    3. Einsteigerfragen
    4. Installation
    5. Update js-controller - "nodejs is NOT correctly installed"
      George_Best @Thomas Braun last edited by
      @thomas-braun sagte in Update js-controller - "nodejs is NOT correctly installed":
      Dann die .list-Datei mit den Backports löschen. Liegt vermutlich in /etc/apt/sources.list.d
      Und die .list-Datei zum Speedtest muss auch auf bullseye statt stretch lauten.
      da liegt nur:
      nodesource.list
      ookla_speedtest-cli.list
      In der sources.list sind diese Einträge drin:
      deb http://deb.debian.org/debian bullseye-backports main
      deb-src http://deb.debian.org/debian bullseye-backports main
      Soll ich diese Einträge aus der sources.list rausnehmen?
        Thomas Braun Most Active @George_Best last edited by
        @george_best
        Ja. Backports will man eigentlich nicht verwenden.
          @thomas-braun Ich versuch mich mal nun wieder nach oben zu hangeln..
          sudo -H -u iobroker npm install iobroker.js-controller
          sagt nun:
          npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.esphome.git
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
          npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
          npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
          npm ERR! code 6
          npm ERR! path /opt/iobroker/node_modules/iobroker.vis-google-fonts
          npm ERR! command failed
          npm ERR! command sh -c node main.js --install
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T12_24_45_263Z-debug-0.log
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          Qix- created this issue in visionmedia/debug
          closed ReDos Vulnerability Regression Visibility Notice #797
            George_Best @George_Best last edited by
            sehr seltsam... Beim 2.
            wurde der js-controller nun installiert...
              Was für ein Kampf 😧
              Aber letztendlich doch erfolgreich - JS-Controller wurde erfolgreich geupdated.
              @Thomas-Braun Vielen, vielen Dank für deine Hilfe und deine unendliche Geduld 😊
                @george_best
                Gut. Dann schau jetzt per
                iob diag
                über Ganze nochmal drüber.
                  Das sieht es jetzt prinzipiell besser aus...
                  Errors in npm tree:
                  npm ERR! code ELSPROBLEMS
                  npm ERR! invalid: iobroker.vis-materialdesign@0.2.62 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                  npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                  npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                  npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                  npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                  npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_17_056Z-debug-0.log
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.12
                  admin:          6.12.0
                  javascript:     7.1.4
                  npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_25_269Z-debug-0.log
                  Adapters from github:   1
                  Aber den iobroker.vis-materialdesign kann ich nicht entfernen, da scheinbar 50% meiner Vis darauf basieren.
                    Thomas Braun Most Active @George_Best last edited by Thomas Braun
                    @george_best
                    Dann installiere den nochmal.
                    iob upgrade vis-materialdesign@0.5.9
                      George_Best @Thomas Braun last edited by George_Best
                      jonny@ioBroker-V2:~$ iob upgrade vis-materialdesign@0.5.9
                      Adapter "vis-materialdesign" is not in the repository and cannot be updated.
                      Der ist (vermutlich) von hier: https://github.com/Scrounger/ioBroker.vis-materialdesign/blob/master/README.md
                        @george_best
                        Dann zieh das aus npm / Beta rein. Der hat es nie nach Stable gebracht:
                        vis-materialdesign
                        github:	0.5.94
                        latest:	0.5.9 for 29 months
                        stable:	-.-.-
                          @george_best
                          socksv5, ipv6 usw wirst du vermultich nicht gefixt bekommen, das ist alles zu alt und ungewartet.
                          cd /opt/iobroker && npm ls xmlbuilder
                          kann man vielleicht noch angehen.
                          • mcm1957
                            mcm1957 @Thomas Braun last edited by
                            @thomas-braun said in Update js-controller - "nodejs is NOT correctly installed":
                            @george_best
                            socksv5 und ipv6 kommen wahrscheinlich via Telegram Adapter rein.
                            Da ist was im Anmarsch. Wir haben heute entschieden den socks Proxy support aus dem Telegram Adapter rauszuschmeißen da die entsprechenden Module total veraltet sind und kein 1:1 Ersatz existiert. Falls ggF ein zu großer Aufschrei kommt müssen wir Aifwand setzen um eine Ersatzlösung zu implementieren - aber derzeit sind Resoiurcen eher knapp ...
                            4407
