    4. Enocean 0.9.0 Geräte hinzufügen geht nicht mehr
      Thomas Braun Most Active @McBeath last edited by
      @mcbeath
      Dann versuch mal die Beta-Version vom nodejs-update:
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
      chmod 744 iob_node_update
      ./iob_node_update
        @mcbeath
        Vorher noch:
        wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
        apt-key add raspberrypi.gpg.key
          McBeath @Thomas Braun last edited by
          @thomas-braun said in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
          admin@raspberrypi:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
          --2023-11-01 20:25:56--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
          Auflösen des Hostnamens archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.84, 176.126.240.167, 176.126.240.86, ...
          Verbindungsaufbau zu archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.84|:80 ... verbunden.
          HTTP-Anforderung gesendet, auf Antwort wird gewartet ... 200 OK
          Länge: 1719 (1,7K) [application/pgp-keys]
          Wird in »raspberrypi.gpg.key« gespeichert.
          raspberrypi.gpg.key                                         100%[=========================================================================================================================================>]   1,68K  --.-KB/s    in 0,001s
          2023-11-01 20:25:56 (2,73 MB/s) - »raspberrypi.gpg.key« gespeichert [1719/1719]
          dmin@raspberrypi:~ $ apt-key add raspberrypi.gpg.key
          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
          E: This command can only be used by root.
            @mcbeath
            Sorry, my fault
            sudo apt-key add raspberrypi.gpg.key
              admin@raspberrypi:~ $ sudo apt-key add raspberrypi.gpg.key
              OK
              admin@raspberrypi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
                % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                               Dload  Upload   Total   Spent    Left  Speed
              100 16575  100 16575    0     0  43892      0 --:--:-- --:--:-- --:--:-- 43965
              admin@raspberrypi:~ $ chmod 744 iob_node_update
              ./iob_node_update
              ioBroker nodejs fixer 2023-10-24
              Recommended nodejs-version is: 18.18.2
              Checking your installation now. Please be patient!
              Your current setup is:
              /usr/bin/nodejs 	v18.13.0
              /usr/bin/node 		v18.13.0
              /usr/bin/npm 		9.2.0
              /usr/bin/npx 		9.2.0
              We found these nodejs versions available for installation:
              nodejs:
                Installed: 18.13.0+dfsg1-1+rpi1
                Candidate: 18.18.2-1nodesource1
                Version table:
                   18.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
               *** 18.13.0+dfsg1-1+rpi1 500
                      500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                      100 /var/lib/dpkg/status
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              Nothing to do - Your installation is using the correct paths.
              You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
              Press <y> to continue or any other key to quit
              Trying to fix your installation now. Please be patient.
              find: '/run/user/1000/doc': Permission denied
              find: '/run/user/1000/gvfs': Permission denied
              Waiting for ioBroker to shut down - Give me a minute...
              *** Removing previous installations of nodejs
              (Reading database ... 167629 files and directories currently installed.)
              Removing npm (9.2.0~ds1-1) ...
              Removing node-css-loader (6.7.2+~cs14.0.11-1) ...
              Removing webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
              Removing eslint (6.4.0~dfsg+~6.1.9-7) ...
              Removing node-tap (16.3.2+ds1+~cs50.8.16-1) ...
              Removing node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
              Removing node-gyp (9.3.0-2) ...
              Removing libnode-dev (18.13.0+dfsg1-1+rpi1) ...
              Removing node-cacache (17.0.3+~cs10.3.7-1) ...
              Removing node-unique-filename (1.1.1+ds-2) ...
              Removing terser (5.16.5-2) ...
              Removing node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
              Removing node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
              Removing node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
              Removing node-ws (8.11.0+~cs13.7.3-1) ...
              Removing node-espree (9.4.1~dfsg-1) ...
              Removing node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
              Removing node-agent-base (6.0.2+~cs5.4.2-2) ...
