    4. Blink Camera System
    Blink Camera System
      Thomas Braun Most Active @Gurke258 last edited by
      @gurke258 sagte in Blink Camera System:
      bash: pipx: Kommando nicht gefunden.
      Musst du halt nachinstallieren.
      sudo apt update
      sudo apt install pipx
        @gurke258
        Es funktioniert hier aber auch mal wieder mit pip3:
        echad@chet:~ $ pip3 install blinkpy
        Defaulting to user installation because normal site-packages is not writeable
        Collecting blinkpy
          Using cached blinkpy-0.22.2-py3-none-any.whl.metadata (13 kB)
        Requirement already satisfied: python-dateutil>=2.8.1 in /usr/lib/python3/dist-packages (from blinkpy) (2.8.2)
        Requirement already satisfied: requests>=2.24.0 in /usr/lib/python3/dist-packages (from blinkpy) (2.31.0)
        Collecting python-slugify>=4.0.1 (from blinkpy)
          Using cached python_slugify-8.0.1-py2.py3-none-any.whl (9.7 kB)
        Collecting sortedcontainers~=2.4.0 (from blinkpy)
          Using cached sortedcontainers-2.4.0-py2.py3-none-any.whl (29 kB)
        Collecting aiohttp>=3.8.4 (from blinkpy)
          Using cached aiohttp-3.8.6-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (7.7 kB)
        Collecting aiofiles>=23.1.0 (from blinkpy)
          Using cached aiofiles-23.2.1-py3-none-any.whl.metadata (9.7 kB)
        Collecting attrs>=17.3.0 (from aiohttp>=3.8.4->blinkpy)
          Using cached attrs-23.1.0-py3-none-any.whl (61 kB)
        Requirement already satisfied: charset-normalizer<4.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp>=3.8.4->blinkpy) (3.3.0)
        Collecting multidict<7.0,>=4.5 (from aiohttp>=3.8.4->blinkpy)
          Using cached multidict-6.0.4-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (120 kB)
        Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp>=3.8.4->blinkpy)
          Using cached async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
        Collecting yarl<2.0,>=1.0 (from aiohttp>=3.8.4->blinkpy)
          Using cached yarl-1.9.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (278 kB)
        Collecting frozenlist>=1.1.1 (from aiohttp>=3.8.4->blinkpy)
          Using cached frozenlist-1.4.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (5.2 kB)
        Collecting aiosignal>=1.1.2 (from aiohttp>=3.8.4->blinkpy)
          Using cached aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
        Collecting text-unidecode>=1.3 (from python-slugify>=4.0.1->blinkpy)
          Using cached text_unidecode-1.3-py2.py3-none-any.whl (78 kB)
        Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp>=3.8.4->blinkpy) (3.3)
        Using cached blinkpy-0.22.2-py3-none-any.whl (30 kB)
        Using cached aiofiles-23.2.1-py3-none-any.whl (15 kB)
        Using cached aiohttp-3.8.6-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.1 MB)
        Using cached async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
        Using cached frozenlist-1.4.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (252 kB)
        Installing collected packages: text-unidecode, sortedcontainers, python-slugify, multidict, frozenlist, attrs, async-timeout, aiofiles, yarl, aiosignal, aiohttp, blinkpy
          WARNING: The script slugify is installed in '/home/echad/.local/bin' which is not on PATH.
          Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
        Successfully installed aiofiles-23.2.1 aiohttp-3.8.6 aiosignal-1.3.1 async-timeout-4.0.3 attrs-23.1.0 blinkpy-0.22.2 frozenlist-1.4.0 multidict-6.0.4 python-slugify-8.0.1 sortedcontainers-2.4.0 text-unidecode-1.3 yarl-1.9.2
        echad@chet:~ $
        • Gurke258
          pipx geht bei mmir nicht:
          pi@HomePi:~ $ sudo apt update
          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
          OK:2 http://deb.debian.org/debian bullseye InRelease
          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Holen:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
          Es wurden 4.586 B in 2 s geholt (2.264 B/s).
