HILFE, kein Zugriff auf IOBroker
iob nodejs-update
@thomas-braun sagte in HILFE, kein Zugriff auf IOBroker:
iob nodejs-update
Läuft nicht wirklich, liegt sicherlich an mir, aber danke für die Geduld!!!
pi@raspberrypi:~ $ iob nodejs-update iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start Starts the js-controller iobroker stop stops the js-controller iobroker restart Restarts js-controller iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host info iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of adapter iobroker install <adapter> Installs a specified adapter iobroker rebuild <adapter>|self Rebuilds a specified adapter iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub iobroker del <adapter> Remove adapter from system iobroker del <adapter>.<instance> Remove adapter instance iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade management iobroker upload Upload management iobroker object Object management iobroker state State management iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file rights iobroker chown <user> <group> <file> Change file ownership iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings of adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate management iobroker clean <yes> Clears all objects and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specified backup iobroker validate <backup name or path> Validate a specified backup iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance iobroker repo [<name>] Show repo information iobroker uuid Show uuid of the installation iobroker unsetup Reset license, installation secret and language iobroker fix Execute the installation fixer script, this updates your ioBroker installation iobroker multihost Multihost management iobroker compact compact group management iobroker plugin Plugin management iobroker version [<adapter>] Show version of js-controller or specified adapter Options: --help Show help [boolean] -v, --version Show version [boolean]
iob stop iob fix iob nodejs-update
Hat geklappt, vielen Dank. Hast Du ne Ahnung warum ich keine neuen Adapter angezeigt bekomme, ich sehe nur die installierten? Ich brauche den Shelly Adapter für meine Heizungs- und Lichtsteuerung.
@tiobb sagte in HILFE, kein Zugriff auf IOBroker:
jo, Du hast einen Filter gesetzt:
Da kommt man einmal zu spät
und die Kiste läuft
Kleiner Tipp... mache Backups zwischendurch und zum Schluss auch noch ...
@djmarc75 sagte in HILFE, kein Zugriff auf IOBroker:
jo, Du hast einen Filter gesetzt:Komisch, da hatte ich ein paar mal drauf geklickt und das hatte nichts geändert
DANKE!
@armilar sagte in HILFE, kein Zugriff auf IOBroker:
und die Kiste läuft
Vor 2 Jahren hatte ich ein Image der Speicherkarte erstellt, aber das zu erstellen dauert jedes mal sehr lange. Gibt es eine einfachere und schnellere Variante?
Wenn dann klickt man immer nur einmal drauf und wartet bis sich die Ansicht aktualisiert (dauert ein wenig)
Den Backitup-Adapter? Der ist genau dafür gemacht.
Wo wir schon beim Neuaufbau des iob sind, gibt es inzwischen eigentlich den Bücherwurm für den Raspberry und wenn nicht soll man dann nicht doch mal den "Normalen" Bücherwurm installieren oder geht da zu viel für den Raspberry verloren?
VG Duffy
Raspberry OS 'Bookworm' ist veröffentlicht.
Was soll denn der 'normale' sein? -
Mit „Normale“ meinte ich das was nicht für den Pi war und schon Mitte des Jahres raus kam.
Wie bekomme ich den Wurm nun auf meinen Pi? So wie von dir damals hier im Forum beschrieben?
Wenn ja, woher weis der Pi dann ob er das „normale“ oder das Pi OS ziehen soll?Du merkst ich bin weit weg von einem Experten
Edit: Habe gerade noch mal deinen Beitrag zum Upgrade gelesen. Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen
, richtig?
Auf meinem Testpi hatte ich mal den „normalen“ Bücherwurm installiert ist es vielleicht ratsam diese Version zu nehmen um eine Neuinstallation zu verhindern?
Ich habe zwar Backups aber never touch a ….. -
@duffy sagte in HILFE, kein Zugriff auf IOBroker:
Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen , richtig?
Am besten.
Aber ich verstehe immer noch nicht, was du mit 'normal' und 'für den Raspberry ' meinst. Es gibt keine zwei Versionen. Lediglich die Raspberry-spezifischen Ergänzungen und Anpassungen wurden erst kürzlich veröffentlicht.
Da war ich wohl zu ungeduldig
MERCI
Danke! Ich dachte es gibt eine "einfache" Möglichkeit das extern zu sichern, falls die SD Karte mal schlapp macht. Aber für den Anfang besser als nichts, und wenn alles läuft mach ich ein Image, und ich werde wohl mal eine SSD statt die SD Karte her nehmen.
Leider bekomme ich den Shelly und das MQTT nicht zum laufen obwohl ich alle Einstellungen so vorgenommen habe wie vor dem Absturz, hatte mir die Einstellungen mal per Screenshot gespeichert.
Wie viel externer als die diversen Möglichkeiten das extern abzulegen soll es denn noch sein? NAS, Google Drive, etc ...
dachte ich könnte es direkt vom Pi extern ablegen.
@tiobb said in HILFE, kein Zugriff auf IOBroker:
Das kannst Du doch im BackItUp-Adapter einstellen. So sicherst Du direkt vom Pi auf irgendwas externes, was Du halt einstellst...
ja und genau dafür gibt es den Backitup Adapter.
? Das macht der Backitup doch. Wenn man den entsprechend einrichtet in regelmäßigen Intervallen vollkommen automatisch.
Dein händisches Image von irgendwas ist dann wieder genauso veraltet wie dein jetziges 'Backup'. -
@Verblizz
@DJMarc75Hab die Einstellungen gefunden und Google Drive aktiviert.