              Removing node-schema-utils (3.1.1~ds-2) ...
              Removing node-ajv-keywords (3.5.2-2) ...
              Removing node-ajv (6.12.6-3) ...
              Removing node-terser (5.16.5-2) ...
              Removing node-ansi-escapes (5.0.0+really.4.3.1-1) ...
              Removing node-tap-mocha-reporter (5.0.3+~2.0.2-2) ...
              Removing node-npmlog (7.0.1+~4.1.4-1) ...
              Removing node-gauge (4.0.4-1) ...
              Removing node-widest-line (3.1.0-2) ...
              Removing node-wide-align (1.1.3-4) ...
              Removing node-cli-truncate (2.1.0-5) ...
              Removing node-watchpack (2.4.0+~cs2.8.1-1) ...
              Removing node-chokidar (3.5.3-2) ...
              Removing node-readdirp (3.6.0-1) ...
              Removing node-move-concurrently (1.0.1-5) ...
              Removing node-copy-concurrently (1.0.5-9) ...
              Removing node-run-queue (2.0.0-3) ...
              Removing node-aproba (2.0.0-3) ...
              Removing node-are-we-there-yet (3.0.1+~1.1.0-1) ...
              Removing node-coveralls (3.1.1-2) ...
              Removing node-async-each (1.0.3-3) ...
              Removing node-auto-bind (4.0.0-2) ...
              Removing node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
              Removing node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
              Removing node-base (3.0.0-3) ...
              Removing node-base64-js (1.5.1+dfsg+~1.3.0-2) ...
              Removing node-is-binary-path (2.1.0-5) ...
              Removing node-binary-extensions (2.2.0-2) ...
              Removing node-npm-package-arg (10.0.0+~3.0.0-2) ...
              Removing node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
              Removing node-builtins (5.0.1-1) ...
              Removing node-cache-base (4.0.2-1) ...
              Removing node-tar (6.1.13+~cs7.0.5-1) ...
              Removing node-chownr (2.0.0-2) ...
              Removing node-chrome-trace-event (1.0.3-2) ...
              Removing node-ci-info (3.6.1+~cs1.1.0-1) ...
              Removing node-cli-boxes (2.2.1-2) ...
              Removing node-cli-cursor (4.0.0-3) ...
              Removing node-cli-table (0.3.11+~cs0.13.4-3) ...
              Removing node-columnify (1.6.0+~1.5.1-1) ...
              Removing node-collection-visit (1.0.0-4) ...
              Removing node-colors (1.4.0-4) ...
              Removing node-concat-stream (2.0.0+~2.0.0-2) ...
              Removing node-console-control-strings (1.1.0-3) ...
              Removing node-enhanced-resolve (5.10.0-1) ...
              Removing node-memory-fs (0.5.0+~0.3.3-2) ...
              Removing node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
              Removing node-fetch (3.3.0+~cs11.4.11-2) ...
              Removing node-data-uri-to-buffer (4.0.0-3) ...
              Removing node-got (11.8.5+~cs58.13.36-3) ...
              Removing node-decompress-response (6.0.0-2) ...
              Removing node-define-property (2.0.2+really+2.0.2-3) ...
              Removing node-delegates (1.0.0-3) ...
              Removing node-depd (2.0.0-2) ...
              Removing node-diff (5.0.0~dfsg+~5.0.1-4) ...
              Removing node-doctrine (3.0.0-4) ...
              Removing node-tap-parser (11.0.2+~cs2.1.4-1) ...
              Removing node-ssri (9.0.1-2) ...
              Removing node-minipass (3.3.6+~cs9.4.19-1) ...
              Removing node-encoding (0.1.13-2) ...
              Removing node-get-stream (6.0.1-1) ...
              Removing node-pump (3.0.0-5) ...
              Removing node-end-of-stream (1.4.4+~1.4.1-1) ...
              Removing node-promise-retry (2.0.1-4) ...
