    4. Enocean 0.9.0 Geräte hinzufügen geht nicht mehr
      Thomas Braun Most Active @McBeath last edited by
      @mcbeath
      Sorry, my fault
      sudo apt-key add raspberrypi.gpg.key
        McBeath @Thomas Braun last edited by
        @thomas-braun said in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
        admin@raspberrypi:~ $ sudo apt-key add raspberrypi.gpg.key
        Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
        OK
        curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
        admin@raspberrypi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                         Dload  Upload   Total   Spent    Left  Speed
        100 16575  100 16575    0     0  43892      0 --:--:-- --:--:-- --:--:-- 43965
        chmod 744 iob_node_update
        admin@raspberrypi:~ $ chmod 744 iob_node_update
        ./iob_node_update
        ioBroker nodejs fixer 2023-10-24
        Recommended nodejs-version is: 18.18.2
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs 	v18.13.0
        /usr/bin/node 		v18.13.0
        /usr/bin/npm 		9.2.0
        /usr/bin/npx 		9.2.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.13.0+dfsg1-1+rpi1
          Candidate: 18.18.2-1nodesource1
          Version table:
             18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
         *** 18.13.0+dfsg1-1+rpi1 500
                500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                100 /var/lib/dpkg/status
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        find: '/run/user/1000/doc': Permission denied
        find: '/run/user/1000/gvfs': Permission denied
        Waiting for ioBroker to shut down - Give me a minute...
        *** Removing previous installations of nodejs
        (Reading database ... 167629 files and directories currently installed.)
        Removing npm (9.2.0~ds1-1) ...
        Removing node-css-loader (6.7.2+~cs14.0.11-1) ...
        Removing webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
        Removing eslint (6.4.0~dfsg+~6.1.9-7) ...
        Removing node-tap (16.3.2+ds1+~cs50.8.16-1) ...
        Removing node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
        Removing node-gyp (9.3.0-2) ...
        Removing libnode-dev (18.13.0+dfsg1-1+rpi1) ...
        Removing node-cacache (17.0.3+~cs10.3.7-1) ...
        Removing node-unique-filename (1.1.1+ds-2) ...
        Removing terser (5.16.5-2) ...
        Removing node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
        Removing node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
        Removing node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
        Removing node-ws (8.11.0+~cs13.7.3-1) ...
        Removing node-espree (9.4.1~dfsg-1) ...
        Removing node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
        Removing node-agent-base (6.0.2+~cs5.4.2-2) ...
        Removing node-schema-utils (3.1.1~ds-2) ...
        Removing node-ajv-keywords (3.5.2-2) ...
        Removing node-ajv (6.12.6-3) ...
        Removing node-terser (5.16.5-2) ...
        Removing node-ansi-escapes (5.0.0+really.4.3.1-1) ...
        Removing node-tap-mocha-reporter (5.0.3+~2.0.2-2) ...
        Removing node-npmlog (7.0.1+~4.1.4-1) ...
        Removing node-gauge (4.0.4-1) ...
        Removing node-widest-line (3.1.0-2) ...
        Removing node-wide-align (1.1.3-4) ...
        Removing node-cli-truncate (2.1.0-5) ...
        Removing node-watchpack (2.4.0+~cs2.8.1-1) ...
        Removing node-chokidar (3.5.3-2) ...
        Removing node-readdirp (3.6.0-1) ...
        Removing node-move-concurrently (1.0.1-5) ...
        Removing node-copy-concurrently (1.0.5-9) ...
        Removing node-run-queue (2.0.0-3) ...
        Removing node-aproba (2.0.0-3) ...
        Removing node-are-we-there-yet (3.0.1+~1.1.0-1) ...
        Removing node-coveralls (3.1.1-2) ...
        Removing node-async-each (1.0.3-3) ...
        Removing node-auto-bind (4.0.0-2) ...
        Removing node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
        Removing node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
        Removing node-base (3.0.0-3) ...
        Removing node-base64-js (1.5.1+dfsg+~1.3.0-2) ...
        Removing node-is-binary-path (2.1.0-5) ...
        Removing node-binary-extensions (2.2.0-2) ...
        Removing node-npm-package-arg (10.0.0+~3.0.0-2) ...
