    4. VIS von Sigi234
    VIS von Sigi234
      RISSN @sigi234 last edited by
      @sigi234 vielen Dank 👍
        Andronid @sigi234 last edited by
        @sigi234 tolle Arbeit, vielen Dank dafür. Wie weit ist das Projekt Huawei Handy?
          sigi234 Forum Testing Most Active @Andronid last edited by
          @andronid sagte in VIS von Sigi234:
          Wird nicht mehr weiter entwickelt wegen Vis2
            Sushibomba last edited by
            @sigi234
            Kannst du mir sagen wie ich die komplette Dropdownliste auf meinem Tablet sichtbar bekommen wenn ich drauf klicke?
            DU hattest selbst mal wegen der Lösung gefragt.
            sigi234 S 2 Replies Last reply Reply Quote 0
              sigi234 Forum Testing Most Active @Sushibomba last edited by
              @sushibomba
              Schrift kleiner machen
                Sushibomba @sigi234 last edited by
                @sigi234
                Aber dann kann man ja nichts mehr lesen auf dem Tablet an der Wand.
                Ist es nicht möglich die Größe des kompletten Fensters zu vergrößern einfach. Also 100% anzeigen bei Klick?
                  @sushibomba
                  Stell das Widget mal rein
                    @sigi234
                    [{"tpl":"tplMaListWindowShutter","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showTitle":true,"onlyTitle":false,"titleSize":" medium","widgetBackground":"","TextColor":"white","subtitleSize":"x-small","valueAlign":"left","valueVertical":"center","opacityColor":"white","inverted":true,"borderRadius":"10","showIcon":true,"centerIcon":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"alias.0.Rolladensteuerung.Rollo_WZ_RECHTS","border":false,"title":"WZ R. ","subtitle":"","valueSize":" medium","valueAsSubtitle":false,"borderColor":"white","useOverallRoundedValues":"checked","roundLeftUp":"10","roundLeftBottom":"0","roundRightUp":"0","roundRightBottom":"10","boxShadow":"unchecked","shadowWidth":"2","readOnly":true},"style":{"left":"1460px","top":"117px","z-index":"1","width":"275px","height":"58px","line-height":"","text-align":"center","font-style":"normal","font-variant":"","color":"#ffb900","font-weight":"","font-size":"0px"},"widgetSet":"vis-material-advanced"}]
                      @sushibomba
                      Ist das das Select Widget?
                        @sigi234
                        vis-material-advanced und das listWindowShutter widget
                          @sigi234 Hast du meine Nachricht überlesen? 😰
                            @sushibomba sagte in VIS von Sigi234:
                            Nein Herz OP
                              @sigi234 schade, aber nicht zu ändern.
                              Noch eine andere Frage. Hast du auch eine Übersicht über Rollläden? Ich hoffe, dass ich nichts übersehen habe.
                                @sigi234
                                Oh ok. ich hoffe sie ist gut verlaufen!? 🙏
                                  Gehts dir wieder besser @sigi234 ?
                                    Ja geht so. Danke. Bin noch schlapp.
                                      @sigi234
                                      Ohhh nicht schön dann gute Besserung weiterhin.
                                      Fühlst du dich denn trotzdem in der Lage meine Frage oben zu beantworten? Wäre echt klasse damit ich die Rollladensteuerung endlich nutzen kann auf dem Tablet. Vielen Dank.
                                        @sushibomba
                                        Zeig mir noch mal was du genau willst.
                                          Sushibomba @Sushibomba last edited by Sushibomba
                                          @sigi234
                                          @sigi234
                                          Und noch das Widget als Code:
                                            @sushibomba
                                            Schau ich mir mal an, haben immer wieder Stromausfall
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            596162