              Removing node-err-code (2.0.3+dfsg-3) ...
              Removing node-errno (1.0.0-3) ...
              Removing node-es-module-lexer (1.1.0+dfsg-2) ...
              Removing node-stack-utils (2.0.6+~2.0.1-1) ...
              Removing node-eslint-scope (7.1.1+~3.7.4-1) ...
              Removing node-eslint-utils (3.0.0-3) ...
              Removing node-eslint-visitor-keys (3.3.0+~1.0.0-1) ...
              Removing node-esquery (1.4.2~ds-1) ...
              Removing node-esrecurse (4.3.0-2) ...
              Removing node-events (3.3.0+~3.0.0-3) ...
              Removing node-fancy-log (1.3.3+~cs1.3.1-2) ...
              Removing node-fast-deep-equal (3.1.3-3) ...
              Removing node-flatted (3.2.7~ds-1) ...
              Removing node-mixin-deep (2.0.1-3) ...
              Removing node-fs-write-stream-atomic (1.0.10-6) ...
              Removing node-rechoir (0.8.0+~0.6.1-2) ...
              Removing node-npm-bundled (2.0.1-2) ...
              Removing node-read-package-json (5.0.2+~2.0.0-1) ...
              Removing node-functional-red-black-tree (1.0.1+20181105-7) ...
              Removing node-union-value (2.0.1-4) ...
              Removing node-unset-value (2.0.1-1) ...
              Removing node-has-value (2.0.2-4) ...
              Removing node-get-value (1:3.0.1-4) ...
              Removing node-growl (1.10.5-4) ...
              Removing node-has-unicode (2.0.1-5) ...
              Removing node-has-values (2.0.1-4) ...
              Removing node-iconv-lite (0.6.3-3) ...
              Removing node-postcss-modules-values (4.0.0+~4.0.0-1) ...
              Removing node-icss-utils (5.1.0+~5.1.0-1) ...
              Removing node-ieee754 (1.2.1-3) ...
              Removing node-iferr (1.0.2+~1.0.2-1) ...
              Removing node-ini (3.0.1-2) ...
              Removing node-interpret (2.2.0-3) ...
              Removing node-ip (2.0.0+~1.1.0-1) ...
              Removing node-ip-regex (4.3.0+~4.1.1-1) ...
              Removing node-is-descriptor (3.0.0-2) ...
              Removing node-set-value (4.1.0+~4.0.1-2) ...
              Removing node-is-primitive (3.0.1-3) ...
              Removing node-postcss-modules-extract-imports (3.0.0-2) ...
              Removing node-postcss (8.4.20+~cs8.0.23-1) ...
              Removing node-map-visit (1.0.0-4) ...
              Removing node-object-visit (1.0.1-5) ...
              Removing node-isobject (4.0.0-2) ...
              Removing node-json-buffer (3.0.1+~3.0.0-1) ...
              Removing node-json-schema (0.4.0+~7.0.11-1) ...
              Removing node-json-schema-traverse (1.0.0-3) ...
              Removing node-json-stable-stringify (1.0.2+~cs5.2.34-1) ...
              Removing node-shell-quote (1.7.4+~1.7.1-1) ...
              Removing node-jsonify (0.0.1-1) ...
              Removing node-jsonparse (1.3.1-10) ...
              Removing node-lcov-parse (1.0.0+20170612git80d039574ed9-6) ...
              Removing node-loader-runner (4.3.0-1) ...
              Removing node-log-driver (1.2.7+git+20180219+bba1761737-7) ...
              Removing node-lowercase-keys (2.0.0-2) ...
              Removing node-memfs (3.4.12+~cs1.0.3-1) ...
              Removing node-merge-stream (2.0.0+~1.1.2-2) ...
              Removing node-mime-types (2.1.35-1) ...
              Removing node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
              Removing node-mimic-response (3.1.0-8) ...
