    4. Test Adapter Lgtv v2.3.x
      Thomas Braun Most Active @Snigga last edited by
      @snigga
      Schau mal ob es diese Datei gibt
      /usr/lib/python3.11/EXTERNALLY-MANAGED
      Kann u. U. auch statt in python3.11 in einem anderen Verzeichnis liegen.
        Snigga @Thomas Braun last edited by
        @thomas-braun sagte in Test Adapter Lgtv v2.0.x:
        existiert
        pi@iobroker:/usr/lib/python3.11 $ dir
        abc.py                           enum.py                  os.py             stat.py
        aifc.py                          EXTERNALLY-MANAGED       _osx_support.py   stringprep.py
        _aix_support.py                  EXTERNALLY-MANAGED.orig  pathlib.py        string.py
        antigravity.py                   filecmp.py               pdb.py            _strptime.py
        argparse.py                      fileinput.py             __phello__        struct.py
        ast.py                           fnmatch.py               pickle.py         subprocess.py
        asynchat.py                      fractions.py             pickletools.py    sunau.py
        asyncio                          ftplib.py                pipes.py          symtable.py
        asyncore.py                      functools.py             pkgutil.py        _sysconfigdata__arm-linux-gnueabihf.py
        base64.py                        __future__.py            platform.py       _sysconfigdata__linux_arm-linux-gnueabihf.py
        bdb.py                           genericpath.py           plistlib.py       sysconfig.py
        bisect.py                        getopt.py                poplib.py         tabnanny.py
        _bootsubprocess.py               getpass.py               posixpath.py      tarfile.py
        bz2.py                           gettext.py               pprint.py         telnetlib.py
        calendar.py                      glob.py                  profile.py        tempfile.py
        cgi.py                           graphlib.py              pstats.py         test
        cgitb.py                         gzip.py                  pty.py            textwrap.py
        chunk.py                         hashlib.py               _py_abc.py        this.py
        cmd.py                           heapq.py                 __pycache__       _threading_local.py
        codecs.py                        __hello__.py             pyclbr.py         threading.py
        codeop.py                        hmac.py                  py_compile.py     timeit.py
        code.py                          html                     _pydecimal.py     tkinter
        collections                      http                     pydoc_data        tokenize.py
        _collections_abc.py              imaplib.py               pydoc.py          token.py
        colorsys.py                      imghdr.py                _pyio.py          tomllib
        _compat_pickle.py                importlib                queue.py          traceback.py
        compileall.py                    imp.py                   quopri.py         tracemalloc.py
        _compression.py                  inspect.py               random.py         trace.py
        concurrent                       io.py                    re                tty.py
        config-3.11-arm-linux-gnueabihf  ipaddress.py             reprlib.py        turtle.py
        configparser.py                  json                     rlcompleter.py    types.py
        contextlib.py                    keyword.py               runpy.py          typing.py
        contextvars.py                   lib2to3                  sched.py          unittest
        copy.py                          lib-dynload              secrets.py        urllib
        copyreg.py                       LICENSE.txt              selectors.py      uuid.py
        cProfile.py                      linecache.py             shelve.py         uu.py
        crypt.py                         locale.py                shlex.py          venv
        csv.py                           logging                  shutil.py         warnings.py
        ctypes                           lzma.py                  signal.py         wave.py
        curses                           mailbox.py               _sitebuiltins.py  weakref.py
        dataclasses.py                   mailcap.py               sitecustomize.py  _weakrefset.py
        datetime.py                      _markupbase.py           site.py           webbrowser.py
        dbm                              mimetypes.py             smtpd.py          wsgiref
        decimal.py                       modulefinder.py          smtplib.py        xdrlib.py
        difflib.py                       multiprocessing          sndhdr.py         xml
        dis.py                           netrc.py                 socket.py         xmlrpc
        dist-packages                    nntplib.py               socketserver.py   zipapp.py
        distutils                        ntpath.py                sqlite3           zipfile.py
        _distutils_system_mod.py         nturl2path.py            sre_compile.py    zipimport.py
        doctest.py                       numbers.py               sre_constants.py  zoneinfo
        email                            opcode.py                sre_parse.py
        encodings                        operator.py              ssl.py
        ensurepip                        optparse.py              statistics.py
          @snigga sagte in Test Adapter Lgtv v2.0.x:
          EXTERNALLY-MANAGED
          sudo rm /usr/lib/python3.11/EXTERNALLY-MANAGED
          Dann nochmal versuchen den Adapter zu installieren.
