Enocean 0.9.0 Geräte hinzufügen geht nicht mehr
@thomas-braun said in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
sudo apt-key add raspberrypi.gpg.key
admin@raspberrypi:~ $ sudo apt-key add raspberrypi.gpg.key Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)). OK admin@raspberrypi:~ $
curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
admin@raspberrypi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 16575 100 16575 0 0 43892 0 --:--:-- --:--:-- --:--:-- 43965 admin@raspberrypi:~ $
chmod 744 iob_node_update
admin@raspberrypi:~ $ chmod 744 iob_node_update admin@raspberrypi:~ $
./iob_node_update
ioBroker nodejs fixer 2023-10-24 Recommended nodejs-version is: 18.18.2 Checking your installation now. Please be patient! Your current setup is: /usr/bin/nodejs v18.13.0 /usr/bin/node v18.13.0 /usr/bin/npm 9.2.0 /usr/bin/npx 9.2.0 We found these nodejs versions available for installation: nodejs: Installed: 18.13.0+dfsg1-1+rpi1 Candidate: 18.18.2-1nodesource1 Version table: 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages *** 18.13.0+dfsg1-1+rpi1 500 500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages 100 /var/lib/dpkg/status 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages Nothing to do - Your installation is using the correct paths. You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2? Press <y> to continue or any other key to quit Trying to fix your installation now. Please be patient. find: '/run/user/1000/doc': Permission denied find: '/run/user/1000/gvfs': Permission denied Waiting for ioBroker to shut down - Give me a minute... ############################################################ *** Removing previous installations of nodejs (Reading database ... 167629 files and directories currently installed.) Removing npm (9.2.0~ds1-1) ... Removing node-css-loader (6.7.2+~cs14.0.11-1) ... Removing webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ... Removing eslint (6.4.0~dfsg+~6.1.9-7) ... Removing node-tap (16.3.2+ds1+~cs50.8.16-1) ... Removing node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ... Removing node-gyp (9.3.0-2) ... Removing libnode-dev (18.13.0+dfsg1-1+rpi1) ... Removing node-cacache (17.0.3+~cs10.3.7-1) ... Removing node-unique-filename (1.1.1+ds-2) ... Removing terser (5.16.5-2) ... Removing node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ... Removing node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ... Removing node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ... Removing node-ws (8.11.0+~cs13.7.3-1) ... Removing node-espree (9.4.1~dfsg-1) ... Removing node-https-proxy-agent (5.0.1+~cs8.0.0-3) ... Removing node-agent-base (6.0.2+~cs5.4.2-2) ... Removing node-schema-utils (3.1.1~ds-2) ... Removing node-ajv-keywords (3.5.2-2) ... Removing node-ajv (6.12.6-3) ... Removing node-terser (5.16.5-2) ... Removing node-ansi-escapes (5.0.0+really.4.3.1-1) ... Removing node-tap-mocha-reporter (5.0.3+~2.0.2-2) ... Removing node-npmlog (7.0.1+~4.1.4-1) ... Removing node-gauge (4.0.4-1) ... Removing node-widest-line (3.1.0-2) ... Removing node-wide-align (1.1.3-4) ... Removing node-cli-truncate (2.1.0-5) ... Removing node-watchpack (2.4.0+~cs2.8.1-1) ... Removing node-chokidar (3.5.3-2) ... Removing node-readdirp (3.6.0-1) ... Removing node-move-concurrently (1.0.1-5) ... Removing node-copy-concurrently (1.0.5-9) ... Removing node-run-queue (2.0.0-3) ... Removing node-aproba (2.0.0-3) ... Removing node-are-we-there-yet (3.0.1+~1.1.0-1) ... Removing node-coveralls (3.1.1-2) ... Removing node-async-each (1.0.3-3) ... Removing node-auto-bind (4.0.0-2) ... Removing node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ... Removing node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ... Removing node-base (3.0.0-3) ... Removing node-base64-js (1.5.1+dfsg+~1.3.0-2) ... Removing node-is-binary-path (2.1.0-5) ... Removing node-binary-extensions (2.2.0-2) ... Removing node-npm-package-arg (10.0.0+~3.0.0-2) ... Removing node-validate-npm-package-name (5.0.0+~4.0.0-1) ... Removing node-builtins (5.0.1-1) ... Removing node-cache-base (4.0.2-1) ... Removing node-tar (6.1.13+~cs7.0.5-1) ... Removing node-chownr (2.0.0-2) ... Removing node-chrome-trace-event (1.0.3-2) ... Removing node-ci-info (3.6.1+~cs1.1.0-1) ... Removing node-cli-boxes (2.2.1-2) ... Removing node-cli-cursor (4.0.0-3) ... Removing node-cli-table (0.3.11+~cs0.13.4-3) ... Removing node-columnify (1.6.0+~1.5.1-1) ... Removing node-collection-visit (1.0.0-4) ... Removing node-colors (1.4.0-4) ... Removing node-concat-stream (2.0.0+~2.0.0-2) ... Removing node-console-control-strings (1.1.0-3) ... Removing node-enhanced-resolve (5.10.0-1) ... Removing node-memory-fs (0.5.0+~0.3.3-2) ... Removing node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ... Removing node-fetch (3.3.0+~cs11.4.11-2) ... Removing node-data-uri-to-buffer (4.0.0-3) ... Removing node-got (11.8.5+~cs58.13.36-3) ... Removing node-decompress-response (6.0.0-2) ... Removing node-define-property (2.0.2+really+2.0.2-3) ... Removing node-delegates (1.0.0-3) ... Removing node-depd (2.0.0-2) ... Removing node-diff (5.0.0~dfsg+~5.0.1-4) ... Removing node-doctrine (3.0.0-4) ... Removing node-tap-parser (11.0.2+~cs2.1.4-1) ... Removing node-ssri (9.0.1-2) ... Removing node-minipass (3.3.6+~cs9.4.19-1) ... Removing node-encoding (0.1.13-2) ... Removing node-get-stream (6.0.1-1) ... Removing node-pump (3.0.0-5) ... Removing node-end-of-stream (1.4.4+~1.4.1-1) ... Removing node-promise-retry (2.0.1-4) ... Removing node-err-code (2.0.3+dfsg-3) ... Removing node-errno (1.0.0-3) ... Removing node-es-module-lexer (1.1.0+dfsg-2) ... Removing node-stack-utils (2.0.6+~2.0.1-1) ... Removing node-eslint-scope (7.1.1+~3.7.4-1) ... Removing node-eslint-utils (3.0.0-3) ... Removing node-eslint-visitor-keys (3.3.0+~1.0.0-1) ... Removing node-esquery (1.4.2~ds-1) ... Removing node-esrecurse (4.3.0-2) ... Removing node-events (3.3.0+~3.0.0-3) ... Removing node-fancy-log (1.3.3+~cs1.3.1-2) ... Removing node-fast-deep-equal (3.1.3-3) ... Removing node-flatted (3.2.7~ds-1) ... Removing node-mixin-deep (2.0.1-3) ... Removing node-fs-write-stream-atomic (1.0.10-6) ... Removing node-rechoir (0.8.0+~0.6.1-2) ... Removing node-npm-bundled (2.0.1-2) ... Removing node-read-package-json (5.0.2+~2.0.0-1) ... Removing node-functional-red-black-tree (1.0.1+20181105-7) ... Removing node-union-value (2.0.1-4) ... Removing node-unset-value (2.0.1-1) ... Removing node-has-value (2.0.2-4) ... Removing node-get-value (1:3.0.1-4) ... Removing node-growl (1.10.5-4) ... Removing node-has-unicode (2.0.1-5) ... Removing node-has-values (2.0.1-4) ... Removing node-iconv-lite (0.6.3-3) ... Removing node-postcss-modules-values (4.0.0+~4.0.0-1) ... Removing node-icss-utils (5.1.0+~5.1.0-1) ... Removing node-ieee754 (1.2.1-3) ... Removing node-iferr (1.0.2+~1.0.2-1) ... Removing