          Abhängigkeitsbaum wird aufgebaut... Fertig
          Statusinformationen werden eingelesen... Fertig
          Alle Pakete sind aktuell.
          pi@HomePi:~ $ sudo apt install pipx
          E: Paket pipx kann nicht gefunden werden.
          pi@HomePi:~ $
          und mit pip3 ist es installiert:
          pi@HomePi:~ $ pip3 install blinkpy
          Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
          Requirement already satisfied: blinkpy in ./.local/lib/python3.9/site-packages (0.22.2)
          Requirement already satisfied: python-dateutil>=2.8.1 in ./.local/lib/python3.9/site-packages (from blinkpy) (2.8.2)
          Requirement already satisfied: requests>=2.24.0 in /usr/lib/python3/dist-packages (from blinkpy) (2.25.1)
          Requirement already satisfied: python-slugify>=4.0.1 in ./.local/lib/python3.9/site-packages (from blinkpy) (8.0.1)
          Requirement already satisfied: sortedcontainers~=2.4.0 in ./.local/lib/python3.9/site-packages (from blinkpy) (2.4.0)
          Requirement already satisfied: aiohttp>=3.8.4 in ./.local/lib/python3.9/site-packages (from blinkpy) (3.8.6)
          Requirement already satisfied: aiofiles>=23.1.0 in ./.local/lib/python3.9/site-packages (from blinkpy) (23.2.1)
          Requirement already satisfied: attrs>=17.3.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (23.1.0)
          Requirement already satisfied: charset-normalizer<4.0,>=2.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (3.3.2)
          Requirement already satisfied: multidict<7.0,>=4.5 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (6.0.4)
          Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (4.0.3)
          Requirement already satisfied: yarl<2.0,>=1.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.9.2)
          Requirement already satisfied: frozenlist>=1.1.1 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.4.0)
          Requirement already satisfied: aiosignal>=1.1.2 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.3.1)
          Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.8.1->blinkpy) (1.16.0)
          Requirement already satisfied: text-unidecode>=1.3 in ./.local/lib/python3.9/site-packages (from python-slugify>=4.0.1->blinkpy) (1.3)
          Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp>=3.8.4->blinkpy) (2.10)
          pi@HomePi:~ $
            node_14
            Bring das dringend auf nodejs@18.
            pipx gibt es für Bullseye nicht, erst ab 'Bookworm'.
            • Gurke258
              Ist eig auf 18 ^^
              Aber dann muss ich mal schauen das ich den ioBroker sichern kann und auch dann auf dem neuen OS wiederherstellen kann ^^
                @gurke258
                Das ist die FALSCHE Version. Das ist die dfsg-Version.
                iob stop
                iob fix
                iob nodejs-update
                iob start
                • Gurke258
                  Gurke258 @Gurke258 last edited by
                  Okay ist jetzt geupdatet auf 18 😉
                  bekomme aber noch immer den gleichen fehler
                  leider wird ja der IFTTT Service von Amazon nicht mehr unterstützt, weswegen ich jetzt wieder auf die „alte“ Variante zurückgreifen muss. Vorher hatte ich es über Homebridge.
                  Bedauerlicherweise bekomme ich es aber nicht mehr installiert. Habe mir alles von Github geklont, aber die setup.py fehlt leider. Somit funktioniert die alte Anleitung nicht mehr und auch mit
                  Gehts nicht.
                  Bekomme immer folgende Meldung:
                  from blinkpy.blinkpy import Blink ImportError: No module named blinkpy.blinkpy
                  Hier ist mein Code:
                  #!/usr/bin/python3
                  from blinkpy.auth import Auth
                  blink = Blink()
                  auth = Auth({"username": "steven.XXXXXXX@YXXX", "password": "XXXXXX"}, no_prompt=True)
                  blink.auth = auth
                  blink.start()
                  auth.send_auth_key(blink, "EuerKey")
                  blink.setup_post_verify()
                  blink.sync['XXXXX'].arm = True
                  Hat da jmd ne Lösung für mich?
