    4. Blink Camera System
    Blink Camera System
    • Gurke258
      Gurke258 @Thomas Braun last edited by
      @thomas-braun sagte in Blink Camera System:
      @gurke258
      Gib mal die Langfassung von
      iob diag
      bekannt.
      Copy text starting here:
      			v.2023-10-10
         Static hostname: HomePi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
      			/usr/local/bin/node 		v18.13.0
      			/usr/local/bin/npm 		8.19.3
      			/usr/local/bin/npx 		8.19.3
      			/usr/local/bin/corepack 	0.15.2
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            3.8G        2.0G        484M         69M        1.3G        1.6G
      Swap:            99M          0B         99M
      Total:          3.9G        2.0G        584M
      Active iob-Instances: 	27
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.12
      			admin 			6.12.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : HomePi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : HomePi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		15766
      States: 		13659
      Size of iob-Database:
      15M	/opt/iobroker/iobroker-data/objects.jsonl
      18M	/opt/iobroker/iobroker-data/states.jsonl
      Er sagt immer noch das es nicht korrekt installiert wurde 😕
      • Gurke258
        @gurke258
        Die Readme hast du gelesen?
        BREAKING CHANGE WARNING: As of 0.22.0 the library uses asyncio which will break any user scripts used prior to this version. Please see the updated examples below and the blinkapp.py or blinksync.py examples in the blinkapp/ directory for examples on how to migrate.
        Quelle: https://github.com/fronzbot/blinkpy
        Hatte ich gelesen und getestet aber auch da nen fehler bekommen. Deswegen wollte ich die alte Version mal testen
        Thomas Braun P Dr. Bakterius 4 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Gurke258 last edited by
          @gurke258
          Schalt den DESKTOP aus.
          Und nodejs ist noch falsch installiert.
          iob nodejs-update
          Da dann die Pfade reparieren lassen.
            @gurke258
            Das war auch nicht die Langfassung.
            Also nochmal, nachdem nodejs repariert ist.
            Gurke258 1 Reply Last reply Reply Quote 0
              Pischleuder @Gurke258 last edited by
              @gurke258
              Moin,
              die Frage ist, was willst Du noch mit dem alten script ? Das wird so nicht mehr funktionieren, da sich die syntax zum einloggen etc. etwas verändert hat.
              Nutze doch einfach das homebridge plugin, sofern Du die Anlage scharf oder unscharf schalten möchtest.
              Gruss
              • Gurke258
                Gurke258 @Pischleuder last edited by
                @pischleuder sagte in Blink Camera System:
                @gurke258
                Moin,
                Gruss
                Ja mit dem Homebridge funktioniert es bei mir nicht mehr 😕 Keine ahnung warum 😕
                  Pischleuder @Gurke258 last edited by Pischleuder
                  @gurke258
                  welches npm Modul hast Du denn in der Homebridge Instanz eingegeben ?
                  Es sollte homebridge-blink-for-home@3.9.2 dort stehen und die Instanz im Wrapper Modus
                  starten.
                  in der Konfig dann so:
                  "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                  "accessories": [],
                  "platforms": [
                  "name": "Blink",
                  "username": "Email-Adresse",
                  "password": "Dein Passwort",
                  "pin": "Deine Pin",
                  "platform": "Blink"
                  • Dr. Bakterius
                    Dr. Bakterius Most Active @Gurke258 last edited by
                    @gurke258 sagte in Blink Camera System:
                    Die alte blinkpy-Version vor dem breaking change? Die kann man mit sudo pip install blinkpy==0.21.0 installieren. Musste ich auch machen, weil ich das Skript auf die v0.22.0 nicht angepasst bekommen habe.
                    @Thomas-Braun: Gibt es für die Erstellung einer Bildaufnahme eine funktionierende Vorlage? Dann würde ich es vielleicht noch einmal mit der neuen Version testen.
                    Meine 'bild.py' für v0.21.0 sieht so aus:
                    import requests
                    from blinkpy.blinkpy import Blink
                    from blinkpy.auth import Auth
                    from blinkpy.camera import BlinkCamera
                    blink = Blink()
                    auth = Auth({"username": "******", "password": "*******"}, no_prompt=True)
                    blink.auth = auth
                    blink.start()
                    auth.send_auth_key(blink, "******")
                    blink.setup_post_verify()
                    bild = '/opt/iobroker/blink.jpg'
                    for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
                    camera = blink.cameras['Eingangstuere']
                    camera.snap_picture()
                    blink.refresh()
                    camera.image_to_file(bild)
                    Thomas Braun Gurke258 P 3 Replies Last reply Reply Quote 0
                    • Gurke258
                      Gurke258 @Pischleuder last edited by Gurke258
                      @gurke258
                      starten.
