    4. Test Adapter Lgtv v2.3.x
      Snigga last edited by
      Ich kann leider den Adapter nicht mehr installieren. (Weder über die Adapterliste noch über Github) Im Log steht folgendes.
      Wo ist bei mir der Fehler? Muss ich noch irgendwas vorinstallieren? Iobroker wurde erst kürzlich neu aufgesetzt.
      LG WebOS SmartTV: Verfügbare Version: 2.1.2
      js-controller: 5.0.16
      *** NodeJS-Installation ***
      /usr/bin/nodejs v18.18.2
      /usr/bin/node v18.18.2
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      /usr/bin/corepack 0.19.0
      iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:5467) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-01T21_03_47_957Z-debug-0.log
        Thomas Braun Most Active @Snigga last edited by
        @snigga
        Wie genau installierst du den? Läuft nämlich hier 1A durch:
        echad@chet:/opt/iobroker $ iob url https://github.com/iobroker-community-adapters/ioBroker.lgtv
        install iobroker-community-adapters/ioBroker.lgtv#65177d6a00ac1822e440176a5f2f48df013b3d9b
        NPM version: 10.2.0
        Installing iobroker-community-adapters/ioBroker.lgtv#65177d6a00ac1822e440176a5f2f48df013b3d9b... (System call)
        added 17 packages in 21s
        106 packages are looking for funding
          run `npm fund` for details
        upload [3] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index.html index.html text/html
        upload [2] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
        upload [1] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
        upload [0] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
        mcm1957 S 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @Thomas Braun last edited by mcm1957
          Im ersten Beitrag hier https://forum.iobroker.net/topic/3263/lgtv-adapter-zur-steuerung-von-lg-webos-smarttvs/859 stand da noch eine Zeile mehr im Log:
          iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.lgtv.git npm ERR! code 1
          Die Meldung kenn ich nur von github installationen.
          Und bevor wer wegen Doppelpost schreit: ICH habe darume rsucht mit dem Thema in diesen aktuellen Topic zu wechseln. DANKE @snigga und Danke für das Ergänzen der Versionen.
          Und damit es klar ist:
          Der Adapter ist ganz normal im Repository verfügbar. Von einer Installation via Github rate ich explizit AB - dazu sollte es keinen Grund geben !
            Snigga @Thomas Braun last edited by
            @thomas-braun normal über die Adapter. Github habe ich nur versucht, da ich den Fehler bekommen habe.
            • mcm1957
              mcm1957 @Snigga last edited by
              @snigga
              Was (zumindest mir) als Info noch fehlt ist das o/s auf dem das Problem existiert.
              Obwohl bei mir funktioniert die Installation auch auf Windows.
              Ich erspar dann mal Thomas seine Standardbitte 🙂
              Bitte post mal den Output von 'iob diag'. Ev. sieht dann wer was ...
                Snigga @mcm1957 last edited by
                @mcm57
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 12 (bookworm)
                          Kernel: Linux 6.1.0-rpi4-rpi-v8
                    Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : armhf
                Systemuptime and Load:
                 17:36:26 up 7 min,  5 users,  load average: 1.97, 1.34, 0.72
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2023-11-03 17:36:26 CET
                           Universal time: Fri 2023-11-03 16:36:26 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.0G        1.4G        1.8G         16M        809M        2.5G
                Swap:           104M          0B        104M
                Total:          4.1G        1.4G        1.9G
                         3792 M total memory
                         1368 M used memory
                         1459 M active memory
                          369 M inactive memory
                         1743 M free memory
                           85 M buffer memory
                          686 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  1.6G     0  1.6G   0% /dev
                tmpfs          tmpfs     380M  980K  379M   1% /run
                /dev/sda2      ext4       56G  6.4G   47G  12% /
                tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                /dev/sda1      vfat      510M  113M  398M  23% /boot/firmware
                tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
                [Fri Nov  3 17:29:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:7F:20:A0 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty        1 root=PARTUUID=00401c0a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                [Fri Nov  3 17:29:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                [Fri Nov  3 17:29:11 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                TARGET           SOURCE    FSTYPE OPTIONS
                /                /dev/sda2 ext4   rw,noatime
                `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                506M    /var/
                143M    /var/cache
                137M    /var/lib
                136M    /var/cache/apt
                125M    /var/log/journal/2633d84c20934117aaba6d9ff4478d36
                Archived and active journals take up 124.0M in the file system.
