      HansJochen @Marc Berg last edited by
      @marc-berg
      (u.a.) diese Docker Container laufen bei mir:
      c389e7d91b5f   influxdb:2.7-alpine             "/entrypoint.sh infl…"   4 months ago    Up 5 hours             0.0.0.0:8086->8086/tcp, :::8086->8086/tcp, 0.0.0.0:8088->8088/tcp, :::8088->8088/tcp        influxdb
      5f33c0bcde82   buanet/iobroker                 "/bin/bash -c /opt/s…"   4 months ago    Up 5 hours (healthy)   0.0.0.0:1882->1882/tcp, :::1882->1882/tcp, 0.0.0.0:8081-8082->8081-8082/tcp, :::8081-8082->8081-8082/tcp, 0.0.0.0:8400->8400/tcp, :::8400->8400/tcp      iobroker
      Ich verwende docker-compose mit dieser Konfiguration für iobroker und influx:
      version: '2'
      services:
        iobroker:
          container_name: iobroker
          image: buanet/iobroker
          hostname: iobroker
          restart: unless-stopped
          ports:
            - "8081:8081" # IOBroker
            - "8082:8082" # Jarvis Web Port
            - "1882:1882" # MQTT Server des Shelly Adapters
            - "8400:8400" # Jarvis Socket Port
          volumes:
            - ./iobroker/data:/sharename
            - ./iobroker/userscripts:/opt/userscripts
            - /run/udev:/run/udev:ro
          devices:
            - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2437275-if00:/dev/ttyACM0
          environment:
            - USBDEVICES=/dev/ttyACM0
            - DEVICE=/dev/ttyACM0
            - IOB_BACKITUP_EXTDB = true
            - PACKAGES = influxdb2-cli
        influxdb:
          image: influxdb:2.7-alpine
          container_name: influxdb
            #    restart: no
          ports:
            - "8086:8086"
            - "8088:8088"
          volumes:
            - ./influxdb/data:/var/lib/influxdb
            - ./influxdb/config:/etc/influxdb
            - ./influxdb/bin:/root
            - ./influxdb/docker-entrypoint-initdb.d:/docker-entrypoint-initdb.d
            - ./influxdb2:/root/lib/influxdb2/data
            - ./influxdb2-config:/etc/influxdb2
            - ./influxdb.conf:/root/influxdb/influxdb.conf
          environment:
            - INFLUXDB_ADMIN_USER=admin
            - INFLUXDB_ADMIN_PASSWORD=xyz
            - DOCKER_INFLUXDB_INIT_USERNAME=admin
            - DOCKER_INFLUXDB_INIT_PASSWORD=xyz
            - DOCKER_INFLUXDB_INIT_MODE=upgrade
            - DOCKER_INFLUXDB_INIT_BUCKET=xyz
            - DOCKER_INFLUXDB_INIT_UPGRADE_V1_CONFIG=/root/influxdb/influxdb.conf
            - DOCKER_INFLUXDB_CONFIG_PATH=/root/influxdb2/config.toml
            - DOCKER_INFLUXDB_BOLT_PATH=/root/influxdb2/influxdb.bolt
            - DOCKER_INFLUXDB_ENGINE_PATH=/root/influxdb2/engine
            - DOCKER_INFLUXDB_INIT_ORG=xyz
              #entrypoint:
              #- sh /entrypoint.sh
        Thomas Braun Most Active @HansJochen last edited by
        @hansjochen
        Sind da die passenden Pakete installiert?
        sudo apt update
        apt policy influxdb*
          @marc-berg
          Die Umgebungsvariablen kommen doch an:
          root@iobroker:/opt/iobroker# env
          Marc Berg andre 2 Replies Last reply Reply Quote 0
          • Marc Berg
            Marc Berg Most Active @HansJochen last edited by
            @hansjochen sagte in Test Adapter ioBroker.backitup v2.8.x:
            Dann wären sie dort sichtbar:
            -----                                 ENV                                  -----
            -----                    SETGID:              1000                         -----
            -----                    SETUID:              1000                         -----
            -----                    USBDEVICES:          /dev/ttyACM0                 -----
            Irgendwas ist hier sehr komisch. In deinem Docker-Log steht auch was von Image 7.0.1.
              @marc-berg sagte in Test Adapter ioBroker.backitup v2.8.x:
              -----                                 ENV                                  -----
              Okay, überzeugt. Ich baue das Image neu, wenn heute Abend die Heizung aus ist. Danach gebe ich Euch hier noch mal ein Update. Danke für Eure Unterstützung.