                  EDIT:
                  Habs in den Ordner blinkpy kopiert und dort ausgeführt aber bekomme trotzdem ne Fehlermeldung:_
                  Traceback (most recent call last):
                    File "blinkarm.py", line 2, in <module>
                    File "/home/pi/blinkpy/blinkpy/blinkpy.py", line 83
                      async def refresh(self, force=False, force_cache=False):
                  SyntaxError: invalid syntax
                    @gurke258
                    Gib mal die Langfassung von
                    iob diag
                    bekannt.
                    Gurke258 1 Reply Last reply Reply Quote 0
                      @gurke258
                      Die Readme hast du gelesen?
                      BREAKING CHANGE WARNING: As of 0.22.0 the library uses asyncio which will break any user scripts used prior to this version. Please see the updated examples below and the blinkapp.py or blinksync.py examples in the blinkapp/ directory for examples on how to migrate.
                      Quelle: https://github.com/fronzbot/blinkpy
                      • Gurke258
                        Gurke258 @Thomas Braun last edited by
                        @thomas-braun sagte in Blink Camera System:
                        @gurke258
                        iob diag
                        bekannt.
                        Copy text starting here:
                        			v.2023-10-10
                           Static hostname: HomePi
                                 Icon name: computer
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Installation: 		native
                        Kernel: 		aarch64
                        Userland: 		arm64
                        Timezone: 		Europe/Berlin (CET, +0100)
                        User-ID: 		1000
                        X-Server: 		true
                        Boot Target: 		graphical.target
                        Pending OS-Updates: 	0
                        Pending iob updates: 	0
                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                        			/usr/local/bin/node 		v18.13.0
                        			/usr/local/bin/npm 		8.19.3
                        			/usr/local/bin/npx 		8.19.3
                        			/usr/local/bin/corepack 	0.15.2
                        Recommended versions are nodejs 18.18.2 and npm 9.8.1
                        *** nodejs is NOT correctly installed ***
                        Wrong installation path detected. This needs to be fixed.
                        Please check
                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                        for more information on how to fix these errors.
                        MEMORY:
                        Mem:            3.8G        2.0G        484M         69M        1.3G        1.6G
                        Swap:            99M          0B         99M
                        Total:          3.9G        2.0G        584M
                        Active iob-Instances: 	27
                        Active repo(s): stable
                        ioBroker Core: 		js-controller 		5.0.12
                        			admin 			6.12.0
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : HomePi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : HomePi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects: 		15766
                        States: 		13659
                        Size of iob-Database:
                        15M	/opt/iobroker/iobroker-data/objects.jsonl
                        18M	/opt/iobroker/iobroker-data/states.jsonl
                        Er sagt immer noch das es nicht korrekt installiert wurde 😕
                        • Gurke258
                          @gurke258
                          Hatte ich gelesen und getestet aber auch da nen fehler bekommen. Deswegen wollte ich die alte Version mal testen
                          Thomas Braun P Dr. Bakterius 4 Replies Last reply Reply Quote 0
                            @gurke258
                            Schalt den DESKTOP aus.
                            Und nodejs ist noch falsch installiert.
                            iob nodejs-update
                            Da dann die Pfade reparieren lassen.
                              @gurke258
                              Das war auch nicht die Langfassung.
                              Also nochmal, nachdem nodejs repariert ist.
                                Pischleuder @Gurke258 last edited by
                                @gurke258
                                Moin,
                                die Frage ist, was willst Du noch mit dem alten script ? Das wird so nicht mehr funktionieren, da sich die syntax zum einloggen etc. etwas verändert hat.
                                Nutze doch einfach das homebridge plugin, sofern Du die Anlage scharf oder unscharf schalten möchtest.
                                Gruss
                                • Gurke258
                                  Gurke258 @Pischleuder last edited by
                                  @pischleuder sagte in Blink Camera System:
                                  @gurke258
                                  Moin,
                                  Gruss
                                  Ja mit dem Homebridge funktioniert es bei mir nicht mehr 😕 Keine ahnung warum 😕
                                    Pischleuder @Gurke258 last edited by Pischleuder
                                    @gurke258
                                    welches npm Modul hast Du denn in der Homebridge Instanz eingegeben ?
