    4. Test Adapter Weather-Warnings
      Thomas Braun Most Active @sigi234 last edited by Thomas Braun
      Wer kann mir denn verraten, warum meine Alexas nicht losquasseln?
      Heute kam über DWD eine Wetterwarnung rein, ich bin aber nicht über Alexa informiert worden.
      Edit: Und mit der Meldung kann ich auch nix anfangen:
      2023-11-03 21:31:15.131  - warn: admin.0 (959) weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      Was ist denn da konkret wo falsch?
        ticaki Developer @sigi234 last edited by
        @sigi234
        Ist Warnung für morgen?
          ticaki Developer @Thomas Braun last edited by
          @thomas-braun sagte in Test Adapter Weather-Warnings:
          Schreib mal was in commands.speak bei Alexa2 in der überallgruppe. Hast keine Ruhezeiten gesetzt?
          Der Fehler ist false positiv.
          https://github.com/ioBroker/adapter-react-v5/issues/195
          foxriver76 created this issue in ioBroker/adapter-react-v5
          closed add component `accordion` to schema #195
            Thomas Braun Most Active @ticaki last edited by
            @ticaki sagte in Test Adapter Weather-Warnings:
            Natürlich nicht. Die soll mich 24/7 informieren.
              sigi234 Forum Testing Most Active @ticaki last edited by sigi234
              @sigi234
              Für Sonntag, aber UWZDE76768
              weather-warnings.0.provider.uwz.UWZATxxxxxxxxx.formatedKeys.00.location
                @sigi234
                Das passt. bei UWZ.at muß man bezahlen wenn man die Warnung für morgen/übermorgen sehen will.
                Und die Warnzelle ist die, die übermittel wurde, das ist häufig nicht die die eingetragen wurde.
                  Was passiert wenn du da drauf drückst: weather-warnings.0.command.alexa2
                    @sigi234
                    Jetzt ist alles klar.
                      Nix.
                      T Thomas Braun 2 Replies Last reply Reply Quote 0
                        ticaki Developer @Thomas Braun last edited by ticaki
                        Nix.
                        ok. Was passiert wenn du alexa2.0.Echo-Devices in dem Echogerät das den common.name Überall hat ind diesen State: alexa2.0.Echo-Devices.IDIDIDID.Commands.speak irgendwas rein schreibst.
                        Ich denke mal auch nix, dann wähle einen andere Gruppe oder einzelne Geräte oder überprüfe in der Alexa App deine Gruppe überall.
                          Thomas Braun Most Active @Thomas Braun last edited by
                          Komm ich nicht mit klar.
                          Bei Ruhezeiten werden irgendwelche Werte reingelesen, die ich nie angegeben habe.
                          2023-11-03 21:47:31.386  - info: weather-warnings.0 (4678) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
                          2023-11-03 21:47:36.472  - info: weather-warnings.0 (4678) Refresh Interval: 15 minutes
                          2023-11-03 21:47:36.739  - info: weather-warnings.0 (4678) DWD activated. Retrieve data.
                          2023-11-03 21:47:36.749  - info: weather-warnings.0 (4678) UWZ activated. Retrieve data.
                          2023-11-03 21:47:42.645  - info: weather-warnings.0 (4678) [provider] Silent time added: Profil: Test start: NaN end: NaN days: null
                          2023-11-03 21:47:42.646  - info: weather-warnings.0 (4678) [provider] Silent time added: Profil: Test start: NaN end: NaN days: null
                          2023-11-03 21:48:01.339  - error: weather-warnings.0 (4678) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-11-03 21:48:01.340  - error: weather-warnings.0 (4678) unhandled promise rejection: Cannot read properties of null (reading 'indexOf')
                          2023-11-03 21:48:01.580  - error: weather-warnings.0 (4678) TypeError: Cannot read properties of null (reading 'indexOf')
                              at ProviderController.setSpeakAllowed (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:937:31)
                              at updateAlertEndless (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:795:20)
                              at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2581:17)
                              at listOnTimeout (node:internal/timers:573:17)
                              at processTimers (node:internal/timers:514:7)
                          2023-11-03 21:48:01.582  - error: weather-warnings.0 (4678) Cannot read properties of null (reading 'indexOf')
                          2023-11-03 21:48:01.599  - info: weather-warnings.0 (4678) terminating
                          2023-11-03 21:48:01.600  - warn: weather-warnings.0 (4678) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2023-11-03 21:48:02.103  - info: weather-warnings.0 (4678) terminating
                          2023-11-03 21:48:02.249  - error: host.chet instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2023-11-03 21:48:34.256  - info: weather-warnings.0 (4757) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
                          2023-11-03 21:48:39.124  - info: weather-warnings.0 (4757) Refresh Interval: 15 minutes
                          2023-11-03 21:48:39.333  - info: weather-warnings.0 (4757) DWD activated. Retrieve data.
