    3. Einsteigerfragen
    4. Installation
    5. Update js-controller - "nodejs is NOT correctly installed"
      Thomas Braun Most Active @George_Best last edited by
      @george_best
      Dann lass
      iob nodejs-update
      nochmal laufen, wenn der iobroker aktualisiert wurde. Dann dürfte da auch nodejs@18 vorgeschlagen werden. Jetzt bist du bestimmt auf 16 gelandet, oder?
        Der Befehl
        iobroker upgrade self
        sagt leider immer noch "js-controller 4.0.24"
        ab.
        Nun bringt mir
        iob diag
        folgende Meldung:
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
        npm ERR! extraneous: 01_icons@ /opt/iobroker/node_modules/01_icons
        npm ERR! extraneous: array-ext@0.1.5 /opt/iobroker/node_modules/array-ext
        npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
        npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
        npm ERR! extraneous: aws-sdk@2.1484.0 /opt/iobroker/node_modules/aws-sdk
        npm ERR! extraneous: axios@0.18.0 /opt/iobroker/node_modules/axios
        npm ERR! extraneous: babel-runtime@5.8.38 /opt/iobroker/node_modules/babel-runtime
        npm ERR! extraneous: big-number@0.3.1 /opt/iobroker/node_modules/big-number
        npm ERR! extraneous: bignumber.js@4.1.0 /opt/iobroker/node_modules/bignumber.js
        npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/buffer
        npm ERR! extraneous: busboy@0.2.14 /opt/iobroker/node_modules/busboy
        npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
        npm ERR! extraneous: castv2-player@2.0.6 /opt/iobroker/node_modules/castv2-player
        npm ERR! extraneous: chainsaw@0.0.9 /opt/iobroker/node_modules/chainsaw
        npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
        npm ERR! extraneous: comment-json@1.1.3 /opt/iobroker/node_modules/comment-json
        npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
        npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
        npm ERR! extraneous: esprima@2.7.3 /opt/iobroker/node_modules/esprima
        npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
        npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
        npm ERR! extraneous: follow-redirects@1.7.0 /opt/iobroker/node_modules/follow-redirects
        npm ERR! extraneous: generic-pool@2.5.4 /opt/iobroker/node_modules/generic-pool
        npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
        npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
        npm ERR! extraneous: hashish@0.0.4 /opt/iobroker/node_modules/hashish
        npm ERR! extraneous: inote-util@1.17.2 /opt/iobroker/node_modules/inote-util
        npm ERR! invalid: iobroker.esphome@0.2.0-0 /opt/iobroker/node_modules/iobroker.esphome
        npm ERR! invalid: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
        npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
        npm ERR! invalid: iobroker.vis-materialdesign@0.2.62 /opt/iobroker/node_modules/iobroker.vis-materialdesign
        npm ERR! invalid: iobroker.vodafone-speedtest@0.0.6 /opt/iobroker/node_modules/iobroker.vodafone-speedtest
        npm ERR! invalid: iobroker.web-speedy@0.1.1 /opt/iobroker/node_modules/iobroker.web-speedy
        npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
        npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/is-generator-function
        npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
        npm ERR! extraneous: jmespath@0.16.0 /opt/iobroker/node_modules/jmespath
        npm ERR! extraneous: json-parser@1.1.5 /opt/iobroker/node_modules/json-parser
        npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
        npm ERR! extraneous: mmmagic@0.5.2 /opt/iobroker/node_modules/mmmagic
        npm ERR! extraneous: mssql@3.3.0 /opt/iobroker/node_modules/mssql
        npm ERR! extraneous: mysql@2.16.0 /opt/iobroker/node_modules/mysql
        npm ERR! extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
        npm ERR! extraneous: node-abi@2.30.1 /opt/iobroker/node_modules/node-abi
        npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
        npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
        npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
        npm ERR! extraneous: pg-connection-string@0.1.3 /opt/iobroker/node_modules/pg-connection-string
        npm ERR! extraneous: pg-pool@2.0.6 /opt/iobroker/node_modules/pg-pool
        npm ERR! extraneous: pg-types@2.0.0 /opt/iobroker/node_modules/pg-types
        npm ERR! extraneous: pg@7.9.0 /opt/iobroker/node_modules/pg
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: postgres-date@1.0.3 /opt/iobroker/node_modules/postgres-date
        npm ERR! extraneous: prebuild-install@6.1.4 /opt/iobroker/node_modules/prebuild-install
        npm ERR! extraneous: priorityqueuejs@1.0.0 /opt/iobroker/node_modules/priorityqueuejs
        npm ERR! extraneous: promise@7.3.1 /opt/iobroker/node_modules/promise
        npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
        npm ERR! extraneous: remove@0.1.5 /opt/iobroker/node_modules/remove
        npm ERR! extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
        npm ERR! extraneous: seedrandom@2.4.4 /opt/iobroker/node_modules/seedrandom
        npm ERR! extraneous: seq@0.3.5 /opt/iobroker/node_modules/seq