                                    Es sollte homebridge-blink-for-home@3.9.2 dort stehen und die Instanz im Wrapper Modus
                                    starten.
                                    in der Konfig dann so:
                                    "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                                    "accessories": [],
                                    "platforms": [
                                    "name": "Blink",
                                    "username": "Email-Adresse",
                                    "password": "Dein Passwort",
                                    "pin": "Deine Pin",
                                    "platform": "Blink"
                                    • Dr. Bakterius
                                      Dr. Bakterius Most Active @Gurke258 last edited by
                                      Die alte blinkpy-Version vor dem breaking change? Die kann man mit sudo pip install blinkpy==0.21.0 installieren. Musste ich auch machen, weil ich das Skript auf die v0.22.0 nicht angepasst bekommen habe.
                                      @Thomas-Braun: Gibt es für die Erstellung einer Bildaufnahme eine funktionierende Vorlage? Dann würde ich es vielleicht noch einmal mit der neuen Version testen.
                                      Meine 'bild.py' für v0.21.0 sieht so aus:
                                      import requests
                                      from blinkpy.camera import BlinkCamera
                                      blink = Blink()
                                      auth = Auth({"username": "******", "password": "*******"}, no_prompt=True)
                                      blink.auth = auth
                                      blink.start()
                                      auth.send_auth_key(blink, "******")
                                      bild = '/opt/iobroker/blink.jpg'
                                      for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
                                      camera = blink.cameras['Eingangstuere']
                                      camera.snap_picture()
                                      blink.refresh()
                                      camera.image_to_file(bild)
                                      Thomas Braun Gurke258 P 3 Replies Last reply Reply Quote 0
                                      • Gurke258
                                        Gurke258 @Pischleuder last edited by Gurke258
                                        @gurke258
                                        starten.
                                        "accessories": [],
                                        "platforms": [
                                        "name": "Blink",
                                        "pin": "Deine Pin",
                                        "platform": "Blink"
                                        So habe ich es jetzt eingestellt aber ich bekomme in der Config folgende Meldung:
                                        Either the "platform" or "accessory" property must be set
                                        EDIT: Okay ich denke ich habe es hinbekommen!.. Ist aber sehr träge im Vergleich zu vorher. 😕
                                          Thomas Braun Most Active @Dr. Bakterius last edited by
                                          @dr-bakterius sagte in Blink Camera System:
                                          Keine Ahnung. Ich hab keine Blink Camera im Einsatz.
                                          • Gurke258
                                            @gurke258
                                            Sorry. Hier bitte 🙂
                                            Skript v.2023-10-10
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm64
                                            Model		: Raspberry Pi 4 Model B Rev 1.1
                                            Docker          : false
                                            Virtualization  : none
                                            Kernel          : aarch64
                                            Userland        : arm64
                                            Systemuptime and Load:
                                             10:25:29 up  5:25,  2 users,  load average: 1.50, 1.40, 1.31
                                            CPU threads: 4
                                            *** RASPBERRY THROTTLING ***
                                            Current issues:
                                            Previously detected issues:
                                            *** Time and Time Zones ***
                                                           Local time: Sun 2023-11-05 10:25:29 CET
                                                       Universal time: Sun 2023-11-05 09:25:29 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** User and Groups ***
                                            pi
                                            /home/pi
                                            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                            *** X-Server-Setup ***
                                            X-Server: 	true
                                            Desktop: 	LXDE-pi
                                            Terminal: 	x11
                                            *** MEMORY ***
                                            Mem:            3.8G        2.3G        505M        164M        965M        1.2G
                                            Swap:            99M          0B         99M
                                            Total:          3.9G        2.3G        605M
                                                     3794 M total memory
                                                     2323 M used memory
                                                     2886 M active memory
                                                       65 M inactive memory
                                                      504 M free memory
                                                        9 M buffer memory
                                                      956 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FAILED SERVICES ***
                                            0 loaded units listed.
