    4. ioBroker stoppt und startet unbeabsichtigt
    • RaspiUser
      RaspiUser @Thomas Braun last edited by
      @thomas-braun sagte in ioBroker stoppt und startet unbeabsichtigt:
      Abwarten. Der fängt sich.
      ... tatsächlich ... hat zwar ca. 15min gedauert aber er läuft wieder.
      Kannst Du (ich sehe nix ...) den Grund des Absturz erkennen ?
      (Wieder zu wenig RAM ? ... aber das habe ich zwischenzeitlich verstanden ... 😰 )
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: ioBroker-Raspi
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       09:49:01 up 1 day, 33 min,  2 users,  load average: 1.00, 16.80, 24.11
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2023-11-02 09:49:01 CET
                 Universal time: Thu 2023-11-02 08:49:01 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.9G        1.4G        403M        1.1M        247M        583M
      Swap:           104M        6.2M         98M
      Total:          2.0G        1.4G        502M
               1849 M total memory
               1292 M used memory
               1345 M active memory
                  4 M inactive memory
                384 M free memory
                 25 M buffer memory
                211 M swap cache
                 99 M total swap
                  5 M used swap
                 94 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       15G  4.4G  9.4G  32% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      tmpfs          tmpfs     370M  1.2M  369M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Wed Nov  1 09:15:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:B4:C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bc66e88d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Nov  1 09:15:53 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Nov  1 09:15:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Nov  1 09:15:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      647M    /var/log
      582M    /var/log/journal/ececfd62e7f741458cc0d2ea60d43f93
      328M    /var/cache
      Archived and active journals take up 581.2M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      215M    /opt/iobroker/iobroker-data/
      153M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/backup-objects
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      7.8M    /opt/iobroker/iobroker-data/states.jsonl
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6edb8350b219ec11a0e039cc47486eb0-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.12.0
      javascript:     7.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker-Raspi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alpha-ess.0              : alpha-ess             : ioBroker-Raspi                           -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker-Raspi                           -  enabled
      + system.adapter.canbus.0                 : canbus                : ioBroker-Raspi                           -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker-Raspi                           - disabled
        system.adapter.feiertage.0              : feiertage             : ioBroker-Raspi                           -  enabled
      + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-Raspi                           -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Raspi                           -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
      + system.adapter.iqontrol.0               : iqontrol              : ioBroker-Raspi                           -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker-Raspi                           -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : ioBroker-Raspi                           -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Raspi                           -  enabled, port: 1883, bind: 192.168.178.36
        system.adapter.onkyo.0                  : onkyo                 : ioBroker-Raspi                           - disabled
      + system.adapter.psa.0                    : psa                   : ioBroker-Raspi                           -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Raspi                           -  enabled, port: 1030, bind: 192.168.178.36
      + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Raspi                           -  enabled
        system.adapter.simple-api.0             : simple-api            : ioBroker-Raspi                           - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : ioBroker-Raspi                           -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-Raspi                           -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker-Raspi                           -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBroker-Raspi                           -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Raspi                           -  enabled
      + system.adapter.web.0                    : web                   : ioBroker-Raspi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : ioBroker-Raspi                           -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alpha-ess"    : 1.0.2    , installed 1.0.2
      Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
      Adapter    "canbus"       : 1.3.1    , installed 1.3.1
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "frontier_silicon": 0.1.1 , installed 0.1.1
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "lgtv"         : 2.1.1    , installed 2.1.1
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "psa"          : 0.0.11   , installed 0.0.11
      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        5773
      States:         4364
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 55
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13851      543/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       428961     7507/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       430255     7507/iobroker.js-co
      tcp        0      0 192.168.178.36:1883     0.0.0.0:*               LISTEN      1001       430408     7700/io.mqtt.0
      tcp        0      0 192.168.178.36:1030     0.0.0.0:*               LISTEN      1001       432555     8067/io.sainlogic.0
      tcp        0      0 192.168.178.36:42010    0.0.0.0:*               LISTEN      1001       431490     7789/io.hm-rpc.1
      tcp        0      0 192.168.178.36:42001    0.0.0.0:*               LISTEN      1001       430426     7733/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       430764     7871/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13862      543/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       429711     7640/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       433227     8097/io.web.0
      udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      1587       708/cannelloni
      udp        0      0 0.0.0.0:49934           0.0.0.0:*                           108        11838      380/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14020      844/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11836      380/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14033      844/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11837      380/avahi-daemon: r
      udp6       0      0 :::39321                :::*                                108        11839      380/avahi-daemon: r
      2023-11-02 09:46:58.713  - info: iqontrol.0 (8112) Creating Widget States...
