    4. Homekit Controller startet ständig neu, bis er gestoppt wird
      Homerunner last edited by
      Das habe bereits gemacht, aber die Fehlermeldungen sind geblieben.
        Thomas Braun Most Active @Homerunner last edited by
        @homerunner
        Dann gibt mal die Langfassung von
        iob diag
        bekannt.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-vm
                     Chassis: vm
              Virtualization: kvm
            Operating System: Debian GNU/Linux 10 (buster)
                      Kernel: Linux 4.19.0-25-amd64
                Architecture: x86-64
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           15:48:37 up 1 day, 20:38,  1 user,  load average: 0.06, 0.11, 0.08
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Wed 2023-11-01 15:48:37 CET
                     Universal time: Wed 2023-11-01 14:48:37 UTC
                           RTC time: Wed 2023-11-01 14:48:38
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          iobroker
          /home/iobroker
          iobroker tty dialout cdrom floppy audio dip video plugdev netdev lpadmin scanner
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           3.0G        1.4G        398M        5.0M        1.2G        1.4G
          Swap:          3.1G         17M        3.1G
          Total:         6.1G        1.4G        3.5G
                   3002 M total memory
                   1405 M used memory
                   1815 M active memory
                    450 M inactive memory
                    398 M free memory
                    247 M buffer memory
                    951 M swap cache
                   3069 M total swap
                     17 M used swap
                   3052 M free swap
          *** FAILED SERVICES ***
          0 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          udev           devtmpfs  1.5G     0  1.5G   0% /dev
          tmpfs          tmpfs     301M  8.0M  293M   3% /run
          /dev/sda1      ext4       29G  6.3G   21G  24% /
          tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     1.5G     0  1.5G   0% /sys/fs/cgroup
          tmpfs          tmpfs     301M     0  301M   0% /run/user/1000
          [Mon Oct 30 19:09:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct 30 19:09:50 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          TARGET        SOURCE    FSTYPE OPTIONS
          /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
          `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          /var:
          896M    /var/
          711M    /var/cache
          692M    /var/cache/apt
          631M    /var/cache/apt/archives
          166M    /var/lib
                Users in the 'systemd-journal' group can see all messages. Pass -q to
                turn off this notice.
          No journal files were opened due to insufficient permissions.
          /opt/iobroker/backups:
          32M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          341M    /opt/iobroker/iobroker-data/
          216M    /opt/iobroker/iobroker-data/files
          100M    /opt/iobroker/iobroker-data/backup-objects
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
          9.3M    /opt/iobroker/iobroker-data/objects.jsonl
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
          8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               10.24.0~dfsg-1~deb10u3 500
                  500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
               10.24.0~dfsg-1~deb10u1 500
                  500 http://ftp.de.debian.org/debian buster/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.1
          javascript:     7.1.4
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
          + system.adapter.mydlink.0                : mydlink               : iobroker                                 -  enabled
          + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.1
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
          Adapter    "backitup"     : 2.8.1    , installed 2.8.7
          Adapter    "deconz"       : 1.3.21   , installed 1.3.22
          Adapter    "discovery"    : 3.1.0    , installed 3.2.0
          Adapter    "homekit-controller": 0.5.8, installed 0.5.8
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.16
          Adapter    "meross"       : 1.15.1   , installed 1.15.1
          Adapter    "mydlink"      : 1.3.4    , installed 1.3.4
          Adapter    "panasonic-comfort-cloud": 2.2.4, installed 2.2.4
          Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "wled"         : 0.7.1    , installed 0.7.1
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Adapter    "zigbee2mqtt"  : 2.13.3   , installed 2.13.3
          Objects and States
          Objects:        4214
          States:         3459
          Hit:1 http://security.debian.org/debian-security buster/updates InRelease
          Hit:2 http://phoscon.de/apt/deconz buster InRelease
          Hit:3 http://ftp.de.debian.org/debian buster InRelease
          Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11436      1/init
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       2104606    17991/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14097      447/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1351999    3148/cupsd
          tcp        0      0 0.0.0.0:44409           0.0.0.0:*               LISTEN      1000       2104641    18021/io.yahka.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2099756    17266/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2099749    17266/iobroker.js-c
          tcp        0      0 127.0.0.1:39051         0.0.0.0:*               LISTEN      1000       2104722    18021/io.yahka.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11444      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2102337    17285/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2104588    17976/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14099      447/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1351998    3148/cupsd
          udp        0      0 0.0.0.0:51504           0.0.0.0:*                           106        13971      384/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       2101736    17389/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       2101737    17389/io.tuya.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1352008    3149/cups-browsed
          udp        0      0 192.168.178.115:5353    0.0.0.0:*                           1000       2103535    17961/io.mydlink.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       2102873    17927/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13969      384/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2104373    17882/io.deconz.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13976      380/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11439      1/init
          udp6       0      0 :::45791                :::*                                106        13972      384/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                106        13970      384/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1000       2104375    17882/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1000       2104374    17882/io.deconz.0
          udp6       0      0 :::111                  :::*                                0          11449      1/init
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]: Error: undefined is not a valid state value
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Array.forEach (<anonymous>)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: Error: undefined is not a valid state value
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Array.forEach (<anonymous>)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
          2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
          2023-11-01 15:48:41.883  - error: host.iobroker instance system.adapter.homekit-controller.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-11-01 15:48:41.884  - info: host.iobroker Restart adapter system.adapter.homekit-controller.0 because enabled
            @homerunner
            Und die Einstellungen im Adapter sehen wie aus?
              Homerunner @Thomas Braun last edited by
              Kurios ist ja, unter Objekten sind Alle Geräte Grün.
              In der Instanz zeigt er keine Geräte an, ist nur am suchen..Screenshot 2023-11-01 155636.png Screenshot 2023-11-01 145643.png Screenshot 2023-11-01 145643 - Kopie.png Screenshot 2023-11-01 155735.png Colored Text Here
                @homerunner
                Keine Ahnung wo es da hakt.
                  Trotzdem danke für deine Mühe.
                  Hast du einen Tipp, an wen ich mich noch wenden könnte?
                    @homerunner sagte in Homekit Controller startet ständig neu, bis er gestoppt wird:
                    Bei GitHub ein Issue eröffnen.
                      Ok, werde es versuchen.
                      Ich habe noch eine Baustelle, weiß nicht, ob das auch dein Bereich ist.
                      Du kennst bestimmt die WLED Garagentor Geschichte.
                      Ich habe WLED seitig vorbereitet. Bei mir scheitert es an der Umsetzung der Signale vom Tor in ein Blockly zu schreiben. Ich habe ein Garagentoröffner von Meross und habe fogende Infos:Screenshot 2023-10-25 121031.png
                        @thomas-braun said in Homekit Controller startet ständig neu, bis er gestoppt wird:
                        Wie und wo kann ich das machen?
                          Thomas Braun Most Active @Homerunner last edited by Thomas Braun
                          @homerunner
                          Hier:
                          https://github.com/Apollon77/ioBroker.homekit-controller
                          Könnte aber das Ding sein:
                          https://github.com/Apollon77/ioBroker.homekit-controller/issues/291
                          Draygv2 created this issue in Apollon77/ioBroker.homekit-controller
                          closed Instanz is terminating itself #291
                            Danke, nun läuft wieder alles gut.
                            875