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       29G   14G   15G  48% /
                                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                            tmpfs          tmpfs     1.9G   20M  1.9G   2% /dev/shm
                                            tmpfs          tmpfs     759M  976K  758M   1% /run
                                            /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                                            tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                                            [Sun Nov  5 05:00:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:63:9E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f229ca1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                            [Sun Nov  5 05:00:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [Sun Nov  5 05:00:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [Sun Nov  5 05:00:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                            TARGET  SOURCE         FSTYPE OPTIONS
                                            /       /dev/mmcblk0p2 ext4   rw,noatime
                                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                            /var:
                                            5.4G	/var/
                                            3.1G	/var/log/journal/c82d6a18bd344322b99e963f9b19b8e6
                                            3.1G	/var/log
                                            1.8G	/var/cache/apt
                                            Archived and active journals take up 3.0G in the file system.
                                            /opt/iobroker/backups:
                                            106M	/opt/iobroker/backups/
                                            /opt/iobroker/iobroker-data:
                                            668M	/opt/iobroker/iobroker-data/
                                            498M	/opt/iobroker/iobroker-data/files
                                            98M	/opt/iobroker/iobroker-data/files/vis-2-beta
                                            72M	/opt/iobroker/iobroker-data/files/telegram.admin
                                            71M	/opt/iobroker/iobroker-data/node-red/node_modules
                                            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                            21M	/opt/iobroker/iobroker-data/objects.jsonl
                                            21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                            19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                            18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                            USB-Devices by-id:
                                            *** NodeJS-Installation ***
                                            /usr/bin/node 		v18.18.2
                                            /usr/bin/npm 		9.8.1
                                            /usr/bin/npx 		9.8.1
                                            /usr/bin/corepack 	0.19.0
                                            nodejs:
                                              Installed: 18.18.2-1nodesource1
                                              Candidate: 18.18.2-1nodesource1
                                              Version table:
                                             *** 18.18.2-1nodesource1 1001
                                                    100 /var/lib/dpkg/status
                                                 18.18.1-1nodesource1 1001
                                                 18.18.0-1nodesource1 1001
                                                 18.17.1-1nodesource1 1001
                                                 18.17.0-1nodesource1 1001
                                                 18.16.1-1nodesource1 1001
                                                 18.16.0-1nodesource1 1001
                                                 18.15.0-1nodesource1 1001
                                                 18.14.2-1nodesource1 1001
                                                 18.14.1-1nodesource1 1001
                                                 18.14.0-1nodesource1 1001
                                                 18.13.0-1nodesource1 1001
                                                 18.12.0-1nodesource1 1001
                                                 18.11.0-1nodesource1 1001
                                                 18.10.0-1nodesource1 1001
                                                 18.9.1-1nodesource1 1001
                                                 18.9.0-1nodesource1 1001
                                                 18.8.0-1nodesource1 1001
                                                 18.7.0-1nodesource1 1001
                                                 18.6.0-1nodesource1 1001
                                                 18.5.0-1nodesource1 1001
                                                 18.4.0-1nodesource1 1001
                                                 18.3.0-1nodesource1 1001
                                                 18.2.0-1nodesource1 1001
                                                 18.1.0-1nodesource1 1001
                                                 18.0.0-1nodesource1 1001
                                                 12.22.12~dfsg-1~deb11u4 500
                                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                            No problems detected
                                            Errors in npm tree:
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Core adapters versions
                                            js-controller: 	5.0.12
                                            admin: 		6.12.0
                                            javascript: 	7.1.4
                                            Adapters from github: 	0
                                            Adapter State
                                            + system.adapter.alexa2.0                 : alexa2                : HomePi                                   -  enabled
                                            + system.adapter.backitup.0               : backitup              : HomePi                                   -  enabled
                                            + system.adapter.bring.0                  : bring                 : HomePi                                   -  enabled
                                              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: HomePi                                   -  enabled
                                              system.adapter.daswetter.0              : daswetter             : HomePi                                   -  enabled
                                              system.adapter.devices.0                : devices               : HomePi                                   - disabled
                                            + system.adapter.discovergy.0             : discovergy            : HomePi                                   -  enabled
                                            + system.adapter.discovery.0              : discovery             : HomePi                                   -  enabled
                                              system.adapter.dwd.0                    : dwd                   : HomePi                                   -  enabled
                                            + system.adapter.ham.0                    : ham                   : HomePi                                   -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : HomePi                                   -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : HomePi                                   -  enabled, port: 18701
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : HomePi                                   -  enabled, port: 12001
                                              system.adapter.ical.0                   : ical                  : HomePi                                   -  enabled
                                              system.adapter.ical.1                   : ical                  : HomePi                                   -  enabled