        Removing node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
        Removing node-builtins (5.0.1-1) ...
        Removing node-cache-base (4.0.2-1) ...
        Removing node-tar (6.1.13+~cs7.0.5-1) ...
        Removing node-chownr (2.0.0-2) ...
        Removing node-chrome-trace-event (1.0.3-2) ...
        Removing node-ci-info (3.6.1+~cs1.1.0-1) ...
        Removing node-cli-boxes (2.2.1-2) ...
        Removing node-cli-cursor (4.0.0-3) ...
        Removing node-cli-table (0.3.11+~cs0.13.4-3) ...
        Removing node-columnify (1.6.0+~1.5.1-1) ...
        Removing node-collection-visit (1.0.0-4) ...
        Removing node-colors (1.4.0-4) ...
        Removing node-concat-stream (2.0.0+~2.0.0-2) ...
        Removing node-console-control-strings (1.1.0-3) ...
        Removing node-enhanced-resolve (5.10.0-1) ...
        Removing node-memory-fs (0.5.0+~0.3.3-2) ...
        Removing node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
        Removing node-fetch (3.3.0+~cs11.4.11-2) ...
        Removing node-data-uri-to-buffer (4.0.0-3) ...
        Removing node-got (11.8.5+~cs58.13.36-3) ...
        Removing node-decompress-response (6.0.0-2) ...
        Removing node-define-property (2.0.2+really+2.0.2-3) ...
        Removing node-delegates (1.0.0-3) ...
        Removing node-depd (2.0.0-2) ...
        Removing node-diff (5.0.0~dfsg+~5.0.1-4) ...
        Removing node-doctrine (3.0.0-4) ...
        Removing node-tap-parser (11.0.2+~cs2.1.4-1) ...
        Removing node-ssri (9.0.1-2) ...
        Removing node-minipass (3.3.6+~cs9.4.19-1) ...
        Removing node-encoding (0.1.13-2) ...
        Removing node-get-stream (6.0.1-1) ...
        Removing node-pump (3.0.0-5) ...
        Removing node-end-of-stream (1.4.4+~1.4.1-1) ...
        Removing node-promise-retry (2.0.1-4) ...
        Removing node-err-code (2.0.3+dfsg-3) ...
        Removing node-errno (1.0.0-3) ...
        Removing node-es-module-lexer (1.1.0+dfsg-2) ...
        Removing node-stack-utils (2.0.6+~2.0.1-1) ...
        Removing node-eslint-scope (7.1.1+~3.7.4-1) ...
        Removing node-eslint-utils (3.0.0-3) ...
        Removing node-eslint-visitor-keys (3.3.0+~1.0.0-1) ...
        Removing node-esquery (1.4.2~ds-1) ...
        Removing node-esrecurse (4.3.0-2) ...
        Removing node-events (3.3.0+~3.0.0-3) ...
        Removing node-fancy-log (1.3.3+~cs1.3.1-2) ...
        Removing node-fast-deep-equal (3.1.3-3) ...
        Removing node-flatted (3.2.7~ds-1) ...
        Removing node-mixin-deep (2.0.1-3) ...
        Removing node-fs-write-stream-atomic (1.0.10-6) ...
        Removing node-rechoir (0.8.0+~0.6.1-2) ...
        Removing node-npm-bundled (2.0.1-2) ...
        Removing node-read-package-json (5.0.2+~2.0.0-1) ...
        Removing node-functional-red-black-tree (1.0.1+20181105-7) ...
        Removing node-union-value (2.0.1-4) ...
        Removing node-unset-value (2.0.1-1) ...
        Removing node-has-value (2.0.2-4) ...
        Removing node-get-value (1:3.0.1-4) ...
        Removing node-growl (1.10.5-4) ...
        Removing node-has-unicode (2.0.1-5) ...
        Removing node-has-values (2.0.1-4) ...
        Removing node-iconv-lite (0.6.3-3) ...
        Removing node-postcss-modules-values (4.0.0+~4.0.0-1) ...
        Removing node-icss-utils (5.1.0+~5.1.0-1) ...
        Removing node-ieee754 (1.2.1-3) ...
        Removing node-iferr (1.0.2+~1.0.2-1) ...
        Removing node-ini (3.0.1-2) ...
