    4. Enocean 0.9.0 Geräte hinzufügen geht nicht mehr
      Thomas Braun Most Active @McBeath last edited by
      @mcbeath
      Vorher noch:
      wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
      apt-key add raspberrypi.gpg.key
        McBeath @Thomas Braun last edited by
        @thomas-braun said in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
        admin@raspberrypi:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
        --2023-11-01 20:25:56--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
        Auflösen des Hostnamens archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.84, 176.126.240.167, 176.126.240.86, ...
        Verbindungsaufbau zu archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.84|:80 ... verbunden.
        HTTP-Anforderung gesendet, auf Antwort wird gewartet ... 200 OK
        Länge: 1719 (1,7K) [application/pgp-keys]
        Wird in »raspberrypi.gpg.key« gespeichert.
        raspberrypi.gpg.key                                         100%[=========================================================================================================================================>]   1,68K  --.-KB/s    in 0,001s
        2023-11-01 20:25:56 (2,73 MB/s) - »raspberrypi.gpg.key« gespeichert [1719/1719]
        dmin@raspberrypi:~ $ apt-key add raspberrypi.gpg.key
        Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
        E: This command can only be used by root.
          @mcbeath
          Sorry, my fault
          sudo apt-key add raspberrypi.gpg.key
            admin@raspberrypi:~ $ sudo apt-key add raspberrypi.gpg.key
            OK
            curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
            admin@raspberrypi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                             Dload  Upload   Total   Spent    Left  Speed
            100 16575  100 16575    0     0  43892      0 --:--:-- --:--:-- --:--:-- 43965
            chmod 744 iob_node_update
            admin@raspberrypi:~ $ chmod 744 iob_node_update
            ./iob_node_update
            ioBroker nodejs fixer 2023-10-24
            Recommended nodejs-version is: 18.18.2
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/nodejs 	v18.13.0
            /usr/bin/node 		v18.13.0
            /usr/bin/npm 		9.2.0
            /usr/bin/npx 		9.2.0
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 18.13.0+dfsg1-1+rpi1
              Candidate: 18.18.2-1nodesource1
              Version table:
                 18.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
             *** 18.13.0+dfsg1-1+rpi1 500
                    500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
            Press <y> to continue or any other key to quit
            Trying to fix your installation now. Please be patient.
            find: '/run/user/1000/doc': Permission denied
            find: '/run/user/1000/gvfs': Permission denied
            Waiting for ioBroker to shut down - Give me a minute...
            *** Removing previous installations of nodejs
            (Reading database ... 167629 files and directories currently installed.)
            Removing npm (9.2.0~ds1-1) ...
            Removing node-css-loader (6.7.2+~cs14.0.11-1) ...
            Removing webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
            Removing eslint (6.4.0~dfsg+~6.1.9-7) ...
            Removing node-tap (16.3.2+ds1+~cs50.8.16-1) ...
            Removing node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
            Removing node-gyp (9.3.0-2) ...
            Removing libnode-dev (18.13.0+dfsg1-1+rpi1) ...
            Removing node-cacache (17.0.3+~cs10.3.7-1) ...
            Removing node-unique-filename (1.1.1+ds-2) ...
            Removing terser (5.16.5-2) ...
            Removing node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
            Removing node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
            Removing node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
            Removing node-ws (8.11.0+~cs13.7.3-1) ...
            Removing node-espree (9.4.1~dfsg-1) ...
            Removing node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
            Removing node-agent-base (6.0.2+~cs5.4.2-2) ...
            Removing node-schema-utils (3.1.1~ds-2) ...
            Removing node-ajv-keywords (3.5.2-2) ...
            Removing node-ajv (6.12.6-3) ...
            Removing node-terser (5.16.5-2) ...
            Removing node-ansi-escapes (5.0.0+really.4.3.1-1) ...
            Removing node-tap-mocha-reporter (5.0.3+~2.0.2-2) ...
            Removing node-npmlog (7.0.1+~4.1.4-1) ...
            Removing node-gauge (4.0.4-1) ...
            Removing node-widest-line (3.1.0-2) ...
            Removing node-wide-align (1.1.3-4) ...
            Removing node-cli-truncate (2.1.0-5) ...
            Removing node-watchpack (2.4.0+~cs2.8.1-1) ...
            Removing node-chokidar (3.5.3-2) ...
