    4. Test Adapter Weather-Warnings
      sigi234 Forum Testing Most Active @ticaki last edited by
      @ticaki sagte in Test Adapter Weather-Warnings:
      nur auf github aber mit Version 0.5.0-alpha.0
      Läuft.
      weather-warnings.0
      2023-11-04 21:36:27.356	info	[provider] Silent time added: Profil: Mo-So start: 22 end: 5 days: ["0","1","2","3","4","5","6"]
      weather-warnings.0
      2023-11-04 21:36:27.356	info	[provider] Silent time added: Profil: Sa-So start: 7 end: 17 days: ["0","6"]
      weather-warnings.0
      2023-11-04 21:36:27.356	info	[provider] Silent time added: Profil: Mo-Fr start: 10 end: 12 days: ["1","2","3","4","5"]
      weather-warnings.0
      2023-11-04 21:36:26.504	info	UWZ activated. Retrieve data.
      weather-warnings.0
      2023-11-04 21:36:25.378	info	ZAMG activated. Retrieve data.
      weather-warnings.0
      2023-11-04 21:36:25.378	info	[alexa2] Create notification service alexa2 state: alexa2.0.Echo-Devices.G0922XXXXXXXXXX.Commands.speak.
      weather-warnings.0
      2023-11-04 21:36:25.363	info	[email] Create notification service email adapter: email.0.
      weather-warnings.0
      2023-11-04 21:36:25.342	info	[history] Create notification service history.
      weather-warnings.0
      2023-11-04 21:36:25.293	info	[json] Create notification service json.
      weather-warnings.0
      2023-11-04 21:36:25.251	info	Refresh Interval: 20 minutes
      weather-warnings.0
      2023-11-04 21:36:20.851	info	starting. Version 0.5.0-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings) in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.18.2, js-controller: 5.0.16
      weather-warnings.0
      2023-11-04 21:35:20.740	info	terminating
      weather-warnings.0
      2023-11-04 21:35:20.235	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      weather-warnings.0
      2023-11-04 21:35:20.235	info	terminating
      weather-warnings.0
      2023-11-04 21:35:20.231	info	Got terminate signal TERMINATE_YOURSELF
        ticaki Developer @Thomas Braun last edited by
        @thomas-braun sagte in Test Adapter Weather-Warnings:
        0.5.0-alpha.0
        Damit quasseln meine Alexen jetzt fröhlich durch die Gegend.
        Fehlt mir nur noch Nina-Unterstützung, um das Skript abzulösen.
        Das kommt erst im nächsten größeren Schritt. Hab gesagt das es bis weihnachten dauern kann. Also hab ich noch Zeit. ^^
          Thomas Braun Most Active @ticaki last edited by
          Ja wie jetzt? Und wenn bis dahin Hochwasser ist, meine Bude abbrennt oder das Dach wegfliegt??? 🙂
            ticaki Developer last edited by
            90 Minuten kein Aufschrei - dann mache ich mal latest fertig. alpha kommt doch nicht ins latest. 🙂
              Läuft.👍
              Adapter fertig....😀
                sigi234 Forum Testing Most Active @ticaki last edited by sigi234
                @ticaki
                Hallo, bei Keine Warnung sind noch einige Komma drinnen
                weather-warnings.0.provider.uwz.UWZATXXXXX.formatedKeys.01.headline
                ...Keys.00-04
                WERT:
                Keine Warnung, , , , , , ,
                Provider :uwz
                  Oh doch:
                  History wird nicht Richtig gelöscht. Bei den Providern ist es ok. Aber bei
                  weather-warnings.0.provider.history
                  nicht.
                  weather-warnings.0.undefined.history
                    ticaki Developer @sigi234 last edited by
                    @sigi234
                    Beides auf github gefixt.
                    • I
                      ioBrokerMike @ticaki last edited by ioBrokerMike
                      Moin
                      Hab bislang immer fleißig mit gelesen.
                      Und finde den Adapter Super.
                      Aber ich habe ein Problem, oder auch nicht ? 🙄
                      Auch unter formatedKeys ist UWZDE38112 aufgeführt.
                      Das passt nicht ganz Überein. Version 0.5.0
                        ticaki Developer @ioBrokerMike last edited by ticaki
                        @iobrokermike
                        UWZ listet nicht alle betroffenen UWZ-ID auf, sondern schreibt da 1 ID in die areaID und liefert die an jede Anfrage im betroffenen Gebiet 🙂
                        Das ist nicht schön aber richtig 🙂
                        Ich werde eine Erklärung dazu in den Datenpunkt common.name schreiben. Der wird aber nur beim neuerstellen geschrieben.
                        Auf die Anfrage: http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZDE29378
                        kommt das:
                            "results": [
                                    "center": "UWZ",
                                    "areaID": "UWZDE38112",
                                    "dtgEnd": 1699225200,
                                    "areaType": "UWZCODE",
                                    "dtgStart": 1699200480,
                                    "payload": {
                                        "translationsLongText": {
                                            "DE": "Am Sonntagabend und -nacht frischt der S\u00fcdwest- bis Westwind vor\u00fcbergehend stark bis st\u00fcrmisch auf. Dabei sind \u00f6rtlich sogar warnrelevante Sturmb\u00f6en um oder knapp \u00fcber 75 km\/h m\u00f6glich. Im Laufe der Nacht lassen die Windb\u00f6en von Westen her dann wieder nach, es bleibt aber windig."
