm64
            Model : Raspberry Pi 4 Model B Rev 1.5
            Docker : false
            Virtualization : none
            Kernel : aarch64
            Userland : armhf
            Systemuptime and Load:
            12:00:55 up 1:24, 4 users, load average: 0.74, 0.60, 0.46
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
            Local time: Wed 2023-11-01 12:00:55 CET
            Universal time: Wed 2023-11-01 11:00:55 UTC
            RTC time: n/a
            NTP service: active
            RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server: true
            Desktop:
            Terminal: tty
            *** MEMORY ***
            total used free shared buff/cache available
            Mem: 3.8G 925M 1.1G 34M 1.7G 2.8G
            Swap: 99M 0B 99M
            Total: 3.9G 925M 1.2G
                 3794 M total memory
                  925 M used memory
                 1049 M active memory
                 1270 M inactive memory
                 1119 M free memory
                  206 M buffer memory
                 1543 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            Filesystem Type Size Used Avail Use% Mounted on
            /dev/root ext4 30G 6.9G 21G 25% /
            devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
            tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
            tmpfs tmpfs 759M 920K 758M 1% /run
            tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
            /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
            tmpfs tmpfs 380M 20K 380M 1% /run/user/1000
            [Wed Nov 1 10:36:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:96:8E:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=42e68ffd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Wed Nov 1 10:36:09 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Wed Nov 1 10:36:09 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Wed Nov 1 10:36:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET SOURCE FSTYPE OPTIONS
            / /dev/mmcblk0p2 ext4 rw,noatime
            `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            1.6G /var/
            908M /var/log
            905M /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
            430M /var/cache
            Archived and active journals take up 904.1M in the file system.
            /opt/iobroker/backups:
            31M /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            375M /opt/iobroker/iobroker-data/
            181M /opt/iobroker/iobroker-data/files
            153M /opt/iobroker/iobroker-data/history
            52M /opt/iobroker/iobroker-data/files/javascript.admin
            34M /opt/iobroker/iobroker-data/files/javascript.admin/static
            21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
            8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
            7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
            6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            USB-Devices by-id:
            USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
            *** NodeJS-Installation ***
            /usr/bin/npm 9.8.1
            /usr/bin/npx 9.8.1
            nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
            *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
            18.18.1-1nodesource1 1001
            18.18.0-1nodesource1 1001
            18.17.1-1nodesource1 1001
            18.17.0-1nodesource1 1001
            18.16.1-1nodesource1 1001
            18.16.0-1nodesource1 1001
            18.15.0-1nodesource1 1001
            18.14.2-1nodesource1 1001
            18.14.1-1nodesource1 1001
            18.14.0-1nodesource1 1001
            18.13.0-1nodesource1 1001
            18.12.0-1nodesource1 1001
            18.11.0-1nodesource1 1001
            18.10.0-1nodesource1 1001
            18.9.1-1nodesource1 1001
            18.9.0-1nodesource1 1001
            18.8.0-1nodesource1 1001
            18.7.0-1nodesource1 1001
            18.6.0-1nodesource1 1001
            18.5.0-1nodesource1 1001
            18.4.0-1nodesource1 1001
            18.3.0-1nodesource1 1001
            18.2.0-1nodesource1 1001
            18.1.0-1nodesource1 1001
            18.0.0-1nodesource1 1001
            12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States type: jsonl
            Core adapters versions
            js-controller: 5.0.12
            admin: 6.12.0
            javascript: 7.1.4
            Adapters from github: 0
            Adapter State
            • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            • system.adapter.backitup.0 : backitup : raspberrypi - enabled
            • system.adapter.discovery.0 : discovery : raspberrypi - enabled
            • system.adapter.email.0 : email : raspberrypi - enabled
              system.adapter.flot.0 : flot : raspberrypi - disabled
            • system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled
              system.adapter.habpanel.0 : habpanel : raspberrypi - disabled
            • system.adapter.history.0 : history : raspberrypi - enabled