            Removing node-readdirp (3.6.0-1) ...
            Removing node-move-concurrently (1.0.1-5) ...
            Removing node-copy-concurrently (1.0.5-9) ...
            Removing node-run-queue (2.0.0-3) ...
            Removing node-aproba (2.0.0-3) ...
            Removing node-are-we-there-yet (3.0.1+~1.1.0-1) ...
            Removing node-coveralls (3.1.1-2) ...
            Removing node-async-each (1.0.3-3) ...
            Removing node-auto-bind (4.0.0-2) ...
            Removing node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
            Removing node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
            Removing node-base (3.0.0-3) ...
            Removing node-base64-js (1.5.1+dfsg+~1.3.0-2) ...
            Removing node-is-binary-path (2.1.0-5) ...
            Removing node-binary-extensions (2.2.0-2) ...
            Removing node-npm-package-arg (10.0.0+~3.0.0-2) ...
            Removing node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
            Removing node-builtins (5.0.1-1) ...
            Removing node-cache-base (4.0.2-1) ...
            Removing node-tar (6.1.13+~cs7.0.5-1) ...
            Removing node-chownr (2.0.0-2) ...
            Removing node-chrome-trace-event (1.0.3-2) ...
            Removing node-ci-info (3.6.1+~cs1.1.0-1) ...
            Removing node-cli-boxes (2.2.1-2) ...
            Removing node-cli-cursor (4.0.0-3) ...
            Removing node-cli-table (0.3.11+~cs0.13.4-3) ...
            Removing node-columnify (1.6.0+~1.5.1-1) ...
            Removing node-collection-visit (1.0.0-4) ...
            Removing node-colors (1.4.0-4) ...
            Removing node-concat-stream (2.0.0+~2.0.0-2) ...
            Removing node-console-control-strings (1.1.0-3) ...
            Removing node-enhanced-resolve (5.10.0-1) ...
            Removing node-memory-fs (0.5.0+~0.3.3-2) ...
            Removing node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
            Removing node-fetch (3.3.0+~cs11.4.11-2) ...
            Removing node-data-uri-to-buffer (4.0.0-3) ...
            Removing node-got (11.8.5+~cs58.13.36-3) ...
            Removing node-decompress-response (6.0.0-2) ...
            Removing node-define-property (2.0.2+really+2.0.2-3) ...
            Removing node-delegates (1.0.0-3) ...
            Removing node-depd (2.0.0-2) ...
            Removing node-diff (5.0.0~dfsg+~5.0.1-4) ...
            Removing node-doctrine (3.0.0-4) ...
            Removing node-tap-parser (11.0.2+~cs2.1.4-1) ...
            Removing node-ssri (9.0.1-2) ...
            Removing node-minipass (3.3.6+~cs9.4.19-1) ...
            Removing node-encoding (0.1.13-2) ...
            Removing node-get-stream (6.0.1-1) ...
            Removing node-pump (3.0.0-5) ...
            Removing node-end-of-stream (1.4.4+~1.4.1-1) ...
            Removing node-promise-retry (2.0.1-4) ...
            Removing node-err-code (2.0.3+dfsg-3) ...
            Removing node-errno (1.0.0-3) ...
            Removing node-es-module-lexer (1.1.0+dfsg-2) ...
            Removing node-stack-utils (2.0.6+~2.0.1-1) ...
            Removing node-eslint-scope (7.1.1+~3.7.4-1) ...
            Removing node-eslint-utils (3.0.0-3) ...
            Removing node-eslint-visitor-keys (3.3.0+~1.0.0-1) ...
            Removing node-esquery (1.4.2~ds-1) ...
            Removing node-esrecurse (4.3.0-2) ...
            Removing node-events (3.3.0+~3.0.0-3) ...
            Removing node-fancy-log (1.3.3+~cs1.3.1-2) ...
            Removing node-fast-deep-equal (3.1.3-3) ...
            Removing node-flatted (3.2.7~ds-1) ...
            Removing node-mixin-deep (2.0.1-3) ...
            Removing node-fs-write-stream-atomic (1.0.10-6) ...
            Removing node-rechoir (0.8.0+~0.6.1-2) ...
            Removing node-npm-bundled (2.0.1-2) ...
            Removing node-read-package-json (5.0.2+~2.0.0-1) ...
            Removing node-functional-red-black-tree (1.0.1+20181105-7) ...
