    4. Test Adapter Adapter-alexa-timer-vis v0.1.x GitHub/Latest
    • Michael Roling
      Michael Roling Developer @Siggi0904 last edited by
      @siggi0904 schau mal hier https://github.com/MiRo1310/ioBroker.alexa-timer-vis/issues/64
      rtwl21 created this issue in MiRo1310/ioBroker.alexa-timer-vis
      closed Adapter funktioniert seit ein paar Tagen nicht mehr #64
        Siggi0904 @Michael Roling last edited by
        @michael-roling ne, das Thema ist mit der aktuellen Stable vom Alexa2-Adapter behoben.
        Bei neuen Timern triggert auch gut. Nur kann ich die Timer nicht abbrechen.
        Siehe og. Fehlerlog passt das Datenformat wohl nicht.
        Deswegen sieht das log ja aktuell so aus:
        2023-11-05 12:00:26.403 - warn: ical.0 (2578407) get state error: Connection is closed.
        2023-11-05 12:00:26.501 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-11-05 12:01:31.927 - error: alexa-timer-vis.0 (2566806) uncaught exception: Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
        2023-11-05 12:01:31.932 - error: alexa-timer-vis.0 (2566806) Error: Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
        at Validator.assertNumber (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:205:19)
        at AlexaTimerVis.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1718:31)
        at interval (/opt/iobroker/node_modules/iobroker.alexa-timer-vis/main.js:646:51)
        at /opt/iobroker/node_modules/iobroker.alexa-timer-vis/main.js:654:11
        at Timeout. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1720:38)
        at listOnTimeout (node:internal/timers:569:17)
        at process.processTimers (node:internal/timers:512:7)
        2023-11-05 12:01:31.932 - error: alexa-timer-vis.0 (2566806) Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
        2023-11-05 12:01:31.943 - info: alexa-timer-vis.0 (2566806) Apdater shuts down
        2023-11-05 12:01:31.948 - info: alexa-timer-vis.0 (2566806) Intervals and timeouts cleared!
        2023-11-05 12:01:31.953 - info: alexa-timer-vis.0 (2566806) terminating
        2023-11-05 12:01:31.955 - warn: alexa-timer-vis.0 (2566806) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-11-05 12:01:32.456 - info: alexa-timer-vis.0 (2566806) terminating
        2023-11-05 12:01:32.576 - error: host.iobroker instance system.adapter.alexa-timer-vis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-11-05 12:01:32.577 - info: host.iobroker Restart adapter system.adapter.alexa-timer-vis.0 because enabled
        2023-11-05 12:02:02.746 - info: host.iobroker instance system.adapter.alexa-timer-vis.0 started with pid 2581587
        2023-11-05 12:02:05.382 - info: alexa-timer-vis.0 (2581587) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.alexa-timer-vis, node: v18.18.2, js-controller: 5.0.12
        2023-11-05 12:02:05.446 - info: alexa-timer-vis.0 (2581587) Alexa State was found
        • Michael Roling
          Michael Roling Developer @Siggi0904 last edited by Michael Roling
          @siggi0904 wie brichst du ab? s
            @michael-roling Ansage "Alexa, Timer abbrechen"
            • Michael Roling
              @siggi0904 leider kann ich so nicht weiter helfen, bei mir läuft es ganz normal durch. welche version hast du denn installiert?
              sorry das steht ja im log, die 0.2.0
                @michael-roling ja, die stable 0.2.0 von deinem Adapter und Alexa2 Version 3.25.5.
                Ach ja, da fällt mir gleich noch was auf:
                Könntest du das Label des Timers aus dem Datenpunkt
                alexa2.0.Echo-Devices.G090L911746609UM.Timer.activeTimerList
                nehmen? Also den Label-Wert aus dem json von dem Datenpunkt?
                Der Text, der in History steht ist zu lang und beinhaltet den kompletten Aufruf.
                Z.B. "Neuer für die wäsche in Timer". Ich benenne nämlich gern die Timer.
                • Michael Roling
                  @siggi0904 du hast doch alles was man braucht 4b6e25a3-15a2-405c-91dd-206b6c0b7ddb-grafik.png
                  oder versteh ich dich da falsch.
                  Anscheinend gibt es immer noch probleme mit alexa2 und der aktualisierung, habe ich gerade mal die latest installiert, im moment geht aber garnichts.
                  Im Moment läuft es doch!
                    @michael-roling Naja, dein Adapter nennt den Timer "Neuer für die wäsche in Timer"
                    Alexa führt unter dem Datenpunkt "TimerID" den Timer mit dem richtigen Namen "Wäsche".
                    Konntest du dir schon das Abbrechen anschauen?
                    Also das falsche Datenformat?
                    Wo finde ich eigentlich den Datenpunkt: "timeout"
                    • Michael Roling
                      @siggi0904 poste mal das komplette log von dem adapter, setze vorher mal log auf debug, wie gesagt hier läuft es ganz normal durch
                        @michael-roling kann ich dir das per Mail senden?
                        Das ist ganz schön viel.
                        Aber jetzt hat er beim Abbrechen des Timers keinen Fehler erzeugt.
                        • Michael Roling
                          @siggi0904 solange kein fehler kommt nutzt das log nichts. mit dem Namen könnte ich mir mal anschauen, am besten ein issue auf machen
                            @michael-roling okay. Dann beobachte ich das und mach ggf. ein Issue auf.
                            Vielleicht dann auch die Feature Requests zum Adapter. 🙂
                            • FredF
                              FredF Most Active Forum Testing last edited by FredF
                              Nach längerer Zeit wollte ich den Adapter wieder nutzen und merke gerade er funktioniert nicht (mehr).
                              Adapter ist grün,
                              Timer Datenpunkt des alexa2.0 Adapters wird auch gefüllt wenn ein Timer eingestellt ist,
                              Debug Log gibt keine Fehlermeldung aus.
                              Ich bin ratlos @Michael-Roling
                              • Michael Roling
                                Michael Roling Developer @FredF last edited by
                                @fredf schau mal im Alexa2.0 Adapter. Da muss man meine ich optionen aktivieren damit etwas aktualisiert wird.
                                FredF 1 Reply Last reply Reply Quote 1
                                • FredF
                                  FredF Most Active Forum Testing @Michael Roling last edited by
                                  @michael-roling
                                  Ja, danke Fehler gefunden.
                                  Ohne die Verlaufseinstellungen im alexa2.0 Adapter aktiviert zu haben geht es nicht.
                                  31.7k
                                  79.8k
                                  92
                                  7278