                          2023-11-03 21:48:39.343  - info: weather-warnings.0 (4757) UWZ activated. Retrieve data.
                          2023-11-03 21:48:44.524  - info: weather-warnings.0 (4757) [provider] Silent time added: Profil: Test start: NaN end: NaN days: null
                          2023-11-03 21:48:44.529  - info: weather-warnings.0 (4757) [provider] Silent time added: Profil: Test start: NaN end: NaN days: null
                            Jetzt stehe ich gerade auf dem Schlauch. Wieso hast du jetzt einen Fehler da? Das passt nicht wirklich zu unserem aktuellen Gesprächsverlauf.
                              Thomas Braun Most Active @ticaki last edited by Thomas Braun
                              @ticaki
                              Ich klick hier wild durch das GUI. Und das kommt halt im LogFile ums Eck.
                              LOL. Jetzt hab ich es kaputt gemacht und es will nicht mehr:
                              2023-11-03 21:50:02.307  - warn: host.chet Do not restart adapter system.adapter.weather-warnings.0 because restart loop detected
                                Ich arbeite an einer Lösung dafür, aber echt kein Plan wieso weshalb warum... Jetzt werden die Daten von der Config noch genauer geprüft.
                                  @ticaki
                                  Jetzt klemmt alles.
                                  Ruhezeiten kann ich nicht aktualisieren:
                                  Optionen können nicht abgerufen werden, da die Instanz offline ist
                                  Sie startet aber auch nicht mehr.
                                    Ist deine Version von latest oder github?
                                    Wenn github für dich ok ist, installiere mal die aktuelle Version von da. Und keine Panik, dass da ist alles einfach zu lösen. 🙂
                                    Und falls nicht, lade deine Adapterkonfigruation runter, poste sie hier, ich repariere se in ner Minute und du läds sie wieder hoch.
                                      Panik verursachen bei mir andere Dinge als nicht startende ioB-Adapter.
                                        "dwdSelectId": "105315000",
                                        "zamgSelectID": "",
                                        "uwzSelectID": "DE50968",
                                        "useTestWarnings": false,
                                        "dwdEnabled": true,
                                        "uwzEnabled": true,
                                        "zamgEnabled": false,
                                        "refreshTime": 15,
                                        "messageTemplate": [],
                                        "templateTable": [
                                            "templateKey": "NewMessage",
                                            "template": "Warnung: ${Warntypename} ab ${starttime}, Stufe: ${warnlevelcolorname}"
                                            "templateKey": "RemoveMessage",
                                            "template": "Entwarnung: ${Warntypename}, Stufe: ${warnlevelcolorname}"
                                            "templateKey": "RemoveAllMessage",
                                            "template": "Entwarnung!"