                                              system.adapter.icons-material-svg.0     : icons-material-svg    : HomePi                                   -  enabled
                                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomePi                                   - disabled
                                              system.adapter.influxdb.0               : influxdb              : HomePi                                   - disabled, port: 8086
                                            + system.adapter.info.0                   : info                  : HomePi                                   -  enabled
                                            + system.adapter.iot.0                    : iot                   : HomePi                                   -  enabled
                                            + system.adapter.javascript.0             : javascript            : HomePi                                   -  enabled
                                            + system.adapter.netatmo.0                : netatmo               : HomePi                                   -  enabled
                                            + system.adapter.nina.0                   : nina                  : HomePi                                   -  enabled
                                            + system.adapter.node-red.0               : node-red              : HomePi                                   -  enabled, port: 1880, bind: 192.168.178.79
                                            + system.adapter.ping.0                   : ping                  : HomePi                                   -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : HomePi                                   -  enabled
                                            + system.adapter.smartthings.0            : smartthings           : HomePi                                   -  enabled
                                              system.adapter.spotify-premium.0        : spotify-premium       : HomePi                                   - disabled
                                            + system.adapter.synology.0               : synology              : HomePi                                   -  enabled, port: 5001
                                              system.adapter.systeminfo.0             : systeminfo            : HomePi                                   - disabled
                                              system.adapter.tankerkoenig.0           : tankerkoenig          : HomePi                                   - disabled
                                            + system.adapter.telegram.0               : telegram              : HomePi                                   -  enabled, port: 8443, bind: 0.0.0.0
                                            + system.adapter.text2command.0           : text2command          : HomePi                                   -  enabled
                                            + system.adapter.trashschedule.0          : trashschedule         : HomePi                                   -  enabled
                                            + system.adapter.tuya.0                   : tuya                  : HomePi                                   -  enabled
                                              system.adapter.vis-2-beta.0             : vis-2-beta            : HomePi                                   - disabled
                                              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : HomePi                                   -  enabled
                                              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : HomePi                                   -  enabled
                                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: HomePi                                   -  enabled
                                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomePi                                   -  enabled
                                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomePi                                   - disabled
                                              system.adapter.vis-icontwo.0            : vis-icontwo           : HomePi                                   - disabled
                                            + system.adapter.vis-inventwo.0           : vis-inventwo          : HomePi                                   -  enabled
                                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomePi                                   - disabled
                                              system.adapter.vis-keyboard.0           : vis-keyboard          : HomePi                                   - disabled
                                              system.adapter.vis-material-advanced.0  : vis-material-advanced : HomePi                                   - disabled
                                              system.adapter.vis-metro.0              : vis-metro             : HomePi                                   - disabled
                                              system.adapter.vis-rgraph.0             : vis-rgraph            : HomePi                                   -  enabled
                                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomePi                                   - disabled
                                              system.adapter.vis.0                    : vis                   : HomePi                                   -  enabled
                                            + instance is alive
                                            ioBroker-Repositories
                                            Installed ioBroker-Instances
                                            Used repository: stable
                                            Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                            Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                            Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
                                            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                            Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                            Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                            Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                            Adapter    "hid-community": 0.3.0    , installed 0.3.0
                                            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                            Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                            Controller "js-controller": 5.0.12   , installed 5.0.12
                                            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                            Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                            Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                            Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                            Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                                            Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                            Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                            Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                            Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
                                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                            Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                            Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                                            Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                            Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                            Objects and States
                                            Objects: 	15792
                                            States: 	13665
                                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Reading package lists...