                /opt/iobroker/backups:
                285M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                454M    /opt/iobroker/iobroker-data/
                254M    /opt/iobroker/iobroker-data/files
                146M    /opt/iobroker/iobroker-data/backup-objects
                67M     /opt/iobroker/iobroker-data/files/javascript.admin
                48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                37M     /opt/iobroker/iobroker-data/objects.jsonl
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
                18M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Installed: 18.18.2-1nodesource1
                  Candidate: 18.18.2-1nodesource1
                  Version table:
                 *** 18.18.2-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0+dfsg1-1+rpi1 500
                        500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Package        s
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                admin:          6.12.1
                javascript:     7.1.6
                Adapters from github:   4
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: ::, run as: admin
                  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                  system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                  system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                  system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                  system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 - disabled
                  system.adapter.google-sharedlocations.1 : google-sharedlocations: iobroker                                 - disabled
                  system.adapter.history.0                : history               : iobroker                                 - disabled
                  system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
                + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
                  system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
                  system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                  system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.smartgarden.0            : smartgarden           : iobroker                                 - disabled
                  system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                  system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                  system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                  system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                  system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                  system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
                  system.adapter.vw-connect.1             : vw-connect            : iobroker                                 - disabled
                  system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
                  system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                ioBroker-Repositories
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "admin"        : 6.12.2   , installed 6.12.1 [Updatable]
                Adapter    "backitup"     : 2.9.1    , installed 2.9.1
                Adapter    "bosch-ebike"  : 0.1.0    , installed 0.1.0
                Adapter    "chromecast"   : 3.0.3    , installed 3.1.0
                Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.16   , installed 5.0.16
                Adapter    "parcel"       : 0.1.6    , installed 0.1.6
                Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                Adapter    "roomba"       : 1.2.2    , installed 1.2.2
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "senec"        : 1.6.10   , installed 1.6.10
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
                Adapter    "text2command" : 3.0.2    , installed 3.0.2
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                Adapter    "vw-connect"   : 0.2.0    , installed 0.2.0
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "weblogin"     : 0.1.1    , installed 0.1.1
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Objects and States
                Objects:        55929
                States:         54865
                W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      799/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16701      775/cupsd
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28779      3071/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27459      3071/iobroker.js-co
                tcp        0      0 0.0.0.0:5999            0.0.0.0:*               LISTEN      0          16048      786/vncserver-virtu
                tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      799/sshd: /usr/sbin
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16700      775/cupsd
                tcp6       0      0 :::5999                 :::*                    LISTEN      0          16047      786/vncserver-virtu
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29788      3113/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       29629      3759/io.web.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19526      1068/cups-browsed
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31989      3246/io.chromecast.