            Removing node-union-value (2.0.1-4) ...
            Removing node-unset-value (2.0.1-1) ...
            Removing node-has-value (2.0.2-4) ...
            Removing node-get-value (1:3.0.1-4) ...
            Removing node-growl (1.10.5-4) ...
            Removing node-has-unicode (2.0.1-5) ...
            Removing node-has-values (2.0.1-4) ...
            Removing node-iconv-lite (0.6.3-3) ...
            Removing node-postcss-modules-values (4.0.0+~4.0.0-1) ...
            Removing node-icss-utils (5.1.0+~5.1.0-1) ...
            Removing node-ieee754 (1.2.1-3) ...
            Removing node-iferr (1.0.2+~1.0.2-1) ...
            Removing node-ini (3.0.1-2) ...
            Removing node-interpret (2.2.0-3) ...
            Removing node-ip (2.0.0+~1.1.0-1) ...
            Removing node-ip-regex (4.3.0+~4.1.1-1) ...
            Removing node-is-descriptor (3.0.0-2) ...
            Removing node-set-value (4.1.0+~4.0.1-2) ...
            Removing node-is-primitive (3.0.1-3) ...
            Removing node-postcss-modules-extract-imports (3.0.0-2) ...
            Removing node-postcss (8.4.20+~cs8.0.23-1) ...
            Removing node-map-visit (1.0.0-4) ...
            Removing node-object-visit (1.0.1-5) ...
            Removing node-isobject (4.0.0-2) ...
            Removing node-json-buffer (3.0.1+~3.0.0-1) ...
            Removing node-json-schema (0.4.0+~7.0.11-1) ...
            Removing node-json-schema-traverse (1.0.0-3) ...
            Removing node-json-stable-stringify (1.0.2+~cs5.2.34-1) ...
            Removing node-shell-quote (1.7.4+~1.7.1-1) ...
            Removing node-jsonify (0.0.1-1) ...
            Removing node-jsonparse (1.3.1-10) ...
            Removing node-lcov-parse (1.0.0+20170612git80d039574ed9-6) ...
            Removing node-loader-runner (4.3.0-1) ...
            Removing node-log-driver (1.2.7+git+20180219+bba1761737-7) ...
            Removing node-lowercase-keys (2.0.0-2) ...
            Removing node-memfs (3.4.12+~cs1.0.3-1) ...
            Removing node-merge-stream (2.0.0+~1.1.2-2) ...
            Removing node-mime-types (2.1.35-1) ...
            Removing node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
            Removing node-mimic-response (3.1.0-8) ...
            Removing node-promzard (0.3.0-2) ...
            Removing node-read (1.0.7-5) ...
            Removing node-mute-stream (0.0.8+~0.0.1-3) ...
            Removing node-negotiator (0.6.3+~0.6.1-1) ...
            Removing node-restore-cursor (4.0.0-2) ...
            Removing node-opener (1.5.2+~1.4.0-1) ...
            Removing node-osenv (0.1.5+~0.1.1-1) ...
            Removing node-p-cancelable (2.1.1-1) ...
            Removing node-pascalcase (1.0.0-1) ...
            Removing node-path-is-absolute (2.0.0-2) ...
            Removing node-postcss-value-parser (4.2.0-1) ...
            Removing node-progress (2.0.3-2) ...
            Removing node-promise-inflight (1.0.1+~1.0.0-1) ...
            Removing node-prr (1.0.1-3) ...
            Removing node-uri-js (4.4.0+dfsg-8) ...
            Removing node-punycode (2.1.1-6) ...
            Removing node-serialize-javascript (6.0.0-2) ...
            Removing node-randombytes (2.1.0+~2.0.0-2) ...
            Removing node-regexpp (3.2.0-4) ...
            Removing node-resolve-cwd (3.0.0-2) ...
            Removing node-retry (0.13.1+~0.12.1-1) ...
            Removing node-sellside-emitter (1.2.1-3) ...
            Removing node-set-blocking (2.0.0-2) ...
            Removing node-set-immediate-shim (2.0.0-2) ...
            Removing node-webpack-sources (3.2.3+~3.2.0-2) ...
            Removing node-source-list-map (2.0.1+dfsg-2) ...
            Removing node-strip-json-comments (4.0.0-4) ...
            Removing node-tapable (2.2.1-2) ...
            Removing node-text-table (0.2.0-4) ...