              Removing node-promzard (0.3.0-2) ...
              Removing node-read (1.0.7-5) ...
              Removing node-mute-stream (0.0.8+~0.0.1-3) ...
              Removing node-negotiator (0.6.3+~0.6.1-1) ...
              Removing node-restore-cursor (4.0.0-2) ...
              Removing node-opener (1.5.2+~1.4.0-1) ...
              Removing node-osenv (0.1.5+~0.1.1-1) ...
              Removing node-p-cancelable (2.1.1-1) ...
              Removing node-pascalcase (1.0.0-1) ...
              Removing node-path-is-absolute (2.0.0-2) ...
              Removing node-postcss-value-parser (4.2.0-1) ...
              Removing node-progress (2.0.3-2) ...
              Removing node-promise-inflight (1.0.1+~1.0.0-1) ...
              Removing node-prr (1.0.1-3) ...
              Removing node-uri-js (4.4.0+dfsg-8) ...
              Removing node-punycode (2.1.1-6) ...
              Removing node-serialize-javascript (6.0.0-2) ...
              Removing node-randombytes (2.1.0+~2.0.0-2) ...
              Removing node-regexpp (3.2.0-4) ...
              Removing node-resolve-cwd (3.0.0-2) ...
              Removing node-retry (0.13.1+~0.12.1-1) ...
              Removing node-sellside-emitter (1.2.1-3) ...
              Removing node-set-blocking (2.0.0-2) ...
              Removing node-set-immediate-shim (2.0.0-2) ...
              Removing node-webpack-sources (3.2.3+~3.2.0-2) ...
              Removing node-source-list-map (2.0.1+dfsg-2) ...
              Removing node-strip-json-comments (4.0.0-4) ...
              Removing node-tapable (2.2.1-2) ...
              Removing node-text-table (0.2.0-4) ...
              Removing node-time-stamp (2.2.0-2) ...
              Removing node-tslib (2.4.1-1) ...
              Removing node-typedarray (0.0.7-1) ...
              Removing node-v8-compile-cache (2.3.0-3) ...
              Removing node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
              Removing node-yaml (2.1.3-2) ...
              Removing node-define-properties (1.1.4+~1.1.3-1) ...
              Removing node-es-abstract (1.20.4+~cs26.27.47-1) ...
              Removing node-deep-equal (2.1.0+~cs31.12.80-1) ...
              Removing node-tape (5.6.1+~cs8.20.19-1) ...
              Removing node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
              Removing node-read-pkg (5.2.0-2) ...
              Removing handlebars (3:4.7.7+~4.1.0-1) ...
              Removing node-nopt (5.0.0-4) ...
              Removing node-abbrev (1.1.1+~1.1.2-1) ...
              Removing node-yargs (16.2.0+~16.0.4-7) ...
              Removing node-cliui (7.0.4+repack+~cs3.1.0-4) ...
              Removing node-wrap-ansi (8.0.1+~8.0.1-3) ...
              Removing node-string-width (4.2.3+~cs13.2.3-1) ...
              Removing node-slice-ansi (5.0.0+~cs9.0.0-5) ...
              Removing node-archy (1.0.0-6) ...
              Removing node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
              Removing node-argparse (2.0.1-2) ...
              Removing node-optimist (0.6.1+~0.0.30-2) ...
              Removing node-minimist (1.2.7+~cs5.3.2-2) ...
              Removing node-arrify (2.0.1-3) ...
              Removing node-async (0.8.0-6) ...
              Removing node-yargs-parser (21.1.1+~21.0.0-4) ...
              Removing node-camelcase (7.0.0-3) ...
              Removing node-wcwidth.js (1.0.2-2) ...
              Removing node-defaults (1.0.4+~1.0.3-1) ...
              Removing node-clone (2.1.2-4) ...
              Removing node-decamelize (4.0.0-2) ...