        Removing node-interpret (2.2.0-3) ...
        Removing node-ip (2.0.0+~1.1.0-1) ...
        Removing node-ip-regex (4.3.0+~4.1.1-1) ...
        Removing node-is-descriptor (3.0.0-2) ...
        Removing node-set-value (4.1.0+~4.0.1-2) ...
        Removing node-is-primitive (3.0.1-3) ...
        Removing node-postcss-modules-extract-imports (3.0.0-2) ...
        Removing node-postcss (8.4.20+~cs8.0.23-1) ...
        Removing node-map-visit (1.0.0-4) ...
        Removing node-object-visit (1.0.1-5) ...
        Removing node-isobject (4.0.0-2) ...
        Removing node-json-buffer (3.0.1+~3.0.0-1) ...
        Removing node-json-schema (0.4.0+~7.0.11-1) ...
        Removing node-json-schema-traverse (1.0.0-3) ...
        Removing node-json-stable-stringify (1.0.2+~cs5.2.34-1) ...
        Removing node-shell-quote (1.7.4+~1.7.1-1) ...
        Removing node-jsonify (0.0.1-1) ...
        Removing node-jsonparse (1.3.1-10) ...
        Removing node-lcov-parse (1.0.0+20170612git80d039574ed9-6) ...
        Removing node-loader-runner (4.3.0-1) ...
        Removing node-log-driver (1.2.7+git+20180219+bba1761737-7) ...
        Removing node-lowercase-keys (2.0.0-2) ...
        Removing node-memfs (3.4.12+~cs1.0.3-1) ...
        Removing node-merge-stream (2.0.0+~1.1.2-2) ...
        Removing node-mime-types (2.1.35-1) ...
        Removing node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
        Removing node-mimic-response (3.1.0-8) ...
        Removing node-promzard (0.3.0-2) ...
        Removing node-read (1.0.7-5) ...
        Removing node-mute-stream (0.0.8+~0.0.1-3) ...
        Removing node-negotiator (0.6.3+~0.6.1-1) ...
        Removing node-restore-cursor (4.0.0-2) ...
        Removing node-opener (1.5.2+~1.4.0-1) ...
        Removing node-osenv (0.1.5+~0.1.1-1) ...
        Removing node-p-cancelable (2.1.1-1) ...
        Removing node-pascalcase (1.0.0-1) ...
        Removing node-path-is-absolute (2.0.0-2) ...
        Removing node-postcss-value-parser (4.2.0-1) ...
        Removing node-progress (2.0.3-2) ...
        Removing node-promise-inflight (1.0.1+~1.0.0-1) ...
        Removing node-prr (1.0.1-3) ...
        Removing node-uri-js (4.4.0+dfsg-8) ...
        Removing node-punycode (2.1.1-6) ...
        Removing node-serialize-javascript (6.0.0-2) ...
        Removing node-randombytes (2.1.0+~2.0.0-2) ...
        Removing node-regexpp (3.2.0-4) ...
        Removing node-resolve-cwd (3.0.0-2) ...
        Removing node-retry (0.13.1+~0.12.1-1) ...
        Removing node-sellside-emitter (1.2.1-3) ...
        Removing node-set-blocking (2.0.0-2) ...
        Removing node-set-immediate-shim (2.0.0-2) ...
        Removing node-webpack-sources (3.2.3+~3.2.0-2) ...
        Removing node-source-list-map (2.0.1+dfsg-2) ...
        Removing node-strip-json-comments (4.0.0-4) ...
        Removing node-tapable (2.2.1-2) ...
        Removing node-text-table (0.2.0-4) ...
        Removing node-time-stamp (2.2.0-2) ...
        Removing node-tslib (2.4.1-1) ...
        Removing node-typedarray (0.0.7-1) ...
        Removing node-v8-compile-cache (2.3.0-3) ...
        Removing node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
        Removing node-yaml (2.1.3-2) ...
        Removing node-define-properties (1.1.4+~1.1.3-1) ...
        Removing node-es-abstract (1.20.4+~cs26.27.47-1) ...
        Removing node-deep-equal (2.1.0+~cs31.12.80-1) ...
        Removing node-tape (5.6.1+~cs8.20.19-1) ...