        npm ERR! extraneous: shelljs@0.8.3 /opt/iobroker/node_modules/shelljs
        npm ERR! extraneous: soef@0.4.15 /opt/iobroker/node_modules/soef
        npm ERR! extraneous: sprintf@0.1.5 /opt/iobroker/node_modules/sprintf
        npm ERR! extraneous: sql-client@1.3.0 /opt/iobroker/node_modules/sql-client
        npm ERR! extraneous: sqlite3@4.0.6 /opt/iobroker/node_modules/sqlite3
        npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
        npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
        npm ERR! extraneous: systeminformation@4.8.3 /opt/iobroker/node_modules/systeminformation
        npm ERR! extraneous: tedious@1.14.0 /opt/iobroker/node_modules/tedious
        npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
        npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
        npm ERR! extraneous: typescript@2.9.2 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
        npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
        npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
        npm ERR! extraneous: @serialport/parser-readline@10.3.0 /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-readline
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/debug
        npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/node-addon-api
        npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/crypto-js
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/isarray
        npm ERR! extraneous: mqtt@2.15.1 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt
        npm ERR! extraneous: readable-stream@2.3.6 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/string_decoder
        npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-sdk/node_modules/sax
        npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-sdk/node_modules/util
        npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-sdk/node_modules/uuid
        npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-sdk/node_modules/xml2js
        npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-sdk/node_modules/xmlbuilder
        npm ERR! extraneous: core-js@1.2.7 /opt/iobroker/node_modules/babel-runtime/node_modules/core-js
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/buffer/node_modules/isarray
        npm ERR! extraneous: streamsearch@0.1.2 /opt/iobroker/node_modules/dicer/node_modules/streamsearch
        npm ERR! extraneous: fs-extra@4.0.3 /opt/iobroker/node_modules/express-fileupload/node_modules/fs-extra
        npm ERR! extraneous: debug@3.2.6 /opt/iobroker/node_modules/follow-redirects/node_modules/debug
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/follow-redirects/node_modules/ms
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/glob-stream/node_modules/isarray
        npm ERR! extraneous: readable-stream@2.3.7 /opt/iobroker/node_modules/glob-stream/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/glob-stream/node_modules/string_decoder
        npm ERR! invalid: node-snap7@ /opt/iobroker/node_modules/node-snap7
        npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/mysql/node_modules/isarray
        npm ERR! extraneous: readable-stream@2.3.6 /opt/iobroker/node_modules/mysql/node_modules/readable-stream
        npm ERR! extraneous: sqlstring@2.3.1 /opt/iobroker/node_modules/mysql/node_modules/sqlstring
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/mysql/node_modules/string_decoder
        npm ERR! extraneous: async@1.5.2 /opt/iobroker/node_modules/nconf/node_modules/async
        npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/nconf/node_modules/camelcase
        npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/nconf/node_modules/window-size
        npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/nconf/node_modules/yargs
        npm ERR! extraneous: minimist@0.0.10 /opt/iobroker/node_modules/optimist/node_modules/minimist
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/ordered-read-streams/node_modules/isarray
        npm ERR! extraneous: readable-stream@2.3.7 /opt/iobroker/node_modules/ordered-read-streams/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/ordered-read-streams/node_modules/string_decoder
        npm ERR! extraneous: semver@4.3.2 /opt/iobroker/node_modules/pg/node_modules/semver
        npm ERR! extraneous: minimist@1.2.8 /opt/iobroker/node_modules/prebuild-install/node_modules/minimist
        npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/prebuild-install/node_modules/pump
        npm ERR! extraneous: nan@2.10.0 /opt/iobroker/node_modules/sqlite3/node_modules/nan
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/tedious/node_modules/isarray
        npm ERR! extraneous: readable-stream@2.3.6 /opt/iobroker/node_modules/tedious/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/tedious/node_modules/string_decoder
        npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/url/node_modules/punycode
        npm ERR! extraneous: debug@3.2.6 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
        npm ERR! extraneous: help-me@1.1.0 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/node_modules/help-me
        npm ERR! extraneous: mqtt-packet@5.6.1 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/node_modules/mqtt-packet
