    3. Einsteigerfragen
    4. [gelöst]NPM ERR! missing node-ssh@^13.1.0, required by io
      guergen last edited by guergen
      Hallo, habe grade mal iob diag aufgerufen und bekomme einen Fehler (s.o)
      EDIT: Zeile 202-204
      Mit iob fix und iob node-update bekomme ich den auch nicht weg.
      Was ist zu tun?
      iob diag: (Langfassung)
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iob
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-13-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:51:06 up 2 days, 20:54,  1 user,  load average: 0.37, 1.21, 1.45
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Fri 2023-11-03 12:51:06 CET
                 Universal time: Fri 2023-11-03 11:51:06 UTC
                       RTC time: Fri 2023-11-03 11:51:06
                    NTP service: n/a
                RTC in local TZ: no
      *** User and Groups ***
      iob
      /home/iob
      iob cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.3G        481M        6.6G        540K        1.5G        7.8G
      Swap:           4.0G          0B        4.0G
      Total:           12G        481M         10G
               7940 M total memory
                459 M used memory
                719 M active memory
                568 M inactive memory
               6328 M free memory
                301 M buffer memory
               1162 M swap cache
               3813 M total swap
                  0 M used swap
               3813 M free swap
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  536K  794M   1% /run
      /dev/sda2      ext4       28G   16G   11G  60% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
      tmpfs          tmpfs     785M     0  785M   0% /run/user/0
      [Tue Oct 31 15:56:09 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Oct 31 15:56:10 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda2 ext4   rw,relatime,errors=remount-ro
      /var:
      2.5G    /var/
      2.0G    /var/log
      1.7G    /var/log/journal/2f4bc42be5da4a1da59ffeb8bb93ce6e
      364M    /var/cache
      Archived and active journals take up 127.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.7G    /opt/iobroker/iobroker-data/
      1.4G    /opt/iobroker/iobroker-data/files
      970M    /opt/iobroker/iobroker-data/files/vis-2-beta
      900M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
      898M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      23M     /opt/iobroker/iobroker-data/objects.json.migrated
      23M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-busware.de_CUL868-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
      npm ERR! A complete log of this run can be found in: /home/iob/.npm/_logs/2023-11-03T11_51_09_483Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.2
      javascript:     7.1.6
      Adapters from github:   5
      Adapter State
        system.adapter.admin.1                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iob                                      -  enabled
        system.adapter.backitup.0               : backitup              : iob                                      -  enabled
        system.adapter.backitup.1               : backitup              : iob-slave                                -  enabled
        system.adapter.ble.0                    : ble                   : iob-slave                                - disabled
        system.adapter.broadlink2.0             : broadlink2            : iob                                      -  enabled
        system.adapter.deconz.0                 : deconz                : iob                                      -  enabled, port: 80
        system.adapter.device-reminder.0        : device-reminder       : iob                                      -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob                                      - disabled
        system.adapter.enigma2.0                : enigma2               : iob                                      -  enabled
        system.adapter.enocean.0                : enocean               : iob-slave                                -  enabled
        system.adapter.feiertage.0              : feiertage             : iob                                      -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iob                                      -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : iob                                      -  enabled
        system.adapter.ical.0                   : ical                  : iob                                      -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob                                      - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob                                      - disabled
        system.adapter.influxdb.0               : influxdb              : iob                                      -  enabled, port: 8086
        system.adapter.influxdb.1               : influxdb              : iob                                      -  enabled, port: 8086
        system.adapter.iot.0                    : iot                   : iob                                      -  enabled
        system.adapter.javascript.0             : javascript            : iob                                      -  enabled
        system.adapter.life360.0                : life360               : iob                                      - disabled
        system.adapter.maxcul.0                 : maxcul                : iob                                      -  enabled
        system.adapter.meater.0                 : meater                : iob                                      - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iob                                      -  enabled, port: 54321
        system.adapter.modbus.0                 : modbus                : iob                                      -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iob                                      -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nut.0                    : nut                   : iob                                      -  enabled
        system.adapter.octoprint.0              : octoprint             : iob                                      - disabled
        system.adapter.openweathermap.0         : openweathermap        : iob                                      -  enabled
        system.adapter.parcel.0                 : parcel                : iob                                      - disabled
        system.adapter.pi-hole.0                : pi-hole               : iob                                      -  enabled
        system.adapter.ping.0                   : ping                  : iob                                      -  enabled
