    4. Autostart Problem
    Autostart Problem
      Revolution1993 last edited by
      @BuZZy Wenn ich systemctl status iobroker.service eingebe bekomme ich folgende Ausgabe:
      root@raspberrypi:/home/pi# systemctl status iobroker.service
      ● iobroker.service - LSB: starts ioBroker
         Loaded: loaded (/etc/init.d/iobroker.sh)
         Active: failed (Result: exit-code) since Do 2017-11-16 10:37:52 CET; 1h 50min       ago
        Process: 773 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=1/FA      ILURE)
      Nov 16 10:37:52 raspberrypi systemd[1]: Starting LSB: starts ioBroker...
      Nov 16 10:37:52 raspberrypi iobroker.sh[773]: Starting ioBrokersudo: Uh, Sie…den
      Nov 16 10:37:52 raspberrypi systemd[1]: iobroker.service: control process ex...1
      Nov 16 10:37:52 raspberrypi systemd[1]: Failed to start LSB: starts ioBroker.
      Nov 16 10:37:52 raspberrypi systemd[1]: Unit iobroker.service entered failed....
      Hint: Some lines were ellipsized, use -l to show in full.
      @knopers1
      Die Datei /etc/init.d/iobroker.sh sieht bei mir momentan so aus:
      #!/bin/bash
      ### BEGIN INIT INFO
      # Provides:          iobroker.sh
      # Required-Start:    $network $local_fs $remote_fs
      # Required-Stop::    $network $local_fs $remote_fs
      # Default-Start:     2 3 4 5
      # Default-Stop:      0 1 6
      # Short-Description: starts ioBroker
      # Description:       starts ioBroker
      ### END INIT INFO
      (( EUID )) && echo .You need to have root privileges.. && exit 1
      PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
      NODECMD=/usr/bin/node
      IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      RETVAL=0
      IOBROKERUSER=root
      start() {
                  export IOBROKER_HOME=/opt/iobroker
                  echo -n "Starting ioBroker"
                  sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                  RETVAL=$?
      stop() {
                  echo -n "Stopping ioBroker"
                  sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                  RETVAL=$?
      case "$1" in
          start)
            start
          stop)
            stop
          restart)
            stop
            start
            echo "Usage: iobroker {start|stop|restart}"
            exit 1
      esac
      exit $RETVAL
      Dominik
        knopers1 last edited by
        Ändere
        die Zeile
        in
        NODECMD=/usr/local/bin/node
        abspeichern und neustarten… und berichten.
          Habe es zu diesem Pfad umbenannt, abgespeichert und neu gestartet, aber Iobroker startet leider immer noch nicht 😞
          • BuZZy
            BuZZy last edited by
            Die Ausgabe von systemctl status iobroker.service wurde "beschnitten"..
            Versuch nochmal````
            systemctl status -l iobroker.service
            (das -l hinter "status" ist ein kleines L)
            Dann nochmal die Ausgabe posten.
            Der Eintrag NODECMD=/usr/bin/node ist schon korrekt.. (Auf meinem Raspberry 3 stimmt er zumindest).
              @Buzzy
              Ich erhalte dann folgende Ausgabe
              root@raspberrypi:/home/pi# systemctl status -l iobroker.service
                 Active: failed (Result: exit-code) since Do 2017-11-16 13:09:29 CET; 10min ago
                Process: 737 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=1/FAILURE)
              Nov 16 13:09:29 raspberrypi iobroker.sh[737]: Starting ioBrokersudo: Uh, Sie müssen ein TTY haben, um sudo zu verwenden
              Nov 16 13:09:29 raspberrypi systemd[1]: iobroker.service: control process exited, code=exited status=1
              Nov 16 13:09:29 raspberrypi systemd[1]: Failed to start LSB: starts ioBroker.Nov 16 13:09:29 raspberrypi systemd[1]: Unit iobroker.service entered failed state.
              Dominik
              • BuZZy
                Da blockiert das System..