node-ini (3.0.1-2) ... Removing node-interpret (2.2.0-3) ... Removing node-ip (2.0.0+~1.1.0-1) ... Removing node-ip-regex (4.3.0+~4.1.1-1) ... Removing node-is-descriptor (3.0.0-2) ... Removing node-set-value (4.1.0+~4.0.1-2) ... Removing node-is-primitive (3.0.1-3) ... Removing node-postcss-modules-extract-imports (3.0.0-2) ... Removing node-postcss (8.4.20+~cs8.0.23-1) ... Removing node-map-visit (1.0.0-4) ... Removing node-object-visit (1.0.1-5) ... Removing node-isobject (4.0.0-2) ... Removing node-json-buffer (3.0.1+~3.0.0-1) ... Removing node-json-schema (0.4.0+~7.0.11-1) ... Removing node-json-schema-traverse (1.0.0-3) ... Removing node-json-stable-stringify (1.0.2+~cs5.2.34-1) ... Removing node-shell-quote (1.7.4+~1.7.1-1) ... Removing node-jsonify (0.0.1-1) ... Removing node-jsonparse (1.3.1-10) ... Removing node-lcov-parse (1.0.0+20170612git80d039574ed9-6) ... Removing node-loader-runner (4.3.0-1) ... Removing node-log-driver (1.2.7+git+20180219+bba1761737-7) ... Removing node-lowercase-keys (2.0.0-2) ... Removing node-memfs (3.4.12+~cs1.0.3-1) ... Removing node-merge-stream (2.0.0+~1.1.2-2) ... Removing node-mime-types (2.1.35-1) ... Removing node-mime (3.0.0+dfsg+~cs3.97.1-1) ... Removing node-mimic-response (3.1.0-8) ... Removing node-promzard (0.3.0-2) ... Removing node-read (1.0.7-5) ... Removing node-mute-stream (0.0.8+~0.0.1-3) ... Removing node-negotiator (0.6.3+~0.6.1-1) ... Removing node-restore-cursor (4.0.0-2) ... Removing node-opener (1.5.2+~1.4.0-1) ... Removing node-osenv (0.1.5+~0.1.1-1) ... Removing node-p-cancelable (2.1.1-1) ... Removing node-pascalcase (1.0.0-1) ... Removing node-path-is-absolute (2.0.0-2) ... Removing node-postcss-value-parser (4.2.0-1) ... Removing node-progress (2.0.3-2) ... Removing node-promise-inflight (1.0.1+~1.0.0-1) ... Removing node-prr (1.0.1-3) ... Removing node-uri-js (4.4.0+dfsg-8) ... Removing node-punycode (2.1.1-6) ... Removing node-serialize-javascript (6.0.0-2) ... Removing node-randombytes (2.1.0+~2.0.0-2) ... Removing node-regexpp (3.2.0-4) ... Removing node-resolve-cwd (3.0.0-2) ... Removing node-retry (0.13.1+~0.12.1-1) ... Removing node-sellside-emitter (1.2.1-3) ... Removing node-set-blocking (2.0.0-2) ... Removing node-set-immediate-shim (2.0.0-2) ... Removing node-webpack-sources (3.2.3+~3.2.0-2) ... Removing node-source-list-map (2.0.1+dfsg-2) ... Removing node-strip-json-comments (4.0.0-4) ... Removing node-tapable (2.2.1-2) ... Removing node-text-table (0.2.0-4) ... Removing node-time-stamp (2.2.0-2) ... Removing node-tslib (2.4.1-1) ... Removing node-typedarray (0.0.7-1) ... Removing node-v8-compile-cache (2.3.0-3) ... Removing node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ... Removing node-yaml (2.1.3-2) ... Removing node-define-properties (1.1.4+~1.1.3-1) ... Removing node-es-abstract (1.20.4+~cs26.27.47-1) ... Removing node-deep-equal (2.1.0+~cs31.12.80-1) ... Removing node-tape (5.6.1+~cs8.20.19-1) ... Removing node-istanbul (0.4.5+repack10+~cs97.25.57-3) ... Removing node-read-pkg (5.2.0-2) ... Removing handlebars (3:4.7.7+~4.1.0-1) ... Removing node-nopt (5.0.0-4) ... Removing node-abbrev (1.1.1+~1.1.2-1) ... Removing node-yargs (16.2.0+~16.0.4-7) ... Removing node-cliui (7.0.4+repack+~cs3.1.0-4) ... Removing node-wrap-ansi (8.0.1+~8.0.1-3) ... Removing node-string-width (4.2.3+~cs13.2.3-1) ... Removing node-slice-ansi (5.0.0+~cs9.0.0-5) ... Removing node-archy (1.0.0-6) ... Removing