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2029       582/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31349      3223/io.shelly.0
                udp        0      0 0.0.0.0:40621           0.0.0.0:*                           104        2031       582/avahi-daemon: r
                udp        0      0 0.0.0.0:5999            0.0.0.0:*                           0          16049      786/vncserver-virtu
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       29249      3200/io.radar2.0
                udp6       0      0 :::33845                :::*                                104        2032       582/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        2030       582/avahi-daemon: r
                udp6       0      0 :::5999                 :::*                                0          16050      786/vncserver-virtu
                2023-11-03 17:38:48.950  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010043-35000262.Position Destination Power: homepilot20.0.Actuator.1010043-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010043-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:48.951  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010045-35000262.Position
                2023-11-03 17:38:49.254  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010045-35000262.Position Destination Power: homepilot20.0.Actuator.1010045-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010045-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:49.264  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010046-35000262.Position
                2023-11-03 17:38:49.733  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010046-35000262.Position Destination Power: homepilot20.0.Actuator.1010046-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010046-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:49.734  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010047-35000262.Position
                2023-11-03 17:38:50.079  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010047-35000262.Position Destination Power: homepilot20.0.Actuator.1010047-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010047-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:50.080  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010049-35000262.Position
                2023-11-03 17:38:50.432  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010049-35000262.Position Destination Power: homepilot20.0.Actuator.1010049-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010049-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:50.433  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010052-35140462.Position
                2023-11-03 17:38:50.720  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010052-35140462.Position Destination Power: homepilot20.0.Actuator.1010052-35140462.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010052-35140462.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:50.721  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010063-35000262.Position
                2023-11-03 17:38:51.217  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010063-35000262.Position Destination Power: homepilot20.0.Actuator.1010063-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010063-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:51.217  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010064-35000262.Position
                2023-11-03 17:38:51.612  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010064-35000262.Position Destination Power: homepilot20.0.Actuator.1010064-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010064-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:51.613  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010065-35000262.Position
                2023-11-03 17:38:52.000  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010065-35000262.Position Destination Power: homepilot20.0.Actuator.1010065-35000262.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010065-35000262.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:38:52.008  - info: cloud.0 (3356) Trying to connect as system.user.admin to cloud
                2023-11-03 17:38:52.000  - info: virtualpowermeter.0 (3734) initial homepilot20.0.Actuator.1010068-35140462.Position
                2023-11-03 17:38:52.181  - info: cloud.0 (3356) Connection changed: connect
                2023-11-03 17:38:52.565  - info: virtualpowermeter.0 (3734) initial done homepilot20.0.Actuator.1010068-35140462.Position Destination Power: homepilot20.0.Actuator.1010068-35140462.Virtual_Energy_Power Destination EnergyTotal: homepilot20.0.Actuator.1010068-35140462.Virtual_Energy_Total Destination Group:  virtualpowermeter.0.group_Licht.
                2023-11-03 17:39:05.458  - info: virtualpowermeter.0 (3734) initial completed
                2023-11-03 17:39:15.049  - info: sourceanalytix.0 (3600) Initialization of 0_userdata.0.HP8620.Info.Scanner_ADF successfully
                2023-11-03 17:39:15.051  - info: sourceanalytix.0 (3600) Initialising (2 of 47) "0_userdata.0.HP8620.Info.Scanner_Gesamt"
                2023-11-03 17:39:18.027  - info: statistics.0 (3635) [SETUP] observing 10 values after startup
                iob diag has finished.
                Press any key for a summary
                Copy text starting here:
                                        v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
                Installation:           native
                Kernel:                 aarch64
                Userland:               armhf
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                X-Server:               true
                Boot Target:            graphical.target
                Pending OS-Updates:     0
                Pending iob updates:    1
                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                Recommended versions are nodejs Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"! and npm
                MEMORY:
                Mem:            4.0G        2.0G        1.2G         16M        841M        2.0G
                Swap:           104M          0B        104M
                Total:          4.1G        2.0G        1.3G
                Active iob-Instances:   33
                ioBroker Core:          js-controller           5.0.16
                                        admin                   6.12.1
                Objects type: jsonl
                States  type: jsonl
                Objects:                55929
                States:                 54865
                Size of iob-Database:
                41M     /opt/iobroker/iobroker-data/objects.jsonl
                21M     /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                pi@iobroker:~ $
                  @snigga
                  Desktop ausschalten, dann den gpg-Schlüssel verschieben.