            Removing node-time-stamp (2.2.0-2) ...
            Removing node-tslib (2.4.1-1) ...
            Removing node-typedarray (0.0.7-1) ...
            Removing node-v8-compile-cache (2.3.0-3) ...
            Removing node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
            Removing node-yaml (2.1.3-2) ...
            Removing node-define-properties (1.1.4+~1.1.3-1) ...
            Removing node-es-abstract (1.20.4+~cs26.27.47-1) ...
            Removing node-deep-equal (2.1.0+~cs31.12.80-1) ...
            Removing node-tape (5.6.1+~cs8.20.19-1) ...
            Removing node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
            Removing node-read-pkg (5.2.0-2) ...
            Removing handlebars (3:4.7.7+~4.1.0-1) ...
            Removing node-nopt (5.0.0-4) ...
            Removing node-abbrev (1.1.1+~1.1.2-1) ...
            Removing node-yargs (16.2.0+~16.0.4-7) ...
            Removing node-cliui (7.0.4+repack+~cs3.1.0-4) ...
            Removing node-wrap-ansi (8.0.1+~8.0.1-3) ...
            Removing node-string-width (4.2.3+~cs13.2.3-1) ...
            Removing node-slice-ansi (5.0.0+~cs9.0.0-5) ...
            Removing node-archy (1.0.0-6) ...
            Removing node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
            Removing node-argparse (2.0.1-2) ...
            Removing node-optimist (0.6.1+~0.0.30-2) ...
            Removing node-minimist (1.2.7+~cs5.3.2-2) ...
            Removing node-arrify (2.0.1-3) ...
            Removing node-async (0.8.0-6) ...
            Removing node-yargs-parser (21.1.1+~21.0.0-4) ...
            Removing node-camelcase (7.0.0-3) ...
            Removing node-wcwidth.js (1.0.2-2) ...
            Removing node-defaults (1.0.4+~1.0.3-1) ...
            Removing node-clone (2.1.2-4) ...
            Removing node-decamelize (4.0.0-2) ...
            Removing node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
            Removing node-optionator (0.9.1+dfsg+~cs1.2.3-1) ...
            Removing node-deep-is (0.1.4-1) ...
            Removing node-defined (1.0.1+~1.0.0-1) ...
            Removing node-es6-error (4.1.1-5) ...
            Removing node-esprima (4.0.1+ds+~4.0.3-2) ...
            Removing node-estraverse (5.3.0+ds+~5.1.1-1) ...
            Removing node-fast-levenshtein (2.0.6+ds-3) ...
            Removing node-foreground-child (2.0.0-5) ...
            Removing node-normalize-package-data (4.0.1+~2.4.1-1) ...
            Removing node-get-caller-file (2.0.5+~cs1.1.1-4) ...
            Removing node-hosted-git-info (6.1.1-2) ...
            Removing node-write-file-atomic (4.0.2+~4.0.0-1) ...
            Removing node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ...
            Removing node-is-plain-obj (3.0.0-2) ...
            Removing node-is-stream (3.0.0-4) ...
            Removing node-typedarray-to-buffer (4.0.0-2) ...
            Removing node-is-typedarray (1.0.0-4) ...
            Removing node-is-windows (1.0.2+~cs1.0.0-1) ...
            Removing node-which (2.0.2+~cs1.3.2-3) ...
            Removing node-isexe (2.0.0+~2.0.1-5) ...
            Removing node-levn (0.4.1+dfsg-2) ...
            Removing node-mkdirp (1.0.4+~1.0.2-4) ...
            Removing node-neo-async (2.6.2+~cs3.0.0-2) ...
            Removing node-npm-run-path (5.1.0+~4.0.0-8) ...
            Removing node-object-inspect (1.12.2+~cs1.8.1-1) ...
            Removing node-type-check (0.4.0+dfsg-3) ...
            Removing node-prelude-ls (1.2.1+dfsg-3) ...
            Removing node-require-directory (2.1.1+~2.1.2-1) ...
            Removing node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ...
            Removing node-resumer (0.0.0-6) ...
            Removing node-shebang-command (2.0.0-1) ...
            Removing node-shebang-regex (3.0.0-2) ...
            Removing node-signal-exit (3.0.7+~3.0.1-1) ...
            Removing node-validate-npm-package-license (3.0.4-2) ...
            Removing node-spdx-correct (3.1.1-2) ...
