    4. Test Adapter Weather-Warnings
      sigi234 Forum Testing Most Active @ticaki last edited by
      @ticaki sagte in Test Adapter Weather-Warnings:
      Du meinst damit die normale History die man als Tab auswählen kann? Button im Admin oder state?
      Ja und state
      • Latzi
        Latzi @ticaki last edited by
        @ticaki
        ich bekomme gelegentlich nach dem Speichern folgendes warning (invalid jsonConfig), woran liegt das?
        2023-11-02 09:46:24.270 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3262784
        2023-11-02 09:46:24.940 - debug: weather-warnings.0 (3262784) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2023-11-02 09:46:24.997 - debug: weather-warnings.0 (3262784) Objects client ready ... initialize now
        2023-11-02 09:46:25.040 - debug: weather-warnings.0 (3262784) Objects create System PubSub Client
        2023-11-02 09:46:25.041 - debug: weather-warnings.0 (3262784) Objects create User PubSub Client
        2023-11-02 09:46:25.141 - debug: weather-warnings.0 (3262784) Objects client initialize lua scripts
        2023-11-02 09:46:25.157 - debug: weather-warnings.0 (3262784) Objects connected to redis: 0.0.0.0:9001
        2023-11-02 09:46:25.209 - debug: weather-warnings.0 (3262784) Redis States: Use Redis connection: 0.0.0.0:9000
        2023-11-02 09:46:25.239 - debug: weather-warnings.0 (3262784) States create System PubSub Client
        2023-11-02 09:46:25.240 - debug: weather-warnings.0 (3262784) States create User PubSub Client
        2023-11-02 09:46:25.337 - debug: weather-warnings.0 (3262784) States connected to redis: 0.0.0.0:9000
        2023-11-02 09:46:25.419 - info: weather-warnings.0 (3262784) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.2, js-controller: 5.0.16
        2023-11-02 09:46:29.740 - info: weather-warnings.0 (3262784) Refresh Interval: 15 minutes
        2023-11-02 09:46:29.823 - debug: weather-warnings.0 (3262784) [telegram] Create notification service telegram
        2023-11-02 09:46:29.824 - info: weather-warnings.0 (3262784) ZAMG activated. Retrieve data.
        2023-11-02 09:46:29.840 - info: weather-warnings.0 (3262784) UWZ activated. Retrieve data.
        2023-11-02 09:46:30.275 - debug: weather-warnings.0 (3262784) [zamg-48.333444483766975,14.6258983209036] Got 0 warnings from server
        2023-11-02 09:46:31.467 - debug: weather-warnings.0 (3262784) [uwz-UWZAT00754] Got 1 warnings from server
        2023-11-02 09:46:32.205 - debug: weather-warnings.0 (3262784) [provider] We have 1 active messages.
        2023-11-02 09:48:08.167 - warn: admin.0 (97069) weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
        2023-11-02 09:48:15.140 - info: host.ioBroker stopInstance system.adapter.weather-warnings.0 (force=false, process=true)
        Eine Frage noch: Kann ich die icons in den Vorlagen einfach mit ${iconbase64} einbinden oder muss ich bei den Pfaden irgend etwas einstellen? Derzeit schaut´s bei mir so aus:
          ticaki Developer @Latzi last edited by ticaki
          @latzi
          1. accordion ist nicht im schema, das ist ein Admin Problem. Die Warnung ist falsch und egal 🙂
          2. iconbase64 ist ein Bild in base64 codiert und in html eingepackt. Das geht nur in Diensten die html unterstützen. Afaik nur email im moment.
          3. Das was du da zeigst ist für iconurl
          EDIT etwas mehr:
          iconurl: entweder die schwarzen/blauen Icons oder eine "Pfad" auf eigene Icons. Das ist ein Vispfad.
          iconbase64: Fertig umgewandelte blaue Icons als base64 pixel 32x32
          Das hier sind von mir im Code fest gelegte Icons umcodiert und mit wenig Pixel, damit sie keinen Platz brauche. Die kann man in emails verwenden.
          iconbase64 fügt z.B. sowas in die Nachricht ein:
          <img src=\"data:image/png;base64,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\" />
          Ich benenne das demnächst um in htmlicon.
          EDIT: bessere Idee: Ich setzte bei html fähigen Diensten das ein, ansonsten gibts 🌡 ⛈
          Hm oder ich mache 2 Tokens htmlwarntypeicon und warntypesmilie
          Latzi 1 Reply Last reply Reply Quote 0
          • Latzi
            ist damit schon das "richtige" Icon ausgewählt, oder muss es vorher ermittelt werden (analog Wiki-Template)?
              @latzi
              Ja. Der Token arbeitet vereinfacht so: /bla/bla/***.png
              Und je nach Warnungstyp ist dann:
              *** = strom rain etc.
              In meinen blauen/schwarzen gibts aber nur 7-8 der möglichen, für den Rest habe ich keine die zum Design passen.
                ticaki Developer last edited by ticaki
                update
                • iconbase64 umbenannt in htmlicon (iconbase64 wird intern umbenannt in htmlicon, aber nicht für immer.)
                • weatheremoji hinzugefügt. (smilies)
                Negalein 2 Replies Last reply Reply Quote 0
                • Negalein
                  update
                  Frage zur ID von UWZ
                  lt. einem alten Script musste da die ID mit Lat/Long ermittelt werden.
                  So ist zB für meinen Ort nicht AT4783 (AT+PLZ) sondern AT00928 (AT+ID lt. Lat/Long).
