    4. Test Adapter Lgtv v2.3.x
    • Fabio
      Fabio @mcm1957 last edited by
      @mcm57 vielen Dank euch. 👍👌
        Snigga last edited by
        Ich kann leider den Adapter nicht mehr installieren. (Weder über die Adapterliste noch über Github) Im Log steht folgendes.
        Wo ist bei mir der Fehler? Muss ich noch irgendwas vorinstallieren? Iobroker wurde erst kürzlich neu aufgesetzt.
        LG WebOS SmartTV: Verfügbare Version: 2.1.2
        js-controller: 5.0.16
        *** NodeJS-Installation ***
        /usr/bin/nodejs v18.18.2
        /usr/bin/node v18.18.2
        /usr/bin/npm 9.8.1
        /usr/bin/npx 9.8.1
        /usr/bin/corepack 0.19.0
        iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:5467) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-01T21_03_47_957Z-debug-0.log
          Thomas Braun Most Active @Snigga last edited by
          @snigga
          Wie genau installierst du den? Läuft nämlich hier 1A durch:
          echad@chet:/opt/iobroker $ iob url https://github.com/iobroker-community-adapters/ioBroker.lgtv
          install iobroker-community-adapters/ioBroker.lgtv#65177d6a00ac1822e440176a5f2f48df013b3d9b
          NPM version: 10.2.0
          Installing iobroker-community-adapters/ioBroker.lgtv#65177d6a00ac1822e440176a5f2f48df013b3d9b... (System call)
          added 17 packages in 21s
          106 packages are looking for funding
            run `npm fund` for details
          upload [3] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index.html index.html text/html
          upload [2] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
          upload [1] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
          upload [0] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
          mcm1957 S 2 Replies Last reply Reply Quote 0
          • mcm1957
            mcm1957 @Thomas Braun last edited by mcm1957
            Im ersten Beitrag hier https://forum.iobroker.net/topic/3263/lgtv-adapter-zur-steuerung-von-lg-webos-smarttvs/859 stand da noch eine Zeile mehr im Log:
            iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.lgtv.git npm ERR! code 1
            Die Meldung kenn ich nur von github installationen.
            Und bevor wer wegen Doppelpost schreit: ICH habe darume rsucht mit dem Thema in diesen aktuellen Topic zu wechseln. DANKE @snigga und Danke für das Ergänzen der Versionen.
            Und damit es klar ist:
            Der Adapter ist ganz normal im Repository verfügbar. Von einer Installation via Github rate ich explizit AB - dazu sollte es keinen Grund geben !
              Snigga @Thomas Braun last edited by
              @thomas-braun normal über die Adapter. Github habe ich nur versucht, da ich den Fehler bekommen habe.
              • mcm1957
                mcm1957 @Snigga last edited by
                @snigga
                Was (zumindest mir) als Info noch fehlt ist das o/s auf dem das Problem existiert.
                Obwohl bei mir funktioniert die Installation auch auf Windows.
                Ich erspar dann mal Thomas seine Standardbitte 🙂
                Bitte post mal den Output von 'iob diag'. Ev. sieht dann wer was ...
                  Snigga @mcm1957 last edited by
                  @mcm57
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 12 (bookworm)
                            Kernel: Linux 6.1.0-rpi4-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.2
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : armhf
                  Systemuptime and Load:
                   17:36:26 up 7 min,  5 users,  load average: 1.97, 1.34, 0.72
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Fri 2023-11-03 17:36:26 CET
                             Universal time: Fri 2023-11-03 16:36:26 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        1.4G        1.8G         16M        809M        2.5G
                  Swap:           104M          0B        104M
                  Total:          4.1G        1.4G        1.9G
                           3792 M total memory
                           1368 M used memory
                           1459 M active memory
                            369 M inactive memory
                           1743 M free memory
                             85 M buffer memory
                            686 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  980K  379M   1% /run
                  /dev/sda2      ext4       56G  6.4G   47G  12% /
                  tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                  /dev/sda1      vfat      510M  113M  398M  23% /boot/firmware
                  tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
                  [Fri Nov  3 17:29:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:7F:20:A0 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty        1 root=PARTUUID=00401c0a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                  [Fri Nov  3 17:29:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                  [Fri Nov  3 17:29:11 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  TARGET           SOURCE    FSTYPE OPTIONS
                  /                /dev/sda2 ext4   rw,noatime
                  `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  506M    /var/
                  143M    /var/cache
                  137M    /var/lib
                  136M    /var/cache/apt
                  125M    /var/log/journal/2633d84c20934117aaba6d9ff4478d36
                  Archived and active journals take up 124.0M in the file system.