            erledigt jedoch problem ist weiterhin da
            $ iobroker add lgtv auto --host iobroker --debug
            NPM version: 9.8.1
            Installing iobroker.lgtv@2.1.2... (System call)
            npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | armnpm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:3508) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-rpi4-rpi-v8npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T17_45_47_557Z-debug-0.loghost.iobroker Cannot install iobroker.lgtv@2.1.2: 1
            ERROR: Process exited with code 25
              @snigga
              Keine Ahnung. Läuft hier 1A durch:
              echad@chet:~ $ iobroker add lgtv --debug
              NPM version: 10.2.0
              added 15 packages in 11s
              108 packages are looking for funding
                run `npm fund` for details
              host.chet install adapter lgtv
              upload [3] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index.html index.html text/html
              upload [2] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
              upload [1] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
              upload [0] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
              host.chet object system.adapter.lgtv created/updated
              host.chet create instance lgtv
              host.chet object system.adapter.lgtv.0.alive created
              host.chet object system.adapter.lgtv.0.connected created
              host.chet object system.adapter.lgtv.0.compactMode created
              host.chet object system.adapter.lgtv.0.cpu created
              host.chet object system.adapter.lgtv.0.cputime created
              host.chet object system.adapter.lgtv.0.memHeapUsed created
              host.chet object system.adapter.lgtv.0.memHeapTotal created
              host.chet object system.adapter.lgtv.0.memRss created
              host.chet object system.adapter.lgtv.0.uptime created
              host.chet object system.adapter.lgtv.0.inputCount created
              host.chet object system.adapter.lgtv.0.outputCount created
              host.chet object system.adapter.lgtv.0.eventLoopLag created
              host.chet object system.adapter.lgtv.0.sigKill created
              host.chet object system.adapter.lgtv.0.logLevel created
              host.chet object lgtv.0.info.connection created
              host.chet object lgtv.0.states created
              host.chet object lgtv.0.states.on created
              host.chet object lgtv.0.states.popup created
              host.chet object lgtv.0.states.turnOff created
              host.chet object lgtv.0.states.power created
              host.chet object lgtv.0.states.mute created
              host.chet object lgtv.0.states.volumeUp created
              host.chet object lgtv.0.states.volumeDown created
              host.chet object lgtv.0.states.3Dmode created
              host.chet object lgtv.0.states.channel created
              host.chet object lgtv.0.states.channelId created
              host.chet object lgtv.0.states.channelUp created
              host.chet object lgtv.0.states.channelDown created
              host.chet object lgtv.0.states.mediaPlay created
              host.chet object lgtv.0.states.mediaPause created
              host.chet object lgtv.0.states.mediaStop created
              host.chet object lgtv.0.states.mediaFastForward created
              host.chet object lgtv.0.states.mediaRewind created
              host.chet object lgtv.0.states.volume created
              host.chet object lgtv.0.states.input created
              host.chet object lgtv.0.states.currentApp created
              host.chet object lgtv.0.states.launch created
              host.chet object lgtv.0.states.openURL created
              host.chet object lgtv.0.states.youtube created
              host.chet object lgtv.0.states.drag created
              host.chet object lgtv.0.states.scroll created
              host.chet object lgtv.0.states.click created
              host.chet object lgtv.0.states.soundOutput created