        npm ERR! extraneous: split2@2.2.0 /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/node_modules/split2
        npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder
        npm ERR! extraneous: cli@1.0.1 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/cli
        npm ERR! extraneous: console-browserify@1.1.0 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/console-browserify
        npm ERR! extraneous: date-now@0.1.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/date-now
        npm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/dom-serializer
        npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/domelementtype
        npm ERR! extraneous: domhandler@2.3.0 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/domhandler
        npm ERR! extraneous: domutils@1.5.1 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/domutils
        npm ERR! extraneous: entities@1.0.0 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/entities
        npm ERR! extraneous: exit@0.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/exit
        npm ERR! extraneous: htmlparser2@3.8.3 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/htmlparser2
        npm ERR! extraneous: jshint@2.13.6 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/jshint
        npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/lodash
        npm ERR! extraneous: domelementtype@2.3.0 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/dom-serializer/node_modules/domelementtype
        npm ERR! extraneous: entities@2.2.0 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/dom-serializer/node_modules/entities
        npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/htmlparser2/node_modules/isarray
        npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/htmlparser2/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/htmlparser2/node_modules/string_decoder
        npm ERR! extraneous: strip-json-comments@1.0.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/jshint/node_modules/strip-json-comments
        npm ERR! invalid: colour@0.7.1 /opt/iobroker/node_modules/colour
        npm ERR! invalid: optjs@3.2.2 /opt/iobroker/node_modules/optjs
        npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-02T13_06_57_592Z-debug-0.log
        iob fix bringt leider keine Besserung.
          @george_best
          Da muss zunächst der npm-Tree gezähmt werden. Mit so vielen Fehlern geht da nix mehr.
          Schmeiß zunächst die mit invalid gekennzeichneten Adapter aus dem System.
            @george_best
            Den gibt es soweit ich weiß gar nicht mehr:
            Jedenfalls nicht unter dem Namen.
              @thomas-braun ja - das stimmt.
              Aber da sind noch einige andere dabei, bei denen ich mir nicht sicher bin ob ich die einfach so löschen kann...
                @george_best
                Oft ergeben die sich, wenn die toten Dinger erstmal raus sind.
                  @george_best
                  Mit socksv5 gibt es zu.B. Probleme, weil das Ding seit Jahren nicht mehr gepflegt wird. Da müsste der Adapter, der das verwendet, auf was anderes umgestellt werden.
                    George_Best @Thomas Braun last edited by
                    @thomas-braun ok - d.h. alle "Invalid" raushauen?
                    Wie lösche ich die am besten? Einfach ordner unter node_modules löschen?
                      @george_best sagte in Update js-controller - "nodejs is NOT correctly installed":
                      Bist du des Wahnsinns?
                      Nein, mit
                      iobroker del ADAPTER
                      zunächst die iobroker-Module rauskratzen. Und dann nochmal schauen wie es dann da ausschaut.
                      Keinesfalls da irgendwas irgendwo einfach löschen.
                        George_Best @Thomas Braun last edited by George_Best
                        @thomas-braun puh...
                        schon mit
                        iobroker del icons-open-icon-library-png
                        gings schon ziemlich rund 😞
                        Delete adapter "icons-open-icon-library-png"
                        host.ioBroker-V2 Counted 1 instances of icons-open-icon-library-png
                        host.ioBroker-V2 Counted 1 meta of icons-open-icon-library-png
                        host.ioBroker-V2 Counted 1 adapter for icons-open-icon-library-png
                        host.ioBroker-V2 Counted 1 states of system.adapter.icons-open-icon-library-png
                        host.ioBroker-V2 Counted 1 states (system.adapter.icons-open-icon-library-png.*) from states
                        host.ioBroker-V2 file icons-open-icon-library-png deleted
                        host.ioBroker-V2 file icons-open-icon-library-png.admin deleted
                        host.ioBroker-V2 object icons-open-icon-library-png deleted
                        host.ioBroker-V2 object icons-open-icon-library-png.admin deleted
                        host.ioBroker-V2 Deleting 4 object(s).
                        host.ioBroker-V2 Deleting 1 state(s).
                        Error deleting adapter icons-open-icon-library-png from disk: host.ioBroker-V2: Cannot uninstall iobroker.icons-open-icon-library-png: 1
                        You might have to delete it yourself!