                  /opt/iobroker/backups:
                  285M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  454M    /opt/iobroker/iobroker-data/
                  254M    /opt/iobroker/iobroker-data/files
                  146M    /opt/iobroker/iobroker-data/backup-objects
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  37M     /opt/iobroker/iobroker-data/objects.jsonl
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
                  18M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                          100 /var/lib/dpkg/status
                       18.18.1-1nodesource1 500
                       18.18.0-1nodesource1 500
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0+dfsg1-1+rpi1 500
                          500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Package        s
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin:          6.12.1
                  javascript:     7.1.6
                  Adapters from github:   4
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: ::, run as: admin
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                    system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
                  + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                    system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                    system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                  + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                    system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 - disabled
                    system.adapter.google-sharedlocations.1 : google-sharedlocations: iobroker                                 - disabled
                    system.adapter.history.0                : history               : iobroker                                 - disabled
                    system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
                  + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
                    system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                  + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                  + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
                    system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                    system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.smartgarden.0            : smartgarden           : iobroker                                 - disabled
                    system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                    system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                    system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                    system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
                    system.adapter.vw-connect.1             : vw-connect            : iobroker                                 - disabled
                    system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
                    system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  ioBroker-Repositories
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 6.12.2   , installed 6.12.1 [Updatable]
                  Adapter    "backitup"     : 2.9.1    , installed 2.9.1
                  Adapter    "bosch-ebike"  : 0.1.0    , installed 0.1.0
                  Adapter    "chromecast"   : 3.0.3    , installed 3.1.0
                  Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                  Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                  Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                  Controller "js-controller": 5.0.16   , installed 5.0.16
                  Adapter    "parcel"       : 0.1.6    , installed 0.1.6
                  Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                  Adapter    "roomba"       : 1.2.2    , installed 1.2.2
                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                  Adapter    "senec"        : 1.6.10   , installed 1.6.10
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                  Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                  Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                  Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                  Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                  Adapter    "vw-connect"   : 0.2.0    , installed 0.2.0
                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                  Adapter    "weblogin"     : 0.1.1    , installed 0.1.1
                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                  Objects and States
                  Objects:        55929
                  States:         54865
                  W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                  Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      799/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16701      775/cupsd
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28779      3071/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27459      3071/iobroker.js-co
                  tcp        0      0 0.0.0.0:5999            0.0.0.0:*               LISTEN      0          16048      786/vncserver-virtu
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      799/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16700      775/cupsd
                  tcp6       0      0 :::5999                 :::*                    LISTEN      0          16047      786/vncserver-virtu
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29788      3113/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       29629      3759/io.web.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19526      1068/cups-browsed
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31989      3246/io.chromecast.
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2029       582/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31349      3223/io.shelly.0
                  udp        0      0 0.0.0.0:40621           0.0.0.0:*                           104        2031       582/avahi-daemon: r
                  udp        0      0 0.0.0.0:5999            0.0.0.0:*                           0          16049      786/vncserver-virtu
                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       29249      3200/io.radar2.0
                  udp6       0      0 :::33845                :::*                                104        2032       582/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        2030       582/avahi-daemon: r
                  udp6       0      0 :::5999                 :::*                                0          16050      786/vncserver-virtu
                  2023-11-03 17:38:48.950  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010043-35000262.Position Destination Power: homepilot20.0.Actuator.1010043-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010043-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:48.951  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010045-35000262.Position