node-js-yaml (4.1.0+dfsg+~4.0.5-7) ... Removing node-argparse (2.0.1-2) ... Removing node-optimist (0.6.1+~0.0.30-2) ... Removing node-minimist (1.2.7+~cs5.3.2-2) ... Removing node-arrify (2.0.1-3) ... Removing node-async (0.8.0-6) ... Removing node-yargs-parser (21.1.1+~21.0.0-4) ... Removing node-camelcase (7.0.0-3) ... Removing node-wcwidth.js (1.0.2-2) ... Removing node-defaults (1.0.4+~1.0.3-1) ... Removing node-clone (2.1.2-4) ... Removing node-decamelize (4.0.0-2) ... Removing node-escodegen (2.0.0+dfsg+~0.0.7-2) ... Removing node-optionator (0.9.1+dfsg+~cs1.2.3-1) ... Removing node-deep-is (0.1.4-1) ... Removing node-defined (1.0.1+~1.0.0-1) ... Removing node-es6-error (4.1.1-5) ... Removing node-esprima (4.0.1+ds+~4.0.3-2) ... Removing node-estraverse (5.3.0+ds+~5.1.1-1) ... Removing node-fast-levenshtein (2.0.6+ds-3) ... Removing node-foreground-child (2.0.0-5) ... Removing node-normalize-package-data (4.0.1+~2.4.1-1) ... Removing node-get-caller-file (2.0.5+~cs1.1.1-4) ... Removing node-hosted-git-info (6.1.1-2) ... Removing node-write-file-atomic (4.0.2+~4.0.0-1) ... Removing node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ... Removing node-is-plain-obj (3.0.0-2) ... Removing node-is-stream (3.0.0-4) ... Removing node-typedarray-to-buffer (4.0.0-2) ... Removing node-is-typedarray (1.0.0-4) ... Removing node-is-windows (1.0.2+~cs1.0.0-1) ... Removing node-which (2.0.2+~cs1.3.2-3) ... Removing node-isexe (2.0.0+~2.0.1-5) ... Removing node-levn (0.4.1+dfsg-2) ... Removing node-mkdirp (1.0.4+~1.0.2-4) ... Removing node-neo-async (2.6.2+~cs3.0.0-2) ... Removing node-npm-run-path (5.1.0+~4.0.0-8) ... Removing node-object-inspect (1.12.2+~cs1.8.1-1) ... Removing node-type-check (0.4.0+dfsg-3) ... Removing node-prelude-ls (1.2.1+dfsg-3) ... Removing node-require-directory (2.1.1+~2.1.2-1) ... Removing node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ... Removing node-resumer (0.0.0-6) ... Removing node-shebang-command (2.0.0-1) ... Removing node-shebang-regex (3.0.0-2) ... Removing node-signal-exit (3.0.7+~3.0.1-1) ... Removing node-validate-npm-package-license (3.0.4-2) ... Removing node-spdx-correct (3.1.1-2) ... Removing node-spdx-expression-parse (3.0.1+~3.0.1-1) ... Removing node-spdx-exceptions (2.3.0-2) ... Removing node-spdx-license-ids (3.0.12-1) ... Removing node-sprintf-js (1.1.2+ds1+~1.1.2-1) ... Removing node-strip-bom (4.0.0-2) ... Removing node-through (2.3.8+~cs0.0.30-1) ... Removing node-uuid (8.3.2+~8.3.3-3) ... Removing node-wordwrap (1.0.0-4) ... Removing node-y18n (5.0.8+~5.0.0-3) ... Removing node-parse-json (5.2.0+~cs5.1.7-1) ... Removing node-assert (2.0.0+~cs3.9.8-2) ... Removing node-util (0.12.5+~1.0.10-1) ... Removing libjs-util (0.12.5+~1.0.10-1) ... Removing node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ... Removing node-babel7 (7.20.15+ds1+~cs214.269.168-3) ... Removing node-find-cache-dir (3.3.2+~3.2.1-1) ... Removing node-del (7.0.0-5) ... Removing node-globby (13.1.3+~cs16.25.40-1) ... Removing node-micromatch (4.0.5+~4.0.2-1) ... Removing node-braces (3.0.2+~3.0.1-1) ... Removing node-fill-range (7.0.1+~7.0.0-1) ... Removing node-to-regex-range (5.0.1-4) ... Removing node-ampproject-remapping (2.2.0+~cs5.15.37-1) ... Removing node-strip-ansi (6.0.1-2) ... Removing node-ansi-regex (5.0.1-1) ... Removing node-chalk (5.2.0-1) ... Removing node-ansi-styles (6.2.1-2) ... Removing node-anymatch (3.1.3+~cs4.6.1-2) ... Removing