              Removing node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
              Removing node-optionator (0.9.1+dfsg+~cs1.2.3-1) ...
              Removing node-deep-is (0.1.4-1) ...
              Removing node-defined (1.0.1+~1.0.0-1) ...
              Removing node-es6-error (4.1.1-5) ...
              Removing node-esprima (4.0.1+ds+~4.0.3-2) ...
              Removing node-estraverse (5.3.0+ds+~5.1.1-1) ...
              Removing node-fast-levenshtein (2.0.6+ds-3) ...
              Removing node-foreground-child (2.0.0-5) ...
              Removing node-normalize-package-data (4.0.1+~2.4.1-1) ...
              Removing node-get-caller-file (2.0.5+~cs1.1.1-4) ...
              Removing node-hosted-git-info (6.1.1-2) ...
              Removing node-write-file-atomic (4.0.2+~4.0.0-1) ...
              Removing node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ...
              Removing node-is-plain-obj (3.0.0-2) ...
              Removing node-is-stream (3.0.0-4) ...
              Removing node-typedarray-to-buffer (4.0.0-2) ...
              Removing node-is-typedarray (1.0.0-4) ...
              Removing node-is-windows (1.0.2+~cs1.0.0-1) ...
              Removing node-which (2.0.2+~cs1.3.2-3) ...
              Removing node-isexe (2.0.0+~2.0.1-5) ...
              Removing node-levn (0.4.1+dfsg-2) ...
              Removing node-mkdirp (1.0.4+~1.0.2-4) ...
              Removing node-neo-async (2.6.2+~cs3.0.0-2) ...
              Removing node-npm-run-path (5.1.0+~4.0.0-8) ...
              Removing node-object-inspect (1.12.2+~cs1.8.1-1) ...
              Removing node-type-check (0.4.0+dfsg-3) ...
              Removing node-prelude-ls (1.2.1+dfsg-3) ...
              Removing node-require-directory (2.1.1+~2.1.2-1) ...
              Removing node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ...
              Removing node-resumer (0.0.0-6) ...
              Removing node-shebang-command (2.0.0-1) ...
              Removing node-shebang-regex (3.0.0-2) ...
              Removing node-signal-exit (3.0.7+~3.0.1-1) ...
              Removing node-validate-npm-package-license (3.0.4-2) ...
              Removing node-spdx-correct (3.1.1-2) ...
              Removing node-spdx-expression-parse (3.0.1+~3.0.1-1) ...
              Removing node-spdx-exceptions (2.3.0-2) ...
              Removing node-spdx-license-ids (3.0.12-1) ...
              Removing node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
              Removing node-strip-bom (4.0.0-2) ...
              Removing node-through (2.3.8+~cs0.0.30-1) ...
              Removing node-uuid (8.3.2+~8.3.3-3) ...
              Removing node-wordwrap (1.0.0-4) ...
              Removing node-y18n (5.0.8+~5.0.0-3) ...
              Removing node-parse-json (5.2.0+~cs5.1.7-1) ...
              Removing node-assert (2.0.0+~cs3.9.8-2) ...
              Removing node-util (0.12.5+~1.0.10-1) ...
              Removing libjs-util (0.12.5+~1.0.10-1) ...
              Removing node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
              Removing node-babel7 (7.20.15+ds1+~cs214.269.168-3) ...
              Removing node-find-cache-dir (3.3.2+~3.2.1-1) ...
              Removing node-del (7.0.0-5) ...
              Removing node-globby (13.1.3+~cs16.25.40-1) ...
              Removing node-micromatch (4.0.5+~4.0.2-1) ...
              Removing node-braces (3.0.2+~3.0.1-1) ...
              Removing node-fill-range (7.0.1+~7.0.0-1) ...
              Removing node-to-regex-range (5.0.1-4) ...
              Removing node-ampproject-remapping (2.2.0+~cs5.15.37-1) ...