        system.adapter.proxmox.0                : proxmox               : iob                                      -  enabled, port: 8006
        system.adapter.pvforecast.0             : pvforecast            : iob                                      - disabled
        system.adapter.renault.0                : renault               : iob                                      -  enabled
        system.adapter.scenes.0                 : scenes                : iob                                      -  enabled
        system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.smartmeter.0             : smartmeter            : iob                                      -  enabled
        system.adapter.snmp.0                   : snmp                  : iob                                      - disabled
        system.adapter.snmp.1                   : snmp                  : iob                                      - disabled
        system.adapter.snmp.2                   : snmp                  : iob                                      - disabled
        system.adapter.socketio.0               : socketio              : iob                                      -  enabled, port: 8084, bind: 192.168.1.201, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iob                                      -  enabled, port: 11883, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : iob                                      -  enabled
        system.adapter.synology.1               : synology              : iob                                      -  enabled, port: 5000
        system.adapter.synology.2               : synology              : iob                                      -  enabled, port: 5000
        system.adapter.tankerkoenig.0           : tankerkoenig          : iob                                      -  enabled
        system.adapter.telegram.0               : telegram              : iob                                      -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iob                                      -  enabled
        system.adapter.tr-064.0                 : tr-064                : iob                                      -  enabled
        system.adapter.trashschedule.0          : trashschedule         : iob                                      -  enabled
        system.adapter.unifi.0                  : unifi                 : iob                                      -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iob                                      - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob                                      - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob                                      - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob                                      - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iob                                      - disabled
        system.adapter.vis-material.0           : vis-material          : iob                                      - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob                                      -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iob                                      - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob                                      - disabled
        system.adapter.vis.0                    : vis                   : iob                                      -  enabled
        system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob                                      - disabled
        system.adapter.wiffi-wz.0               : wiffi-wz              : iob                                      -  enabled
        system.adapter.wled.0                   : wled                  : iob-slave                                -  enabled
        system.adapter.zigbee.0                 : zigbee                : iob-slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e61ee51d512ec11a2f121c7bd930c07-if00-port0
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Stable (default): http://download.iobroker.net/sources-dist.json
      Active repo(s): Beta (latest)
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.12.2   , installed 6.12.2
      Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
      Adapter    "backitup"     : 2.9.1    , installed 2.9.1
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "deconz"       : 1.3.22   , installed 1.3.22
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fullybrowser" : 3.0.2    , installed 3.0.2
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
      Adapter    "meater"       : 1.0.2    , installed 1.0.2
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "modbus"       : 6.0.1    , installed 6.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "openweathermap": 0.4.5   , installed 0.4.5
      Adapter    "parcel"       : 0.1.6    , installed 0.1.6
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "renault"      : 0.0.21   , installed 0.0.21
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        38316
      States:         42925
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://ftp.de.debian.org/debian bookworm InRelease
      Hit:3 http://ftp.de.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1527       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16976      474/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13493      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16978      474/sshd: /usr/sbin
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12786      1/init
      udp        0      0 192.168.1.201:123       0.0.0.0:*                           0          16996      483/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          16994      483/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          16990      483/ntpd
      udp6       0      0 :::111                  :::*                                0          12787      1/init
      udp6       0      0 2a00:6020:a5b5:bb56:123 :::*                                109        17080      483/ntpd
      udp6       0      0 fe80::dc29:faff:fe1:123 :::*                                109        17030      483/ntpd
      udp6       0      0 ::1:123                 :::*                                0          16998      483/ntpd
      udp6       0      0 :::123                  :::*                                0          16987      483/ntpd
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (node:events:632:26)
          at Socket.emit (node:events:517:28)
          at TCP.<anonymous> (node:net:350:12)
      2023-11-03 12:48:32.634  - error: enigma2.0 (615007) DB closed
      2023-11-03 12:48:32.583  - warn: sonoff.0 (614747) get state error: Connection is closed.
      2023-11-03 12:48:32.613  - warn: sonoff.0 (614747) get state error: Connection is closed.
