    4. Proxmox: Backup der CT/VMs in eine Cloud
    • Negalein
      Negalein Global Moderator @Meister Mopper last edited by
      @meister-mopper sagte in Proxmox: Backup der CT/VMs in eine Cloud:
      Es geht um die guest-Berechtigung.
      hab ich übersehen und nun geändert.
      Aber Fehler bleibt.
      INFO: starting new backup job: vzdump 102 --remove 0 --mode snapshot --storage Proxmox-Backup --node proxmox --compress zstd
      INFO: Starting Backup of VM 102 (lxc)
      INFO: Backup started at 2021-12-16 17:56:57
      INFO: status = running
      INFO: CT Name: pihole
      INFO: including mount point rootfs ('/') in backup
      INFO: backup mode: snapshot
      INFO: ionice priority: 7
      INFO: create storage snapshot 'vzdump'
        Logical volume "snap_vm-102-disk-0_vzdump" created.
      INFO: creating vzdump archive '/mnt/pve/Proxmox-Backup/dump/vzdump-lxc-102-2021_12_16-17_56_57.tar.zst'
      INFO: tar: /mnt/pve/Proxmox-Backup/dump/vzdump-lxc-102-2021_12_16-17_56_57.tmp: Cannot open: Permission denied
      INFO: tar: Error is not recoverable: exiting now
      INFO: cleanup temporary 'vzdump' snapshot
        Logical volume "snap_vm-102-disk-0_vzdump" successfully removed
      ERROR: Backup of VM 102 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/mnt/pve/Proxmox-Backup/dump/vzdump-lxc-102-2021_12_16-17_56_57.tmp' ./etc/vzdump/pct.conf ./etc/vzdump/pct.fw '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | zstd --rsyncable '--threads=1' >/mnt/pve/Proxmox-Backup/dump/vzdump-lxc-102-2021_12_16-17_56_57.tar.dat' failed: exit code 2
      INFO: Failed at 2021-12-16 17:56:58
      INFO: Backup job finished with errors
      TASK ERROR: job errors
        @homoran sagte in Proxmox: Backup der CT/VMs in eine Cloud:
        dass da was mit UUID und Sonst nochwelchen IDs passen muss
        🙂 Ja, in der Grundkonfiguration sollte es auf dem NFS-Server die gleichen user (bzw. die userid aka uid) geben. Das Dateisystem des NFS-Servers ist als 'Verlängerung' des lokalen Dateisystems zu sehen. Daher gilt dann dort zunächst die gleiche Rechtestruktur. Da das aber auf komplexen Installationen schwierig ist schaltet man dann noch einen 'Übersetzer' dazwischen. Aber bei den vermutlich eher überschaubaren Installationen hier kann man sich den imho sparen. Aber dann sollten halt die user einheitlich definiert sein.
        • Negalein
          Negalein Global Moderator @Thomas Braun last edited by
          @thomas-braun sagte in Proxmox: Backup der CT/VMs in eine Cloud:
          der mir den Proxmox eingerichtet hat, hat nur den User root (nicht mich schimpfen 😉 ) eingerichtet.
          Einen neuen User habe ich in Proxmox angelegt. Aber finde nichts dem Berechtigungen zu geben.
          Komisch, dass es mit identen Einstellungen bei @Meister-Mopper geht und bei mir nicht. 😞
          • Negalein
            ich hab mir jetzt mehrere Tutorials durchgelesen und auf YT angeschaut.
            Alle gehen nach dem gleichen Schema.
            Nur bei mir funktionierts nicht.
            • Negalein
              @Meister-Mopper
              Es funktioniert! 🙂
              Musste dies verwenden.
              • Meister Mopper
                Meister Mopper @Negalein last edited by
                @negalein sagte in Proxmox: Backup der CT/VMs in eine Cloud:
                Es funktioniert!
                Bei sieht es so aus:
                • David G.