                  sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                    @thomas-braun Erledigt. Jetzt habe ich aber fehler im iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                     18:20:04 up 10 min,  2 users,  load average: 1.85, 2.45, 1.57
                    CPU threads: 4
                    Current issues:
                                   Local time: Fri 2023-11-03 18:20:04 CET
                               Universal time: Fri 2023-11-03 17:20:04 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            4.0G        2.1G        1.3G        1.0M        644M        1.8G
                    Swap:           104M          0B        104M
                    Total:          4.1G        2.1G        1.4G
                             3792 M total memory
                             2028 M used memory
                             2022 M active memory
                              386 M inactive memory
                             1225 M free memory
                               52 M buffer memory
                              562 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    tmpfs          tmpfs     380M  912K  379M   1% /run
                    tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                    [Fri Nov  3 18:09:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:7F:20:A0 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty        1 root=PARTUUID=00401c0a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                    [Fri Nov  3 18:09:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                    [Fri Nov  3 18:09:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    /var:
                    522M    /var/
                    143M    /var/cache
                    141M    /var/log/journal/2633d84c20934117aaba6d9ff4478d36
                    141M    /var/log
                    Archived and active journals take up 140.0M in the file system.
                    478M    /opt/iobroker/iobroker-data/
                    58M     /opt/iobroker/iobroker-data/objects.jsonl
                    20M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                    npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/node-addon-api
                    npm ERR! extraneous: node-gyp-build@4.6.1 /opt/iobroker/node_modules/node-gyp-build
                    npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
                    npm ERR! missing: mytelegrammenu@^0.0.17, required by iobroker.javascript@7.1.6
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-03T17_20_16_493Z-debug-0.log
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.2
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                    + system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                    + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                    + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
                    + instance is alive
                    Adapter    "admin"        : 6.12.2   , installed 6.12.2
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Objects and States
                    Objects:        55932
                    States:         54867
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:5999            0.0.0.0:*               LISTEN      0          13212      736/vncserver-virtu
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16884      727/cupsd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13236      759/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17545      731/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18492      731/iobroker.js-con
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16883      727/cupsd
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24968      2136/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21001      1393/io.web.0
                    tcp6       0      0 :::5999                 :::*                    LISTEN      0          13211      736/vncserver-virtu
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13238      759/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17564      826/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19902      1054/io.chromecast.
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16692      562/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18976      1032/io.shelly.0
                    udp        0      0 0.0.0.0:38704           0.0.0.0:*                           104        16694      562/avahi-daemon: r
                    udp        0      0 0.0.0.0:5999            0.0.0.0:*                           0          13213      736/vncserver-virtu
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       17999      1013/io.radar2.0
                    udp6       0      0 :::5353                 :::*                                104        16693      562/avahi-daemon: r
                    udp6       0      0 :::34220                :::*                                104        16695      562/avahi-daemon: r
                    udp6       0      0 :::5999                 :::*                                0          13214      736/vncserver-virtu
                    2023-11-03 18:18:27.556  - info: statistics.0 (2332) [SETUP] enabled statistics for 0_userdata.0.HP8620.Info.Seite_Gesamt
                    2023-11-03 18:18:27.556  - info: statistics.0 (2332) [SETUP] enabled statistics for 0_userdata.0.HP8620.Info.Seite_SW
                    2023-11-03 18:18:27.557  - info: statistics.0 (2332) [SETUP] enabled statistics for alias.0.Audi.km
                    2023-11-03 18:18:27.558  - info: statistics.0 (2332) [SETUP] enabled statistics for senec.0._api.Anlagen.86808.Dashboard.heute.autarkie