            Removing node-spdx-expression-parse (3.0.1+~3.0.1-1) ...
            Removing node-spdx-exceptions (2.3.0-2) ...
            Removing node-spdx-license-ids (3.0.12-1) ...
            Removing node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
            Removing node-strip-bom (4.0.0-2) ...
            Removing node-through (2.3.8+~cs0.0.30-1) ...
            Removing node-uuid (8.3.2+~8.3.3-3) ...
            Removing node-wordwrap (1.0.0-4) ...
            Removing node-y18n (5.0.8+~5.0.0-3) ...
            Removing node-parse-json (5.2.0+~cs5.1.7-1) ...
            Removing node-assert (2.0.0+~cs3.9.8-2) ...
            Removing node-util (0.12.5+~1.0.10-1) ...
            Removing libjs-util (0.12.5+~1.0.10-1) ...
            Removing node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
            Removing node-babel7 (7.20.15+ds1+~cs214.269.168-3) ...
            Removing node-find-cache-dir (3.3.2+~3.2.1-1) ...
            Removing node-del (7.0.0-5) ...
            Removing node-globby (13.1.3+~cs16.25.40-1) ...
            Removing node-micromatch (4.0.5+~4.0.2-1) ...
            Removing node-braces (3.0.2+~3.0.1-1) ...
            Removing node-fill-range (7.0.1+~7.0.0-1) ...
            Removing node-to-regex-range (5.0.1-4) ...
            Removing node-ampproject-remapping (2.2.0+~cs5.15.37-1) ...
            Removing node-strip-ansi (6.0.1-2) ...
            Removing node-ansi-regex (5.0.1-1) ...
            Removing node-chalk (5.2.0-1) ...
            Removing node-ansi-styles (6.2.1-2) ...
            Removing node-anymatch (3.1.3+~cs4.6.1-2) ...
            Removing node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ...
            Removing node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
            Removing node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ...
            Removing node-regenerator-transform (0.15.1+~0.10.8-1) ...
            Removing node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3) ...
            Removing node-rimraf (3.0.2-2) ...
            Removing node-glob (8.0.3+~cs8.4.15-1) ...
            Removing node-minimatch (5.1.1+~5.1.2-1) ...
            Removing node-brace-expansion (2.0.1-2) ...
            Removing node-balanced-match (2.0.0-1) ...
            Removing node-core-js-compat (3.26.1-3) ...
            Removing node-browserslist (4.21.4+~cs6.1.17-2) ...
            Removing node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ...
            Removing node-clone-deep (4.0.1+~cs7.0.2-1) ...
            Removing node-color-convert (2.0.1+~cs2.0.0-2) ...
            Removing node-color-name (1.1.4+~1.1.1-2) ...
            Removing node-commander (9.4.1-1) ...
            Removing node-commondir (1.0.1+~1.0.0-1) ...
            Removing node-convert-source-map (1.9.0+~1.5.2-1) ...
            Removing node-core-js (3.26.1-3) ...
            Removing node-core-js-pure (3.26.1-3) ...
            Removing node-n3 (1.16.3+~1.2.3+~1.10.4-1) ...
            Removing node-readable-stream (3.6.0+~cs3.0.0-4) ...
            Removing node-core-util-is (1.0.3-1) ...
            Removing node-electron-to-chromium (1.4.284-1) ...
            Removing node-error-ex (1.3.2-4) ...
            Removing node-p-map (4.0.0+~3.1.0+~3.0.1-1) ...
            Removing node-escape-string-regexp (4.0.0-2) ...
            Removing node-esutils (2.0.3+~2.0.0-1) ...
            Removing node-pkg-dir (5.0.0-2) ...
            Removing node-find-up (6.3.0-7) ...
            Removing node-for-own (1.0.0-3) ...
            Removing node-for-in (1.0.2-4) ...
            Removing node-fs-readdir-recursive (1.1.0+~1.1.0-1) ...
            Removing node-fs.realpath (1.0.0-3) ...
            Removing node-glob-parent (6.0.2+~5.1.1-2) ...
            Removing node-globals (13.18.0-1) ...
            Removing node-graceful-fs (4.2.10-1) ...
            Removing node-supports-color (8.1.1+~8.1.1-1) ...
            Removing node-has-flag (4.0.0-3) ...
            Removing node-ignore (5.2.1-1) ...