                        Es gab dann einiges an errors im iobroker-log:
                        15786	2023-11-02 15:39:10.158	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html'
                        vis.0
                        15786	2023-11-02 15:39:10.158	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js'
                        vis.0
                        15786	2023-11-02 15:39:10.156	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js'
                        vis.0
                        15786	2023-11-02 15:39:10.152	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js'
                        vis.0
                        15786	2023-11-02 15:39:10.152	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js'
                        vis.0
                        15786	2023-11-02 15:39:10.151	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js'
                        vis.0
                        15786	2023-11-02 15:39:10.151	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js'
                        vis.0
                        15786	2023-11-02 15:39:10.150	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js'
                        vis.0
                        15786	2023-11-02 15:39:10.150	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js'Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js'
                        vis.0
                        15786	2023-11-02 15:39:10.149	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js'
                        vis.0
                        15786	2023-11-02 15:39:10.149	error	Error: Cannot upload /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobr
                          George_Best @George_Best last edited by
                          Hab ich irgendwie die Chance mein ioBroker ohne komplette Neuinstallation wieder hinzubekommen?
                            @george_best
                            iob update
                            iobroker upgrade icons-open-icon-library-png@0.1.2
                            iobroker upgrade vis-materialdesign@vis-materialdesign@0.5.9
                            versuchen.
                              @thomas-braun sagte in Update js-controller - "nodejs is NOT correctly installed":
                              icons-open
                              Habe ich gerade gemacht. Offensichtlich habe ich - wie auch immer - für diesen Adapter eine Version höher installiert als verfügbar (installiert: 1.0.3, verfügbar 1.02.). Wie auch immer - das Upgrade hat dann wohl einen "Downgrade" auf 1.0.2 gemacht, was auch erfolgreich durchlief.
                              Aber dies hat mir irgendwie den js-controller zerschossen:
                              iobroker status
                              node:internal/modules/cjs/loader:1080
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                  at Module._load (node:internal/modules/cjs/loader:922:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                                  at node:internal/main/run_main_module:23:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              Node.js v18.18.2
                              Ich habe jetzt eine Rollback gemacht damit das System erstmal wieder läuft. Gibt es noch eine Idee?
                                @george_best
                                Den js-controller nochmal drüber installieren.
                                  @thomas-braun mit
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                    @george_best
                                    Ja, aber im richtigen Verzeichnis.
                                    Vorher
                                    cd /opt/iobroker
                                      @thomas-braun sieht leider nicht so gut as:
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rename
                                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                      npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T10_47_37_114Z-debug-0.log
                                      Das Log-file: 2023-11-03T10_47_43_654Z-debug-0.log
                                        @george_best
                                        iob stop
                                        iob fix
                                          iob fix:
                                          library: loaded
                                          Library version=2023-10-13
                                              Welcome to the ioBroker installation fixer!
                                              Script version: 2023-10-13
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/5)
                                          Ign:1 http://security.debian.org/debian-security bullseye/updates InRelease
                                          OK:2 http://deb.debian.org/debian bullseye InRelease
                                          Ign:3 http://security.debian.org/debian-security bullseyeupdates InRelease
                                          OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                                          OK:5 http://deb.debian.org/debian bullseye-backports InRelease
                                          Fehl:6 http://security.debian.org/debian-security bullseye/updates Release
                                            404  Not Found [IP: 199.232.190.132 80]
                                          Fehl:7 http://security.debian.org/debian-security bullseyeupdates Release
                                          OK:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Holen:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease [24,5 kB]
                                          Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease
                                            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                          Paketlisten werden gelesen… Fertig
                                          E: Das Depot »http://security.debian.org/debian-security bullseye/updates Release« enthält keine Release-Datei.
                                          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                          E: Das Depot »http://security.debian.org/debian-security bullseyeupdates Release« enthält keine Release-Datei.
                                          W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                          E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease« ist nicht signiert.
                                              Checking ioBroker user and directory permissions (2/5)
                                          Created /etc/sudoers.d/iobroker
                                          Fixing directory permissions...
                                              Check and cleanup npm temporary directories (3/5)
                                          Done.
                                              Database maintenance (4/5)
                                          Checking for uncompressed JSONL databases... This might take a while!
                                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                          Compressed 2 JSONL files. Done
                                              Checking autostart (5/5)
                                          Enabling autostart...
                                          Autostart enabled!
                                              Your installation was fixed successfully
                                              Run iobroker start to start ioBroker again!
