    4. HILFE, kein Zugriff auf IOBroker
    • tiobb
      tiobb @Thomas Braun last edited by tiobb
      @thomas-braun sagte in HILFE, kein Zugriff auf IOBroker:
      iob nodejs-update
      Läuft nicht wirklich, liegt sicherlich an mir, aber danke für die Geduld!!!
      pi@raspberrypi:~ $ iob nodejs-update
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-controller
        iobroker stop                                                stops the js-controller
        iobroker restart                                             Restarts js-controller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter
        iobroker install <adapter>                                   Installs a specified adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter from system
        iobroker del <adapter>.<instance>                            Remove adapter instance
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
        Thomas Braun Most Active @tiobb last edited by
        @tiobb
        iob stop
        iob fix
        iob nodejs-update
        tiobb 1 Reply Last reply Reply Quote 0
        • tiobb
          Hat geklappt, vielen Dank. Hast Du ne Ahnung warum ich keine neuen Adapter angezeigt bekomme, ich sehe nur die installierten? Ich brauche den Shelly Adapter für meine Heizungs- und Lichtsteuerung.
          DJMarc75 Armilar 2 Replies Last reply Reply Quote 0
          • DJMarc75
            DJMarc75 @tiobb last edited by
            @tiobb sagte in HILFE, kein Zugriff auf IOBroker:
            jo, Du hast einen Filter gesetzt:
            • Armilar
              Armilar Most Active Forum Testing @tiobb last edited by Armilar
              Da kommt man einmal zu spät 😉 und die Kiste läuft 😊 ...
              Kleiner Tipp... mache Backups zwischendurch und zum Schluss auch noch ...
              • tiobb
                tiobb @DJMarc75 last edited by
                @djmarc75 sagte in HILFE, kein Zugriff auf IOBroker:
                Komisch, da hatte ich ein paar mal drauf geklickt und das hatte nichts geändert 🤷‍♂️ DANKE!
                @armilar sagte in HILFE, kein Zugriff auf IOBroker:
                Vor 2 Jahren hatte ich ein Image der Speicherkarte erstellt, aber das zu erstellen dauert jedes mal sehr lange. Gibt es eine einfachere und schnellere Variante?
                DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  Wenn dann klickt man immer nur einmal drauf und wartet bis sich die Ansicht aktualisiert (dauert ein wenig) 😉
                    Den Backitup-Adapter? Der ist genau dafür gemacht.
                    • Duffy
                      Duffy @Thomas Braun last edited by
                      Wo wir schon beim Neuaufbau des iob sind, gibt es inzwischen eigentlich den Bücherwurm für den Raspberry und wenn nicht soll man dann nicht doch mal den "Normalen" Bücherwurm installieren oder geht da zu viel für den Raspberry verloren?
                      VG Duffy
                        Thomas Braun Most Active @Duffy last edited by
                        @duffy
                        Raspberry OS 'Bookworm' ist veröffentlicht.
                        Was soll denn der 'normale' sein?
                        • Duffy
                          Duffy @Thomas Braun last edited by Duffy
                          Mit „Normale“ meinte ich das was nicht für den Pi war und schon Mitte des Jahres raus kam.
                          Wie bekomme ich den Wurm nun auf meinen Pi? So wie von dir damals hier im Forum beschrieben?
                          Wenn ja, woher weis der Pi dann ob er das „normale“ oder das Pi OS ziehen soll?
                          Du merkst ich bin weit weg von einem Experten ☹️
                          Edit: Habe gerade noch mal deinen Beitrag zum Upgrade gelesen. Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen 🙈, richtig?
                          Auf meinem Testpi hatte ich mal den „normalen“ Bücherwurm installiert ist es vielleicht ratsam diese Version zu nehmen um eine Neuinstallation zu verhindern?
                          Ich habe zwar Backups aber never touch a …..
                            @duffy sagte in HILFE, kein Zugriff auf IOBroker:
                            Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen , richtig?
                            Am besten.
                            Aber ich verstehe immer noch nicht, was du mit 'normal' und 'für den Raspberry ' meinst. Es gibt keine zwei Versionen. Lediglich die Raspberry-spezifischen Ergänzungen und Anpassungen wurden erst kürzlich veröffentlicht.
                            • tiobb
                              Da war ich wohl zu ungeduldig 😇 MERCI
                              Danke! Ich dachte es gibt eine "einfache" Möglichkeit das extern zu sichern, falls die SD Karte mal schlapp macht. Aber für den Anfang besser als nichts, und wenn alles läuft mach ich ein Image, und ich werde wohl mal eine SSD statt die SD Karte her nehmen.
                              Leider bekomme ich den Shelly und das MQTT nicht zum laufen obwohl ich alle Einstellungen so vorgenommen habe wie vor dem Absturz, hatte mir die Einstellungen mal per Screenshot gespeichert.
                                Wie viel externer als die diversen Möglichkeiten das extern abzulegen soll es denn noch sein? NAS, Google Drive, etc ...
                                • tiobb
                                  dachte ich könnte es direkt vom Pi extern ablegen.
                                  V DJMarc75 Thomas Braun 3 Replies Last reply Reply Quote 0
                                  • V
                                    Verblizz @tiobb last edited by
                                    @tiobb said in HILFE, kein Zugriff auf IOBroker:
                                    Das kannst Du doch im BackItUp-Adapter einstellen. So sicherst Du direkt vom Pi auf irgendwas externes, was Du halt einstellst...
                                    • DJMarc75
                                      ja und genau dafür gibt es den Backitup Adapter.
                                        @tiobb
                                        ? Das macht der Backitup doch. Wenn man den entsprechend einrichtet in regelmäßigen Intervallen vollkommen automatisch.
                                        Dein händisches Image von irgendwas ist dann wieder genauso veraltet wie dein jetziges 'Backup'.
                                        • tiobb
                                          @Verblizz
                                          @DJMarc75
                                          Hab die Einstellungen gefunden und Google Drive aktiviert.
                                          • Duffy
                                            Dann will ich mal noch kurz meine Unglückliche Formulierung korrigieren 🙂
                                            Mit "normal" meinte ich das Bookworm der OHNE die Raspberry-spezifischen Ergänzungen und Anpassungen.
                                            138
                                            9252
