    2. English
    3. Development
    4. New Adapter - Soliscloud
    • Trixx
      Trixx @Luapsi last edited by
      @luapsi
      Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
      From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
        Homoran Global Moderator Administrators @Luapsi last edited by
        @luapsi sagte in New Adapter - Soliscloud:
        No SolisCloud is displayed in the instances
        that is the regular behavior by installing via github.
        The instance has to be added manually
          Luapsi @Homoran last edited by
          Hello, I just found it in the documentation.
          Thank you very much:)
            Luapsi @Trixx last edited by
            @trixx sagte in New Adapter - Soliscloud:
            battery_current_usage
            hi @trixx,
            The SolisCloud adapter also works for me. Thank you for your implementation.
            As you requested, it would be great if these values ​​could be added:
            from the Power Station List:
            1. batteryTodayDischargeEnergy
            2. batteryTodayChargeEnergy
            3. homeLoadTodayEnergy
            4. state
            5. oneSelf
            from the Inverter List:
            1. eToday
            2. etodayStr
            3. state
            Gerne teste ich für Dich!
            Trixx 1 Reply Last reply Reply Quote 0
            • Trixx
              @luapsi said in New Adapter - Soliscloud:
              hi @trixx,
              4. state
              5. oneSelf
              1. eToday
              2. etodayStr
              3. state
              Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
              I'll let you know once I have an update on this.
              L 2 Replies Last reply Reply Quote 1
                @trixx
                hi @Trixx
                thank you for taking the suggestions!
                Here's a little addition!
                In ioBroker, instances are assigned a category!
                Would you be so kind as to put your instance in the “Energy” category?
                Here is an excerpt from instances in this category
                Thx Sven
                • Trixx
                  @luapsi
                  I've just pushed a new version to github, I think it should include all requested additions 🙂
                  Regards,
                  Trixx
                    @trixx
                    Your performance is great, thank you very much.
                    I will test extensively and give you feedback.
                    I wish you a pleasant day
                      Luapsi @Trixx last edited by Luapsi
                      Hi @trixx,
                      all data fields are correct.
                      Thanks for the quick and professional work.
                      from the v1/api/InverterDetail:
                      1. familyLoadPower
                      2. familyLoadPowerStr
                      3. id inverter id
                      4. sn inverter sn
                      5. iAc1 AC current R
                      6. iAc2 AC current S
                      7. iAc3 AC current T
                      8. uAc1 AC voltage R
                      9. uAc2 AC voltage S
                      10. uAc3 AC voltage T
                      11. inverterTemperature
                      12. batteryPower
                      13. batterypowerStr
                      14. batteryPowerPec
                      15. batteryTodayChargeEnergy
                      16. batteryTodayChargeEnergyStr
                      17. batteryMonthChargeEnergy
                      18. batteryMonthChargeEnergyStr
                      19. batteryYearChargeEnergy
                      20. batteryYearChargeEnergyStr
                      21. batteryTotalChargeEnergy
                      22. batteryTotalChargeEnergyStr
                      23. batteryTodayDischargeEnergy
                      24. batteryTodayDischargeEnergyStr
                      25. batteryMonthDischargeEnergy
                      26. batteryMonthDischargeEnergyStr
                      27. batteryYearDischargeEnergy
                      28. batteryYearDischargeEnergyStr
                      29. batteryTotalDischargeEnergy
                      30. batteryTotalDischargeEnergyStr
                      another note about the data structure:
                      Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
                      • Power Station List (v1/api/userStationList)
                      • Power Station Detail (v1/api/stationDetail)
                      • Datalogger List (v1/api/collectorList)
                      • Data logger details (v1/api/collectorDetail)
                      Inverter List (v1/api/inverterList)
                      • Inverter details (v1/api/inverterDetail)
                        possible!
                      If I can support you here, please let me know.
                      Greetings from Saxony
                      PS: the app currently available from Solis cannot be used in this way.
                      • Trixx
                        @luapsi
                        I've pushed another version to github.
                        The values are split up between the inverter & station details, for the values I did have to switch some things.
                        The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
                        I still have a few more to add and need to adjust some units .
                        I'll try to get to those later today or later this week.
                        Regards,
                        Trixx
                          @trixx
                          Thank you for your enthusiasm and commitment!
                          For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
                          Let me know if there is any news.
                          Greetings Sven
                            Luapsi @Luapsi last edited by Luapsi
                            @Trixx
                            The problem with the API is solved.
                            An additional group is still needed 🙂
                            Is it possible for you to integrate these?
                            is needed to calculate data!
                            Thank you very much in advance!
                            from v1/api/epmDetail:
                            1. state
                            2. iAc1 Current U
                            3. iAc2 Current V
                            4. iAc3 Current W
                            5. uAc1 Voltage U
                            6. uAc2 Voltage V
                            7. uAc3 Voltage W
                            8. pAc1 Power U
                            9. pAc2 Power V
                            10. pAc3 Power W
                            11. facMeter
                            12. pEpmTotal
                            13. pEpmTotalStr
                            14. eTotalBuy
                            15. eTotalBayStr
                            16. eTotalSell
                            17. etotalSellStr
                            Thanks
                            Trixx 2 Replies Last reply Reply Quote 0
                            • Trixx
                              @luapsi
                              I'll see what I can do !
                              • Trixx
                                @luapsi
                                Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
                                I do have some IRL things to take care of this week, so it might be a few days before I get to this.
                                Regards,
                                Trixx
                                • Trixx
                                  Trixx last edited by Trixx
                                  @luapsi
                                  Hi !
                                  Sorry for the long delay. I had some stuff going on that I needed to handle first...
                                  I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                                  Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                                  With that I should be able to map the values you requested.
                                  Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                                  Happy holidays !
                                  Regards,
                                  Trixx
                                  • M T
                                    M T @Schneider_Helmut last edited by
                                    Hallo
                                    Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                                    @schneider_helmut said in New Adapter - Soliscloud:
                                    @trixx
                                    Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                                    Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                                    mcm1957 M T 2 Replies Last reply Reply Quote 0
                                    • mcm1957
                                      mcm1957 @M T last edited by mcm1957
                                      @m-t said in New Adapter - Soliscloud:
                                      Hallo
                                      Können sie bitte einen Bild hochladen .........
                                      This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                                      M T 1 Reply Last reply Reply Quote 0
                                      • M T
                                        M T @mcm1957 last edited by
                                        Can you give me a screenshot of the app settings? how to enter the data
                                        @mcm57 said in New Adapter - Soliscloud:
                                        Hallo
                                        • M T
                                          M T @M T last edited by
                                          Can you tell me what data I need to enter??
                                          Hallo
                                          @trixx
                                          • mcm1957
                                            @m-t
                                            Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
                                            What information do you miss in detail?
                                            57
                                            8523