              system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled
            • system.adapter.jarvis.0 : jarvis : raspberrypi - enabled
            • system.adapter.javascript.0 : javascript : raspberrypi - enabled
            • system.adapter.net-tools.0 : net-tools : raspberrypi - enabled
            • system.adapter.ping.0 : ping : raspberrypi - enabled
            • system.adapter.sonoff.1 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
            • system.adapter.sonoff.2 : sonoff : raspberrypi - enabled, port: 1884, bind: 0.0.0.0
            • system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 0.0.0.0, run as: admin
              system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled
              system.adapter.tr-064.1 : tr-064 : raspberrypi - disabled
              system.adapter.tr-064.2 : tr-064 : raspberrypi - disabled
              system.adapter.tr-064.3 : tr-064 : raspberrypi - disabled
            • system.adapter.tuya.0 : tuya : raspberrypi - enabled
              system.adapter.vis-bars.0 : vis-bars : raspberrypi - disabled
              system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled
            • system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled
              system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled
              system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled
              system.adapter.vis.0 : vis : raspberrypi - enabled
            • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled
            • system.adapter.yahka.0 : yahka : raspberrypi - enabled
            • instance is alive
            ioBroker-Repositories
            stable : http://download.iobroker.net/sources-dist.json
            beta : http://download.iobroker.net/sources-dist-latest.json
            Installed ioBroker-Instances
            Used repository: stable
            Adapter "admin" : 6.12.0 , installed 6.12.0
            Adapter "backitup" : 2.8.1 , installed 2.8.1
            Adapter "discovery" : 3.1.0 , installed 3.1.0
            Adapter "email" : 1.2.0 , installed 1.2.0
            Adapter "flot" : 1.12.0 , installed 1.12.0
            Adapter "fritzdect" : 2.3.1 , installed 2.3.1
            Adapter "habpanel" : 0.5.0 , installed 0.5.0
            Adapter "history" : 3.0.1 , installed 3.0.1
            Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
            Adapter "jarvis" : 3.1.2 , installed 3.1.2
            Adapter "javascript" : 7.1.4 , installed 7.1.4
            Controller "js-controller": 5.0.12 , installed 5.0.12
            Adapter "net-tools" : 0.2.0 , installed 0.2.0
            Adapter "ping" : 1.6.2 , installed 1.6.2
            Adapter "simple-api" : 2.7.2 , installed 2.7.2
            Adapter "socketio" : 6.5.5 , installed 6.5.5
            Adapter "sonoff" : 2.5.3 , installed 2.5.3
            Adapter "terminal" : 1.0.0 , installed 1.0.0
            Adapter "tr-064" : 4.2.18 , installed 4.2.18
            Adapter "tuya" : 3.14.2 , installed 3.14.2
            Adapter "vis" : 1.4.16 , installed 1.4.16
            Adapter "vis-bars" : 0.1.4 , installed 0.1.4
            Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
            Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
            Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
            Adapter "vis-metro" : 1.2.0 , installed 1.2.0
            Adapter "web" : 6.1.2 , installed 6.1.2
            Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
            Adapter "ws" : 2.5.5 , installed 2.5.5
            Adapter "yahka" : 1.0.3 , installed 1.0.3
            Objects and States
            Objects: 1296
            States: 1180
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
            tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 11965 528/cupsd
            tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15508 567/sshd: /usr/sbin
            tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 47629 5692/iobroker.js-co
            tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 46901 5692/iobroker.js-co
            tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 50312 6025/io.jarvis.0
            tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 48033 5937/io.sonoff.2
            tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 50183 5920/io.sonoff.1
            tcp 0 0 0.0.0.0:42173 0.0.0.0:* LISTEN 1001 50085 6077/io.yahka.0
            tcp6 0 0 :::22 :::* LISTEN 0 15510 567/sshd: /usr/sbin
            tcp6 0 0 :::45069 :::* LISTEN 1001 50083 6077/io.yahka.0
            tcp6 0 0 :::8088 :::* LISTEN 1001 51424 6111/io.terminal.0
            tcp6 0 0 :::8082 :::* LISTEN 1001 51239 6010/io.web.0
            tcp6 0 0 :::8081 :::* LISTEN 1001 46930 5711/io.admin.0
            tcp6 0 0 ::1:631 :::* LISTEN 0 11964 528/cupsd
            udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 47871 5822/io.tuya.0
            udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 47872 5822/io.tuya.0
            udp 0 0 0.0.0.0:631 0.0.0.0:* 0 15590 580/cups-browsed
            udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11790 384/avahi-daemon: r
            udp 0 0 0.0.0.0:58920 0.0.0.0:* 108 11792 384/avahi-daemon: r
            udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13283 441/dhcpcd
            udp6 0 0 :::546 :::* 0 16455 441/dhcpcd
            udp6 0 0 :::44193 :::* 108 11793 384/avahi-daemon: r
            udp6 0 0 :::5353 :::* 108 11791 384/avahi-daemon: r
            2023-11-01 11:32:04.365 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.3 because disabled or deleted
            2023-11-01 11:32:11.459 - error: tr-064.2 (7611) adapter disabled
            2023-11-01 11:32:11.512 - warn: tr-064.2 (7611) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            2023-11-01 11:32:12.066 - error: host.raspberrypi instance system.adapter.tr-064.2 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2023-11-01 11:32:12.066 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.2 because disabled or deleted
            2023-11-01 11:32:16.631 - error: tr-064.1 (7625) adapter disabled
            2023-11-01 11:32:16.687 - warn: tr-064.1 (7625) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            2023-11-01 11:32:17.242 - error: host.raspberrypi instance system.adapter.tr-064.1 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2023-11-01 11:32:17.243 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.1 because disabled or deleted
            2023-11-01 11:37:18.989 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
            2023-11-01 11:37:18.990 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
            2023-11-01 11:42:54.301 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
            2023-11-01 11:42:54.302 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
            2023-11-01 11:45:29.193 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Connect locally to device
            2023-11-01 11:45:29.194 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj Init with IP=192.168.178.66, Key=rKNJX%q%j/9y<JKX, Version=3.4
            2023-11-01 11:46:16.458 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (1): connection timed out
            2023-11-01 11:46:39.522 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.66:6668
            2023-11-01 11:47:22.594 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.66:6668
            2023-11-01 11:48:25.666 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.66:6668
            2023-11-01 11:48:29.595 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
            2023-11-01 11:48:29.596 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
            2023-11-01 11:54:04.892 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
            2023-11-01 11:54:04.893 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
            2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
            2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
            iob diag has finished.
              Thomas Braun Most Active @GerdNutzinger last edited by Thomas Braun
              @gerdnutzinger
              Die Zusammenfassung zeigt die wesentlichen Punkte als i.O. an.
                @gerdnutzinger
                Kannst du mal bitte die Ausgabe von
                pgrep -f 'Xorg|ayland|X11'
                posten?
                  pi@raspberrypi:~ $ pgrep -f 'Xorg|ayland|X11'
                  575
                  pi@raspberrypi:~ $
                    @gerdnutzinger sagte in Probleme bei 4.0.23 auf 5.0.12:
                    Danke. Bitte noch
                    ps aux | grep -E 'Xorg|ayland|X11'
                      ps aux
                      Für was sind diese Daten die Du von mir brauchst?
                        pi@raspberrypi:~ $ ps aux | grep -E 'Xorg|ayland|X11'
                        root 575 0.0 1.3 198080 52660 tty7 Ssl+ 10:36 0:04 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                        pi 20525 0.0 0.0 7464 544 pts/0 S+ 16:13 0:00 grep --color=auto -E Xorg|ayland|X11
                          Für das iob diag Kommando. Wollte mal sehen warum da bei dir noch was bezgl. des X-Servers gefunden wird, das dürfte eigentlich nicht mehr der Fall sein.
                          Kannst du die Kiste mal komplett neustarten und dann nochmal
                          bitte.
                            Schaut anders aus...
                            pi 1579 0.0 0.0 7464 484 pts/0 S+ 16:36 0:00 grep --color=auto -E Xorg|ayland|X11
                            pi@raspberrypi:~ $
                              Ja, so soll es auch aussehen. Danke für die Mithilfe!
                                Ich muss DANKE sagen und das sehr gerne.
                                Was muss ich machen das ich das Problem als gelöst kennzeichne?
                                • Meister Mopper
                                  Meister Mopper last edited by
                                  Deinen ersten Eintrag mit [gelöst] ergänzen.
                                    @gerdnutzinger
                                    Editiere den ersten Beitrag entsprechend.
                                    1158