                                            "templateKey": "NewJson",
                                            "template": "{ „action“: „${status}“, „start“: „${starttime}“, „ende“: „${endtime}“, \"type\": „${warntypename}“ \\}"
                                            "templateKey": "RemoveJson",
                                            "template": "{ „headline“: „${Headline}“, „status“: „${status}“\\}"
                                            "templateKey": "RemoveAllJson",
                                            "template": "{ \"status\": \"Entwarnung!\"\\}"
                                            "templateKey": "EmailHeader",
                                            "template": "template.EmailHeader"
                                            "templateKey": "EmailMessage",
                                            "template": "template.EmailMessage"
                                            "templateKey": "EmailFooter",
                                            "template": "template.EmailFooter"
                                            "templateKey": "NewMessageWithArray",
                                            "template": "Luke, wir haben eine neue Warnung ${Warntypename} ab ${starttime} erhalten, sieht aus wie ein ${_CustomArray}"
                                            "templateKey": "_CustomArray",
                                            "template": "${[Keks,Sturmtrooper,Tie-Jäger,Imperialer Kreuzer,Todesstern]warnlevelnumber}"
                                        "dwdLanguage": "ger",
                                        "uwzLanguage": "DE",
                                        "zamgLanguage": "de",
                                        "dwdTypeFilter": [],
                                        "zamgTypeFilter": [],
                                        "uwzTypeFilter": [],
                                        "dwdLevelFilter": 0,
                                        "uwzLevelFilter": 0,
                                        "zamgLevelFilter": 0,
                                        "telegram_DwdEnabled": true,
                                        "telegram_UwzEnabled": true,
                                        "telegram_ZamgEnabled": true,
                                        "telegram_TypeFilter": [],
                                        "telegram_LevelFilter": 0,
                                        "telegram_Enabled": false,
                                        "telegram_Adapter": "none",
                                        "telegram_MessageNew": "addedPush",
                                        "telegram_MessageRemove": "removePush",
                                        "telegram_MessageAllRemove": "removeAllPush",
                                        "whatsapp_DwdEnabled": true,
                                        "whatsapp_UwzEnabled": true,
                                        "whatsapp_ZamgEnabled": true,
                                        "whatsapp_TypeFilter": [],
                                        "whatsapp_LevelFilter": 0,
                                        "whatsapp_Enabled": true,
                                        "whatsapp_Adapter": "whatsapp-cmb.0",
                                        "whatsapp_MessageNew": "addedPush",
                                        "whatsapp_MessageRemove": "removePush",
                                        "whatsapp_MessageAllRemove": "removeAllPush",
                                        "pushover_DwdEnabled": true,
                                        "pushover_UwzEnabled": true,
                                        "pushover_ZamgEnabled": true,
                                        "pushover_TypeFilter": [],
                                        "pushover_LevelFilter": 0,
                                        "pushover_Enabled": false,
                                        "pushover_Adapter": "none",
                                        "pushover_MessageNew": "addedPush",
                                        "pushover_MessageRemove": "removePush",
                                        "pushover_MessageAllRemove": "removeAllPush",
                                        "json_DwdEnabled": true,
                                        "json_UwzEnabled": true,
                                        "json_ZamgEnabled": true,
                                        "json_TypeFilter": [],
                                        "json_LevelFilter": 0,
                                        "json_Enabled": false,
                                        "json_MessageNew": "addedPush",
                                        "json_MessageAllRemove": "removeAllPush",
                                        "json_parse": false,
                                        "history_DwdEnabled": true,
                                        "history_UwzEnabled": true,
                                        "history_ZamgEnabled": true,
                                        "history_TypeFilter": [],
                                        "history_LevelFilter": 0,
                                        "history_Enabled": false,
                                        "history_MessageNew": "addedPush",
                                        "history_MessageRemove": "removePush",
                                        "allowedDirs": [
                                            "providerService": "DWD",
                                            "dpWarning": true,
                                            "dpMessage": true,
                                            "dpFormated": true,
                                            "dpAlerts": true
                                            "providerService": "ZAMG",
                                            "dpWarning": true,
                                            "dpMessage": true,
                                            "dpFormated": true,
                                            "dpAlerts": true
                                            "providerService": "UWZ",
                                            "dpWarning": true,
