    4. HILFE, kein Zugriff auf IOBroker
      Thomas Braun Most Active @tiobb last edited by
      @tiobb
      iob stop
      iob fix
      iob start
      iob diag
      tiobb 1 Reply Last reply Reply Quote 0
      • tiobb
        tiobb @Thomas Braun last edited by tiobb
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.52-v7l+
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         15:52:50 up  2:11,  1 user,  load average: 0.99, 1.10, 1.15
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2023-11-02 15:52:51 CET
                   Universal time: Thu 2023-11-02 14:52:51 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.9G        209M        6.9G         57M        755M        7.4G
        Swap:           99M          0B         99M
        Total:         8.0G        209M        7.0G
                 7898 M total memory
                  208 M used memory
                  367 M active memory
                  414 M inactive memory
                 6935 M free memory
                  140 M buffer memory
                  614 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT            LOAD   ACTIVE SUB    DESCRIPTION
        * lightdm.service loaded failed failed Light Display Manager
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   13G   16G  45% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G   41M  3.9G   2% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  205M  20% /boot
        tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
        [Thu Nov  2 13:41:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:35:E0:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5168531a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Nov  2 13:41:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Nov  2 13:41:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Nov  2 13:41:18 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET                       SOURCE         FSTYPE            OPTIONS
        /                            /dev/mmcblk0p2 ext4              rw,noatime
        |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
        |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        /var:
        1.9G	/var/
        1.2G	/var/cache/apt
        1.2G	/var/cache
        1.1G	/var/cache/apt/archives
        526M	/var/log
        Archived and active journals take up 40.0M in the file system.
        /opt/iobroker/backups:
        54M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        505M	/opt/iobroker/iobroker-data/
        337M	/opt/iobroker/iobroker-data/history
        146M	/opt/iobroker/iobroker-data/files
        29M	/opt/iobroker/iobroker-data/files/javascript.admin
        24M	/opt/iobroker/iobroker-data/files/vis
        11M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.d8ebf8a2.chunk.js.map
        11M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.d8ebf8a2.chunk.js.map
        9.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
        7.0M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.9483ccfd.chunk.js.map
        4.4M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v12.22.5
        /usr/bin/node 		v12.22.5
        /usr/bin/npm 		6.14.14
        /usr/bin/npx 		6.14.14
        /home/iobroker/.diag.sh: line 281: corepack: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 12.22.5-1nodesource1
          Candidate: 12.22.12-deb-1nodesource1
          Version table:
             12.22.12-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         *** 12.22.5-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! extraneous: @babel/cli@7.15.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
        npm ERR! extraneous: @babel/preset-env@7.15.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
        npm ERR! extraneous: @babel/preset-typescript@7.15.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
        npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
        npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
        npm ERR! extraneous: @types/jest@27.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
        npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
        npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
        npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
        npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.31.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
        npm ERR! extraneous: @typescript-eslint/parser@4.31.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
        npm ERR! extraneous: eslint@7.32.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
        npm ERR! extraneous: jest@27.2.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
        npm ERR! extraneous: typedoc@0.22.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
        npm ERR! extraneous: typedoc-plugin-markdown@3.11.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
        npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
        npm ERR! extraneous: typescript@4.4.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
        npm ERR! extraneous: eslint@7.32.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
        npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
        npm ERR! extraneous: eslint-plugin-jest@24.4.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
        npm ERR! extraneous: jest@27.2.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
        npm ERR! extraneous: @babel/cli@7.15.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
        npm ERR! extraneous: @babel/preset-env@7.15.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
        npm ERR! extraneous: @babel/preset-typescript@7.15.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
        npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
        npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
        npm ERR! extraneous: @types/jest@27.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
        npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
        npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
        npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
        npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.31.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
        npm ERR! extraneous: @typescript-eslint/parser@4.31.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
        npm ERR! extraneous: eslint@7.32.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
        npm ERR! extraneous: jest@27.1.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
        npm ERR! extraneous: typedoc@0.22.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
        npm ERR! extraneous: typedoc-plugin-markdown@3.10.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
        npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
        npm ERR! extraneous: typescript@4.4.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
        *** ioBroker-Installation ***
        ioBroker Status
         Cannot read system.config: null (OK when migrating or restoring)
        iobroker is not running on this host.
        Objects type: file
        States  type: file
        Core adapters versions
        js-controller: 	3.3.15
        admin: 		5.1.23
        javascript: 	5.2.8
        Adapters from github: 	4
        Adapter State
        + instance is alive
        ioBroker-Repositories
        Cannot get list: undefined
        Installed ioBroker-Instances
        Error: Object "system.config" not found
        Ab hier passiert immer das das gleiche "cannot read system.config
        Thomas Braun 4 Replies Last reply Reply Quote 0
          @tiobb sagte in HILFE, kein Zugriff auf IOBroker:
          *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * lightdm.service loaded failed failed Light Display Manager
          Der Fehler kann nur beim Desktop auftreten. Schalt dem Mumpitz aus!
          sudo systemctl set-default multi-user.target
          sudo reboot
          Und dann per SSH auf die Kiste drauf.