                  2023-11-03 17:38:49.254  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010045-35000262.Position Destination Power: homepilot20.0.Actuator.1010045-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010045-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:49.264  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010046-35000262.Position
                  2023-11-03 17:38:49.733  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010046-35000262.Position Destination Power: homepilot20.0.Actuator.1010046-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010046-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:49.734  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010047-35000262.Position
                  2023-11-03 17:38:50.079  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010047-35000262.Position Destination Power: homepilot20.0.Actuator.1010047-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010047-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:50.080  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010049-35000262.Position
                  2023-11-03 17:38:50.432  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010049-35000262.Position Destination Power: homepilot20.0.Actuator.1010049-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010049-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:50.433  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010052-35140462.Position
                  2023-11-03 17:38:50.720  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010052-35140462.Position Destination Power: homepilot20.0.Actuator.1010052-35140462.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010052-35140462.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:50.721  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010063-35000262.Position
                  2023-11-03 17:38:51.217  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010063-35000262.Position Destination Power: homepilot20.0.Actuator.1010063-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010063-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:51.217  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010064-35000262.Position
                  2023-11-03 17:38:51.612  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010064-35000262.Position Destination Power: homepilot20.0.Actuator.1010064-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010064-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:51.613  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010065-35000262.Position
                  2023-11-03 17:38:52.000  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010065-35000262.Position Destination Power: homepilot20.0.Actuator.1010065-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010065-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:38:52.008  - info: cloud.0 (3356) Trying to connect as system.user.admin to cloud
                  2023-11-03 17:38:52.000  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010068-35140462.Position
                  2023-11-03 17:38:52.181  - info: cloud.0 (3356) Connection changed: connect
                  2023-11-03 17:38:52.565  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010068-35140462.Position Destination Power: homepilot20.0.Actuator.1010068-35140462.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010068-35140462.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                  2023-11-03 17:39:05.458  - info: virtualpowermeter.0 (3734) initial completed
                  2023-11-03 17:39:15.049  - info: sourceanalytix.0 (3600) Initialization of 0_userdata.0.HP8620.Info.Scanner_ADF successfully
                  2023-11-03 17:39:15.051  - info: sourceanalytix.0 (3600) Initialising (2 of 47) "0_userdata.0.HP8620.Info.Scanner_Gesamt"
                  2023-11-03 17:39:18.027  - info: statistics.0 (3635) [SETUP] observing 10 values after startup
                  iob diag has finished.
                  Press any key for a summary
                  Copy text starting here:
                                          v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               armhf
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  X-Server:               true
                  Boot Target:            graphical.target
                  Pending OS-Updates:     0
                  Pending iob updates:    1
                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                  Recommended versions are nodejs Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"! and npm
                  MEMORY:
                  Mem:            4.0G        2.0G        1.2G         16M        841M        2.0G
                  Swap:           104M          0B        104M
                  Total:          4.1G        2.0G        1.3G
                  Active iob-Instances:   33
                  ioBroker Core:          js-controller           5.0.16
                                          admin                   6.12.1
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                55929
                  States:                 54865
                  Size of iob-Database:
                  41M     /opt/iobroker/iobroker-data/objects.jsonl
                  21M     /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  pi@iobroker:~ $
                    @snigga
                    Desktop ausschalten, dann den gpg-Schlüssel verschieben.
                    sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                      @thomas-braun Erledigt. Jetzt habe ich aber fehler im iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       18:20:04 up 10 min,  2 users,  load average: 1.85, 2.45, 1.57
                      CPU threads: 4
                      Current issues:
                                     Local time: Fri 2023-11-03 18:20:04 CET
                                 Universal time: Fri 2023-11-03 17:20:04 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            4.0G        2.1G        1.3G        1.0M        644M        1.8G
                      Swap:           104M          0B        104M
                      Total:          4.1G        2.1G        1.4G
                               3792 M total memory
                               2028 M used memory
                               2022 M active memory
                                386 M inactive memory
                               1225 M free memory
                                 52 M buffer memory
                                562 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      tmpfs          tmpfs     380M  912K  379M   1% /run
                      tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                      [Fri Nov  3 18:09:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:7F:20:A0 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty        1 root=PARTUUID=00401c0a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                      [Fri Nov  3 18:09:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                      [Fri Nov  3 18:09:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      /var:
                      522M    /var/
                      143M    /var/cache
                      141M    /var/log/journal/2633d84c20934117aaba6d9ff4478d36
                      141M    /var/log
                      Archived and active journals take up 140.0M in the file system.