              Removing node-strip-ansi (6.0.1-2) ...
              Removing node-ansi-regex (5.0.1-1) ...
              Removing node-chalk (5.2.0-1) ...
              Removing node-ansi-styles (6.2.1-2) ...
              Removing node-anymatch (3.1.3+~cs4.6.1-2) ...
              Removing node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ...
              Removing node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
              Removing node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ...
              Removing node-regenerator-transform (0.15.1+~0.10.8-1) ...
              Removing node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3) ...
              Removing node-rimraf (3.0.2-2) ...
              Removing node-glob (8.0.3+~cs8.4.15-1) ...
              Removing node-minimatch (5.1.1+~5.1.2-1) ...
              Removing node-brace-expansion (2.0.1-2) ...
              Removing node-balanced-match (2.0.0-1) ...
              Removing node-core-js-compat (3.26.1-3) ...
              Removing node-browserslist (4.21.4+~cs6.1.17-2) ...
              Removing node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ...
              Removing node-clone-deep (4.0.1+~cs7.0.2-1) ...
              Removing node-color-convert (2.0.1+~cs2.0.0-2) ...
              Removing node-color-name (1.1.4+~1.1.1-2) ...
              Removing node-commander (9.4.1-1) ...
              Removing node-commondir (1.0.1+~1.0.0-1) ...
              Removing node-convert-source-map (1.9.0+~1.5.2-1) ...
              Removing node-core-js (3.26.1-3) ...
              Removing node-core-js-pure (3.26.1-3) ...
              Removing node-n3 (1.16.3+~1.2.3+~1.10.4-1) ...
              Removing node-readable-stream (3.6.0+~cs3.0.0-4) ...
              Removing node-core-util-is (1.0.3-1) ...
              Removing node-electron-to-chromium (1.4.284-1) ...
              Removing node-error-ex (1.3.2-4) ...
              Removing node-p-map (4.0.0+~3.1.0+~3.0.1-1) ...
              Removing node-escape-string-regexp (4.0.0-2) ...
              Removing node-esutils (2.0.3+~2.0.0-1) ...
              Removing node-pkg-dir (5.0.0-2) ...
              Removing node-find-up (6.3.0-7) ...
              Removing node-for-own (1.0.0-3) ...
              Removing node-for-in (1.0.2-4) ...
              Removing node-fs-readdir-recursive (1.1.0+~1.1.0-1) ...
              Removing node-fs.realpath (1.0.0-3) ...
              Removing node-glob-parent (6.0.2+~5.1.1-2) ...
              Removing node-globals (13.18.0-1) ...
              Removing node-graceful-fs (4.2.10-1) ...
              Removing node-supports-color (8.1.1+~8.1.1-1) ...
              Removing node-has-flag (4.0.0-3) ...
              Removing node-ignore (5.2.1-1) ...
              Removing node-indent-string (4.0.0-2) ...
              Removing node-inflight (1.0.6-2) ...
              Removing node-inherits (2.0.4-6) ...
              Removing node-is-arrayish (0.3.2-3) ...
              Removing node-is-number (7.0.0-4) ...
              Removing node-kind-of (6.0.3+dfsg-2) ...
              Removing node-is-buffer (2.0.5-2) ...
              Removing node-is-extendable (1.0.1-3) ...
              Removing node-is-glob (4.0.3-2) ...
              Removing node-is-extglob (2.1.1-5) ...
              Removing node-is-path-cwd (2.2.0-2) ...
              Removing node-is-path-inside (3.0.3-2) ...
              Removing node-is-plain-object (5.0.0-7) ...
              Removing node-isarray (2.0.5-4) ...
              Removing node-js-tokens (8.0.0-2) ...
              Removing node-regexpu-core (5.2.2-3) ...
              Removing node-regjsparser (0.9.1+ds-2) ...
              Removing node-jsesc (3.0.2+~3.0.1-1) ...
              Removing node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ...