        Removing node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
        Removing node-read-pkg (5.2.0-2) ...
        Removing handlebars (3:4.7.7+~4.1.0-1) ...
        Removing node-nopt (5.0.0-4) ...
        Removing node-abbrev (1.1.1+~1.1.2-1) ...
        Removing node-yargs (16.2.0+~16.0.4-7) ...
        Removing node-cliui (7.0.4+repack+~cs3.1.0-4) ...
        Removing node-wrap-ansi (8.0.1+~8.0.1-3) ...
        Removing node-string-width (4.2.3+~cs13.2.3-1) ...
        Removing node-slice-ansi (5.0.0+~cs9.0.0-5) ...
        Removing node-archy (1.0.0-6) ...
        Removing node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
        Removing node-argparse (2.0.1-2) ...
        Removing node-optimist (0.6.1+~0.0.30-2) ...
        Removing node-minimist (1.2.7+~cs5.3.2-2) ...
        Removing node-arrify (2.0.1-3) ...
        Removing node-async (0.8.0-6) ...
        Removing node-yargs-parser (21.1.1+~21.0.0-4) ...
        Removing node-camelcase (7.0.0-3) ...
        Removing node-wcwidth.js (1.0.2-2) ...
        Removing node-defaults (1.0.4+~1.0.3-1) ...
        Removing node-clone (2.1.2-4) ...
        Removing node-decamelize (4.0.0-2) ...
        Removing node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
        Removing node-optionator (0.9.1+dfsg+~cs1.2.3-1) ...
        Removing node-deep-is (0.1.4-1) ...
        Removing node-defined (1.0.1+~1.0.0-1) ...
        Removing node-es6-error (4.1.1-5) ...
        Removing node-esprima (4.0.1+ds+~4.0.3-2) ...
        Removing node-estraverse (5.3.0+ds+~5.1.1-1) ...
        Removing node-fast-levenshtein (2.0.6+ds-3) ...
        Removing node-foreground-child (2.0.0-5) ...
        Removing node-normalize-package-data (4.0.1+~2.4.1-1) ...
        Removing node-get-caller-file (2.0.5+~cs1.1.1-4) ...
        Removing node-hosted-git-info (6.1.1-2) ...
        Removing node-write-file-atomic (4.0.2+~4.0.0-1) ...
        Removing node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ...
        Removing node-is-plain-obj (3.0.0-2) ...
        Removing node-is-stream (3.0.0-4) ...
        Removing node-typedarray-to-buffer (4.0.0-2) ...
        Removing node-is-typedarray (1.0.0-4) ...
        Removing node-is-windows (1.0.2+~cs1.0.0-1) ...
        Removing node-which (2.0.2+~cs1.3.2-3) ...
        Removing node-isexe (2.0.0+~2.0.1-5) ...
        Removing node-levn (0.4.1+dfsg-2) ...
        Removing node-mkdirp (1.0.4+~1.0.2-4) ...
        Removing node-neo-async (2.6.2+~cs3.0.0-2) ...
        Removing node-npm-run-path (5.1.0+~4.0.0-8) ...
        Removing node-object-inspect (1.12.2+~cs1.8.1-1) ...
        Removing node-type-check (0.4.0+dfsg-3) ...
        Removing node-prelude-ls (1.2.1+dfsg-3) ...
        Removing node-require-directory (2.1.1+~2.1.2-1) ...
        Removing node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ...
        Removing node-resumer (0.0.0-6) ...
        Removing node-shebang-command (2.0.0-1) ...
        Removing node-shebang-regex (3.0.0-2) ...
        Removing node-signal-exit (3.0.7+~3.0.1-1) ...
        Removing node-validate-npm-package-license (3.0.4-2) ...
        Removing node-spdx-correct (3.1.1-2) ...
        Removing node-spdx-expression-parse (3.0.1+~3.0.1-1) ...
        Removing node-spdx-exceptions (2.3.0-2) ...
        Removing node-spdx-license-ids (3.0.12-1) ...
        Removing node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
        Removing node-strip-bom (4.0.0-2) ...
        Removing node-through (2.3.8+~cs0.0.30-1) ...
        Removing node-uuid (8.3.2+~8.3.3-3) ...