              • Marc Berg
                Marc Berg Most Active @Marc Berg last edited by Marc Berg
                @marc-berg
                Die Unterstüzung für IOB_BACKITUP_EXTDB gibt es erst seit Image 7.2!!! Und für die Umgebungsvariable PACKAGES=influxdb2-cli seit 8.x
                • andre
                  andre Developer @HansJochen last edited by andre
                  @marc-berg
                  Mach mal die Leerzeichen weg. Weiß nicht ob das was bringt aber:
                  Dein docker-compose enthält:
                      environment:
                  Aber laut log kommt nur USBDEVICES an. DEVICE gibt es nicht und bei den anderen beiden sind Leerzeichen drin.
                  -----                        Debugging information                         -----
                  -----                                System                                -----
                  -----                    arch:                x86_64                       -----
                  -----                    hostname:            iobroker                     -----
                  -----                             Docker-Image                             -----
                  -----                    image:               v7.0.1                       -----
                  -----                    build:               2022-07-05T18:51:52+00:00    -----
                  -----                               Versions                               -----
                  -----                    node:                v16.20.1                     -----
                  -----                    npm:                 8.19.4                       -----
                  -----                                 ENV                                  -----
                  Versuch mal so:
                      environment:
                        - IOB_BACKITUP_EXTDB=true
                        - PACKAGES=influxdb2-cli
                  Alternativ mal sauber compose down, compose up... Damit der Container neu gebaut wird...
                  MfG,
                  André
                  • Marc Berg
                    Marc Berg Most Active @andre last edited by
                    @andre sagte in Test Adapter ioBroker.backitup v2.8.x:
                    @HansJochen hatte (warum auch immer) das Image 7.0.1 am Start. Damit war das Setzen der Umgebungsvariablen sowieso für die Katz.
                    andre H 2 Replies Last reply Reply Quote 1
                    • andre
                      andre Developer @Marc Berg last edited by
                      @marc-berg In der Tat! 😂 Das habe ich glatt überlesen, bzw. habe ich wirklich v9.0.1 gelesen, was ja aktuell wäre.
                      Hätte mir aber auch spätestens bei node 16 komisch vorkommen müssen. 🙂 Naja, ich schiebe es mal darauf, dass heut Sonntag ist...
                        @marc-berg
                        Was für ein image 7.0.1 ist das denn eigentlich? Die Version bezieht sich doch auf das iobroker Image, oder? Ich habe jetzt ein docker-compose down und docker-compose up gemacht, aber es wird wieder diese Version gebaut. Die habe ich aber nirgends explizit angegeben.
                        Offenbar mache ich da fundamental was falsch.
                        Service Section sieht jetzt so aus:
                        services:
                          iobroker:
                            hostname: iobroker
                            ports:
                            volumes:
                            devices:
                            environment:
                          Alles klar, jetzt passt es. Selbst mit latest wurde bei mir 7.0.1 gebaut, warum auch immer. Ich habe jetzt explizit 8.0.0 reingeschrieben, das sieht freundlicher aus:
                          -----                    image:               v8.0.0                       -----
                          -----                    build:               2023-04-07T23:45:19+00:00    -----
                          -----                    node:                v18.15.0                     -----
                          -----                    npm:                 9.5.0                        -----
                          -----                        Environment Variables                         -----
                          -----                    IOB_BACKITUP_EXTDB:  true                         -----
                          -----                    PACKAGES:            influxdb2-cli                -----
                          • FredF
                            FredF Most Active Forum Testing @HansJochen last edited by
                            @hansjochen
                            Nachlesen hilft https://hub.docker.com/r/buanet/iobroker
                            Stichpunkt supported tags
                            also eher latest-v9
                            • Marc Berg
                              Marc Berg Most Active @HansJochen last edited by Marc Berg
                              ich habe jetzt ein docker-compose down und docker-compose up gemacht, aber es wird wieder diese Version gebaut.
                              Mit diesen Befehlen werden übrigens keine neuen Versionen heruntergeladen, sondern einfach die Container neu erstellt mit dem bereits heruntergeladenen Image (so denn das Tag noch das gleiche ist).
                              Du müsstest vorher noch
                              docker-compose pull
                              ausführen. In diesem Fall hätte Docker das aktuelle "latest" heruntergeladen. Das müsste im Moment die 9.0.1 sein.