                    2023-11-03 18:18:27.559  - info: statistics.0 (2332) [SETUP] enabled statistics for senec.0._api.Anlagen.86808.Dashboard.heute.speicherfuellstand
                    2023-11-03 18:18:27.560  - info: statistics.0 (2332) [SETUP] enabled statistics for virtualpowermeter.0.group_Licht.Virtual_Energy_Total_group_Licht
                    2023-11-03 18:18:29.984  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapter.search":"l","Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031909970}
                    2023-11-03 18:18:30.808  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapter.search":"lgtv","Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031910800}
                    2023-11-03 18:18:32.863  - info: statistics.0 (2332) [SETUP] observing 10 values after startup
                    2023-11-03 18:18:37.470  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"true"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031917464}
                    2023-11-03 18:18:44.095  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031924091}
                    2023-11-03 18:18:46.829  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false","Adapter.search":"l"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031926810}
                    2023-11-03 18:18:47.176  - silly: iot.0 (1226) Objects user redis pmessage system.adapter.*/cfg.o.system.adapter.admin.0.guiSettings:{"type":"state","common":{"type":"boolean","read":true,"write":false,"role":"state"},"native":{"localStorage":{"Adapters.updateList":"false","Adapter.search":"lg"},"sessionStorage":{}},"_id":"system.adapter.admin.0.guiSettings","acl":{"object":1638,"state":1638,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1699031927143}
                    2023-11-03 18:18:52.548  - info: host.iobroker iobroker add lgtv auto --host iobroker --debug
                    2023-11-03 18:18:57.827  - info: host.iobroker iobroker NPM version: 9.8.1
                    2023-11-03 18:18:57.828  - info: host.iobroker iobroker Installing iobroker.lgtv@2.1.2... (System call)
                    2023-11-03 18:19:14.954  - info: admin.0 (2136) ==> Connected system.user.admin from ::ffff:192.168.188.36
                    2023-11-03 18:19:18.281  - info: host.iobroker iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:2444) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args   'binding.gyp',npm ERR! gyp info spawn args   '-f',npm ERR! gyp info spawn args   'make',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args   '-Dlibrary=shared_library',npm ERR! gyp info spawn args   '-Dvisibility=default',npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args   '-Dnode_engine=v8',npm ERR! gyp info spawn args   '--depth=.',npm ERR! gyp info spawn args   '--no-parallel',npm ERR! gyp info spawn args   '--generator-output',npm ERR! gyp info spawn args   'build',npm ERR! gyp info spawn args   '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_18_59_072Z-debug-0.log
                    2023-11-03 18:19:18.374  - error: host.iobroker iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:2444) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args   'binding.gyp',npm ERR! gyp info spawn args   '-f',npm ERR! gyp info spawn args   'make',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args   '-I',npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args   '-Dlibrary=shared_library',npm ERR! gyp info spawn args   '-Dvisibility=default',npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args   '-Dnode_engine=v8',npm ERR! gyp info spawn args   '--depth=.',npm ERR! gyp info spawn args   '--no-parallel',npm ERR! gyp info spawn args   '--generator-output',npm ERR! gyp info spawn args   'build',npm ERR! gyp info spawn args   '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_18_59_072Z-debug-0.loghost.iobroker Cannot install iobroker.lgtv@2.1.2: 1
                    2023-11-03 18:19:18.947  - warn: fb-checkpresence.0 (1412) getAllFbObjects: Hostname of fritzbox device FE:6E:FD:F7:AF:21 is empty!
                    2023-11-03 18:19:18.948  - warn: fb-checkpresence.0 (1412) getAllFbObjects: To delete this device in the fritzbox please add the device manually in the fritzbox with a hostname and the shown mac-address. After a reboot you can hopefully delete the device.
                    2023-11-03 18:19:19.769  - info: host.iobroker iobroker exit 25
                    2023-11-03 18:20:04.685  - debug: iot.0 (1226) Data: "Fri Nov 03 2023 18:20:04 GMT 0100 (Mitteleuropäische Normalzeit)"
                                            v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               armhf
                    User-ID:                1000
                    X-Server:               false
                    Pending iob updates:    0
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                    Recommended versions are nodejs 18.18.2 and npm 9.8.1
                    MEMORY:
                    Mem:            4.0G        1.9G        1.3G        1.0M        853M        2.1G
                    Swap:           104M          0B        104M
                    Total:          4.1G        1.9G        1.4G
                                            admin                   6.12.2
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                55932
                    States:                 54867
                    22M     /opt/iobroker/iobroker-data/states.jsonl
                    pi@iobroker:~ $
                      @snigga
                      Schau mal ob es diese Datei gibt
                      /usr/lib/python3.11/EXTERNALLY-MANAGED
                      Kann u. U. auch statt in python3.11 in einem anderen Verzeichnis liegen.