      2023-11-02 09:46:58.714  - info: iqontrol.0 (8112) Lists deactivated.
      2023-11-02 09:46:58.715  - info: iqontrol.0 (8112) Deleting unused Objects...
      2023-11-02 09:46:58.716  - info: iqontrol.0 (8112) Subscribing to states...
      2023-11-02 09:46:58.719  - info: iqontrol.0 (8112) iQontrol ready.
      2023-11-02 09:46:59.522  - info: host.ioBroker-Raspi instance system.adapter.vw-connect.0 started with pid 8127
      2023-11-02 09:47:02.502  - info: vw-connect.0 (8127) starting. Version 0.2.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.18.2, js-controller: 5.0.12
      2023-11-02 09:47:02.556  - info: vw-connect.0 (8127) Login in with vwv2
      2023-11-02 09:47:04.995  - info: vw-connect.0 (8127) Login successful
      2023-11-02 09:47:05.489  - info: vw-connect.0 (8127) {"mandatoryConsentInfo":[{"id":"termsOfUse","status":"VALID"}],"mandatoryFieldsStatus":true,"mbbIdStatus":true,"mbbUserId":"5qIgGpN2LkvdHc2H0TWDvtlwap51","missingMandatoryFields":[],"scopeId":"commonMandatoryFields","spinStatus":true,"ssoId":"de858a4a-f971-40f1-b375-baf01b331d2a"}
      2023-11-02 09:47:05.748  - info: vw-connect.0 (8127) Found 1 vehicles
      2023-11-02 09:47:41.431  - info: sonoff.0 (7871) Client [Steckdose-6-Kuehlkombi] connected with secret 1698914861421_288
      2023-11-02 09:47:46.989  - info: sonoff.0 (7871) Client [Steckdose-1-Trockner] connected with secret 1698914866986_6241
      2023-11-02 09:47:48.809  - info: sonoff.0 (7871) Client [Bodenlampen] connected with secret 1698914868808_4658
      2023-11-02 09:47:49.620  - warn: zigbee.0 (7823) Device '0x0017880102a2b974' announced itself
      2023-11-02 09:47:54.695  - info: sonoff.0 (7871) Client [Steckdose-2-Waschmaschine] connected with secret 1698914874694_3145
      2023-11-02 09:47:59.110  - info: sonoff.0 (7871) Client [Smartmeter] connected with secret 1698914879107_367
      2023-11-02 09:48:02.306  - info: sonoff.0 (7871) Client [Steckdose-4-OG-Medien] connected with secret 1698914882305_5112
      2023-11-02 09:48:03.405  - warn: zigbee.0 (7823) Device '0x7cb03eaa0a03fb8a' announced itself
      2023-11-02 09:48:03.407  - warn: zigbee.0 (7823) Device '0x7cb03eaa0a059b32' announced itself
      2023-11-02 09:48:06.841  - info: sonoff.0 (7871) Client [Steckdose-3-Geschirrspueler] connected with secret 1698914886840_7258
      2023-11-02 09:48:09.379  - info: sonoff.0 (7871) Client [Steckdose-5-EG-Medien] connected with secret 1698914889378_439
      2023-11-02 09:48:09.594  - info: sonoff.0 (7871) Client [Steckdose-9] connected with secret 1698914889592_1177
      2023-11-02 09:48:10.457  - info: sonoff.0 (7871) Client [Steckdose-7-Gefrierschrank] connected with secret 1698914890455_4919
      2023-11-02 09:48:10.481  - info: sonoff.0 (7871) Client [Steckdose-8] connected with secret 1698914890479_891
      iob diag has finished.