        Removing node-wordwrap (1.0.0-4) ...
        Removing node-y18n (5.0.8+~5.0.0-3) ...
        Removing node-parse-json (5.2.0+~cs5.1.7-1) ...
        Removing node-assert (2.0.0+~cs3.9.8-2) ...
        Removing node-util (0.12.5+~1.0.10-1) ...
        Removing libjs-util (0.12.5+~1.0.10-1) ...
        Removing node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
        Removing node-babel7 (7.20.15+ds1+~cs214.269.168-3) ...
        Removing node-find-cache-dir (3.3.2+~3.2.1-1) ...
        Removing node-del (7.0.0-5) ...
        Removing node-globby (13.1.3+~cs16.25.40-1) ...
        Removing node-micromatch (4.0.5+~4.0.2-1) ...
        Removing node-braces (3.0.2+~3.0.1-1) ...
        Removing node-fill-range (7.0.1+~7.0.0-1) ...
        Removing node-to-regex-range (5.0.1-4) ...
        Removing node-ampproject-remapping (2.2.0+~cs5.15.37-1) ...
        Removing node-strip-ansi (6.0.1-2) ...
        Removing node-ansi-regex (5.0.1-1) ...
        Removing node-chalk (5.2.0-1) ...
        Removing node-ansi-styles (6.2.1-2) ...
        Removing node-anymatch (3.1.3+~cs4.6.1-2) ...
        Removing node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ...
        Removing node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
        Removing node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ...
        Removing node-regenerator-transform (0.15.1+~0.10.8-1) ...
        Removing node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3) ...
        Removing node-rimraf (3.0.2-2) ...
        Removing node-glob (8.0.3+~cs8.4.15-1) ...
        Removing node-minimatch (5.1.1+~5.1.2-1) ...
        Removing node-brace-expansion (2.0.1-2) ...
        Removing node-balanced-match (2.0.0-1) ...
        Removing node-core-js-compat (3.26.1-3) ...
        Removing node-browserslist (4.21.4+~cs6.1.17-2) ...
        Removing node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ...
        Removing node-clone-deep (4.0.1+~cs7.0.2-1) ...
        Removing node-color-convert (2.0.1+~cs2.0.0-2) ...
        Removing node-color-name (1.1.4+~1.1.1-2) ...
        Removing node-commander (9.4.1-1) ...
        Removing node-commondir (1.0.1+~1.0.0-1) ...
        Removing node-convert-source-map (1.9.0+~1.5.2-1) ...
        Removing node-core-js (3.26.1-3) ...
        Removing node-core-js-pure (3.26.1-3) ...
        Removing node-n3 (1.16.3+~1.2.3+~1.10.4-1) ...
        Removing node-readable-stream (3.6.0+~cs3.0.0-4) ...
        Removing node-core-util-is (1.0.3-1) ...
        Removing node-electron-to-chromium (1.4.284-1) ...
        Removing node-error-ex (1.3.2-4) ...
        Removing node-p-map (4.0.0+~3.1.0+~3.0.1-1) ...
        Removing node-escape-string-regexp (4.0.0-2) ...
        Removing node-esutils (2.0.3+~2.0.0-1) ...
        Removing node-pkg-dir (5.0.0-2) ...
        Removing node-find-up (6.3.0-7) ...
        Removing node-for-own (1.0.0-3) ...
        Removing node-for-in (1.0.2-4) ...
        Removing node-fs-readdir-recursive (1.1.0+~1.1.0-1) ...
        Removing node-fs.realpath (1.0.0-3) ...
        Removing node-glob-parent (6.0.2+~5.1.1-2) ...
        Removing node-globals (13.18.0-1) ...
        Removing node-graceful-fs (4.2.10-1) ...
        Removing node-supports-color (8.1.1+~8.1.1-1) ...
        Removing node-has-flag (4.0.0-3) ...
        Removing node-ignore (5.2.1-1) ...
        Removing node-indent-string (4.0.0-2) ...
        Removing node-inflight (1.0.6-2) ...
        Removing node-inherits (2.0.4-6) ...
        Removing node-is-arrayish (0.3.2-3) ...
        Removing node-is-number (7.0.0-4) ...
        Removing node-kind-of (6.0.3+dfsg-2) ...
