    3. Einsteigerfragen
    4. Installation
    5. Probleme bei 4.0.23 auf 5.0.12 [gelöst]
      Thomas Braun Most Active @GerdNutzinger last edited by
      @gerdnutzinger
      Abschlussdiagnose per Langfassung von
      iob diag
      bitte.
      G 2 Replies Last reply Reply Quote 0
        GerdNutzinger @Thomas Braun last edited by
        @thomas-braun sagte in Probleme bei 4.0.23 auf 5.0.12:
        iob diag
                                v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               true
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        MEMORY:
        Mem:            3.8G        945M        1.1G         34M        1.7G        2.7G
        Swap:            99M          0B         99M
        Total:          3.9G        945M        1.2G
        Active iob-Instances:   19
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                1296
        States:                 1180
        Size of iob-Database:
        6.3M    /opt/iobroker/iobroker-data/objects.jsonl
        2.7M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Skript v.2023-10-10
          *** BASE SYSTEM ***
          Icon name: computer
          Architecture: arm64
          Model : Raspberry Pi 4 Model B Rev 1.5
          Docker : false
          Virtualization : none
          Kernel : aarch64
          Userland : armhf
          Systemuptime and Load:
          12:00:55 up 1:24, 4 users, load average: 0.74, 0.60, 0.46
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
          Local time: Wed 2023-11-01 12:00:55 CET
          Universal time: Wed 2023-11-01 11:00:55 UTC
          RTC time: n/a
          NTP service: active
          RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: true
          Desktop:
          Terminal: tty
          *** MEMORY ***
          total used free shared buff/cache available
          Mem: 3.8G 925M 1.1G 34M 1.7G 2.8G
          Swap: 99M 0B 99M
          Total: 3.9G 925M 1.2G
               3794 M total memory
                925 M used memory
               1049 M active memory
               1270 M inactive memory
               1119 M free memory
                206 M buffer memory
               1543 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem Type Size Used Avail Use% Mounted on
          /dev/root ext4 30G 6.9G 21G 25% /
          devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
          tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
          tmpfs tmpfs 759M 920K 758M 1% /run
          tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
          /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
          tmpfs tmpfs 380M 20K 380M 1% /run/user/1000
          [Wed Nov 1 10:36:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:96:8E:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=42e68ffd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Nov 1 10:36:09 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Nov 1 10:36:09 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Nov 1 10:36:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET SOURCE FSTYPE OPTIONS
          / /dev/mmcblk0p2 ext4 rw,noatime
          `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          1.6G /var/
          908M /var/log
          905M /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
          430M /var/cache
          Archived and active journals take up 904.1M in the file system.
          /opt/iobroker/backups:
          31M /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          375M /opt/iobroker/iobroker-data/
          181M /opt/iobroker/iobroker-data/files
          153M /opt/iobroker/iobroker-data/history
          52M /opt/iobroker/iobroker-data/files/javascript.admin
          34M /opt/iobroker/iobroker-data/files/javascript.admin/static
          21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
          7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
          6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          USB-Devices by-id:
          USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
          *** NodeJS-Installation ***
          /usr/bin/npm 9.8.1
          /usr/bin/npx 9.8.1
          nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
          *** 18.18.2-1nodesource1 1001
          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
          100 /var/lib/dpkg/status
          18.18.1-1nodesource1 1001
          18.18.0-1nodesource1 1001
          18.17.1-1nodesource1 1001
          18.17.0-1nodesource1 1001
          18.16.1-1nodesource1 1001
          18.16.0-1nodesource1 1001
          18.15.0-1nodesource1 1001
          18.14.2-1nodesource1 1001
          18.14.1-1nodesource1 1001
          18.14.0-1nodesource1 1001
          18.13.0-1nodesource1 1001
          18.12.0-1nodesource1 1001
          18.11.0-1nodesource1 1001
          18.10.0-1nodesource1 1001
          18.9.1-1nodesource1 1001
          18.9.0-1nodesource1 1001
          18.8.0-1nodesource1 1001
          18.7.0-1nodesource1 1001
          18.6.0-1nodesource1 1001
          18.5.0-1nodesource1 1001
          18.4.0-1nodesource1 1001
          18.3.0-1nodesource1 1001
          18.2.0-1nodesource1 1001
          18.1.0-1nodesource1 1001
          18.0.0-1nodesource1 1001
          12.22.12~dfsg-1~deb11u4 500