                                            "dpMessage": true,
                                            "dpFormated": true,
                                            "dpAlerts": true
                                        "useJsonHistory": false,
                                        "dwdwarncellTable": [
                                            "dwdSelectId": "805315000",
                                            "dwdCityname": "Köln-Bayenthal"
                                        "uwzwarncellTable": [
                                            "uwzSelectId": "DE50968",
                                            "uwzCityname": "Köln-Bayenthal"
                                        "zamgwarncellTable": [],
                                        "history_allinOne": false,
                                        "email_Adapter": "none",
                                        "email_line_break": "\n",
                                        "email_DwdEnabled": true,
                                        "email_UwzEnabled": true,
                                        "email_ZamgEnabled": true,
                                        "email_TypeFilter": [],
                                        "email_LevelFilter": 0,
                                        "email_Enabled": false,
                                        "email_MessageNew": "addedPush",
                                        "email_MessageRemove": "removePush",
                                        "email_allinOne": false,
                                        "notPushAtStart": true,
                                        "email_Header": "none",
                                        "email_Footer": "none",
                                        "json_MessageAll": "tableNew",
                                        "alexa2_Adapter": "alexa2.0",
                                        "alexa2_DwdEnabled": true,
                                        "alexa2_UwzEnabled": true,
                                        "alexa2_ZamgEnabled": true,
                                        "alexa2_device_ids": [
                                          "f11bc24f45914615a92ba00dcb4ba9d5"
                                        "alexa2_TypeFilter": [],
                                        "alexa2_LevelFilter": 0,
                                        "alexa2_Enabled": true,
                                        "alexa2_MessageNew": "NewMessage",
                                        "alexa2_MessageRemove": "RemoveMessage",
                                        "alexa2_MessageAllRemove": "none",
                                        "alexa2_volumen": 50,
                                        "dwdHourFilter": 0,
                                        "uwzHourFilter": 0,
                                        "zamgHourFilter": 0,
                                        "telegram_ManualTypeFilter": [],
                                        "telegram_ManualLevelFilter": 0,
                                        "telegram_manualAll": "NewMessage",
                                        "whatsapp_ManualTypeFilter": [],
                                        "whatsapp_ManualLevelFilter": 0,
                                        "whatsapp_manualAll": "NewMessage",
                                        "pushover_ManualTypeFilter": [],
                                        "pushover_ManualLevelFilter": 0,
                                        "pushover_manualAll": "NewMessage",
                                        "email_ManualTypeFilter": [],
                                        "email_ManualLevelFilter": 0,
                                        "email_manualAll": "NewMessage",
                                        "alexa2_ManualTypeFilter": [],
                                        "alexa2_ManualLevelFilter": 0,
                                        "alexa2_manualAll": "NewMessage",
                                        "alexa2_sounds": [
                                            "warntypenumber": 1,
                                            "warntype": "Unbekannt",
                                            "sound": ""
                                            "warntypenumber": 2,
                                            "warntype": "Sturm",
                                            "sound": ""
                                            "warntypenumber": 3,
                                            "warntype": "Schneefall",
                                            "sound": ""
                                            "warntypenumber": 4,
                                            "warntype": "Regen",
                                            "sound": ""
                                            "warntypenumber": 5,
                                            "warntype": "Kälte",
                                            "sound": ""
                                            "warntypenumber": 6,
                                            "warntype": "Waldbrand",
                                            "sound": ""
                                            "warntypenumber": 7,
                                            "warntype": "Gewitter",
                                            "sound": ""
                                            "warntypenumber": 8,
                                            "warntype": "Glatteis/rutschig",
                                            "sound": ""
                                            "warntypenumber": 9,
                                            "warntype": "Hitze",
                                            "sound": ""
                                            "warntypenumber": 10,
                                            "warntype": "Hagel",
                                            "sound": ""
                                            "warntypenumber": 11,
                                            "warntype": "Nebel",
                                            "sound": ""
                                            "warntypenumber": 12,
                                            "warntype": "Tauwetter",