                                          npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.esphome.git
                                          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                          npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                                          npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                          npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                          npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                          npm WARN cleanup Failed to remove some directories [
                                          npm WARN cleanup   [
                                          npm WARN cleanup     '/opt/iobroker/node_modules/raw-socket',
                                          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/raw-socket'] {
                                          npm WARN cleanup       errno: -39,
                                          npm WARN cleanup       code: 'ENOTEMPTY',
                                          npm WARN cleanup       syscall: 'rmdir',
                                          npm WARN cleanup       path: '/opt/iobroker/node_modules/raw-socket'
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     '/opt/iobroker/node_modules/node-snap7',
                                          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/node-snap7'] {
                                          npm WARN cleanup       path: '/opt/iobroker/node_modules/node-snap7'
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     '/opt/iobroker/node_modules/pcap',
                                          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/pcap'] {
                                          npm WARN cleanup       path: '/opt/iobroker/node_modules/pcap'
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ]
                                          npm WARN cleanup ]
                                          npm ERR! code 1
                                          npm ERR! path /opt/iobroker/node_modules/node-libcurl
                                          npm ERR! command failed
                                          npm ERR! command sh -c node-pre-gyp install --fallback-to-build
                                          npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
                                          npm ERR! node-pre-gyp info it worked if it ends with ok
                                          npm ERR! node-pre-gyp info using node-pre-gyp@1.0.5
                                          npm ERR! node-pre-gyp info using node@18.18.2 | linux | x64
                                          npm ERR! node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
                                          npm ERR! node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
                                          npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
                                          npm ERR! node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@2.3.4 and node@18.18.2 (node-v108 ABI, glibc) (falling back to source compile with node-gyp)
                                          npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
                                          npm ERR! gyp info it worked if it ends with ok
                                          npm ERR! gyp info using node-gyp@9.4.0
                                          npm ERR! gyp info using node@18.18.2 | linux | x64
                                          npm ERR! gyp info ok
                                          npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                                          npm ERR! gyp info spawn /usr/bin/python3
                                          npm ERR! gyp info spawn args [
                                          npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                                          npm ERR! gyp info spawn args   'binding.gyp',
                                          npm ERR! gyp info spawn args   '-f',
                                          npm ERR! gyp info spawn args   'make',
                                          npm ERR! gyp info spawn args   '-I',
                                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
                                          npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                                          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                                          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                                          npm ERR! gyp info spawn args   '-Dvisibility=default',
                                          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                                          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                                          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                                          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
                                          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                                          npm ERR! gyp info spawn args   '--depth=.',
                                          npm ERR! gyp info spawn args   '--no-parallel',
                                          npm ERR! gyp info spawn args   '--generator-output',
                                          npm ERR! gyp info spawn args   'build',
                                          npm ERR! gyp info spawn args   '-Goutput_dir=.'
                                          npm ERR! gyp info spawn args ]
                                          npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
                                          npm ERR! Output: /bin/sh: 1: curl-config: not found
                                          npm ERR!
                                          npm ERR! gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                          npm ERR! gyp ERR! configure error
                                          npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
                                          npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:325:16)
                                          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
                                          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                          npm ERR! gyp ERR! System Linux 5.10.0-26-amd64
                                          npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v108"
                                          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
                                          npm ERR! gyp ERR! node -v v18.18.2
                                          npm ERR! gyp ERR! node-gyp -v v9.4.0
                                          npm ERR! gyp ERR! not ok
                                          npm ERR! node-pre-gyp ERR! build error
                                          npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
                                          npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                                          npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
                                          npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1098:16)
                                          npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:303:5)
                                          npm ERR! node-pre-gyp ERR! System Linux 5.10.0-26-amd64
                                          npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
                                          npm ERR! node-pre-gyp ERR! node -v v18.18.2
                                          npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.5
                                          npm ERR! node-pre-gyp ERR! not ok
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T11_01_57_465Z-debug-0.log
                                          mikeal created this issue in request/request
                                          open Request’s Past, Present and Future #3142
                                          Qix- created this issue in visionmedia/debug
                                          closed ReDos Vulnerability Regression Visibility Notice #797
                                            @george_best
                                            Du hast auch Chaos in den Repos. Insbesondere im Security-Repo. Und das Speedtest-Rrpo muss auch angepasst werden. Sieht man sowas nicht beim üblichen System-Update?
                                            sudo apt update
                                            apt policy libcurl*
                                            sagt?
                                            1.2k
                                            4406