                      "accessories": [],
                      "platforms": [
                      "name": "Blink",
                      "pin": "Deine Pin",
                      "platform": "Blink"
                      So habe ich es jetzt eingestellt aber ich bekomme in der Config folgende Meldung:
                      Either the "platform" or "accessory" property must be set
                      EDIT: Okay ich denke ich habe es hinbekommen!.. Ist aber sehr träge im Vergleich zu vorher. 😕
                        Thomas Braun Most Active @Dr. Bakterius last edited by
                        @dr-bakterius sagte in Blink Camera System:
                        Keine Ahnung. Ich hab keine Blink Camera im Einsatz.
                        • Gurke258
                          @gurke258
                          Sorry. Hier bitte 🙂
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Model		: Raspberry Pi 4 Model B Rev 1.1
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           10:25:29 up  5:25,  2 users,  load average: 1.50, 1.40, 1.31
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Sun 2023-11-05 10:25:29 CET
                                     Universal time: Sun 2023-11-05 09:25:29 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server: 	true
                          Desktop: 	LXDE-pi
                          Terminal: 	x11
                          *** MEMORY ***
                          Mem:            3.8G        2.3G        505M        164M        965M        1.2G
                          Swap:            99M          0B         99M
                          Total:          3.9G        2.3G        605M
                                   3794 M total memory
                                   2323 M used memory
                                   2886 M active memory
                                     65 M inactive memory
                                    504 M free memory
                                      9 M buffer memory
                                    956 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G   14G   15G  48% /
                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                          tmpfs          tmpfs     1.9G   20M  1.9G   2% /dev/shm
                          tmpfs          tmpfs     759M  976K  758M   1% /run
                          /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                          [Sun Nov  5 05:00:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:63:9E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f229ca1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Sun Nov  5 05:00:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun Nov  5 05:00:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sun Nov  5 05:00:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          TARGET  SOURCE         FSTYPE OPTIONS
                          /       /dev/mmcblk0p2 ext4   rw,noatime
                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                          /var:
                          5.4G	/var/
                          3.1G	/var/log/journal/c82d6a18bd344322b99e963f9b19b8e6
                          3.1G	/var/log
                          1.8G	/var/cache/apt
                          Archived and active journals take up 3.0G in the file system.
                          /opt/iobroker/backups:
                          106M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          668M	/opt/iobroker/iobroker-data/
                          498M	/opt/iobroker/iobroker-data/files
                          98M	/opt/iobroker/iobroker-data/files/vis-2-beta
                          72M	/opt/iobroker/iobroker-data/files/telegram.admin
                          71M	/opt/iobroker/iobroker-data/node-red/node_modules
                          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          21M	/opt/iobroker/iobroker-data/objects.jsonl
                          21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                          19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                          18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                          USB-Devices by-id:
                          *** NodeJS-Installation ***
                          /usr/bin/node 		v18.18.2
                          /usr/bin/npm 		9.8.1
                          /usr/bin/npx 		9.8.1
                          /usr/bin/corepack 	0.19.0
                          nodejs:
                            Installed: 18.18.2-1nodesource1
                            Candidate: 18.18.2-1nodesource1
                            Version table:
                           *** 18.18.2-1nodesource1 1001
                                  100 /var/lib/dpkg/status
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller: 	5.0.12
                          admin: 		6.12.0
                          javascript: 	7.1.4
                          Adapters from github: 	0
                          Adapter State
                          + system.adapter.alexa2.0                 : alexa2                : HomePi                                   -  enabled
                          + system.adapter.backitup.0               : backitup              : HomePi                                   -  enabled
                          + system.adapter.bring.0                  : bring                 : HomePi                                   -  enabled
                            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: HomePi                                   -  enabled
                            system.adapter.daswetter.0              : daswetter             : HomePi                                   -  enabled
                            system.adapter.devices.0                : devices               : HomePi                                   - disabled
                          + system.adapter.discovergy.0             : discovergy            : HomePi                                   -  enabled
                          + system.adapter.discovery.0              : discovery             : HomePi                                   -  enabled
                            system.adapter.dwd.0                    : dwd                   : HomePi                                   -  enabled
                          + system.adapter.ham.0                    : ham                   : HomePi                                   -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : HomePi                                   -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : HomePi                                   -  enabled, port: 18701
                          + system.adapter.hm-rpc.1                 : hm-rpc                : HomePi                                   -  enabled, port: 12001
                            system.adapter.ical.0                   : ical                  : HomePi                                   -  enabled
                            system.adapter.ical.1                   : ical                  : HomePi                                   -  enabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : HomePi                                   -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomePi                                   - disabled