              Removing node-json5 (2.2.3+dfsg-1) ...
              Removing node-locate-path (7.1.1-2) ...
              Removing node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
              Removing node-make-dir (3.1.0-3) ...
              Removing node-normalize-path (3.0.0+~3.0.0-1) ...
              Removing node-object-assign (4.1.1-7) ...
              Removing node-once (1.4.0-7) ...
              Removing node-p-locate (6.0.0-12) ...
              Removing node-p-limit (4.0.0+~cs4.0.0-5) ...
              Removing node-path-dirname (1.0.2-2) ...
              Removing node-path-exists (5.0.0-8) ...
              Removing node-path-is-inside (1.0.2+~1.0.0-1) ...
              Removing node-path-type (4.0.0-3) ...
              Removing node-picocolors (1.0.0-4) ...
              Removing node-pify (5.0.0+~cs5.0.1-1) ...
              Removing node-process-nextick-args (2.0.1-3) ...
              Removing node-quick-lru (6.1.1-4) ...
              Removing node-regenerate-unicode-properties (10.1.0+ds-1) ...
              Removing node-regenerate (1.4.2-3) ...
              Removing node-regenerator-runtime (0.15.1+~0.10.8-1) ...
              Removing node-regjsgen (0.7.1+ds-1) ...
              Removing node-repeat-string (1.6.1+repack-1) ...
              Removing node-string-decoder (1.3.0-6) ...
              Removing node-safe-buffer (5.2.1+~cs2.1.2-3) ...
              Removing node-slash (4.0.0-3) ...
              Removing node-source-map-support (0.5.21+ds+~0.5.4-1) ...
              Removing node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
              Removing node-to-fast-properties (3.0.1-3) ...
              Removing node-unicode-match-property-ecmascript (2.0.0-2) ...
              Removing node-unicode-canonical-property-names-ecmascript (2.0.0-2) ...
              Removing node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ...
              Removing node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ...
              Removing node-util-deprecate (1.0.2-3) ...
              Removing node-v8flags (3.2.0+~3.1.1-1) ...
              Removing node-wrappy (1.0.2-3) ...
              Removing node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
              Removing node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1) ...
              Removing node-debug (4.3.4+~cs4.1.7-1) ...
              Removing node-resolve (1.22.1+~cs5.31.10-1) ...
              Removing node-function-bind (1.1.1+repacked+~1.0.3-2) ...
              Removing node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
              Removing node-semver (7.3.5+~7.3.9-2) ...
              Removing node-lru-cache (7.14.1-1) ...
              Removing node-ms (2.1.3+~cs0.7.31-3) ...
              Removing node-yallist (4.0.0+~4.0.1-1) ...
              Removing nodejs (18.13.0+dfsg1-1+rpi1) ...
              Removing libnode108:armhf (18.13.0+dfsg1-1+rpi1) ...
              Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
              Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ...
              Removing node-busboy (1.6.0+~cs2.6.0-2) ...
              Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
              Removing node-xtend (4.0.2-3) ...
              Processing triggers for man-db (2.11.2-2) ...
              Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
              (Reading database ... 138896 files and directories currently installed.)
              Purging configuration files for npm (9.2.0~ds1-1) ...
              Purging configuration files for node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
              Purging configuration files for node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
              Purging configuration files for node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
              Purging configuration files for node-esprima (4.0.1+ds+~4.0.3-2) ...
              *** These repos are active on your system:
              Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
              Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
              Reading package lists... Done
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
              W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
              Package: nodejs
              Pin: origin deb.nodesource.com
              Pin-Priority: 1001
              *** These repos are active after the adjustments:
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Installing the recommended nodejs version now!
              Installing the recommended nodejs version!
              Removing nodejs-doc (18.13.0+dfsg1-1+rpi1) ...
              Selecting previously unselected package nodejs.
              (Reading database ... 138692 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ...
              Unpacking nodejs (18.18.2-1nodesource1) ...