          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States type: jsonl
          Core adapters versions
          js-controller: 5.0.12
          admin: 6.12.0
          javascript: 7.1.4
          Adapters from github: 0
          Adapter State
          • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.backitup.0 : backitup : raspberrypi - enabled
          • system.adapter.discovery.0 : discovery : raspberrypi - enabled
          • system.adapter.email.0 : email : raspberrypi - enabled
            system.adapter.flot.0 : flot : raspberrypi - disabled
          • system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled
            system.adapter.habpanel.0 : habpanel : raspberrypi - disabled
          • system.adapter.history.0 : history : raspberrypi - enabled
            system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled
          • system.adapter.jarvis.0 : jarvis : raspberrypi - enabled
          • system.adapter.javascript.0 : javascript : raspberrypi - enabled
          • system.adapter.net-tools.0 : net-tools : raspberrypi - enabled
          • system.adapter.ping.0 : ping : raspberrypi - enabled
          • system.adapter.sonoff.1 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
          • system.adapter.sonoff.2 : sonoff : raspberrypi - enabled, port: 1884, bind: 0.0.0.0
          • system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled
            system.adapter.tr-064.1 : tr-064 : raspberrypi - disabled
            system.adapter.tr-064.2 : tr-064 : raspberrypi - disabled
            system.adapter.tr-064.3 : tr-064 : raspberrypi - disabled
          • system.adapter.tuya.0 : tuya : raspberrypi - enabled
            system.adapter.vis-bars.0 : vis-bars : raspberrypi - disabled
            system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled
          • system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled
            system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled
            system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled
            system.adapter.vis.0 : vis : raspberrypi - enabled
          • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled
          • system.adapter.yahka.0 : yahka : raspberrypi - enabled
          • instance is alive
          ioBroker-Repositories
          stable : http://download.iobroker.net/sources-dist.json
          beta : http://download.iobroker.net/sources-dist-latest.json
          Installed ioBroker-Instances
          Used repository: stable
          Adapter "admin" : 6.12.0 , installed 6.12.0
          Adapter "backitup" : 2.8.1 , installed 2.8.1
          Adapter "discovery" : 3.1.0 , installed 3.1.0
          Adapter "email" : 1.2.0 , installed 1.2.0
          Adapter "flot" : 1.12.0 , installed 1.12.0
          Adapter "fritzdect" : 2.3.1 , installed 2.3.1
          Adapter "habpanel" : 0.5.0 , installed 0.5.0
          Adapter "history" : 3.0.1 , installed 3.0.1
          Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
          Adapter "jarvis" : 3.1.2 , installed 3.1.2
          Adapter "javascript" : 7.1.4 , installed 7.1.4
          Controller "js-controller": 5.0.12 , installed 5.0.12
          Adapter "net-tools" : 0.2.0 , installed 0.2.0
          Adapter "ping" : 1.6.2 , installed 1.6.2
          Adapter "simple-api" : 2.7.2 , installed 2.7.2
          Adapter "socketio" : 6.5.5 , installed 6.5.5
          Adapter "sonoff" : 2.5.3 , installed 2.5.3
          Adapter "terminal" : 1.0.0 , installed 1.0.0
          Adapter "tr-064" : 4.2.18 , installed 4.2.18
          Adapter "tuya" : 3.14.2 , installed 3.14.2
          Adapter "vis" : 1.4.16 , installed 1.4.16
          Adapter "vis-bars" : 0.1.4 , installed 0.1.4
          Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
          Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
          Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
          Adapter "vis-metro" : 1.2.0 , installed 1.2.0
          Adapter "web" : 6.1.2 , installed 6.1.2
          Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
          Adapter "ws" : 2.5.5 , installed 2.5.5
          Adapter "yahka" : 1.0.3 , installed 1.0.3
          Objects and States
          Objects: 1296
          States: 1180
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
          tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 11965 528/cupsd
          tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15508 567/sshd: /usr/sbin
          tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 47629 5692/iobroker.js-co
          tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 46901 5692/iobroker.js-co
          tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 50312 6025/io.jarvis.0
          tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 48033 5937/io.sonoff.2
          tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 50183 5920/io.sonoff.1
          tcp 0 0 0.0.0.0:42173 0.0.0.0:* LISTEN 1001 50085 6077/io.yahka.0
          tcp6 0 0 :::22 :::* LISTEN 0 15510 567/sshd: /usr/sbin
          tcp6 0 0 :::45069 :::* LISTEN 1001 50083 6077/io.yahka.0
          tcp6 0 0 :::8088 :::* LISTEN 1001 51424 6111/io.terminal.0
          tcp6 0 0 :::8082 :::* LISTEN 1001 51239 6010/io.web.0
          tcp6 0 0 :::8081 :::* LISTEN 1001 46930 5711/io.admin.0
          tcp6 0 0 ::1:631 :::* LISTEN 0 11964 528/cupsd
          udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 47871 5822/io.tuya.0
          udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 47872 5822/io.tuya.0
          udp 0 0 0.0.0.0:631 0.0.0.0:* 0 15590 580/cups-browsed
          udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11790 384/avahi-daemon: r
          udp 0 0 0.0.0.0:58920 0.0.0.0:* 108 11792 384/avahi-daemon: r
          udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13283 441/dhcpcd
          udp6 0 0 :::546 :::* 0 16455 441/dhcpcd
          udp6 0 0 :::44193 :::* 108 11793 384/avahi-daemon: r
          udp6 0 0 :::5353 :::* 108 11791 384/avahi-daemon: r
          2023-11-01 11:32:04.365 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.3 because disabled or deleted
          2023-11-01 11:32:11.459 - error: tr-064.2 (7611) adapter disabled
          2023-11-01 11:32:11.512 - warn: tr-064.2 (7611) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
          2023-11-01 11:32:12.066 - error: host.raspberrypi instance system.adapter.tr-064.2 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          2023-11-01 11:32:12.066 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.2 because disabled or deleted
          2023-11-01 11:32:16.631 - error: tr-064.1 (7625) adapter disabled
          2023-11-01 11:32:16.687 - warn: tr-064.1 (7625) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
          2023-11-01 11:32:17.242 - error: host.raspberrypi instance system.adapter.tr-064.1 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          2023-11-01 11:32:17.243 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.1 because disabled or deleted
          2023-11-01 11:37:18.989 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
          2023-11-01 11:37:18.990 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
          2023-11-01 11:42:54.301 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
          2023-11-01 11:42:54.302 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
          2023-11-01 11:45:29.193 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Connect locally to device
          2023-11-01 11:45:29.194 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj Init with IP=192.168.178.66, Key=rKNJX%q%j/9y<JKX, Version=3.4
          2023-11-01 11:46:16.458 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (1): connection timed out
          2023-11-01 11:46:39.522 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.66:6668
          2023-11-01 11:47:22.594 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.66:6668
          2023-11-01 11:48:25.666 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.66:6668
          2023-11-01 11:48:29.595 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
          2023-11-01 11:48:29.596 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
          2023-11-01 11:54:04.892 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
          2023-11-01 11:54:04.893 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
          2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
          2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
          iob diag has finished.
            Thomas Braun Most Active @GerdNutzinger last edited by Thomas Braun
            @gerdnutzinger
            Die Zusammenfassung zeigt die wesentlichen Punkte als i.O. an.
              @gerdnutzinger
              Kannst du mal bitte die Ausgabe von
              pgrep -f 'Xorg|ayland|X11'
              posten?
                pi@raspberrypi:~ $ pgrep -f 'Xorg|ayland|X11'
                575
                pi@raspberrypi:~ $
                  @gerdnutzinger sagte in Probleme bei 4.0.23 auf 5.0.12:
                  Danke. Bitte noch
                  ps aux | grep -E 'Xorg|ayland|X11'
                    ps aux
                    Für was sind diese Daten die Du von mir brauchst?
                      pi@raspberrypi:~ $ ps aux | grep -E 'Xorg|ayland|X11'
                      root 575 0.0 1.3 198080 52660 tty7 Ssl+ 10:36 0:04 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                      pi 20525 0.0 0.0 7464 544 pts/0 S+ 16:13 0:00 grep --color=auto -E Xorg|ayland|X11
                        Für das iob diag Kommando. Wollte mal sehen warum da bei dir noch was bezgl. des X-Servers gefunden wird, das dürfte eigentlich nicht mehr der Fall sein.
                        Kannst du die Kiste mal komplett neustarten und dann nochmal
                        bitte.
                          Schaut anders aus...
                          pi 1579 0.0 0.0 7464 484 pts/0 S+ 16:36 0:00 grep --color=auto -E Xorg|ayland|X11
                          pi@raspberrypi:~ $
                            Ja, so soll es auch aussehen. Danke für die Mithilfe!
                              Ich muss DANKE sagen und das sehr gerne.
                              Was muss ich machen das ich das Problem als gelöst kennzeichne?
                              • Meister Mopper
                                Meister Mopper last edited by
                                Deinen ersten Eintrag mit [gelöst] ergänzen.
                                  @gerdnutzinger
                                  Editiere den ersten Beitrag entsprechend.
                                  1.2k
                                  1158