            @tiobb
            Und STEINalt.
            iob nodejs-update
              @tiobb
              Noch viel älter...
              Die Baustelle wird immer mehr zu: Abreißen, neubauen.
                Thomas Braun Most Active @tiobb last edited by Thomas Braun
                @tiobb
                Jetzt hast du solange dein 'System never getatscht' bis da halt nix mehr 'runnt'.
                Versuch ein Upgrade des js-controllers:
                https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable
                • tiobb
                  tiobb last edited by tiobb
                  Updates laufen.
                  Abgestürzt ist alles nach einem Stromausfall.
                  Gibt es eine Möglichkeit alles vom IoBroker irgendwie zu kopieren und in das Backup auf der anderen Speicherkarte zu übertragen?
                    Nein. Jedenfalls nicht mit zu vertretenem Aufwand.
                    • tiobb
                      Ok, hätte ja sein können das es einen "Ordner" gibt, in dem z.B. die Scripte abgelegt sind, und die man dann hätte per copy paste in das Backup einspielen können.
                        Da ich davon ausgehe, das du auch selbstverständlich kein Spiegelverzeichnis für die Skripte hast...
                        Es gibt ein Skript von @fastfoot , mit dem man Skripte rauskratzen kann. Ob das mit kaputten Installationen parat kommt weiß ich allerdings nicht.
                        • haselchen
                          haselchen Most Active @Thomas Braun last edited by
                          Ganz zu schweigen vom toten Buster OS
                          @tiobb
                            Thomas Braun Most Active @haselchen last edited by
                            Updates und Backups sind immer nur für andere. Man selber braucht die nicht.
                            • tiobb
                              @haselchen
                              Ich habe ja ein Backup, aber leider viel zu alt, da fehlen bestimmt 10 Scripte, von denen ich leider heute nicht mehr weiß wie ich sie neu schreiben soll 😥
                                Backups hat man immer aktuell, ergibt ja sonst keinen Sinn. Deswegen läuft der Backitup-Adapter ja z. B. auch in regelmäßigen Intervallen.
                                  Updates laufen.
                                  Welche und wie weit ist das gediehen?
                                  • tiobb
                                    Das iob nodejs update ist durchgelaufen, und der Pi hat einen Neustart gemacht. Js-controler bekomme ich das update irgendwie nicht zum laufen
                                      @tiobb
                                      iob diag
                                      sagt nun?
                                      • tiobb
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm
                                        Docker          : false
                                        Kernel          : armv7l
                                        Userland        : armhf
                                         18:00:21 up  4:19,  1 user,  load average: 0.25, 0.08, 0.02
                                        CPU threads: 4
                                        Current issues:
                                        This system needs to be REBOOTED!
                                                       Local time: Thu 2023-11-02 18:00:21 CET
                                                   Universal time: Thu 2023-11-02 17:00:21 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        /home/iobroker/.diag.sh: line 200: [[: 4036
                                        8227: syntax error in expression (error token is "8227")
                                        X-Server: 	false
                                        Desktop: 	LXDE-pi
                                        Terminal: 	x11
                                        *** MEMORY ***
                                        Mem:           7.9G        282M        3.8G         74M        3.9G        7.3G
                                        Swap:           99M        2.0M         97M
                                        Total:         8.0G        285M        3.9G
                                                 7898 M total memory
                                                  282 M used memory
                                                  534 M active memory
                                                 3357 M inactive memory
                                                 3760 M free memory
                                                  275 M buffer memory
                                                 3579 M swap cache
                                                   99 M total swap
                                                    2 M used swap
                                                   97 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        * iobroker.service loaded failed failed ioBroker Server
                                        2 loaded units listed. Pass --all to see loaded but inactive units, too.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G   14G   15G  49% /
                                        tmpfs          tmpfs     3.9G   49M  3.9G   2% /run
                                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                        /var:
                                        2.8G	/var/
                                        2.0G	/var/cache/apt/archives
                                        2.0G	/var/cache/apt
                                        2.0G	/var/cache
                                        526M	/var/log
                                        Archived and active journals take up 48.0M in the file system.
                                        USB-Devices by-id:
                                        /usr/bin/nodejs 	v18.18.2
                                        /usr/bin/node 		v18.18.2
                                        /usr/bin/npm 		9.8.1
                                        /usr/bin/npx 		9.8.1
                                        /usr/bin/corepack 	0.19.0
                                        nodejs:
                                          Installed: 18.18.2-1nodesource1
                                          Candidate: 18.18.2-1nodesource1
                                          Version table:
                                         *** 18.18.2-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        Errors in npm tree:
                                        ioBroker Status
                                         Cannot find view "system" for search "host"
                                        Objects type: file
                                        States  type: file
                                        admin: 		5.1.23
                                        javascript: 	5.2.8
                                        Adapters from github: 	1
                                        Adapter State
                                        + instance is alive
                                        scheint alles beim alten zu sein
                                            @tiobb
                                            Und du eimerst da immer noch mit einem Desktop durch die Gegend. AUSSCHALTEN!!!!
                                            138
                                            9026