        Thomas Braun Most Active @RaspiUser last edited by
        @raspiuser
        Kein Wunder. Ab 4 ist die Kiste voll ausgelastet.
        Da knallt irgendwas heftig rein.
        Spiel die Updates ein!
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Und auch den ioBroker auf Stand halten.
        RaspiUser 1 Reply Last reply Reply Quote 0
        • RaspiUser
          ? ... meinst Du die Uhrzeit ?! 🙄 Was sagt diese "load average" ?
          irgendwas
          ... aber WAS sieht man scheinbar nicht ?
          ... ich mache alle 4 Wochen ...
          sudo apt-get update
          sudo apt-get upgrade
            @raspiuser sagte in ioBroker stoppt und startet unbeabsichtigt:
            Ein Wert von 1 wäre eine Auslastung von 100% (pro Kern). Da du auf der CPU vier Kerne hast ist ab 4 der Prozessor vollständig dicht.
            Die Werte sind der Durchschnitt über 1, 5 und 15 Minuten. Kann man aber auch alles nachlesen.
            Updates: Mach sie häufiger.
            RaspiUser 1 Reply Last reply Reply Quote 1
              Sieht man in Tools wie 'top' oder 'htop'.
              • RaspiUser
                Updates
                ... habe jetzt ein Update mit "deinen" Befehlen durchgeführt ... hat etwas gedauert, war wohl nötig ....
                Ich habe jetzt auch (zufällig "gefunden") in deinen "LINUX-Werkzeugkaste" reingeschaut ... sehr interessant !!!
                  Das sind nicht 'meine Befehle ', das sind absolute Grundlagen.
                  • RaspiUser
                    ... schon klar ... damit wollte ich nur zum Ausdruck bringen, dass ich "meine" Befehle nicht genutzt habe ...
                    • RaspiUser
                      Sorry ... ich nerve weiter ...:
                      Ich habe jetzt im Terminal "top" bzw. "htop" ausgeführt ...
                      Auf was muss ich achten bzw. WAS knallt da rein ?
                        @raspiuser
                        Die Prozesse werden da angezeigt.
                        • RaspiUser
                          ... aber wo muss ich bzgl. meinem Problem genauer hinschauen ... ? Welcher Wert ?
                          Tasks: 170 total,   1 running, 169 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  4.5 us,  0.7 sy,  0.0 ni, 94.4 id,  0.2 wa,  0.0 hi,  0.1 si,  0.0 st
                          MiB Mem :   1849.2 total,    169.9 free,   1346.7 used,    401.5 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.    502.5 avail Mem
                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                             2735 iobroker  20   0 5198148 162752  44132 S   7.0   8.6   1:12.02 iobroker.js-con
                             3053 iobroker  20   0  662620  72140  38296 S   3.3   3.8   0:05.25 io.sainlogic.0
                             2809 iobroker  20   0  671776  80036  37112 S   2.6   4.2   0:05.13 io.mqtt.0
                             2772 iobroker  20   0  998016 148360  37172 S   1.7   7.8   0:27.47 io.javascript.0
                             2790 iobroker  20   0  807240  93184  43108 S   1.3   4.9   0:08.92 io.telegram.0
                             3072 iobroker  20   0  924548  71424  37808 S   1.0   3.8   0:05.45 io.alpha-ess.0
                             2828 iobroker  20   0  666680  76528  38384 S   0.7   4.0   0:05.90 io.hm-rpc.0
                             2843 iobroker  20   0  670960  81628  37824 S   0.7   4.3   0:09.38 io.hm-rega.0
                             3042 iobroker  20   0  665712  81488  42348 S   0.7   4.3   0:06.26 io.shuttercontr
                             3117 iobroker  20   0 5128684  89056  39592 S   0.7   4.7   0:07.81 io.vw-connect.0
                            @raspiuser
                            %CPU oder %MEM sind erste Indikatoren. Man kann das auch danach sortieren. Jedenfalls bei htop.
                            • RaspiUser
                              %CPU oder %MEM
                              OK ... ich verdaue jetzt erstmal deine Anmerkungen.
                              Danke soweit.
                              1477