                      478M    /opt/iobroker/iobroker-data/
                      58M     /opt/iobroker/iobroker-data/objects.jsonl
                      20M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                      npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/node-addon-api
                      npm ERR! extraneous: node-gyp-build@4.6.1 /opt/iobroker/node_modules/node-gyp-build
                      npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                      npm ERR! missing: mytelegrammenu@^0.0.17, required by iobroker.javascript@7.1.6
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-03T17_20_16_493Z-debug-0.log
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.2
                      javascript:     7.1.6
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                      + system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                      + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                      + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
                      + instance is alive
                      Adapter    "admin"        : 6.12.2   , installed 6.12.2
                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                      Objects and States
                      Objects:        55932
                      States:         54867
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:5999            0.0.0.0:*               LISTEN      0          13212      736/vncserver-virtu
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16884      727/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13236      759/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17545      731/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18492      731/iobroker.js-con
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16883      727/cupsd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24968      2136/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21001      1393/io.web.0
                      tcp6       0      0 :::5999                 :::*                    LISTEN      0          13211      736/vncserver-virtu
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13238      759/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17564      826/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19902      1054/io.chromecast.
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16692      562/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18976      1032/io.shelly.0
                      udp        0      0 0.0.0.0:38704           0.0.0.0:*                           104        16694      562/avahi-daemon: r
                      udp        0      0 0.0.0.0:5999            0.0.0.0:*                           0          13213      736/vncserver-virtu
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       17999      1013/io.radar2.0
                      udp6       0      0 :::5353                 :::*                                104        16693      562/avahi-daemon: r
                      udp6       0      0 :::34220                :::*                                104        16695      562/avahi-daemon: r
                      udp6       0      0 :::5999                 :::*                                0          13214      736/vncserver-virtu
                      2023-11-03 18:18:27.556  - info: statistics.0 (2332) [SETUP] enabled statistics for 0_userdata.0.HP8620.Info.Seite_Gesamt
                      2023-11-03 18:18:27.556  - info: statistics.0 (2332) [SETUP] enabled statistics for 0_userdata.0.HP8620.Info.Seite_SW
                      2023-11-03 18:18:27.557  - info: statistics.0 (2332) [SETUP] enabled statistics for alias.0.Audi.km
                      2023-11-03 18:18:27.558  - info: statistics.0 (2332) [SETUP] enabled statistics for senec.0._api.Anlagen.86808.Dashboard.heute.autarkie
                      2023-11-03 18:18:27.559  - info: statistics.0 (2332) [SETUP] enabled statistics for senec.0._api.Anlagen.86808.Dashboard.heute.speicherfuellstand
                      2023-11-03 18:18:27.560  - info: statistics.0 (2332) [SETUP] enabled statistics for virtualpowermeter.0.group_Licht.Virtual_Energy_Total_group_Licht
                      2023-11-03 18:18:29.984  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapter.search":"l","Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031909970}
                      2023-11-03 18:18:30.808  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapter.search":"lgtv","Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031910800}
                      2023-11-03 18:18:32.863  - info: statistics.0 (2332) [SETUP] observing 10 values after startup
                      2023-11-03 18:18:37.470  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031917464}
                      2023-11-03 18:18:44.095  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031924091}
                      2023-11-03 18:18:46.829  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false","Adapter.search":"l"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031926810}
                      2023-11-03 18:18:47.176  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false","Adapter.search":"lg"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031927143}
                      2023-11-03 18:18:52.548  - info: host.iobroker iobroker add lgtv auto --host iobroker --debug
                      2023-11-03 18:18:57.827  - info: host.iobroker iobroker NPM version: 9.8.1
                      2023-11-03 18:18:57.828  - info: host.iobroker iobroker Installing iobroker.lgtv@2.1.2... (System call)
                      2023-11-03 18:19:14.954  - info: admin.0 (2136) ==> Connected system.user.admin from ::ffff:192.168.188.36
                      2023-11-03 18:19:18.281  - info: host.iobroker iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:2444) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args   'binding.gyp',npm ERR! gyp info spawn args   '-f',npm ERR! gyp info spawn args   'make',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args   '-Dlibrary=shared_library',npm ERR! gyp info spawn args   '-Dvisibility=default',npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args   '-Dnode_engine=v8',npm ERR! gyp info spawn args   '--depth=.',npm ERR! gyp info spawn args   '--no-parallel',npm ERR! gyp info spawn args   '--generator-output',npm ERR! gyp info spawn args   'build',npm ERR! gyp info spawn args   '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_18_59_072Z-debug-0.log
                      2023-11-03 18:19:18.374  - error: host.iobroker iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:2444) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args   'binding.gyp',npm ERR! gyp info spawn args   '-f',npm ERR! gyp info spawn args   'make',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args   '-Dlibrary=shared_library',npm ERR! gyp info spawn args   '-Dvisibility=default',npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args   '-Dnode_engine=v8',npm ERR! gyp info spawn args   '--depth=.',npm ERR! gyp info spawn args   '--no-parallel',npm ERR! gyp info spawn args   '--generator-output',npm ERR! gyp info spawn args   'build',npm ERR! gyp info spawn args   '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_18_59_072Z-debug-0.loghost.iobroker Cannot install iobroker.lgtv@2.1.2: 1
                      2023-11-03 18:19:18.947  - warn: fb-checkpresence.0 (1412) getAllFbObjects: Hostname of fritzbox device FE:6E:FD:F7:AF:21 is empty!