              Preparing to unpack .../archives/piwiz_0.65_armhf.deb ...
              Unpacking piwiz (0.65) over (0.64) ...
              Setting up nodejs (18.18.2-1nodesource1) ...
              Setting up piwiz (0.65) ...
              We tried our best to fix your nodejs. Please run iob diag again to verify.
              *** RESTARTING ioBroker NOW! ***
               Please refresh or restart your browser in a few moments.
              Sieht soweit doch gut aus, oder? 😊
              admin@raspberrypi:~ $ nodejs -v
              v18.18.2
              admin@raspberrypi:~ $ node -v
              v18.18.2
              admin@raspberrypi:~ $ npm -v
              9.8.1
                @mcbeath
                Ja, schaut besser aus. Bitte nochmal
                sudo apt update
                  sudo apt update
                  admin@raspberrypi:~ $ sudo apt update
                  OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                  OK:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  OK:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                  Fehl:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                    Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                  Abhängigkeitsbaum wird aufgebaut... Fertig
                  Statusinformationen werden eingelesen... Fertig
                  Alle Pakete sind aktuell.
                  W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                  W: Fehlschlag beim Holen von http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                  W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                    @mcbeath sagte in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
                    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                    sudo apt update
                      admin@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                      Executing: /tmp/apt-key-gpghome.4buJsFmM0I/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                      gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert
                      gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
                      gpg:                              importiert: 1
                      OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                      OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                        @mcbeath
                        sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                          admin@raspberrypi:~ $ sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                          hab der sache schon mal vorgefriffen 😉
                            @mcbeath Dann schau dir jetzt nochmal 'das große Ganze' an per
                            iob diag
                            an.
                            Und dann schau mal was enocean nun sagt. Falls der immer noch herumspinnen sollte mach am besten nochmal einen eigenen Thread dazu auf.
                              Copy text starting here:
                              			v.2023-10-10
                               Static hostname: raspberrypi
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 12 (bookworm)
                                        Kernel: Linux 6.1.0-rpi4-rpi-v8
                                  Architecture: arm64
                              Installation: 		native
                              Kernel: 		aarch64
                              Userland: 		armhf
                              Timezone: 		Europe/Berlin (CET, +0100)
                              User-ID: 		1000
                              X-Server: 		false
                              Boot Target: 		graphical.target
                              Pending OS-Updates: 	0
                              Pending iob updates: 	0
                              Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                              			/usr/bin/node 		v18.18.2
                              			/usr/bin/npm 		9.8.1
                              			/usr/bin/npx 		9.8.1
                              			/usr/bin/corepack 	0.19.0
                              Recommended versions are nodejs 18.18.2 and npm 9.8.1
                              MEMORY:
                              Mem:            4.0G        1.4G        1.3G        259M        1.6G        2.6G
                              Swap:           104M          0B        104M
                              Total:          4.1G        1.4G        1.4G
                              Active iob-Instances: 	5
                              Active repo(s): stable
                              ioBroker Core: 		js-controller 		5.0.14
                              			admin 			6.12.0
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects: 		463
                              States: 		323
                              Size of iob-Database:
                              8.7M	/opt/iobroker/iobroker-data/objects.jsonl
                              1.3M	/opt/iobroker/iobroker-data/states.jsonl
                              === Mark text until here for copying ===
                              Für mich sieht das jetzt prima aus 🙂
                                @mcbeath
                                Das ist zwar nur das 'kleine Ganze', bis auf Marginalien schaut das aber jetzt befahrbar aus.
                                  McBeath @Thomas Braun last edited by McBeath
                                  Danke schon mal für deine Mühen an dieser stelle.
                                  Leider werden wir wohl noch einen neuen Thread öffnen müssen,
                                  es ist leider noch immer nicht möglich neue Geräte hinzuzufügen 😞
                                  Hier geht es weiter
                                  1534