                                @marc-berg und alle
                                vielen Dank für Eure Unterstützung. Dass es den pull braucht, wusste ich nicht. Ich habe mir gestern Abend explizit die latest-v9 gebaut. Damit lief es auf Anhieb sauber durch und auch die Backups funktionieren wieder. Da mir der docker-compose down auch die Influx und auch die Grafana DB gelöscht hat und ich die Influx danach händisch wieder hergestellt habe, bin ich dort jetzt damit am Ringen, die Verbindung zwischen den beiden wieder vernünftig hin zu bekommen. Ich schätze mal, dass da mit den Token auf Grafana-Seite etwas nicht passt. In der Diagramm Darstellung einzelner Objekte im IOBroker bekomme ich vollständige Charts auch über ein ganzes Jahr bis heute angezeigt, insofern sollte da jetzt eigentlich nichts verloren gehen. Denke, das werde ich gelöst bekommen.
                                Marc Berg simatec 2 Replies Last reply Reply Quote 0
                                • Marc Berg
                                  Da hast du dann grundsätzlich was falsch angelegt, aber das wird hier endgültig off topic.
                                  • simatec
                                    simatec Developer Most Active @HansJochen last edited by
                                    @hansjochen Bitte mache dafür einen separaten Thread auf. Das hat nix mehr mit Backitup zu tun
                                      HansJochen @simatec last edited by
                                      @simatec
                                      Ich bin fertig. Wollte ja nur mitteilen, dass die Backups jetzt wieder laufen.
                                        Jetzt habe ich doch noch etwas gefunden, was ich für ein Backup Thema halte.
                                        Der Influx Adapter hat eine Einstellung, wie lange die Daten aufgehoben werden sollen (S. 2, Standard Einstellungen, Storage Vorhaltezeit). Ich bin nicht sicher, ob es diese Einstellung früher schon gab oder die irgendwann reingekommen ist. Bei mir stand die auf "1 Jahr". Ich glaube aber nicht, dass ich die selbst so gesetzt hatte. Ich hatte ja über Jahre Daten in Influx gesammelt.
                                        Im Zuge meiner Recovery Aktion jetzt habe ich meine IOBroker Installation über das Backup wiederhergestellt und dann mehrfach ein Backup meiner Influx Installation wiederhergestellt. Dabei bin ich ein paar Mal darüber gestolpert, dass nach der Wiederherstellung meine Daten im Influx zunächst vollständig waren, aber nach dem Verbinden mit IOBroker auf ein Jahr eingestutzt wurden - bis ich diese Option entdeckt habe.
                                        Meine Vermutung ist, dass die Option im Influx Adapter irgendwann neu eingeführt wurde und dabei der Default auf "1 Jahr" gesetzt wurde. Das ist an der Stelle ja auch in Ordnung - wer den Adapter neu aufsetzt und konfiguriert, wird sicher alle Optionen durch schauen. Wenn man aber ein Backup wiederherstellt mit jahrelangem Datenbestand und diese Änderung nicht bemerkt, hat man nachher u. U. Datenverlust. Eine richtig gute Lösung dafür fällt mir ehrlich gesagt auch nicht ein. Den Parameter ungefragt zu ändern ist vielleicht auch nicht der beste Weg. Evtl. ein Warnhinweis?
                                        • Marc Berg
                                          Steile These. Abgesehen davon, dass dieses Thema nichts mit dem backitup-Adapter Thema zu tun hat (in dessen Thread wir uns hier befinden) stimmt deine Vermutung meines Erachtens auch nicht. Wenn du das Thema "Vorhaltezeit im Influxdb Adapter" diskutieren möchtest, mach' bitte einen neuen Thread auf.
                                            Hallo @marc-berg ,
                                            ich glaube, Du hast mich falsch verstanden und will hier sicher niemanden nerven. Ich bin nicht der Ansicht, dass das Backup etwas falsches wiederhergestellt hat, sondern eher, dass dieser vermutlich irgendwann neu eingeführte Parameter etwas unglücklich ist (der setzt eh' nur die Retention in Influx, das könnte man auch selbst in Influx setzen.).
                                            Ich glaube aber, dass ein Benutzer, der eine Jahre alte IOBroker Instanz und einen Influx Datenbestand dazu am Ende eher nicht damit rechnet, dass nach der Wiederherstellung sein Datenbestand abgeschnitten wird - und das vielleicht auch nicht gleich bemerkt. Am Influx Adapter wird man da aber nichts ändern können, der ist ja so vermutlich schon seit längerem im Feld.
                                            Daher war meine Überlegung, dass eine Warnung bei einer Recovery für andere Nutzer hilfreich sein könnte. Denn getriggert wird das Symptom m. E. erst durch das Wiederherstellen eines Backups mit Einstellungen im InfluxDB Adapter.
                                            Ich werde aber ungefragt zu dem Thema hier nichts mehr schreiben. Wenn Ihr das nicht diskutieren wollt, respektiere ich das natürlich.
                                            170
                                            2780
                                            2372851