node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ... Removing node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ... Removing node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ... Removing node-regenerator-transform (0.15.1+~0.10.8-1) ... Removing node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3) ... Removing node-rimraf (3.0.2-2) ... Removing node-glob (8.0.3+~cs8.4.15-1) ... Removing node-minimatch (5.1.1+~5.1.2-1) ... Removing node-brace-expansion (2.0.1-2) ... Removing node-balanced-match (2.0.0-1) ... Removing node-core-js-compat (3.26.1-3) ... Removing node-browserslist (4.21.4+~cs6.1.17-2) ... Removing node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ... Removing node-clone-deep (4.0.1+~cs7.0.2-1) ... Removing node-color-convert (2.0.1+~cs2.0.0-2) ... Removing node-color-name (1.1.4+~1.1.1-2) ... Removing node-commander (9.4.1-1) ... Removing node-commondir (1.0.1+~1.0.0-1) ... Removing node-convert-source-map (1.9.0+~1.5.2-1) ... Removing node-core-js (3.26.1-3) ... Removing node-core-js-pure (3.26.1-3) ... Removing node-n3 (1.16.3+~1.2.3+~1.10.4-1) ... Removing node-readable-stream (3.6.0+~cs3.0.0-4) ... Removing node-core-util-is (1.0.3-1) ... Removing node-electron-to-chromium (1.4.284-1) ... Removing node-error-ex (1.3.2-4) ... Removing node-p-map (4.0.0+~3.1.0+~3.0.1-1) ... Removing node-escape-string-regexp (4.0.0-2) ... Removing node-esutils (2.0.3+~2.0.0-1) ... Removing node-pkg-dir (5.0.0-2) ... Removing node-find-up (6.3.0-7) ... Removing node-for-own (1.0.0-3) ... Removing node-for-in (1.0.2-4) ... Removing node-fs-readdir-recursive (1.1.0+~1.1.0-1) ... Removing node-fs.realpath (1.0.0-3) ... Removing node-glob-parent (6.0.2+~5.1.1-2) ... Removing node-globals (13.18.0-1) ... Removing node-graceful-fs (4.2.10-1) ... Removing node-supports-color (8.1.1+~8.1.1-1) ... Removing node-has-flag (4.0.0-3) ... Removing node-ignore (5.2.1-1) ... Removing node-indent-string (4.0.0-2) ... Removing node-inflight (1.0.6-2) ... Removing node-inherits (2.0.4-6) ... Removing node-is-arrayish (0.3.2-3) ... Removing node-is-number (7.0.0-4) ... Removing node-kind-of (6.0.3+dfsg-2) ... Removing node-is-buffer (2.0.5-2) ... Removing node-is-extendable (1.0.1-3) ... Removing node-is-glob (4.0.3-2) ... Removing node-is-extglob (2.1.1-5) ... Removing node-is-path-cwd (2.2.0-2) ... Removing node-is-path-inside (3.0.3-2) ... Removing node-is-plain-object (5.0.0-7) ... Removing node-isarray (2.0.5-4) ... Removing node-js-tokens (8.0.0-2) ... Removing node-regexpu-core (5.2.2-3) ... Removing node-regjsparser (0.9.1+ds-2) ... Removing node-jsesc (3.0.2+~3.0.1-1) ... Removing node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ... Removing node-json5 (2.2.3+dfsg-1) ... Removing node-locate-path (7.1.1-2) ... Removing node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ... Removing node-make-dir (3.1.0-3) ... Removing node-normalize-path (3.0.0+~3.0.0-1) ... Removing node-object-assign (4.1.1-7) ... Removing node-once (1.4.0-7) ... Removing node-p-locate (6.0.0-12) ... Removing node-p-limit (4.0.0+~cs4.0.0-5) ... Removing node-path-dirname (1.0.2-2) ... Removing node-path-exists (5.0.0-8) ... Removing node-path-is-inside (1.0.2+~1.0.0-1) ... Removing node-path-type (4.0.0-3) ... Removing node-picocolors (1.0.0-4) ... Removing node-pify (5.0.0+~cs5.0.1-1) ... Removing node-process-nextick-args (2.0.1-3) ... Removing node-quick-lru (6.1.1-4) ... Removing node-regenerate-unicode-properties (10.1.0+ds-1) ... Removing node-regenerate (1.4.2-3) ... Removing node-regenerator-runtime (0.15.1+~0.10.8-1) ... Removing node-regjsgen (0.7.1+ds-1) ... Removing node-repeat-string (1.6.1+repack-1) ... Removing node-string-decoder (1.3.0-6) ... Removing node-safe-buffer (5.2.1+~cs2.1.2-3) ... Removing node-slash (4.0.0-3) ... Removing node-source-map-support (0.5.21+ds+~0.5.4-1) ... Removing node-source-map (0.7.0++dfsg2+really.0.6.1-15) ... Removing node-to-fast-properties (3.0.1-3) ... Removing node-unicode-match-property-ecmascript (2.0.0-2) ... Removing node-unicode-canonical-property-names-ecmascript (2.0.0-2) ... Removing node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ... Removing node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ... Removing node-util-deprecate (1.0.2-3) ... Removing node-v8flags (3.2.0+~3.1.1-1) ... Removing node-wrappy (1.0.2-3) ... Removing node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ... Removing node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1) ... Removing node-debug (4.3.4+~cs4.1.7-1) ... Removing node-resolve (1.22.1+~cs5.31.10-1) ... Removing node-function-bind (1.1.1+repacked+~1.0.3-2) ... Removing node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ... Removing node-semver (7.3.5+~7.3.9-2) ... Removing node-lru-cache (7.14.1-1) ... Removing node-ms (2.1.3+~cs0.7.31-3) ... Removing node-yallist (4.0.0+~4.0.1-1) ... Removing nodejs (18.13.0+dfsg1-1+rpi1) ... Removing libnode108:armhf (18.13.0+dfsg1-1+rpi1) ... Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ... Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ... Removing node-busboy (1.6.0+~cs2.6.0-2) ... Removing node-cjs-module-lexer (1.2.2+dfsg-5) ... Removing node-xtend (4.0.2-3) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... (Reading database ... 138896 files and directories currently installed.) Purging configuration files for npm (9.2.0~ds1-1) ... Purging configuration files for node-mime (3.0.0+dfsg+~cs3.97.1-1) ... Purging configuration files for node-sprintf-js (1.1.2+ds1+~1.1.2-1) ... Purging configuration files for node-source-map (0.7.0++dfsg2+really.0.6.1-15) ... Purging configuration files for node-esprima (4.0.1+ds+~4.0.3-2) ... *** These repos are active on your system: Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Some index files failed to download. They have been ignored, or old ones used instead. *** Installing ca-certificates, curl and gnupg, just in case they are missing. *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main Package: nodejs Pin: origin deb.nodesource.com Pin-Priority: 1001 *** These repos are active after the adjustments: Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Some index files failed to download. They have been ignored, or old ones used instead. Installing the recommended nodejs version now! Installing the recommended nodejs version! W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E W: Some index files failed to download. They have been ignored, or old ones used instead. (Reading database ... 138896 files and directories currently installed.) Removing nodejs-doc (18.13.0+dfsg1-1+rpi1) ... Selecting previously unselected package nodejs. (Reading database ... 138692 files and directories currently installed.) Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ... Unpacking nodejs (18.18.2-1nodesource1) ... Preparing to unpack .../archives/piwiz_0.65_armhf.deb ... Unpacking piwiz (0.65) over (0.64) ... Setting up nodejs (18.18.2-1nodesource1) ... Setting up piwiz (0.65) ... Processing triggers for man-db (2.11.2-2) ... We tried our best to fix your nodejs. Please run iob diag again to verify. *** RESTARTING ioBroker NOW! *** Please refresh or restart your browser in a few moments. admin@raspberrypi:~ $