            Removing node-indent-string (4.0.0-2) ...
            Removing node-inflight (1.0.6-2) ...
            Removing node-inherits (2.0.4-6) ...
            Removing node-is-arrayish (0.3.2-3) ...
            Removing node-is-number (7.0.0-4) ...
            Removing node-kind-of (6.0.3+dfsg-2) ...
            Removing node-is-buffer (2.0.5-2) ...
            Removing node-is-extendable (1.0.1-3) ...
            Removing node-is-glob (4.0.3-2) ...
            Removing node-is-extglob (2.1.1-5) ...
            Removing node-is-path-cwd (2.2.0-2) ...
            Removing node-is-path-inside (3.0.3-2) ...
            Removing node-is-plain-object (5.0.0-7) ...
            Removing node-isarray (2.0.5-4) ...
            Removing node-js-tokens (8.0.0-2) ...
            Removing node-regexpu-core (5.2.2-3) ...
            Removing node-regjsparser (0.9.1+ds-2) ...
            Removing node-jsesc (3.0.2+~3.0.1-1) ...
            Removing node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ...
            Removing node-json5 (2.2.3+dfsg-1) ...
            Removing node-locate-path (7.1.1-2) ...
            Removing node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
            Removing node-make-dir (3.1.0-3) ...
            Removing node-normalize-path (3.0.0+~3.0.0-1) ...
            Removing node-object-assign (4.1.1-7) ...
            Removing node-once (1.4.0-7) ...
            Removing node-p-locate (6.0.0-12) ...
            Removing node-p-limit (4.0.0+~cs4.0.0-5) ...
            Removing node-path-dirname (1.0.2-2) ...
            Removing node-path-exists (5.0.0-8) ...
            Removing node-path-is-inside (1.0.2+~1.0.0-1) ...
            Removing node-path-type (4.0.0-3) ...
            Removing node-picocolors (1.0.0-4) ...
            Removing node-pify (5.0.0+~cs5.0.1-1) ...
            Removing node-process-nextick-args (2.0.1-3) ...
            Removing node-quick-lru (6.1.1-4) ...
            Removing node-regenerate-unicode-properties (10.1.0+ds-1) ...
            Removing node-regenerate (1.4.2-3) ...
            Removing node-regenerator-runtime (0.15.1+~0.10.8-1) ...
            Removing node-regjsgen (0.7.1+ds-1) ...
            Removing node-repeat-string (1.6.1+repack-1) ...
            Removing node-string-decoder (1.3.0-6) ...
            Removing node-safe-buffer (5.2.1+~cs2.1.2-3) ...
            Removing node-slash (4.0.0-3) ...
            Removing node-source-map-support (0.5.21+ds+~0.5.4-1) ...
            Removing node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
            Removing node-to-fast-properties (3.0.1-3) ...
            Removing node-unicode-match-property-ecmascript (2.0.0-2) ...
            Removing node-unicode-canonical-property-names-ecmascript (2.0.0-2) ...
            Removing node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ...
            Removing node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ...
            Removing node-util-deprecate (1.0.2-3) ...
            Removing node-v8flags (3.2.0+~3.1.1-1) ...
            Removing node-wrappy (1.0.2-3) ...
            Removing node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
            Removing node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1) ...
            Removing node-debug (4.3.4+~cs4.1.7-1) ...
            Removing node-resolve (1.22.1+~cs5.31.10-1) ...
            Removing node-function-bind (1.1.1+repacked+~1.0.3-2) ...
            Removing node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
            Removing node-semver (7.3.5+~7.3.9-2) ...
            Removing node-lru-cache (7.14.1-1) ...
            Removing node-ms (2.1.3+~cs0.7.31-3) ...
            Removing node-yallist (4.0.0+~4.0.1-1) ...
            Removing nodejs (18.13.0+dfsg1-1+rpi1) ...
            Removing libnode108:armhf (18.13.0+dfsg1-1+rpi1) ...
            Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
            Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ...
            Removing node-busboy (1.6.0+~cs2.6.0-2) ...
            Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
            Removing node-xtend (4.0.2-3) ...
            Processing triggers for man-db (2.11.2-2) ...
            Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
            (Reading database ... 138896 files and directories currently installed.)
            Purging configuration files for npm (9.2.0~ds1-1) ...
