    4. js controller update nicht möglich
      Thomas Braun Most Active @spaddel last edited by
      @spaddel sagte in js controller update nicht möglich:
      Ich habe noch den Homematic server auf den Pi laufen und keine Ahnung, wie das damals gemacht habe.
      Ich auch nicht.
        spaddel @Thomas Braun last edited by
        Hallo Thomas,
        leider auch im zweiten Ansatz kein Erfolg.
        Hier der Log:
        ioBroker nodejs fixer 2023-10-13
        Recommended nodejs-version is: 16.20.2
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        Nothing to do - Your installation is using the correct paths.
        Nothing to do - Your version is the recommended one.
        You can now keep your whole system up-to-date using the usual 'sudo apt update &       & sudo apt full-upgrade' commands.
        Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel.        They will break your current installation!
        pi@raspberrypi:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.3.5  [Updatable]
        Adapter    "bmw"          : 2.5.7    , installed 2.5.7
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
        Adapter    "lgtv"         : 2.1.1    , installed 1.1.12 [Updatable]
        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "synology"     : 3.0.0    , installed 2.1.13 [Updatable]
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
        pi@raspberrypi:~ $ iob upgrade all
        This upgrade of "hm-rpc" will introduce the following changes:
        -> 1.15.19:
        Updated packages
        -> 1.15.18:
        no longer support EOL versions, please upgrade to node 16
        -> 1.15.17:
        added new images (closes #778, closes #873, closes #882)
        fix wrong paramsets (closes #617, closes #584, closes #539, closes #764, closes #460, c
        fix wrong events (closes #872)
        Would you like to upgrade hm-rpc from @1.15.16 to @1.15.19 now? [(y)es, (n)o]: y
        Update hm-rpc from @1.15.16 to @1.15.19
        NPM version: 8.19.4
        Installing iobroker.hm-rpc@1.15.19... (System call)
        upload [275] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
        upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/154_hmip-spdr_thumb.png icons/154_hmip-spdr_thumb.png image/png
        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/201_hmip-stv_thumb.png icons/201_hmip-stv_thumb.png image/png
        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/42_hm-cc-tc_thumb.png icons/42_hm-cc-tc_thumb.png image/png
        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/51_hm-sec-sd_thumb.png icons/51_hm-sec-sd_thumb.png image/png
        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/59_hmw-io-12-fm_thumb.png icons/59_hmw-io-12-fm_thumb.png image/png
        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/69_hm-lc-sw2-dr_thumb.png icons/69_hm-lc-sw2-dr_thumb.png image/png
        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/7_hm-lc-bl1-fm_thumb.png icons/7_hm-lc-bl1-fm_thumb.png image/png
        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/87_hm-sen-rd-o_thumb.png icons/87_hm-sen-rd-o_thumb.png image/png
        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/99_hm-mod-em-8_thumb.png icons/99_hm-mod-em-8_thumb.png image/png
        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/IP65_G201_thumb.png icons/IP65_G201_thumb.png image/png
        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
        This upgrade of "admin" will at least introduce the following changes:
        -> 6.12.0:
        fixed issue when updating news in backend
        validate json config against the schema
        update socket-client to improve performance
        -> 6.11.0:
        jsonConfig type number now stores values as number instead of string
        objects browser number value input behavior change to allow leading minus
        Added component `interfaces` to the JSON config
        Implemented Backend to GUI communication
        -> 6.10.9:
        Improvement of the public accessibility check
        -> 6.10.8:
        update adapter-react-v5 to fix issues with object browser
        -> 6.10.7:
        Corrected adapter termination if the alias has no target
        -> 6.10.6:
        Added possibility to show the icon on JSON config tabs
        on upgrade all, not yet started commands can now be aborted
        Added security check if the server is available from the internet without protection
        Corrected navigation after the settings closing
        -> 6.10.5:
        JSON config component `port` does no longer mark port as occupied if it is only occupied on another host
        register news as notifications
        if upgrade all is stopped on error, activate close button
        Export/import objects with its values
        Would you like to upgrade admin from @6.3.5 to @6.12.0 now? [(y)es, (n)o]: y
        Update admin from @6.3.5 to @6.12.0
        NPM version: 8.19.4
        Installing iobroker.admin@6.12.0... (System call)
        Update "system.adapter.admin.0"
        upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        This upgrade of "ws" will at least introduce the following changes:
        -> 2.5.5:
        upgraded socket-classes to fix crash cases
        -> 2.5.4:
        added missing node16 requirement
        -> 2.5.3:
        Added the subscribing on the specific instance messages
        -> 2.4.0:
        (bluefox) extended the getObjects function with the possibility to read the list of IDs
        -> 2.3.6:
        Allowed deletion of fullcalendar objects
        -> 2.3.5:
        added `publishFileAll` method (for future use)
        -> 2.3.4:
        corrected connection string
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade ws from @1.3.0 to @2.5.5 now? [(y)es, (n)o]: y
        Update ws from @1.3.0 to @2.5.5
        NPM version: 8.19.4
        Installing iobroker.ws@2.5.5... (System call)
        upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
        This upgrade of "web" will at least introduce the following changes:
        -> 6.1.2:
        upgrade socketio and ws dependencies
        -> 6.1.1:
        -> 6.1.0:
        -> 6.0.3:
        Updated packages
        Implemented the possibility to view folder content
        -> 6.0.1:
        Removed letsencrypt handling from web adapter
        -> 5.5.3:
        Increased max size of the uploaded file via socket.io to 200MB (from 10MB)
        -> 5.5.2:
        Would you like to upgrade web from @4.3.0 to @6.1.2 now? [(y)es, (n)o]: y
        Update web from @4.3.0 to @6.1.2
        NPM version: 8.19.4
        Installing iobroker.web@6.1.2... (System call)
        upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
        upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
        upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
        upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
        upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
        upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
        upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
        upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
        upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
        upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
        upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
        upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
        upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
        upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
        upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
        upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
        upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
        upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
        upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
        upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
        upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
        upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
        upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
        upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
        upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
        upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
        upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
        upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
        upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
        upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
        upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
        upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
        upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
        upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
        upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
        upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
        upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
        upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
        upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
        upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
        upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
        upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
        upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
        upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
        upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
        upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
        upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
        upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
        upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
        upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
        upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
        This upgrade of "synology" will introduce the following changes:
        -> 3.0.0:
        Added WOL to awake Synology NAS server
        Only node 16 or higher supported
        Would you like to upgrade synology from @2.1.13 to @3.0.0 now? [(y)es, (n)o]: y
        Update synology from @2.1.13 to @3.0.0
        NPM version: 8.19.4
        Installing iobroker.synology@3.0.0... (System call)
        upload [19] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/_data.json _data.json application/json
        upload [18] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/admin.d.ts admin.d.ts video/mp2t
        upload [17] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/background.jpg background.jpg image/jpeg
        upload [16] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/cover.png cover.png image/png
        upload [15] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [14] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [13] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [12] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [11] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [10] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [9] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [8] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [7] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [6] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [5] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/index_m.html index_m.html text/html
        upload [4] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/jsonConfig.json jsonConfig.json application/json
        upload [3] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology.png synology.png image/png
        upload [2] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology_admin.png synology_admin.png image/png
        upload [1] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/tsconfig.json tsconfig.json application/json
        upload [0] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/words.js words.js application/javascript
        This upgrade of "lgtv" will introduce the following changes:
        -> 2.1.1:
        Websocket configuration has been fixed [#161].
        -> 2.1.1-alpha.0:
        -> 2.1.0:
        A bug that destryed the actual app state on changing from tv to app mode has been fixed.
        Websocket SSL states can now be sent / received again due to the websocket ssl changes.
        Plain websocket has been replaced by SSL Websocket.
        -> 2.0.0:
        Adapter has been moved to iobroker-community-adapters area
        POSSIBLE BREAKING: Adapter has been built from current github content. As latest npm packages have been created external, theres a chance that some changes got lost.
        Travis and AppVeyor have been replced by GitHub Actions, based on ioBroker/create-adapter
        Adpter requires NodeJS 16 minimum now
        Dependencies have been updated
        Configuration item healthIntervall has been rename/correct to healthInterval
        -> 2.0.0-alpha.0:
        Travis and AppVeyor have been replaced by GitHub Actions, based on ioBroker/create-adapter
        Adapter requires NodeJS 16 minimum now
        Would you like to upgrade lgtv from @1.1.12 to @2.1.1 now? [(y)es, (n)o]: y
        Update lgtv from @1.1.12 to @2.1.1
        NPM version: 8.19.4
        Installing iobroker.lgtv@2.1.1... (System call)
        upload [3] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index.html index.html text/html
        upload [2] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
        upload [1] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
        upload [0] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
        This upgrade of "info" will introduce the following changes:
        -> 2.0.0:
        Updated packages
        Breaking change: minimal supported node.js version is 16.x
        Would you like to upgrade info from @1.9.26 to @2.0.0 now? [(y)es, (n)o]: y
        Update info from @1.9.26 to @2.0.0
        NPM version: 8.19.4
        Installing iobroker.info@2.0.0... (System call)
        Adapter "system.adapter.vis.0" restarted.