                        @thomas-braun sagte in Test Adapter Lgtv v2.0.x:
                        existiert
                        pi@iobroker:/usr/lib/python3.11 $ dir
                        abc.py                           enum.py                  os.py             stat.py
                        aifc.py                          EXTERNALLY-MANAGED       _osx_support.py   stringprep.py
                        _aix_support.py                  EXTERNALLY-MANAGED.orig  pathlib.py        string.py
                        antigravity.py                   filecmp.py               pdb.py            _strptime.py
                        argparse.py                      fileinput.py             __phello__        struct.py
                        ast.py                           fnmatch.py               pickle.py         subprocess.py
                        asynchat.py                      fractions.py             pickletools.py    sunau.py
                        asyncio                          ftplib.py                pipes.py          symtable.py
                        asyncore.py                      functools.py             pkgutil.py        _sysconfigdata__arm-linux-gnueabihf.py
                        base64.py                        __future__.py            platform.py       _sysconfigdata__linux_arm-linux-gnueabihf.py
                        bdb.py                           genericpath.py           plistlib.py       sysconfig.py
                        bisect.py                        getopt.py                poplib.py         tabnanny.py
                        _bootsubprocess.py               getpass.py               posixpath.py      tarfile.py
                        bz2.py                           gettext.py               pprint.py         telnetlib.py
                        calendar.py                      glob.py                  profile.py        tempfile.py
                        cgi.py                           graphlib.py              pstats.py         test
                        cgitb.py                         gzip.py                  pty.py            textwrap.py
                        chunk.py                         hashlib.py               _py_abc.py        this.py
                        cmd.py                           heapq.py                 __pycache__       _threading_local.py
                        codecs.py                        __hello__.py             pyclbr.py         threading.py
                        codeop.py                        hmac.py                  py_compile.py     timeit.py
                        code.py                          html                     _pydecimal.py     tkinter
                        collections                      http                     pydoc_data        tokenize.py
                        _collections_abc.py              imaplib.py               pydoc.py          token.py
                        colorsys.py                      imghdr.py                _pyio.py          tomllib
                        _compat_pickle.py                importlib                queue.py          traceback.py
                        compileall.py                    imp.py                   quopri.py         tracemalloc.py
                        _compression.py                  inspect.py               random.py         trace.py
                        concurrent                       io.py                    re                tty.py
                        config-3.11-arm-linux-gnueabihf  ipaddress.py             reprlib.py        turtle.py
                        configparser.py                  json                     rlcompleter.py    types.py
                        contextlib.py                    keyword.py               runpy.py          typing.py
                        contextvars.py                   lib2to3                  sched.py          unittest
                        copy.py                          lib-dynload              secrets.py        urllib
                        copyreg.py                       LICENSE.txt              selectors.py      uuid.py
                        cProfile.py                      linecache.py             shelve.py         uu.py
                        crypt.py                         locale.py                shlex.py          venv
                        csv.py                           logging                  shutil.py         warnings.py
                        ctypes                           lzma.py                  signal.py         wave.py
                        curses                           mailbox.py               _sitebuiltins.py  weakref.py
                        dataclasses.py                   mailcap.py               sitecustomize.py  _weakrefset.py
                        datetime.py                      _markupbase.py           site.py           webbrowser.py
                        dbm                              mimetypes.py             smtpd.py          wsgiref
                        decimal.py                       modulefinder.py          smtplib.py        xdrlib.py
                        difflib.py                       multiprocessing          sndhdr.py         xml
                        dis.py                           netrc.py                 socket.py         xmlrpc
                        dist-packages                    nntplib.py               socketserver.py   zipapp.py
                        distutils                        ntpath.py                sqlite3           zipfile.py
                        _distutils_system_mod.py         nturl2path.py            sre_compile.py    zipimport.py
                        doctest.py                       numbers.py               sre_constants.py  zoneinfo
                        email                            opcode.py                sre_parse.py
                        encodings                        operator.py              ssl.py
                        ensurepip                        optparse.py              statistics.py
                          @snigga sagte in Test Adapter Lgtv v2.0.x:
                          EXTERNALLY-MANAGED
                          sudo rm /usr/lib/python3.11/EXTERNALLY-MANAGED
                          Dann nochmal versuchen den Adapter zu installieren.