                      2023-11-03 18:19:18.948  - warn: fb-checkpresence.0 (1412) getAllFbObjects: To delete this device in the fritzbox please add the device manually in the fritzbox with a hostname and the shown mac-address. After a reboot you can hopefully delete the device.
                      2023-11-03 18:19:19.769  - info: host.iobroker iobroker exit 25
                      2023-11-03 18:20:04.685  - debug: iot.0 (1226) Data: "Fri Nov 03 2023 18:20:04 GMT 0100 (Mitteleuropäische Normalzeit)"
                                              v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               armhf
                      User-ID:                1000
                      X-Server:               false
                      Pending iob updates:    0
                                              /usr/bin/npm            9.8.1
                                              /usr/bin/npx            9.8.1
                      Recommended versions are nodejs 18.18.2 and npm 9.8.1
                      MEMORY:
                      Mem:            4.0G        1.9G        1.3G        1.0M        853M        2.1G
                      Swap:           104M          0B        104M
                      Total:          4.1G        1.9G        1.4G
                                              admin                   6.12.2
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                55932
                      States:                 54867
                      22M     /opt/iobroker/iobroker-data/states.jsonl
                      pi@iobroker:~ $
                        @snigga
                        Schau mal ob es diese Datei gibt
                        /usr/lib/python3.11/EXTERNALLY-MANAGED
                        Kann u. U. auch statt in python3.11 in einem anderen Verzeichnis liegen.
                          @thomas-braun sagte in Test Adapter Lgtv v2.0.x:
                          existiert
                          pi@iobroker:/usr/lib/python3.11 $ dir
                          abc.py                           enum.py                  os.py             stat.py
                          aifc.py                          EXTERNALLY-MANAGED       _osx_support.py   stringprep.py
                          _aix_support.py                  EXTERNALLY-MANAGED.orig  pathlib.py        string.py
                          antigravity.py                   filecmp.py               pdb.py            _strptime.py
                          argparse.py                      fileinput.py             __phello__        struct.py
                          ast.py                           fnmatch.py               pickle.py         subprocess.py
                          asynchat.py                      fractions.py             pickletools.py    sunau.py
                          asyncio                          ftplib.py                pipes.py          symtable.py
                          asyncore.py                      functools.py             pkgutil.py        _sysconfigdata__arm-linux-gnueabihf.py
                          base64.py                        __future__.py            platform.py       _sysconfigdata__linux_arm-linux-gnueabihf.py
                          bdb.py                           genericpath.py           plistlib.py       sysconfig.py
                          bisect.py                        getopt.py                poplib.py         tabnanny.py
                          _bootsubprocess.py               getpass.py               posixpath.py      tarfile.py
                          bz2.py                           gettext.py               pprint.py         telnetlib.py
                          calendar.py                      glob.py                  profile.py        tempfile.py
                          cgi.py                           graphlib.py              pstats.py         test
                          cgitb.py                         gzip.py                  pty.py            textwrap.py
                          chunk.py                         hashlib.py               _py_abc.py        this.py
                          cmd.py                           heapq.py                 __pycache__       _threading_local.py
                          codecs.py                        __hello__.py             pyclbr.py         threading.py
                          codeop.py                        hmac.py                  py_compile.py     timeit.py
                          code.py                          html                     _pydecimal.py     tkinter
                          collections                      http                     pydoc_data        tokenize.py
                          _collections_abc.py              imaplib.py               pydoc.py          token.py
                          colorsys.py                      imghdr.py                _pyio.py          tomllib
                          _compat_pickle.py                importlib                queue.py          traceback.py
                          compileall.py                    imp.py                   quopri.py         tracemalloc.py
                          _compression.py                  inspect.py               random.py         trace.py
                          concurrent                       io.py                    re                tty.py
                          config-3.11-arm-linux-gnueabihf  ipaddress.py             reprlib.py        turtle.py
                          configparser.py                  json                     rlcompleter.py    types.py
                          contextlib.py                    keyword.py               runpy.py          typing.py
                          contextvars.py                   lib2to3                  sched.py          unittest
                          copy.py                          lib-dynload              secrets.py        urllib
                          copyreg.py                       LICENSE.txt              selectors.py      uuid.py