                                            "sound": ""
                                            "warntypenumber": 0,
                                            "warntype": "Entwarnung!",
                                            "sound": ""
                                        "templateHelp": "Tokens:\n${altitude}: Warnung gilt ab einer Höhe von (in Metern).\n${cdfuture}: Countdown, Warnung steht bevor.\n${cdhour}: Restzeit-Stunden-Teil. Bis zu 30 * 24 Stunden\n${cdminute}: Restzeit-Minuten-Teil.\n${ceiling}: Warnung gilt ab einer Höhe von (in Metern).\n${countdown}: Zeit bis/vom Start\n${description}: Beschreibung der Warnung.\n${enddate}: Enddatum der Warnung\n${endday}: Tag des Warnungsendes\n${enddayofweek}: End Wochentag lang\n${enddayofweekshort}: End Wochentag kurz\n${enddaytime}: Ende: Tageszeit.\n${endmonth}: Monat des Warnungsendes\n${endtime}: Endzeit der Warnung\n${endtimems}: Endzeit als ms\n${headline}: Überschrift der Warnung\n${htmlicon}: Base64-codierte Symbole mit HTML-Tags.\n${iconurl}: URL zu Wettersymbolen.\n${impact}: Auswirkungen der Warnung.\n${instruction}: Handlungsempfehlungen der Warnung.\n${location}: Standort\n${locationcustom}: Benutzerstandort aus der Konfiguration.\n${provider}: Datenanbieter\n${startadverb}: Anfang: Temporaladverb.\n${startdate}: Beginndatum der Warnung\n${startday}: Tag des Warnstarts.\n${startdayofweek}: Start Wochentag lang\n${startdayofweekshort}: Start Wochentag kurz\n${startdaytime}: Beginn: Tageszeit.\n${startmonth}: Monat des Warnungsbeginns\n${starttime}: Startzeit HH:MM der Warnung\n${starttimems}: Startzeit als ms.\n${status}: Warnzustand.\n${warningcount}: Anzahl der Warnungen\n${warnlevelcolorhex}: Warnstufe als Farbe (hex)\n${warnlevelcolorname}: Warnstufe als Farbname\n${warnlevelname}: Warnstufe als Levelname\n${warnlevelnumber}: Warnstufe als Zahl\n${warntypegeneric}: Generischer Warnungstyp als Nummer.\n${warntypegenericname}: Der generischer Typ der Warnung als Text.\n${warntypename}: Die Art der Warnung als Text.\n${weatheremoji}: Emoji für den Warntyp dieser Nachricht.",
                                        "icon_color": "blue",
                                        "iobrokerUrl": "",
                                        "imExpert": true,
                                        "alexa2_Audio": "",
                                        "alexa2_sounds_enabled": false,
                                        "sayit_Enabled": false,
                                        "sayit_MessageNew": "NewMessage",
                                        "sayit_MessageRemove": "RemoveMessage",
                                        "sayit_MessageAllRemove": "RemoveAllMessage",
                                        "sayit_volumen": 15,
                                        "sayit_manualAll": "NewMessage",
                                        "icons_description": "none, unknown, storm, snowfall, rain, cold, forest_fire, thunderstorm, black_ice_slippery, heat, hail, fog, thaw",
                                        "pushover_Title": "none",
                                        "email_Title": "none",
                                        "silentTime": [
                                            "speakProfile": "Test",
                                            "silentTime": []
                                        "icons_prefix": "",
                                        "icons_suffix": ".png"
                                        Müsste noch wissen ob dein Adapter repo lastest oder github ist
                                          @ticaki
                                          iobroker.weather-warnings@0.4.8 (git+ssh://git@github.com/ticaki/ioBroker.weather-warnings.git#ceeee0eeea798ae2b86796143e547397f1cc6963)
                                            Folgende Frage noch:
                                            1. Der ursprüngliche Fehler ist mit der fast aktuellen Version von Github aufgetreten?
                                            2. Du hast den Adapter manuell nach dem letzten Update von Github restartet?
                                                "zamgSelectID": "",
                                                "dwdEnabled": true,
                                                "uwzEnabled": true,
                                                "refreshTime": 15,
                                                "templateTable": [
                                                "allowedDirs": [
                                                    "dpWarning": true,
                                                    "dpMessage": true,
                                                    "dpFormated": true,
                                                    "dpAlerts": true
                                                    "dpWarning": true,
                                                    "dpMessage": true,
                                                    "dpFormated": true,
                                                    "dpAlerts": true
                                                    "dpWarning": true,
                                                    "dpMessage": true,
                                                    "dpFormated": true,
                                                    "dpAlerts": true
                                                "dwdHourFilter": 0,
                                                "uwzHourFilter": 0,
                                                "alexa2_sounds": [
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                    "sound": ""
                                                "iobrokerUrl": "",
                                                "imExpert": true,
                                                "alexa2_Audio": "",
                                                "silentTime": [],
                                                "icons_prefix": "",
                                            Ich verstehe nicht wie der 4 Zeiten durchlaufen kann. Da war NIX.
                                            1077
                                            269715