                            system.adapter.influxdb.0               : influxdb              : HomePi                                   - disabled, port: 8086
                          + system.adapter.info.0                   : info                  : HomePi                                   -  enabled
                          + system.adapter.iot.0                    : iot                   : HomePi                                   -  enabled
                          + system.adapter.javascript.0             : javascript            : HomePi                                   -  enabled
                          + system.adapter.netatmo.0                : netatmo               : HomePi                                   -  enabled
                          + system.adapter.nina.0                   : nina                  : HomePi                                   -  enabled
                          + system.adapter.node-red.0               : node-red              : HomePi                                   -  enabled, port: 1880, bind: 192.168.178.79
                          + system.adapter.ping.0                   : ping                  : HomePi                                   -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : HomePi                                   -  enabled
                          + system.adapter.smartthings.0            : smartthings           : HomePi                                   -  enabled
                            system.adapter.spotify-premium.0        : spotify-premium       : HomePi                                   - disabled
                          + system.adapter.synology.0               : synology              : HomePi                                   -  enabled, port: 5001
                            system.adapter.systeminfo.0             : systeminfo            : HomePi                                   - disabled
                            system.adapter.tankerkoenig.0           : tankerkoenig          : HomePi                                   - disabled
                          + system.adapter.telegram.0               : telegram              : HomePi                                   -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.text2command.0           : text2command          : HomePi                                   -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : HomePi                                   -  enabled
                          + system.adapter.tuya.0                   : tuya                  : HomePi                                   -  enabled
                            system.adapter.vis-2-beta.0             : vis-2-beta            : HomePi                                   - disabled
                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : HomePi                                   -  enabled
                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : HomePi                                   -  enabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: HomePi                                   -  enabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomePi                                   -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomePi                                   - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : HomePi                                   - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : HomePi                                   -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomePi                                   - disabled
                            system.adapter.vis-keyboard.0           : vis-keyboard          : HomePi                                   - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : HomePi                                   - disabled
                            system.adapter.vis-metro.0              : vis-metro             : HomePi                                   - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : HomePi                                   -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomePi                                   - disabled
                            system.adapter.vis.0                    : vis                   : HomePi                                   -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
                          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                          Adapter    "bring"        : 1.8.4    , installed 1.8.4
                          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                          Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                          Adapter    "ham"          : 5.3.1    , installed 5.3.1
                          Adapter    "hid-community": 0.3.0    , installed 0.3.0
                          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                          Adapter    "iot"          : 1.14.5   , installed 1.14.5
                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                          Controller "js-controller": 5.0.12   , installed 5.0.12
                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                          Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                          Adapter    "synology"     : 3.0.1    , installed 3.0.1
                          Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                          Adapter    "text2command" : 3.0.2    , installed 3.0.2
                          Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
                          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                          Adapter    "vis"          : 1.4.16   , installed 1.4.16
                          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                          Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                          Adapter    "withings"     : 0.0.13   , installed 0.0.13
                          Adapter    "ws"           : 2.5.5    , installed 2.5.5
                          Objects and States
                          Objects: 	15792
                          States: 	13665
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15591      542/cupsd
                          tcp        0      0 192.168.178.79:18701    0.0.0.0:*               LISTEN      1001       280874     29233/io.hm-rpc.0
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       280609     29088/iobroker.js-c
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       280616     29088/iobroker.js-c
                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16404      578/vncserver-x11-c
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13802      606/sshd: /usr/sbin
                          tcp        0      0 192.168.178.79:1880     0.0.0.0:*               LISTEN      1001       279873     29195/node-red
                          tcp        0      0 192.168.178.79:12001    0.0.0.0:*               LISTEN      1001       280923     29256/io.hm-rpc.1