      2023-11-03 12:48:34.207  - error: host.iob Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]: Error: DB closed
      2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
      2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
      2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Object.onceWrapper (node:events:632:26)
      2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Socket.emit (node:events:517:28)
      2023-11-03 12:48:34.211  - error: host.iob Caught by controller[0]:     at Socket.emit (node:domain:489:12)
      2023-11-03 12:48:34.211  - error: host.iob Caught by controller[0]:     at TCP.<anonymous> (node:net:350:12)
      2023-11-03 12:48:36.149  - warn: host.iob instance system.adapter.ping.0 terminated due to SIGTERM
      2023-11-03 12:48:36.196  - warn: host.iob instance system.adapter.javascript.0 terminated due to SIGTERM
      2023-11-03 12:48:36.240  - warn: host.iob instance system.adapter.sonoff.0 terminated due to SIGTERM
      2023-11-03 12:48:36.288  - warn: host.iob instance system.adapter.enigma2.0 terminated due to SIGTERM
      2023-11-03 12:48:36.304  - warn: host.iob instance system.adapter.heatingcontrol.0 terminated due to SIGTERM
      2023-11-03 12:48:36.364  - warn: host.iob instance system.adapter.maxcul.0 terminated due to SIGTERM
      2023-11-03 12:48:36.499  - warn: host.iob instance system.adapter.web.0 terminated due to SIGTERM
      2023-11-03 12:48:36.555  - warn: host.iob instance system.adapter.telegram.0 terminated due to SIGTERM
      2023-11-03 12:48:36.659  - warn: host.iob instance system.adapter.synology.2 terminated due to SIGTERM
      2023-11-03 12:48:36.660  - warn: host.iob instance system.adapter.mihome-vacuum.0 terminated due to SIGTERM
      Hier dieSummary:
                              v.2023-10-10
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            8.3G        484M        6.6G        548K        1.5G        7.8G
      Swap:           4.0G          0B        4.0G
      Total:           12G        484M         10G
      Active iob-Instances:   1
      ioBroker Core:          js-controller           5.0.16
                              admin                   6.12.2
      ioBroker Status:        iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects:                38316
      States:                 42925
      Size of iob-Database:
      19M     /opt/iobroker/iobroker-data/objects.json.old
      9.9M    /opt/iobroker/iobroker-data/states.jsonl
      7.8M    /opt/iobroker/iobroker-data/states.json.migrated
      7.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      2.5M    /opt/iobroker/iobroker-data/states.json.old
      0       /opt/iobroker/iobroker-data/states.json.broken
      Hier das Log aus Zeile 206:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@9.8.1
      2 info using node@v18.18.2
      3 timing npm:load:whichnode Completed in 2ms
      4 timing config:load:defaults Completed in 3ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 2ms
      7 timing config:load:cli Completed in 6ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
      10 timing config:load:project Completed in 8ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 0ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 0ms
      15 timing config:load:setEnvs Completed in 1ms
      16 timing config:load Completed in 22ms
      17 timing npm:load:configload Completed in 22ms
      18 timing config:load:flatten Completed in 4ms
      19 timing npm:load:mkdirpcache Completed in 1ms
      20 timing npm:load:mkdirplogs Completed in 0ms
      21 verbose title npm x @iobroker/jsonltool@latest /opt/iobroker/iobroker-data
      22 verbose argv "x" "--yes" "@iobroker/jsonltool@latest" "/opt/iobroker/iobroker-data"
      23 timing npm:load:setTitle Completed in 1ms
      24 timing npm:load:display Completed in 1ms
      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-11-03T11_49_31_141Z-
      26 verbose logfile /home/iobroker/.npm/_logs/2023-11-03T11_49_31_141Z-debug-0.log
      27 timing npm:load:logFile Completed in 12ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 1ms
      30 timing npm:load Completed in 66ms
      31 silly logfile start cleaning logs, removing 2 files
      32 timing arborist:ctor Completed in 1ms
      33 silly logfile done cleaning log files
      34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.admin
      35 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjsonltool 376ms (cache revalidated)
      36 timing arborist:ctor Completed in 0ms
      37 timing arborist:ctor Completed in 0ms
      38 timing arborist:ctor Completed in 1ms
      39 timing command:x Completed in 6680ms
      40 verbose exit 0
      41 timing npm Completed in 7030ms
      42 info ok
      • haselchen
        haselchen Most Active @guergen last edited by
        @guergen
        Ich würde ins Blaue tippen und node-ssh im Javascript Adapter eintragen. Siehe unten.
        Und dann den Adapter neu starten, wenn er es nicht schon alleine macht.
          guergen @haselchen last edited by
          @haselchen Steht und stand drin:
          • haselchen
            haselchen Most Active last edited by
            @guergen
            dann schreib doch mal
            node-ssh@13.1.0
            rein
              @haselchen sagte in NPM ERR! missing node-ssh@^13.1.0, required by iobroker:
              node-ssh@13.1.0
              Habe jetzt mal node-ssh@13.1.0 eingetragen und iob diag nochmal ausgeführt, dann passte es.
              Aus Neugier wieder den alten Eintrag gemacht (ohne die Versionsnummer):
              Passt immer noch...
              Wer weiss was es war 😉
              Danke!
              • haselchen
                @guergen
                Gern geschehen 😝
