    3. Einsteigerfragen
    4. Keine Geräterkennung in Proxmox LXC Container Installation
      A Former User @ARO65 last edited by
      @aro65 sagte in Keine Geräterkennung in Proxmox LXC Container Installation:
      Könnt Ihr mir evtl. einen Tipp geben.
      Moin,
      willkommen im Club.
      Schau Dir erst einmal das hier an https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
      Dann kannst Du auch gleich mal noch den langen Output von, hier posten
      # iob diag
      VG
      Bernd
        ARO65 @Guest last edited by Homoran
        @dp20eic Hallo Danke für den Tipp.
        hier der Dialog.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: Proxmox181
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.3 LTS
                  Kernel: Linux 6.2.16-3-pve
            Architecture: x86-64
        model name      : Intel(R) N95
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         16:38:56 up 1 day,  7:23,  2 users,  load average: 0.07, 0.14, 0.15
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sun 2023-11-05 16:38:56 CET
                   Universal time: Sun 2023-11-05 15:38:56 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        aro
        /home/aro
        aro sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            4.1G        882M        2.7G        0.0K        515M        3.2G
        Swap:           512M        0.0K        511M
        Total:          4.6G        882M        3.2G
                 4096 M total memory
                  883 M used memory
                  170 M active memory
                 1160 M inactive memory
                 2697 M free memory
                    0 M buffer memory
                  515 M swap cache
                  512 M total swap
                    0 M used swap
                  511 M free swap
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--181--disk--0 ext4    63G  2.4G   57G   4% /
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs  7.7G     0  7.7G   0% /dev/shm
        tmpfs                            tmpfs  3.1G  116K  3.1G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--181--disk--0 ext4   rw,relatime,stripe=16
        /var:
        516M    /var/
        251M    /var/lib
        239M    /var/cache
        232M    /var/cache/apt
        156M    /var/lib/apt/lists
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        14M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        166M    /opt/iobroker/iobroker-data/
        123M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        find: Failed to change directory: /root: Permission denied
        find: Failed to restore initial working directory: /root: Permission denied
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.9~dfsg-1ubuntu3.1 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Proxmox181                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : Proxmox181                               -  enabled
        + system.adapter.discovery.0              : discovery             : Proxmox181                               -  enabled
        + system.adapter.history.0                : history               : Proxmox181                               -  enabled
        + system.adapter.jarvis.0                 : jarvis                : Proxmox181                               -  enabled
        + system.adapter.javascript.0             : javascript            : Proxmox181                               -  enabled
        + system.adapter.shelly.0                 : shelly                : Proxmox181                               -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.vis.0                    : vis                   : Proxmox181                               -  enabled
        + system.adapter.web.0                    : web                   : Proxmox181                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "shelly"       : 6.4.5    , installed 6.4.5
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        292
        States:         222
        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          35138774   1/init
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       35141083   402/io.jarvis.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       35325246   1098/io.shelly.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       35139904   113/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35137968   113/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          35138081   296/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        35140671   107/systemd-resolve
        tcp6       0      0 :::111                  :::*                    LISTEN      0          35138776   1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          35137509   1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          35138082   296/master
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35140735   149/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       35140974   387/io.web.0
        udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       35147332   357/io.discovery.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        35140670   107/systemd-resolve
        udp        0      0 192.168.1.181:68        0.0.0.0:*                           105        35139848   84/systemd-networkd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          35138775   1/init
        udp6       0      0 :::111                  :::*                                0          35138777   1/init
        2023-11-05 14:09:32.083  - error: host.Proxmox181 cannot call visUtils: Not exists
        2023-11-05 14:10:11.797  - info: discovery.0 (357) Discovering devices with a HF-LPB100 chipset...
        2023-11-05 14:10:11.799  - info: discovery.0 (357) Discovering mDNS devices...
        2023-11-05 14:10:11.800  - info: discovery.0 (357) Discovering ping devices...
        2023-11-05 14:10:11.809  - info: discovery.0 (357) Done discovering serial devices. 0 packages received
        2023-11-05 14:10:11.811  - info: discovery.0 (357) Discovering UPnP devices...
        2023-11-05 14:10:11.812  - info: discovery.0 (357) Discovering wifi-mi-light devices...