                            erledigt jedoch problem ist weiterhin da
                            $ iobroker add lgtv auto --host iobroker --debug
                            NPM version: 9.8.1
                            npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:3508) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_45_47_557Z-debug-0.loghost.iobroker Cannot install iobroker.lgtv@2.1.2: 1
                            ERROR: Process exited with code 25
                              @snigga
                              Keine Ahnung. Läuft hier 1A durch:
                              echad@chet:~ $ iobroker add lgtv --debug
                              NPM version: 10.2.0
                              added 15 packages in 11s
                              108 packages are looking for funding
                              host.chet install adapter lgtv
                              host.chet object system.adapter.lgtv created/updated
                              host.chet create instance lgtv
                              host.chet object system.adapter.lgtv.0.alive created
                              host.chet object system.adapter.lgtv.0.connected created
                              host.chet object system.adapter.lgtv.0.compactMode created
                              host.chet object system.adapter.lgtv.0.cpu created
                              host.chet object system.adapter.lgtv.0.cputime created
                              host.chet object system.adapter.lgtv.0.memHeapUsed created
                              host.chet object system.adapter.lgtv.0.memHeapTotal created
                              host.chet object system.adapter.lgtv.0.memRss created
                              host.chet object system.adapter.lgtv.0.uptime created
                              host.chet object system.adapter.lgtv.0.inputCount created
                              host.chet object system.adapter.lgtv.0.outputCount created
                              host.chet object system.adapter.lgtv.0.eventLoopLag created
                              host.chet object system.adapter.lgtv.0.sigKill created
                              host.chet object system.adapter.lgtv.0.logLevel created
                              host.chet object lgtv.0.info.connection created
                              host.chet object lgtv.0.states created
                              host.chet object lgtv.0.states.on created
                              host.chet object lgtv.0.states.popup created
                              host.chet object lgtv.0.states.turnOff created
                              host.chet object lgtv.0.states.power created
                              host.chet object lgtv.0.states.mute created
                              host.chet object lgtv.0.states.volumeUp created
                              host.chet object lgtv.0.states.volumeDown created
                              host.chet object lgtv.0.states.3Dmode created
                              host.chet object lgtv.0.states.channel created
                              host.chet object lgtv.0.states.channelId created
                              host.chet object lgtv.0.states.channelUp created
                              host.chet object lgtv.0.states.channelDown created
                              host.chet object lgtv.0.states.mediaPlay created
                              host.chet object lgtv.0.states.mediaPause created
                              host.chet object lgtv.0.states.mediaStop created
                              host.chet object lgtv.0.states.mediaFastForward created
                              host.chet object lgtv.0.states.mediaRewind created
                              host.chet object lgtv.0.states.volume created
                              host.chet object lgtv.0.states.input created
                              host.chet object lgtv.0.states.currentApp created
                              host.chet object lgtv.0.states.launch created
                              host.chet object lgtv.0.states.openURL created
                              host.chet object lgtv.0.states.youtube created
                              host.chet object lgtv.0.states.drag created
                              host.chet object lgtv.0.states.scroll created
                              host.chet object lgtv.0.states.click created
                              host.chet object lgtv.0.states.soundOutput created
                              host.chet object lgtv.0.states.raw created
                              host.chet object lgtv.0.remote.power created
                              host.chet object lgtv.0.remote.red created
                              host.chet object lgtv.0.remote.green created
                              host.chet object lgtv.0.remote.yellow created
                              host.chet object lgtv.0.remote.blue created
                              host.chet object lgtv.0.remote.home created
                              host.chet object lgtv.0.remote.menu created
                              host.chet object lgtv.0.remote.cc created
                              host.chet object lgtv.0.remote.back created
                              host.chet object lgtv.0.remote.up created
                              host.chet object lgtv.0.remote.down created