              host.chet object lgtv.0.states.raw created
              host.chet object lgtv.0.remote.power created
              host.chet object lgtv.0.remote.red created
              host.chet object lgtv.0.remote.green created
              host.chet object lgtv.0.remote.yellow created
              host.chet object lgtv.0.remote.blue created
              host.chet object lgtv.0.remote.home created
              host.chet object lgtv.0.remote.menu created
              host.chet object lgtv.0.remote.cc created
              host.chet object lgtv.0.remote.back created
              host.chet object lgtv.0.remote.up created
              host.chet object lgtv.0.remote.down created
              host.chet object lgtv.0.remote.left created
              host.chet object lgtv.0.remote.right created
              host.chet object lgtv.0.remote.enter created
              host.chet object lgtv.0.remote.dash created
              host.chet object lgtv.0.remote.exit created
              host.chet object lgtv.0.remote.0 created
              host.chet object lgtv.0.remote.1 created
              host.chet object lgtv.0.remote.2 created
              host.chet object lgtv.0.remote.3 created
              host.chet object lgtv.0.remote.4 created
              host.chet object lgtv.0.remote.5 created
              host.chet object lgtv.0.remote.6 created
              host.chet object lgtv.0.remote.7 created
              host.chet object lgtv.0.remote.8 created
              host.chet object lgtv.0.remote.9 created
              host.chet object lgtv.0.states.mac created
              host.chet object lgtv.0.states.model created
              host.chet Set default value of lgtv.0.info.connection: false
              host.chet object system.adapter.lgtv.0 created
              echad@chet:~ $
                Thomas Braun Most Active last edited by Thomas Braun
                node-gyp -v
                Hast du das separat installiert?
                apt policy node-gyp
                • mcm1957
                  mcm1957 @Thomas Braun last edited by
                  Mir ist das da aufgefallen:
                  Kann es deiner Meinung nach sein, dass da irgendein Schrott gecashed wird?
                  Liegt auch unter /home ?!?!
                  Ev. sagt dir das ja was - ich kenn mich leider mit python null aus.
                    Thomas Braun Most Active @mcm1957 last edited by
                    @mcm57 sagte in Test Adapter Lgtv v2.0.x:
                    Nöööö, das ist normal.
                    Das Problem hier ist, das python 3.11 erst mit node-gyp >=8 funktioniert.
                    Beim TE ist aber node-gyp -v v7.1.2 am Start.
                    S mcm1957 2 Replies Last reply Reply Quote 0
                      @thomas-braun ich hab nichts installiert raspi os image geflasht und iobroker installiert, danach backupit und das wars
                        Thomas Braun Most Active @Snigga last edited by Thomas Braun
                        @snigga
                        Schau mal in die Datei
                        /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                        rein und such die Stelle mit
                        build_file_contents = open (Müsste so um die Zeile 230 herum zu finden sein).
                        Wenn da
                        build_file_contents = open(build_file_path, 'rU').read()
                        drin steht, änder es auf
                        build_file_contents = open(build_file_path, 'r').read()
                        ab. Also das U löschen.
                        • mcm1957
                          @thomas-braun said in Test Adapter Lgtv v2.0.x:
                          Kann das irgendwie an den dependencies liegen die der Adapter ausliefert?
                          Im package-lock hab ich nichts gefunden, außer "node-gyp-build": "^4.3.0", Für node-gyp steht nix drinnen.
                            @mcm57
                            node-gyp kommt soweit ich weiß eigentlich (wie npm) beim Paket 'nodejs' huckepack mit. Deswegen ja meine Frage, ob da irgendwas mal nebenher installiert worden ist.