        2023-11-05 14:10:11.850  - warn: discovery.0 (357) tr-064.0 not installed
        2023-11-05 14:10:11.850  - info: discovery.0 (357) Done discovering tr064 devices. 0 packages received
        2023-11-05 14:10:13.812  - info: discovery.0 (357) Done discovering wifi-mi-light devices. 0 packages received
        2023-11-05 14:10:16.809  - info: discovery.0 (357) Done discovering udp devices. 1 packages received
        2023-11-05 14:10:21.801  - info: discovery.0 (357) Done discovering HF-LPB100 devices. 0 packages received
        2023-11-05 14:10:25.761  - info: discovery.0 (357) Done discovering ping devices. 1 packages received
        2023-11-05 14:10:26.801  - info: discovery.0 (357) Done discovering mdns devices. 3 packages received
        2023-11-05 14:10:26.812  - info: discovery.0 (357) Done discovering upnp devices. 89 packages received
        2023-11-05 14:10:28.353  - info: discovery.0 (357) Found 13 addresses
        2023-11-05 14:10:38.515  - info: discovery.0 (357) Discovery finished. Found new or modified 68 instances
        2023-11-05 14:10:38.542  - info: discovery.0 (357) Discovery finished
        2023-11-05 15:10:52.360  - info: admin.0 (149) <== Disconnect system.user.admin from ::ffff:192.168.1.143 admin
        2023-11-05 16:33:39.866  - info: admin.0 (149) failed connection to socket.io from ::ffff:192.168.1.143: Passport was not initialized
        2023-11-05 16:34:12.804  - info: admin.0 (149) ==> Connected system.user.admin from ::ffff:192.168.1.143
        2023-11-05 16:34:12.909  - error: host.Proxmox181 cannot call visUtils: Not exists
        2023-11-05 16:35:57.108  - info: admin.0 (149) ==> Connected system.user.admin from ::ffff:192.168.1.143
        2023-11-05 16:36:03.263  - info: admin.0 (149) <== Disconnect system.user.admin from ::ffff:192.168.1.143 javascript
        2023-11-05 16:39:13.144  - error: host.Proxmox181 cannot call visUtils: Not exists
        iob diag has finished.
        DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @ARO65 last edited by
          @aro65 bitte den Text in CODETAGS hier posten, danke.
            ARO65 @DJMarc75 last edited by
            @djmarc75 Hallo, danke dir mache ich morgen und melde dich. Sorry fange gerade erst an !
            A DJMarc75 Homoran 3 Replies Last reply Reply Quote 0
              ARO65 @ARO65 last edited by
              @aro65 Melde mich natürlich 🙂
                Thomas Braun Most Active @ARO65 last edited by Thomas Braun
                Du stehst in Verzeichnissen herum, in denen du nichts verloren hast.
                Und füg den aro in die Gruppe adm ein.
                sudo usermod -a -G adm aro
                exit
                • DJMarc75
                  Na dann:
                  • da_Woody
                    da_Woody @ARO65 last edited by da_Woody
                    @aro65 meine Meinung:
                    Iob in eine VM, den discovery Adapter braucht man nicht.
                    Warum Ubuntu?
                      Homoran Global Moderator Administrators @ARO65 last edited by
                      dann rein aus Neugierde:
                      Warum Container mit all seinen Stolperfallen und Warum Ubuntu?
                        ARO65 @Homoran last edited by
                        @homoran Tja, wie gesagt, ich fange erst an und kann hier nur bedingt mitreden.-. Habe mich mit Youtube Videos durchgehangelt und fand die Proxmox Installation mit den Containern interessant . Ubuntu wurde dort als Template empfohlen. Das hat ja auch eigentlich gut funktioniert 😞
                        Ich werde dann nochmal die VM Installation in Proxmox versuchen.
                        Welches Linux ist den zu empfehlen ? Spricht etwas gegen Ubuntu ?
                        Danke und Gruß Andreas
                          Ich würde das Original (Debian) immer der Kopie vorziehen.
                            ARO65 @Thomas Braun last edited by
                            @thomas-braun Danke Dir, teste ich. Das Forum ist klasse muss ich sagen und das man als Anfänger nicht gleich rund gemacht wird.
                            Grüße und noch einen schönen Abend Euch Allen
                            • da_Woody
                              @aro65 ja, da wird sehr gerne geholfen!
                              Die YT Videos sind meist uralt und großteils Mumpitz.
                              Da bekommt man immer alles frisch.
                                A Former User @da_Woody last edited by
                                @da_woody sagte in Keine Geräterkennung in Proxmox LXC Container Installation:
                                Moin,
                                da hat der liebe @da_Woody wohl den Link vergessen ⇒ https://www.iobroker.net/#de/documentation/install/proxmox.md
                                VG
                                Bernd
                                479