                                        "id": "16991681627164.2",
                                        "creation": 1699168500000,
                                        "uwzLevel": 10,
                                        "translationsShortText": {
                                            "DE": "Sturmb\u00f6en am Sonntagabend und -nacht m\u00f6glich. 60-80 km\/h."
                                        "fileName": "meteogroup_warn_16991681627164_20231105071511_1699225200_1699168571.xml",
                                        "levelName": "alert_warn_orange",
                                        "shortText": "Stormy gusts. 60-80 km\/h.",
                                        "longText": "On Sunday evening and night considerable stormy gusts may occur locally. Accordingly, gale-force gusts of 60 to 80 km\/h are expected, locally even more. Winds blow from southwest to west. Sunday night wind gusts decrease.",
                                        "altMin": -10,
                                        "altMax": 9000
                                    "severity": 10,
                                    "type": 2
                            "cached": 1
                        Aber gut das du gefragt hast, hab gesehen das ich zwar alles für Fremdsprachen bei uwz eingebaut habe... nur nicht die url entsprechend verändere. 😄
                        update
                        • Fremdsprachen auch für UWZ auf github:
                        headline: 'Des rafales tempétueuses. 70-90 km/h.'
                        • I
                          @ticaki Vielen Dank für die Erklärung.
                          Ich will nicht Nerven, aber das mit den Warnattributen ( UZW, DWD, ZAMG) habt Ihr ja schon hinlänglich Besprochen, und nun komm ich wieder damit. 😌
                          Aber ich habe zur schnellen Ansicht auf meinem Tablet die Kartenansicht von UWZ und dort ist alles Orange während im Adapter Gelb ausgegeben wird.
                          Denn für nähere Info lass ich mir ein Popup Anzeigen was mit der Farbe aus dem Adapter erscheinen soll.
                          Vielen Dank
                          T Negalein 2 Replies Last reply Reply Quote 0
                            @iobrokermike
                            Da du nicht aufgepasst hast, nochmal den ganzen Topic von vorne lesen 😄
                            Du bist der erste der das mit den UWZ Farben sagt. Glaube ich...
                            korrigiere ich.
                            EDIT:
                            Ich packe dann Vorwarnungen, zur Kenntnisnahme und gelbe Warnungen alle in Stufe 1
                            • I
                              @ticaki
                              Doch aufgepasst schon, mir war die Diskussion um die Farben usw bekannt.
                              Nur es hat noch keiner (glaube ich) die Karten dazu genutzt.
                              Vielen Dank für deine Geduld mit mir. 🙂
                              • Negalein
                                Negalein Global Moderator @ioBrokerMike last edited by
                                @iobrokermike sagte in Test Adapter Weather-Warnings:
                                hast du da schon einen View für den Weather-Warnings Adapter?
                                Und könnte ich deine Tablet-VIS sehen (gerne mach ich einen neuen Thread um nicht zu OT zu werden).
                                I sigi234 2 Replies Last reply Reply Quote 0
                                • I
                                  ioBrokerMike @Negalein last edited by
                                  **@negalein sagte in Test Adapter Weather-Warnings:
                                  d könnte ich deine Tablet-VIS sehen (gerne mach ich einen neuen Thread um nicht zu OT zu werden)**
                                  Bin noch am Anfang.
                                  Das ist das was ich bis jetzt habe.
                                  @ticaki
                                  Das mit der Warnfarbe habe ich erstmal mit einem Blockly übersetzt.
                                  Vielen Dank für den Adapter, denn darauf haben bestimmt einige gewartet. 👍
                                  M Negalein Nashra 3 Replies Last reply Reply Quote 0
                                    0.5.1 ist auf dem Weg
                                    • Farben uwz angepasst
                                    • die 2 Sachen von Sigi
                                    • und die Fremdsprachen für uwz
                                      sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                                      @negalein
                                      VIS2
                                        MartyBr @ioBrokerMike last edited by
                                        @iobrokermike Würdest du deine Widgets teilen, wenn du fertig bist? Das sieht schon jetzt sehr gut aus.
                                          Dieser DP wird 2 mal beschrieben:Ist bei allen formatedKeys.00-04
                                          weather-warnings.0.provider.uwz.UWZATxxxxx.formatedKeys.00.locationcustom
                                          Wert:
                                          ORT, ORT
                                            ticaki Developer @sigi234 last edited by ticaki
                                            @sigi234
                                            Das ist so gewollt, bei keiner Warnung. Damit dann sowas wie Keine Warnung für Köln, Berlin als Title möglich ist. Was ich noch ändern könnte wäre das Berlin, Berlin zu Berlin zusammengefasst wird. Hab das auf github angepasst.
                                            EDIT:
                                            Bin jetzt am Grübeln ob das unpassend ist das ich alle benuzterdefinierten Orte da zusammenfasse. Für Nachrichten ist das optimal, Für VIS eher nicht. Soll ich da noch einen Datenpunkt anlegen in dem der Name steht. Wobei - kann man den mit VIS nicht aus dem common.name des übergeordneten Warnzellenchannels nehmen?
                                            1077
                                            267674