                              host.chet object lgtv.0.remote.left created
                              host.chet object lgtv.0.remote.right created
                              host.chet object lgtv.0.remote.enter created
                              host.chet object lgtv.0.remote.dash created
                              host.chet object lgtv.0.remote.exit created
                              host.chet object lgtv.0.remote.0 created
                              host.chet object lgtv.0.remote.1 created
                              host.chet object lgtv.0.remote.2 created
                              host.chet object lgtv.0.remote.3 created
                              host.chet object lgtv.0.remote.4 created
                              host.chet object lgtv.0.remote.5 created
                              host.chet object lgtv.0.remote.6 created
                              host.chet object lgtv.0.remote.7 created
                              host.chet object lgtv.0.remote.8 created
                              host.chet object lgtv.0.remote.9 created
                              host.chet object lgtv.0.states.mac created
                              host.chet object lgtv.0.states.model created
                              host.chet Set default value of lgtv.0.info.connection: false
                              host.chet object system.adapter.lgtv.0 created
                              echad@chet:~ $
                                Thomas Braun Most Active last edited by Thomas Braun
                                node-gyp -v
                                Hast du das separat installiert?
                                apt policy node-gyp
                                • mcm1957
                                  Mir ist das da aufgefallen:
                                  Kann es deiner Meinung nach sein, dass da irgendein Schrott gecashed wird?
                                  Liegt auch unter /home ?!?!
                                  Ev. sagt dir das ja was - ich kenn mich leider mit python null aus.
                                    Thomas Braun Most Active @mcm1957 last edited by
                                    @mcm57 sagte in Test Adapter Lgtv v2.0.x:
                                    Nöööö, das ist normal.
                                    Das Problem hier ist, das python 3.11 erst mit node-gyp >=8 funktioniert.
                                    Beim TE ist aber node-gyp -v v7.1.2 am Start.
                                    S mcm1957 2 Replies Last reply Reply Quote 0
                                      @thomas-braun ich hab nichts installiert raspi os image geflasht und iobroker installiert, danach backupit und das wars
                                        Thomas Braun Most Active @Snigga last edited by Thomas Braun
                                        @snigga
                                        Schau mal in die Datei
                                        /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                        rein und such die Stelle mit
                                        build_file_contents = open (Müsste so um die Zeile 230 herum zu finden sein).
                                        Wenn da
                                        build_file_contents = open(build_file_path, 'rU').read()
                                        drin steht, änder es auf
                                        build_file_contents = open(build_file_path, 'r').read()
                                        ab. Also das U löschen.
                                        • mcm1957
                                          @thomas-braun said in Test Adapter Lgtv v2.0.x:
                                          Kann das irgendwie an den dependencies liegen die der Adapter ausliefert?
                                          Im package-lock hab ich nichts gefunden, außer "node-gyp-build": "^4.3.0", Für node-gyp steht nix drinnen.
                                            @mcm57
                                            node-gyp kommt soweit ich weiß eigentlich (wie npm) beim Paket 'nodejs' huckepack mit. Deswegen ja meine Frage, ob da irgendwas mal nebenher installiert worden ist.
                                            echad@chet:~ $ dpkg -S /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                            nodejs: /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                            echad@chet:~ $ apt policy node-gyp
                                            node-gyp:
                                              Installed: (none)
                                              Candidate: 9.3.0-2
                                              Version table:
                                                 9.3.0-2 500
                                                    500 http://deb.debian.org/debian testing/main arm64 Packages
                                                    500 http://deb.debian.org/debian testing/main armhf Packages
                                            echad@chet:~ $
                                            31.7k
                                            79.8k
                                            76
                                            5989