                          cProfile.py                      linecache.py             shelve.py         uu.py
                          crypt.py                         locale.py                shlex.py          venv
                          csv.py                           logging                  shutil.py         warnings.py
                          ctypes                           lzma.py                  signal.py         wave.py
                          curses                           mailbox.py               _sitebuiltins.py  weakref.py
                          dataclasses.py                   mailcap.py               sitecustomize.py  _weakrefset.py
                          datetime.py                      _markupbase.py           site.py           webbrowser.py
                          dbm                              mimetypes.py             smtpd.py          wsgiref
                          decimal.py                       modulefinder.py          smtplib.py        xdrlib.py
                          difflib.py                       multiprocessing          sndhdr.py         xml
                          dis.py                           netrc.py                 socket.py         xmlrpc
                          dist-packages                    nntplib.py               socketserver.py   zipapp.py
                          distutils                        ntpath.py                sqlite3           zipfile.py
                          _distutils_system_mod.py         nturl2path.py            sre_compile.py    zipimport.py
                          doctest.py                       numbers.py               sre_constants.py  zoneinfo
                          email                            opcode.py                sre_parse.py
                          encodings                        operator.py              ssl.py
                          ensurepip                        optparse.py              statistics.py
                            @snigga sagte in Test Adapter Lgtv v2.0.x:
                            EXTERNALLY-MANAGED
                            sudo rm /usr/lib/python3.11/EXTERNALLY-MANAGED
                            Dann nochmal versuchen den Adapter zu installieren.
                              erledigt jedoch problem ist weiterhin da
                              $ iobroker add lgtv auto --host iobroker --debug
                              NPM version: 9.8.1
                              npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:3508) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_45_47_557Z-debug-0.loghost.iobroker Cannot install iobroker.lgtv@2.1.2: 1
                              ERROR: Process exited with code 25
                                @snigga
                                Keine Ahnung. Läuft hier 1A durch:
                                echad@chet:~ $ iobroker add lgtv --debug
                                NPM version: 10.2.0
                                added 15 packages in 11s
                                108 packages are looking for funding
                                host.chet install adapter lgtv
                                host.chet object system.adapter.lgtv created/updated
                                host.chet create instance lgtv
                                host.chet object system.adapter.lgtv.0.alive created
                                host.chet object system.adapter.lgtv.0.connected created
                                host.chet object system.adapter.lgtv.0.compactMode created
                                host.chet object system.adapter.lgtv.0.cpu created
                                host.chet object system.adapter.lgtv.0.cputime created
                                host.chet object system.adapter.lgtv.0.memHeapUsed created
                                host.chet object system.adapter.lgtv.0.memHeapTotal created
                                host.chet object system.adapter.lgtv.0.memRss created
                                host.chet object system.adapter.lgtv.0.uptime created
                                host.chet object system.adapter.lgtv.0.inputCount created
                                host.chet object system.adapter.lgtv.0.outputCount created
                                host.chet object system.adapter.lgtv.0.eventLoopLag created
                                host.chet object system.adapter.lgtv.0.sigKill created
                                host.chet object system.adapter.lgtv.0.logLevel created
                                host.chet object lgtv.0.info.connection created
                                host.chet object lgtv.0.states created
                                host.chet object lgtv.0.states.on created
                                host.chet object lgtv.0.states.popup created
                                host.chet object lgtv.0.states.turnOff created
                                host.chet object lgtv.0.states.power created
                                host.chet object lgtv.0.states.mute created
                                host.chet object lgtv.0.states.volumeUp created
                                host.chet object lgtv.0.states.volumeDown created
                                host.chet object lgtv.0.states.3Dmode created
                                host.chet object lgtv.0.states.channel created
                                host.chet object lgtv.0.states.channelId created
                                host.chet object lgtv.0.states.channelUp created
                                host.chet object lgtv.0.states.channelDown created
                                host.chet object lgtv.0.states.mediaPlay created
                                host.chet object lgtv.0.states.mediaPause created
                                host.chet object lgtv.0.states.mediaStop created
                                host.chet object lgtv.0.states.mediaFastForward created