                          tcp6       0      0 :::3310                 :::*                    LISTEN      115        15720      661/mariadbd
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15590      542/cupsd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       278103     29109/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       283724     29863/io.web.0
                          tcp6       0      0 :::5900                 :::*                    LISTEN      0          16403      578/vncserver-x11-c
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13804      606/sshd: /usr/sbin
                          tcp6       0      0 :::80                   :::*                    LISTEN      0          16428      687/apache2
                          udp        0      0 0.0.0.0:53157           0.0.0.0:*                           108        14400      407/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16455      485/dhcpcd
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       279265     29478/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       279266     29478/io.tuya.0
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14572      666/cups-browsed
                          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303130     32252/chromium-brow
                          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303128     32252/chromium-brow
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14398      407/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          13950      485/dhcpcd
                          udp6       0      0 :::37916                :::*                                108        14401      407/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        14399      407/avahi-daemon: r
                          2023-11-05 10:19:34.236  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name: value = Blink Flur Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                          2023-11-05 10:19:34.259  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name {"val":"Blink Flur Privacy Mode","ack":true,"ts":1699175968047,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092789}
                          2023-11-05 10:19:34.306  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                          2023-11-05 10:19:34.334  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On {"val":false,"ack":true,"ts":1699175968067,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092845}
                          2023-11-05 10:19:37.943  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699175977940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175977940}
                          2023-11-05 10:19:41.270  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699175981267,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175977940}
                          2023-11-05 10:19:56.106  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699175996101,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175996101}
                          2023-11-05 10:19:56.129  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699175996125,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175996101}
                          2023-11-05 10:20:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32168
                          2023-11-05 10:20:03.699  - info: dwd.0 (32168) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                          2023-11-05 10:20:06.936  - info: dwd.0 (32168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-11-05 10:20:07.480  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-11-05 10:20:36.192  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176036188,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176036188}
                          2023-11-05 10:20:36.215  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176036210,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176036188}
                          2023-11-05 10:20:41.279  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699176041276,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176041276}
                          2023-11-05 10:20:44.229  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699176044225,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176041276}
                          2023-11-05 10:20:53.611  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176053606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176053606}
                          2023-11-05 10:20:53.683  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176053678,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176053606}
                          2023-11-05 10:21:32.141  - info: web.0 (29863) ==> Connected system.user.admin from ::ffff:192.168.178.79
                          2023-11-05 10:23:41.482  - info: admin.0 (29109) ==> Connected system.user.admin from ::ffff:192.168.178.123
                          2023-11-05 10:23:49.815  - info: admin.0 (29109) <== Disconnect system.user.admin from ::ffff:192.168.178.123
                          2023-11-05 10:25:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32832
                          2023-11-05 10:25:03.554  - info: dwd.0 (32832) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                          2023-11-05 10:25:06.028  - info: dwd.0 (32832) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-11-05 10:25:06.573  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          [/s]
                          • Gurke258
                            Gurke258 @Dr. Bakterius last edited by
                            @dr-bakterius
                            Da habe ich leider nach wie vor den selben Fehler...
                            from blinkpy.blinkpy import Blink ImportError: No module named blinkpy.blinkpy
                            Trotz dem 0.21.0 😞
                            Naja ich habe dank @Pischleuder erstmal ne Lösung und muss denke ich auch mal von bullseye auf Bookworm wechseln mim Pi4
                              Pischleuder @Dr. Bakterius last edited by
                              import requests
                              blink = Blink()
                              blink.auth = auth
                              blink.start()
                              blink.refresh()
                              Moin,
                              nein - ich hatte dieses script damals zusammengedängelt, mir aber nicht die Mühe gemacht, das auf die neue blinkpy umzusetzen, da es immer noch keinen livestream support geben wird.
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @Pischleuder last edited by
                                Verstehe. Allerdings haben alle die die aktuelle v0.22.0 installieren dann das Problem, dass das Skript nicht tut. Ich hatte zwar versucht es nach der Beschreibung auf Git-Hub anzupassen, bin aber gescheitert. Für meinen Zweck würde es schon reichen ein Bild aufzunehmen und am gewünschten Ort zu speichern. Livestream ist mit Batterie ohnehin eine weniger gute Idee und könnte ich ja immer noch mit der Blink-App haben.