            Purging configuration files for node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
            Purging configuration files for node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
            Purging configuration files for node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
            Purging configuration files for node-esprima (4.0.1+ds+~4.0.3-2) ...
            *** These repos are active on your system:
            Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
            Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
            Reading package lists... Done
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
            W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Installing the recommended nodejs version now!
            Installing the recommended nodejs version!
            Removing nodejs-doc (18.13.0+dfsg1-1+rpi1) ...
            Selecting previously unselected package nodejs.
            (Reading database ... 138692 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ...
            Unpacking nodejs (18.18.2-1nodesource1) ...
            Preparing to unpack .../archives/piwiz_0.65_armhf.deb ...
            Unpacking piwiz (0.65) over (0.64) ...
            Setting up nodejs (18.18.2-1nodesource1) ...
            Setting up piwiz (0.65) ...
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
             Please refresh or restart your browser in a few moments.
            Sieht soweit doch gut aus, oder? 😊
            admin@raspberrypi:~ $ nodejs -v
            v18.18.2
            admin@raspberrypi:~ $ node -v
            v18.18.2
            admin@raspberrypi:~ $ npm -v
            9.8.1
              @mcbeath
              Ja, schaut besser aus. Bitte nochmal
              sudo apt update
                sudo apt update
                admin@raspberrypi:~ $ sudo apt update
                OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                OK:2 http://archive.raspberrypi.com/debian bookworm InRelease
                OK:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                Fehl:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                Abhängigkeitsbaum wird aufgebaut... Fertig
                Statusinformationen werden eingelesen... Fertig
                Alle Pakete sind aktuell.
                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                W: Fehlschlag beim Holen von http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
                W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                  @mcbeath sagte in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
                  sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                  sudo apt update
                    admin@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                    Executing: /tmp/apt-key-gpghome.4buJsFmM0I/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                    gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert
                    gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
                    gpg:                              importiert: 1
                    OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                    OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                      @mcbeath
                      sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                        admin@raspberrypi:~ $ sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                        hab der sache schon mal vorgefriffen 😉
                          @mcbeath Dann schau dir jetzt nochmal 'das große Ganze' an per
                          iob diag
                          an.
                          Und dann schau mal was enocean nun sagt. Falls der immer noch herumspinnen sollte mach am besten nochmal einen eigenen Thread dazu auf.
                            Copy text starting here:
                            			v.2023-10-10
                             Static hostname: raspberrypi
                                   Icon name: computer
                            Operating System: Raspbian GNU/Linux 12 (bookworm)
                                      Kernel: Linux 6.1.0-rpi4-rpi-v8
                                Architecture: arm64
                            Installation: 		native
                            Kernel: 		aarch64
                            Userland: 		armhf
                            Timezone: 		Europe/Berlin (CET, +0100)
                            User-ID: 		1000
                            X-Server: 		false
                            Boot Target: 		graphical.target
                            Pending OS-Updates: 	0
                            Pending iob updates: 	0
                            Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                            			/usr/bin/node 		v18.18.2
                            			/usr/bin/npm 		9.8.1
                            			/usr/bin/npx 		9.8.1
                            			/usr/bin/corepack 	0.19.0
                            Recommended versions are nodejs 18.18.2 and npm 9.8.1
                            MEMORY:
                            Mem:            4.0G        1.4G        1.3G        259M        1.6G        2.6G
                            Swap:           104M          0B        104M
                            Total:          4.1G        1.4G        1.4G
                            Active iob-Instances: 	5
                            Active repo(s): stable
                            ioBroker Core: 		js-controller 		5.0.14
                            			admin 			6.12.0
                            ioBroker Status: 	iobroker is running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects: 		463
                            States: 		323
                            Size of iob-Database:
                            8.7M	/opt/iobroker/iobroker-data/objects.jsonl
                            1.3M	/opt/iobroker/iobroker-data/states.jsonl
                            === Mark text until here for copying ===
                            Für mich sieht das jetzt prima aus 🙂
                              @mcbeath
                              Das ist zwar nur das 'kleine Ganze', bis auf Marginalien schaut das aber jetzt befahrbar aus.
                                McBeath @Thomas Braun last edited by McBeath
                                Danke schon mal für deine Mühen an dieser stelle.
                                Leider werden wir wohl noch einen neuen Thread öffnen müssen,
                                es ist leider noch immer nicht möglich neue Geräte hinzuzufügen 😞
                                Hier geht es weiter
                                1534