                  Auch wenn das Topic hier mega alt ist....
                  Hab das hier grad bei der Recherche nach etwas anderem gefunden.
                  Ich nutze für meine Proxmox-Cloud-Backups hier das hier in der free Version.
                  https://www.tuxis.nl/de/proxmox-backup-server/
                    saeft_2003 Most Active @David G. last edited by
                    @david-g
                    d.h. wenn ich unter 150GB bleibe, ist das ganze komplett kostenlos?
                    • David G.
                      David G. @saeft_2003 last edited by
                      @saeft_2003
                      Jepp,
                      lauft bei mir seit ca. 4 Wochen.
                      Absolut stabil.
                      Backup ist verschlüsselt konfiguriert.
                        @david-g
                        alles klar ich werde es testen
                        • David G.
                          @saeft_2003
                          Mit 150GB kommt man ja recht weit.
                          Zumindest wenn es bei iobroker, einer Datenbank und was Kleinkram bleibt.
                          Dass schöne ist ja, dass der PBS inkrimentell sichert.
                          S Negalein 2 Replies Last reply Reply Quote 1
                            @david-g
                            inkrimentell heißt das nicht immer die kompletten x GB hochgeladen werden, sondern nur das was sich geändert hat?
                            • Negalein
                              Negalein Global Moderator @David G. last edited by
                              @david-g sagte in Proxmox: Backup der CT/VMs in eine Cloud:
                              hab mich auch gleich angemeldet.
                              Danke für den Tipp.
                              Jetzt muss ich noch schaun, wie ich die 2 verbinde. 😞
                              • Meister Mopper
                                Danke für den Tipp.
                                Ja ich auch, bin aber mal wieder zu blöd.
                                Mit welchen Zugangsdaten kann man denn dort auf den pbs, wenn man per sms das Kennwort erhalten hat.
                                Mir fehlt schlicht die url.
                                • Negalein
                                  Negalein Global Moderator @Meister Mopper last edited by Negalein
                                  schau in deinem Support-Ticket nach.
                                  Da steht die URL
                                  https://support.tuxis.nl/en/login
                                  Edit: Link zum Support-Ticket musst du per Mail bekommen haben.
                                    A Former User @Negalein last edited by A Former User
                                    Moin,
                                    Edit
                                    war Unsinn, daher einfach vergessen 🙂
                                    Negalein 2 Replies Last reply Reply Quote 0
                                    • Negalein
                                      Negalein Global Moderator @Guest last edited by
                                      @dp20eic sagte in Proxmox: Backup der CT/VMs in eine Cloud:
                                      na das steht doch alles im Dialog
                                      soweit war ich noch nicht.
                                      Hatte mit die Wiki angesehen und wurde erschlagen. 😞
                                        Jaksa last edited by
                                        Noch eine Möglichkeit ist es die Storage Box von Hetzner zu nutzen.
                                        Bei mir laufen die Proxmox Backups auf eine Synology. Die lädt die Dateien dann mit Cloud Sync verschlüsselt in die Storage Box. 3,80€/Monat für 1TB Speicher.
                                        Für das Geld lohnt es sich mMn nicht eine zweite Synology noch irgendwo anders hinzustellen 🙂
                                        • Meister Mopper
                                          @negalein
                                          Danke, gründlich lesen bringt echt was 😲
                                          • David G.
                                            David G. @Jaksa last edited by
                                            @jaksa
                                            Das geht natürlich auch. Hat nur 3 Nachteile.
                                            • Jedes Backup braucht die volle Größe
                                            • Zumindest bei mir ist die Storagebox abartig langsam. Ich sicher da täglich die Daten aus TrueNas hin.
                                            • Es ist (wie ich glaube gelesen habe) nicht so leicht über die WebUI möglich Backups von nicht zuvor verbundenen Festplatten einzuspielen.
                                            backup ccrypt cloud proxmox rclone
                                            14
                                            74
                                            13765