                            echad@chet:~ $ dpkg -S /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                            nodejs: /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                            echad@chet:~ $ apt policy node-gyp
                            node-gyp:
                              Installed: (none)
                              Candidate: 9.3.0-2
                              Version table:
                                 9.3.0-2 500
                                    500 http://deb.debian.org/debian testing/main arm64 Packages
                                    500 http://deb.debian.org/debian testing/main armhf Packages
                            echad@chet:~ $
                              pi@iobroker:~ $ dpkg -S /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                              pi@iobroker:~ $ apt policy node-gyp
                              node-gyp:
                                Installiert:           (keine)
                                Installationskandidat: 9.3.0-2
                                Versionstabelle:
                                   9.3.0-2 500
                                      500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                                pi@iobroker:/opt/iobroker/node_modules $ npm install node-gyp
                                Jetzt kann ich den Adapter wieder installieren
                                  Krys last edited by
                                  Ich hatte mit der neusten Version leider kein Glück.
                                  Der "on"-state wird nicht zuverlässig erkannt bzw. wechselt zwischendurch, obwohl der TV SJ800V an ist, egal in welchem TV-MODE (live-tv, HDMI, Cast)
                                  Der State sagt einem eigens erstellen Datenpunkt, ob der TV an oder aus ist (falls nicht per Alexa eingeschaltet wurde. Wenn "Alexa, Fernseher an", ist klar, dass der Datenpunkt wahr wird und der TV eingeschaltet wird).
                                  Wenn ich den TV per Fernbedienung einschalte, geht der eigene Datenpunkt auf wahr, wechselt aber irgendwann auch wieder auf falsch und die verknüpfte Hintergrundbeleuchtung geht aus. Er geht aber nicht mehr auf wahr, obwohl der TV läuft.
                                  Wenn ich dann per "Alexa, Fernseher aus" sage, passiert logischerweise nichts mehr. Ich muss erst "Alexa, Fernseher an" (obwohl TV an) & dann "Alexa, Fernseher aus" sagen, damit es passt.
                                  Skripte hatte ich bereits neu erstellt/angepasst, aber der Fehler bleibt.
                                  Iobroker läuft unter
                                  Node.js
                                  v18.19.0
                                  NPM
                                  10.2.3
                                  Bin nun wieder auf 1.1.12. Darunter läufts.
                                  • mcm1957
                                    mcm1957 @Krys last edited by
                                    @krys
                                    Gibst dazu dchon ein issue?
                                    Wenn ja schreib bitte deine Erkenntnisse dazu. Wenn nein leg bitte eins an.
                                      Crazy last edited by
                                      Hi, ich habe leider das Problem, dass mein TV mich nach dem einschalten (und sporadisch auch zwischendurch) wieder fragt, ob die die Verbindung ziwschen TV und "Mobilgerät" erlauben möchte.
                                      Adapter version: 2.1.2
                                      JS-Controller version: 4.0.24
                                      Node version: 18.16.1
                                      Operating system: linux
                                      LG webOS version: 6.4.0-15
                                      Kennt jemand eine Lösung für das Problem?
                                      Ich habe bereits in Issue im Github Projekt angelegt.
                                      Abgesehen von der Permission Anfrage funktioniert aber alles soweit.
                                      Thomas Braun Neuschwansteini 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Crazy last edited by
                                        @crazy sagte in Test Adapter Lgtv v2.0.x:
                                        Zunächst einmal den ganzen Sums auf einen aktuellen Stand bringen.
                                        • Neuschwansteini
                                          Neuschwansteini @Crazy last edited by
                                          @crazy
                                          Habe 3 LGTV mit dem Adapter laufen, auf einem habe ich auch das Problem gehabt, dass ich ca 2 Tage lang dauernd mal die Anfrage bestaetigen musste, dann war auf einmal ruhe... bei den anderen war nach 3x fragen Ruhe..
                                          Denke, das liegt evt. auch noch an der Software Version des TV, nicht unbedingt an iobroker.
                                          Welche WebOS Versionen meine haben, kann ich dir leider nicht sagen, da diese nur im Netzwerk hängen und der Adapter diese Info nicht bereitstellt...
                                            Mit Adapter Version 1.1.2 habe ich erstmal Ruhe. Obs wirklich daran liegt oder der TV sich jetzt auch dran "gewöhnt" hat weiß ich allerdings nicht 😁
                                            Neuschwansteini 1 Reply Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            76
                                            5989