                  • Negalein
                    Negalein Global Moderator @ticaki last edited by
                    muss also <tr><td style="padding: 5px 0 5px 0;" bgcolor="${warnlevelcolorhex}"><b><font color=#000000>${headline}</font></b></td></tr><tr><td style="padding: 5px 0 20px 0;">${iconbase64}${description}</td></tr> nicht verändert werden?
                    • Negalein
                      Negalein Global Moderator @ticaki last edited by Negalein
                      @ticaki
                      noch was 😉
                      Hab hier eine aktive Warnung.
                      Jedoch kommt keine Email oder Telegram.
                        "results": [
                            "center": "UWZ",
                            "areaID": "UWZAT00663",
                            "dtgEnd": 1699002000,
                            "areaType": "UWZCODE",
                            "dtgStart": 1698926400,
                            "payload": {
                              "translationsLongText": {
                                "DE": "Am Donnerstagnachmittag ist weiterhin mit kräftigem Regen zu rechnen. Dabei kommen Niederschlagsmengen zwischen 30 und 50 l/m² in 24 Stunden, örtlich auch mehr zustande. Die Schneefallgrenze sinkt bis Freitagmorgen auf 1200 Meter: dadurch fallen oberhalb 2000 m 20-30 cm Neuschnee. Freitagmorgen lässt der Regen von Westen her nach."
                              "id": "16987767775897",
                              "creation": 1698932760000,
                              "uwzLevel": 10,
                              "translationsShortText": {
                                "DE": "Kräftiger Dauerregen mit 30-50 l/m² in 24 Stunden"
                              "fileName": "meteogroup_warn_16987767775897_20231102134615_1699002000_1698932825.xml",
                              "levelName": "alert_warn_orange",
                              "shortText": "Rain. 30-50 l/m²",
                              "longText": "From Thursday noon intense rain is expected. Accordingly, precipitation amounts of 30 to 50 l/m² in 24 hours are expected, locally even more. Friday morning the snow line drops to 1200 meters. Friday morning rain decreases.",
                              "altMin": -10,
                              "altMax": 9000
                            "severity": 10,
                            "type": 4
                        "cached": 1
                        ticaki Developer @Negalein last edited by
                        @negalein
                        Rest beantworte ich später:
                        Kannst du zu dem letzten Punkt mal bitte das Keiner bei Filtern nach warntypen raus machen und den Adapter mit ausgeschaltetem "Warnungen gelten als bekannt" starten. Wenn es dann geht haben wir den FEhler. Wenn nicht bitte deinen Adapter einstellungen posten/per nachricht. (kannst das json oben rechts in der Adapterkonfiguration downloaden)
                        • Negalein
                          Danke, das wars!
                          So funktioniert es.
                          Dann schalt ich Eingehende Warnungen nach dem Adapterstart gelten als bekannt wieder ein.
                          T Negalein 2 Replies Last reply Reply Quote 0
                            ticaki Developer @Negalein last edited by ticaki
                            @negalein
                            super, das "keiner" hab ich nachträglich eingebaut für was anderes. 🙂 Werde ich mir nachher mal ansehen.
                            zu UWZ - uff - jetzt hab ich das schon über 4 Jahre drin und mir hat das keiner verraten. @sigi234 benutzt man in AT die Koordinaten?
                            Die Vorlage solltest du ändern, ich hab das nur drin, weils leute gibt die es vergessen, überlesen usw.
                            Ich teste das heute abend alles und wenn ok gibts ne neue Version
                            • Negalein
                              ich such mal eine AT-Gemeinde mit aktiver Warnung und teste es.
                              • Negalein
                                So, Test erfolgreich
                                Mit ID kommen 2 Meldungen
                                Mit PLZ kommt nichts
                                  @negalein
                                  Und wie kommt man an die id?
                                  Ich kann das nicht nachvollziehen mit dem "keiner" oder hast du den Adapter auf eine neue UWZzelle mit Warnung zum testen gestartet und es hat an der "Warnungen gelten als bekannt" gelegen?
                                  • Negalein
                                    https://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=lookupCoord&lat=48.456680&lon=13.431940
                                    (lat & long anpassen (ermitteln zB mit https://www.latlong.net/))
                                    im Ergebnis steht dann die ID
                                    [{"AREA_TYPE":"UWZ","AREA_ID":"UWZAT00926","CENTER_ID":"2"}]
                                      @negalein
                                      Dat baue ich dann so ein, dass man bei uwz coordinaten eingeben muß 🙂
                                      • Negalein
                                        Nö, dann kommt der nächste und fragt, warum es mit DE48.456680,13.431940 nicht funktioniert! 😉
                                        Es muss lt. meiner Beschreibung über den Link (mit passenden Koordinaten) die ID ermittelt werden. Und dann diese Zahl an das Landeskennzeichen angehängt werden.
                                        Das mit der ID kann auch für Deutschland (obwohl hier auch mit PLZ funktioniert) verwendet werden.
                                        T sigi234 2 Replies Last reply Reply Quote 0
                                          @negalein sagte in Test Adapter Weather-Warnings:
                                          Das funktioniert 🙂
                                          https://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=lookupCoord&lat=53.456680&lon=13.431940
                                          Da kommt die PLZ von Berlin raus.
                                          • Negalein
                                            Das funktioniert
                                            was? ATxx.xxxxxx,xx.xxxxxx funktioniert?
                                            man lernt nie aus. 🙂
                                            1077
                                            264802