                                host.chet object lgtv.0.states.mediaRewind created
                                host.chet object lgtv.0.states.volume created
                                host.chet object lgtv.0.states.input created
                                host.chet object lgtv.0.states.currentApp created
                                host.chet object lgtv.0.states.launch created
                                host.chet object lgtv.0.states.openURL created
                                host.chet object lgtv.0.states.youtube created
                                host.chet object lgtv.0.states.drag created
                                host.chet object lgtv.0.states.scroll created
                                host.chet object lgtv.0.states.click created
                                host.chet object lgtv.0.states.soundOutput created
                                host.chet object lgtv.0.states.raw created
                                host.chet object lgtv.0.remote.power created
                                host.chet object lgtv.0.remote.red created
                                host.chet object lgtv.0.remote.green created
                                host.chet object lgtv.0.remote.yellow created
                                host.chet object lgtv.0.remote.blue created
                                host.chet object lgtv.0.remote.home created
                                host.chet object lgtv.0.remote.menu created
                                host.chet object lgtv.0.remote.cc created
                                host.chet object lgtv.0.remote.back created
                                host.chet object lgtv.0.remote.up created
                                host.chet object lgtv.0.remote.down created
                                host.chet object lgtv.0.remote.left created
                                host.chet object lgtv.0.remote.right created
                                host.chet object lgtv.0.remote.enter created
                                host.chet object lgtv.0.remote.dash created
                                host.chet object lgtv.0.remote.exit created
                                host.chet object lgtv.0.remote.0 created
                                host.chet object lgtv.0.remote.1 created
                                host.chet object lgtv.0.remote.2 created
                                host.chet object lgtv.0.remote.3 created
                                host.chet object lgtv.0.remote.4 created
                                host.chet object lgtv.0.remote.5 created
                                host.chet object lgtv.0.remote.6 created
                                host.chet object lgtv.0.remote.7 created
                                host.chet object lgtv.0.remote.8 created
                                host.chet object lgtv.0.remote.9 created
                                host.chet object lgtv.0.states.mac created
                                host.chet object lgtv.0.states.model created
                                host.chet Set default value of lgtv.0.info.connection: false
                                host.chet object system.adapter.lgtv.0 created
                                echad@chet:~ $
                                  Thomas Braun Most Active last edited by Thomas Braun
                                  node-gyp -v
                                  Hast du das separat installiert?
                                  apt policy node-gyp
                                  • mcm1957
                                    Mir ist das da aufgefallen:
                                    Kann es deiner Meinung nach sein, dass da irgendein Schrott gecashed wird?
                                    Liegt auch unter /home ?!?!
                                    Ev. sagt dir das ja was - ich kenn mich leider mit python null aus.
                                      Thomas Braun Most Active @mcm1957 last edited by
                                      @mcm57 sagte in Test Adapter Lgtv v2.0.x:
                                      Nöööö, das ist normal.
                                      Das Problem hier ist, das python 3.11 erst mit node-gyp >=8 funktioniert.
                                      Beim TE ist aber node-gyp -v v7.1.2 am Start.
                                      S mcm1957 2 Replies Last reply Reply Quote 0
                                        @thomas-braun ich hab nichts installiert raspi os image geflasht und iobroker installiert, danach backupit und das wars
                                          Thomas Braun Most Active @Snigga last edited by Thomas Braun
                                          @snigga
                                          Schau mal in die Datei
                                          /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                          rein und such die Stelle mit
                                          build_file_contents = open (Müsste so um die Zeile 230 herum zu finden sein).
                                          Wenn da
                                          build_file_contents = open(build_file_path, 'rU').read()
                                          drin steht, änder es auf
                                          build_file_contents = open(build_file_path, 'r').read()
                                          ab. Also das U löschen.
                                          • mcm1957
                                            @thomas-braun said in Test Adapter Lgtv v2.0.x:
                                            Kann das irgendwie an den dependencies liegen die der Adapter ausliefert?
                                            Im package-lock hab ich nichts gefunden, außer "node-gyp-build": "^4.3.0", Für node-gyp steht nix drinnen.
                                            1.0k
                                            82
                                            9898