        upload [91] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/memory.png lib/img/icons/memory.png image/png
        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
        upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
        pi@raspberrypi:~ $ iob stop
        ^[[A^[[Api@raspberrypi:~ $ iob upgrade self
        Update js-controller from @4.0.24 to @5.0.12
        Stopped Objects DB
        Stopped States DB
        NPM version: 8.19.4
        Installing iobroker.js-controller@5.0.12... (System call)
        pi@raspberrypi:~ $ iob start
        pi@raspberrypi:~ $ iobroker start admin
        The adapter "admin.0" was started.
        pi@raspberrypi:~ $
          @spaddel
          Gib mal die Ausgabe von
          iob diag
          Vorher mal
          iob nodejs-update 18
            Hier der Log:
                                    v.2023-10-10
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7l+
                  Architecture: arm
            Installation:           native
            Kernel:                 armv7l
            Userland:               armhf
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    8
            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                    /usr/bin/node           v18.18.2
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    /usr/bin/corepack       0.19.0
            Recommended versions are nodejs 16.20.2 and npm 8.19.4
            MEMORY:
            Mem:           3.8G        995M        1.2G        8.0M        1.7G        2.7G
            Swap:           99M          0B         99M
            Total:         3.9G        995M        1.3G
            Active iob-Instances:   13
            Active repo(s): stable
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                2753
            States:                 2429
            Size of iob-Database:
            15M     /opt/iobroker/iobroker-data/objects.jsonl
            4.0M    /opt/iobroker/iobroker-data/objects.json.migrated
            4.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            2.7M    /opt/iobroker/iobroker-data/states.jsonl
            320K    /opt/iobroker/iobroker-data/states.json.migrated
            320K    /opt/iobroker/iobroker-data/states.json.bak.migrated
            0       /opt/iobroker/iobroker-data/states.json.broken
              @spaddel
              Die Langfassung bitte.
                Hi Thomas, leider bekomme ich eine Fehlermeldung (Payload), wenn ich den Log posten will.
                Ich versuche es aber später noch mal.
                  Dann ist die Datei zu groß -> Zu viele Fehler.
                  Lad eine txt-Datei mit dem Inhalt hoch.
                    Mit Chrome bekomme ich ständig Fehlermeldung. Mit Edge funktioniert es aber. Hier der Log
                    Log.txt
                    Christian
                      @spaddel
                      Das ist nicht vollständig.
                        @spaddel
                        Die beiden sind aber schon mal krumm:
                        npm ERR! invalid: iobroker.samsung_tizen@0.0.12 /opt/iobroker/node_modules/iobroker.samsung_tizen
                        npm ERR! invalid: iobroker.samsung2016@0.0.2 /opt/iobroker/node_modules/iobroker.samsung2016
                        Schmeiß die raus:
                        iob del samsung_tizen
                        iob del samsung2016
                        iob update
                        iob upgrade
                          Ich habe den kompletten Inhalt aus Putty kopiert. Mehr war da nicht. Ich starte es noch mal und poste es.
                            @spaddel
                            Das log liegt auch in /home/iobroker/iob_diag.log herum.
                            • mcm1957
                              mcm1957 @Thomas Braun last edited by
                              samsung_tizen ist als 1.0.0 im repo verfügbar. Diese Release ist für js-controlelr 5 auch erforderlich.
                                Thomas Braun Most Active @mcm1957 last edited by
                                @mcm57 sagte in js controller update nicht möglich:
                                Ja, das ist aber bei weitem nicht der einzige Fehler im Tree.
                                • mcm1957
                                  Nö - wollt nur die Info gleich mal deponieren.
                                  Was da alles im npm tree nicht passt - keine Ahnung. Da kannst du sicher besser helfen.
                                    Da ist so viel... Muss mal schauen was da noch geht.
                                      Zweiter Versuch
                                      iob_diag.log
                                        @spaddel
                                        Höchste Zeit das Ding komplett neuauzusetzen.
                                        Als Bookworm-64Bit-Version 'Lite'.
                                        Versuch
                                        find "/opt/iobroker/" -iname "*package-lock*" -exec rm -rf "{}" \;
                                        dann
                                        iob update
                                        iob upgrade
                                          Wenn ich die Kommentare lese scheint einiges im Argen zu sein. Wie kann ich das System sauber neu aufsetzen. Wenn ich mich richtig erinnere, habe ich damals eine Anleitung von verdrahtet.info auf youtube verwendet.
                                          CHristian
                                            @spaddel
                                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                            Zu allem was da sonst noch läuft musst du dir aber selber Gedanken machen.
                                            js controller
                                            1841