Sieht soweit doch gut aus, oder?
admin@raspberrypi:~ $ nodejs -v v18.18.2 admin@raspberrypi:~ $ node -v v18.18.2 admin@raspberrypi:~ $ npm -v 9.8.1 admin@raspberrypi:~ $
sudo apt update
admin@raspberrypi:~ $ sudo apt update OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease OK:2 http://archive.raspberrypi.com/debian bookworm InRelease OK:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease Fehl:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut... Fertig Statusinformationen werden eingelesen... Fertig Alle Pakete sind aktuell. W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E W: Fehlschlag beim Holen von http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt. admin@raspberrypi:~ $
@mcbeath sagte in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E sudo apt update
admin@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)). Executing: /tmp/apt-key-gpghome.4buJsFmM0I/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1 gpg: importiert: 1 admin@raspberrypi:~ $
admin@raspberrypi:~ $ sudo apt update OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease OK:3 http://archive.raspberrypi.com/debian bookworm InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut... Fertig Statusinformationen werden eingelesen... Fertig Alle Pakete sind aktuell. W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. admin@raspberrypi:~ $
sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
admin@raspberrypi:~ $ sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/ admin@raspberrypi:~ $
hab der sache schon mal vorgefriffen
admin@raspberrypi:~ $ sudo apt update OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease OK:3 http://archive.raspberrypi.com/debian bookworm InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut... Fertig Statusinformationen werden eingelesen... Fertig Alle Pakete sind aktuell. admin@raspberrypi:~ $
@mcbeath Dann schau dir jetzt nochmal 'das große Ganze' an per
iob diag
an.
Und dann schau mal was enocean nun sagt. Falls der immer noch herumspinnen sollte mach am besten nochmal einen eigenen Thread dazu auf. -
Copy text starting here: ======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi4-rpi-v8 Architecture: arm64 Installation: native Kernel: aarch64 Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 4.0G 1.4G 1.3G 259M 1.6G 2.6G Swap: 104M 0B 104M Total: 4.1G 1.4G 1.4G Active iob-Instances: 5 Active repo(s): stable ioBroker Core: js-controller 5.0.14 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 463 States: 323 Size of iob-Database: 8.7M /opt/iobroker/iobroker-data/objects.jsonl 1.3M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== === Mark text until here for copying === admin@raspberrypi:~ $
Für mich sieht das jetzt prima aus
@mcbeath
Das ist zwar nur das 'kleine Ganze', bis auf Marginalien schaut das aber jetzt befahrbar aus. -
Danke schon mal für deine Mühen an dieser stelle.Leider werden wir wohl noch einen neuen Thread öffnen müssen,
es ist leider noch immer nicht möglich neue Geräte hinzuzufügen