                                  @dr-bakterius
                                  ja, das Problem ist nur, dass Module benötigt werden, die in der aktuellen Python-Version (3.11) noch nicht enthalten sind und man kann diese nicht so ohne weiteres über pip nachladen. Lediglich als venv Variante. Der Aufwand ist derzeit zum Nutzen einfach zu hoch.
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active last edited by
                                    Ich grabe diesen Thread aus aktuellem Anlass wieder aus.
                                    Seit irgendwann im April hat Blinkpy nicht mehr funktioniert, weil Amazon bei der Anmeldung etwas geändert hat und dadurch jedes Mal ein neuer 2FA Code gesendet wurde. Das wurde auch auf GitHub behandelt (https://github.com/fronzbot/blinkpy/issues/917). Inzwischen dürfte es eine Lösung geben die ich hier gerne zusammenfassen möchte. Vielleicht nützt es ja jemandem.
                                    Aktuell muss man folgende beiden Skripte von GitHub herunterladen und bei sich im Ordner /home/<user>/.local/lib/python3.11/site-packages/blinkpy ersetzen: auth.py und blinkpy.py.
                                    Man erstellt einmalig ein Skript (z.B. anmelden.py) mit folgendem Inhalt:
                                    import asyncio
                                    from aiohttp import ClientSession
                                    async def start():
                                        blink = Blink(session=ClientSession())
                                        # Can set no_prompt when initializing auth handler
                                        auth = Auth({"username": <your username>, "password": <your password>}, no_prompt=True)
                                        blink.auth = auth
                                        await blink.start()
                                        await blink.save("/opt/iobroker/blink_auth.json")
                                        return blink
                                    blink = asyncio.run(start())
                                    Wenn man dieses von der Console aufruft
                                    python3.11 anmelden.py
                                    , wird man nach seinen Anmeldedaten gefragt und erhält dann den 2FA Code welchen man angibt. Anschließend wird in /opt/iobroker die Datei blink_auth.json erstellt. Diese enthält die Anmeldedaten für künftige Abfragen. Danach kann man das Skript wenn man möchte wieder löschen.
                                    Um jetzt ein Bild abzufragen braucht man folgendes Skript:
                                    import asyncio
                                    from blinkpy.helpers.util import json_load
                                    async def start():
                                        blink = Blink()
                                        auth = Auth(await json_load("/opt/iobroker/blink_auth.json"))   # Anmeldeinformationen laden
                                        blink.auth = auth   # Anmeldeinformationen senden
                                        await blink.start()   # Verbindung starten
                                        camera = blink.cameras['<Kameraname>']   # Kameraname angeben
                                        await camera.snap_picture()   # Bild aufnehmen
                                        await blink.refresh()   # Daten vom Blink-Server abfragen
                                        await camera.image_to_file('/opt/iobroker/blink.jpg')   # Bild speichern
                                        return blink
                                    Leider ist es mir nicht gelungen das Skript mit exec (JS oder Blockly) wegen fehlender Berechtigung aufzurufen. Ich habe das dann mit dem Linux-Control Adapter gelöst.
                                    Judas2016 created this issue in fronzbot/blinkpy
                                    closed PIN Code Rejection #917
                                    F D 2 Replies Last reply Reply Quote 1
                                      Flowski @Dr. Bakterius last edited by
                                      gibt es mittlerweile eine Möglichkeit auf die Bilder der Cam zuzugreifen??
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active @Flowski last edited by
                                        @flowski Geht doch wie oben beschrieben.
                                        F 2 Replies Last reply Reply Quote 1
                                          @dr-bakterius said in Blink Camera System:
                                          oh wow das habe ich wohl übersehen, bzw. inhaltlich garnicht wirklich begriffen, befinde mich noch in den Anfängen des ganzen... wie zuverlässig läuft das ganze? Sind die Bilder auch schnell verfügbar dass es auch Sinn macht?
                                          • Dr. Bakterius
                                            @flowski Was ist schnell? Ich lasse mir die Bilder mit Pushover ans Handy schicken. Das dauert etwa 15 Sekunden. Der Verbinungsaufbau meiner Blink Outdoor dauert alleine schon 10-12 Sekunden.
                                            1.2k
                                            blink xt camera
                                            63
                                            406
                                            116409