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15591      542/cupsd
                                            tcp        0      0 192.168.178.79:18701    0.0.0.0:*               LISTEN      1001       280874     29233/io.hm-rpc.0
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       280609     29088/iobroker.js-c
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       280616     29088/iobroker.js-c
                                            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16404      578/vncserver-x11-c
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13802      606/sshd: /usr/sbin
                                            tcp        0      0 192.168.178.79:1880     0.0.0.0:*               LISTEN      1001       279873     29195/node-red
                                            tcp        0      0 192.168.178.79:12001    0.0.0.0:*               LISTEN      1001       280923     29256/io.hm-rpc.1
                                            tcp6       0      0 :::3310                 :::*                    LISTEN      115        15720      661/mariadbd
                                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15590      542/cupsd
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       278103     29109/io.admin.0
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       283724     29863/io.web.0
                                            tcp6       0      0 :::5900                 :::*                    LISTEN      0          16403      578/vncserver-x11-c
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          13804      606/sshd: /usr/sbin
                                            tcp6       0      0 :::80                   :::*                    LISTEN      0          16428      687/apache2
                                            udp        0      0 0.0.0.0:53157           0.0.0.0:*                           108        14400      407/avahi-daemon: r
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16455      485/dhcpcd
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       279265     29478/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       279266     29478/io.tuya.0
                                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14572      666/cups-browsed
                                            udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303130     32252/chromium-brow
                                            udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303128     32252/chromium-brow
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14398      407/avahi-daemon: r
                                            udp6       0      0 :::546                  :::*                                0          13950      485/dhcpcd
                                            udp6       0      0 :::37916                :::*                                108        14401      407/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                108        14399      407/avahi-daemon: r
                                            2023-11-05 10:19:34.236  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name: value = Blink Flur Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                            2023-11-05 10:19:34.259  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name {"val":"Blink Flur Privacy Mode","ack":true,"ts":1699175968047,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092789}
                                            2023-11-05 10:19:34.306  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                            2023-11-05 10:19:34.334  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On {"val":false,"ack":true,"ts":1699175968067,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092845}
                                            2023-11-05 10:19:37.943  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699175977940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175977940}
                                            2023-11-05 10:19:41.270  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699175981267,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175977940}
                                            2023-11-05 10:19:56.106  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699175996101,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175996101}
                                            2023-11-05 10:19:56.129  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699175996125,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175996101}
                                            2023-11-05 10:20:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32168
                                            2023-11-05 10:20:03.699  - info: dwd.0 (32168) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-05 10:20:06.936  - info: dwd.0 (32168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2023-11-05 10:20:07.480  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2023-11-05 10:20:36.192  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176036188,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176036188}
                                            2023-11-05 10:20:36.215  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176036210,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176036188}
                                            2023-11-05 10:20:41.279  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699176041276,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176041276}
                                            2023-11-05 10:20:44.229  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699176044225,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176041276}
                                            2023-11-05 10:20:53.611  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176053606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176053606}
                                            2023-11-05 10:20:53.683  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176053678,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176053606}
                                            2023-11-05 10:21:32.141  - info: web.0 (29863) ==> Connected system.user.admin from ::ffff:192.168.178.79
                                            2023-11-05 10:23:41.482  - info: admin.0 (29109) ==> Connected system.user.admin from ::ffff:192.168.178.123
                                            2023-11-05 10:23:49.815  - info: admin.0 (29109) <== Disconnect system.user.admin from ::ffff:192.168.178.123
                                            2023-11-05 10:25:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32832
                                            2023-11-05 10:25:03.554  - info: dwd.0 (32832) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-05 10:25:06.028  - info: dwd.0 (32832) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2023-11-05 10:25:06.573  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            [/s]
                                            blink xt camera
                                            63
                                            406
                                            117089