        Removing node-is-buffer (2.0.5-2) ...
        Removing node-is-extendable (1.0.1-3) ...
        Removing node-is-glob (4.0.3-2) ...
        Removing node-is-extglob (2.1.1-5) ...
        Removing node-is-path-cwd (2.2.0-2) ...
        Removing node-is-path-inside (3.0.3-2) ...
        Removing node-is-plain-object (5.0.0-7) ...
        Removing node-isarray (2.0.5-4) ...
        Removing node-js-tokens (8.0.0-2) ...
        Removing node-regexpu-core (5.2.2-3) ...
        Removing node-regjsparser (0.9.1+ds-2) ...
        Removing node-jsesc (3.0.2+~3.0.1-1) ...
        Removing node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ...
        Removing node-json5 (2.2.3+dfsg-1) ...
        Removing node-locate-path (7.1.1-2) ...
        Removing node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
        Removing node-make-dir (3.1.0-3) ...
        Removing node-normalize-path (3.0.0+~3.0.0-1) ...
        Removing node-object-assign (4.1.1-7) ...
        Removing node-once (1.4.0-7) ...
        Removing node-p-locate (6.0.0-12) ...
        Removing node-p-limit (4.0.0+~cs4.0.0-5) ...
        Removing node-path-dirname (1.0.2-2) ...
        Removing node-path-exists (5.0.0-8) ...
        Removing node-path-is-inside (1.0.2+~1.0.0-1) ...
        Removing node-path-type (4.0.0-3) ...
        Removing node-picocolors (1.0.0-4) ...
        Removing node-pify (5.0.0+~cs5.0.1-1) ...
        Removing node-process-nextick-args (2.0.1-3) ...
        Removing node-quick-lru (6.1.1-4) ...
        Removing node-regenerate-unicode-properties (10.1.0+ds-1) ...
        Removing node-regenerate (1.4.2-3) ...
        Removing node-regenerator-runtime (0.15.1+~0.10.8-1) ...
        Removing node-regjsgen (0.7.1+ds-1) ...
        Removing node-repeat-string (1.6.1+repack-1) ...
        Removing node-string-decoder (1.3.0-6) ...
        Removing node-safe-buffer (5.2.1+~cs2.1.2-3) ...
        Removing node-slash (4.0.0-3) ...
        Removing node-source-map-support (0.5.21+ds+~0.5.4-1) ...
        Removing node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
        Removing node-to-fast-properties (3.0.1-3) ...
        Removing node-unicode-match-property-ecmascript (2.0.0-2) ...
        Removing node-unicode-canonical-property-names-ecmascript (2.0.0-2) ...
        Removing node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ...
        Removing node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ...
        Removing node-util-deprecate (1.0.2-3) ...
        Removing node-v8flags (3.2.0+~3.1.1-1) ...
        Removing node-wrappy (1.0.2-3) ...
        Removing node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
        Removing node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1) ...
        Removing node-debug (4.3.4+~cs4.1.7-1) ...
        Removing node-resolve (1.22.1+~cs5.31.10-1) ...
        Removing node-function-bind (1.1.1+repacked+~1.0.3-2) ...
        Removing node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
        Removing node-semver (7.3.5+~7.3.9-2) ...
        Removing node-lru-cache (7.14.1-1) ...
        Removing node-ms (2.1.3+~cs0.7.31-3) ...
        Removing node-yallist (4.0.0+~4.0.1-1) ...
        Removing nodejs (18.13.0+dfsg1-1+rpi1) ...
        Removing libnode108:armhf (18.13.0+dfsg1-1+rpi1) ...
        Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
        Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ...
        Removing node-busboy (1.6.0+~cs2.6.0-2) ...
        Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
        Removing node-xtend (4.0.2-3) ...
        Processing triggers for man-db (2.11.2-2) ...
        Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
        (Reading database ... 138896 files and directories currently installed.)
        Purging configuration files for npm (9.2.0~ds1-1) ...
        Purging configuration files for node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
        Purging configuration files for node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
        Purging configuration files for node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
        Purging configuration files for node-esprima (4.0.1+ds+~4.0.3-2) ...
        *** These repos are active on your system:
        Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
        Reading package lists... Done
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
        W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Installing the recommended nodejs version now!
        Installing the recommended nodejs version!
        Removing nodejs-doc (18.13.0+dfsg1-1+rpi1) ...
        Selecting previously unselected package nodejs.
        (Reading database ... 138692 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ...
        Unpacking nodejs (18.18.2-1nodesource1) ...
        Preparing to unpack .../archives/piwiz_0.65_armhf.deb ...
        Unpacking piwiz (0.65) over (0.64) ...
        Setting up nodejs (18.18.2-1nodesource1) ...
        Setting up piwiz (0.65) ...
        We tried our best to fix your nodejs. Please run iob diag again to verify.
        *** RESTARTING ioBroker NOW! ***
         Please refresh or restart your browser in a few moments.
        Sieht soweit doch gut aus, oder? 😊
        admin@raspberrypi:~ $ nodejs -v
        v18.18.2
        admin@raspberrypi:~ $ node -v
        v18.18.2
        admin@raspberrypi:~ $ npm -v
        9.8.1
          @mcbeath
          Ja, schaut besser aus. Bitte nochmal
          sudo apt update
            sudo apt update
            admin@raspberrypi:~ $ sudo apt update
            OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease
            OK:2 http://archive.raspberrypi.com/debian bookworm InRelease
            OK:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
            Fehl:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
            Abhängigkeitsbaum wird aufgebaut... Fertig
            Statusinformationen werden eingelesen... Fertig
            Alle Pakete sind aktuell.
            W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
            W: Fehlschlag beim Holen von http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
            W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
              @mcbeath sagte in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
              sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
              sudo apt update
                admin@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                Executing: /tmp/apt-key-gpghome.4buJsFmM0I/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
                gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert
                gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
                gpg:                              importiert: 1
                OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
                W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                  @mcbeath
                  sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                    admin@raspberrypi:~ $ sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                    hab der sache schon mal vorgefriffen 😉
                      @mcbeath Dann schau dir jetzt nochmal 'das große Ganze' an per
                      iob diag
                      an.
                      Und dann schau mal was enocean nun sagt. Falls der immer noch herumspinnen sollte mach am besten nochmal einen eigenen Thread dazu auf.
                        Copy text starting here:
                        			v.2023-10-10
                         Static hostname: raspberrypi
                               Icon name: computer
                        Operating System: Raspbian GNU/Linux 12 (bookworm)
                                  Kernel: Linux 6.1.0-rpi4-rpi-v8
                            Architecture: arm64
                        Installation: 		native
                        Kernel: 		aarch64
                        Userland: 		armhf
                        Timezone: 		Europe/Berlin (CET, +0100)
                        User-ID: 		1000
                        X-Server: 		false
                        Boot Target: 		graphical.target
                        Pending OS-Updates: 	0
                        Pending iob updates: 	0
                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                        			/usr/bin/node 		v18.18.2
                        			/usr/bin/npm 		9.8.1
                        			/usr/bin/npx 		9.8.1
                        			/usr/bin/corepack 	0.19.0
                        Recommended versions are nodejs 18.18.2 and npm 9.8.1
                        MEMORY:
                        Mem:            4.0G        1.4G        1.3G        259M        1.6G        2.6G
                        Swap:           104M          0B        104M
                        Total:          4.1G        1.4G        1.4G
                        Active iob-Instances: 	5
                        Active repo(s): stable
                        ioBroker Core: 		js-controller 		5.0.14
                        			admin 			6.12.0
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects: 		463
                        States: 		323
                        Size of iob-Database:
                        8.7M	/opt/iobroker/iobroker-data/objects.jsonl
                        1.3M	/opt/iobroker/iobroker-data/states.jsonl
                        === Mark text until here for copying ===
                        Für mich sieht das jetzt prima aus 🙂
                          @mcbeath
                          Das ist zwar nur das 'kleine Ganze', bis auf Marginalien schaut das aber jetzt befahrbar aus.
                            McBeath @Thomas Braun last edited by McBeath
                            Danke schon mal für deine Mühen an dieser stelle.
                            Leider werden wir wohl noch einen neuen Thread öffnen müssen,
                            es ist leider noch immer nicht möglich neue Geräte hinzuzufügen 😞
                            Hier geht es weiter
                            1534