                Siehe````
                ... Starting ioBrokersudo: Uh, Sie müssen ein TTY haben, um sudo zu verwenden
                Welches Betriebssystem verwendest du bzw. welche Version?
                Raspbian Jessie?
                Raspbian Stretch?
                nano /etc/sudoers
                Hast du da irgendwo sowas wie
                Defaults requiretty
                (Im "Nano Editor" scrollen mit den Pfeiltasten der Tastatur, beenden des Bearbeitungsmodus mit STRG+X)
                  Hi Buzzy,
                  Ich bin der Meinung dass auf meinem Raspberry momentan Raspian Jessie installiert ist.
                  Hab mir Mal die Datei sudoers angeschaut, da ist tatsächlich etwas mit requiretty.
                  GNU nano 2.2.6           Datei: /etc/sudoers
                  # This file MUST be edited with the 'visudo' command as root.
                  # Please consider adding local content in /etc/sudoers.d/ instead of
                  # directly modifying this file.
                  # See the man page for details on how to write a sudoers file.
                  Defaults        env_reset
                  Defaults        mail_badpass
                  Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
                  # Host alias specification
                  # User alias specification
                  # Cmnd alias specification
                  # User privilege specification
                  root    ALL=(ALL:ALL) ALL
                  # Allow members of group sudo to execute any command
                  %sudo   ALL=(ALL:ALL) ALL
                  # See sudoers(5) for more information on "#include" directives:
                  #includedir /etc/sudoers.d
                  #Für fhem damit dieses scripte im shell ausführen darf
                  Defaults requiretty
                  Defaults:%dialout !requiretty
                  Defaults:fhem !requiretty
                  fhem ALL=(ALL) NOPASSWD: ALL
                  Muss ich hier irgendwas anpassen?
                  Dominik
                  • BuZZy
                    Ja,
                    allerdings musst du jetzt zum Bearbeiten den Befehl````
                    visudo
                    Also:
                    visudo
                    Dann änderst du die vierte Zeile von unten:
                    von````
                    Defaults requiretty
                    ````in````
                    #Defaults requiretty
                    ````- also ein # vorne dran hängen um den Eintrag auszukommentieren. Dann speicherst du mit STRG+X und drückst J bzw. Y auf der Tastatur um das Überschreiben zu bestätigen. (je nachdem ob du deutsche oder englische Sprache auf dem Raspberry eingestellt hast).
                    Dann reboot und dann sollte es laufen.
                    Die Datei sollte nach dem Bearbeiten also so bei dir aussehen:
                    Defaults env_reset
                    • BuZZy
                      Und denk dran - diese Änderung die du vorhin vorgenommen hast rückgängig zu machen..
                      @knopers1:
                      Ändere die Zeile
                      ````..in..````
                        Ihr seid die besten. 🙂
                        Jetzt funktioniert der Autostart 😄
                        Ich habe die Änderungen in /etc/init.d wieder Rückgängig gemacht in NODECMD=/usr/bin/node.
                        Das auskommentieren des Befehls````
                        Jetzt startet das Programm wieder bei jedem neustart.
                        Besten Dank!
                        Dominik
                          LHBL2003 last edited by
                          Siehe nächsten Eintrag:
                            Hi, ich habe mir den Beitrag nochmal in Ruhe durchgelesen und hatte das selbe Problem.
                            Da man aus FEHM heraus gerne auch Linux System Befehle ausführen möchte, fügt man gerne kn die Datei
                            nano /etc/sudoers
                            Die folgenden Zeilen ein:
                            Defaults requiretty
                            Wobei die Zeile
                            Defaults requiretty
                            Gift für den Autostart vom ioBrocker ist.
                            Somit muss diese auskommentiert oder gelöscht werden:
                            Wobei ich noch nicht die Aufgabe von der Zeile geprüft habe, denn in FHEM kann ich dennoch SSH Befehle ausführen.
                            Dennoch danke für den Beitrag hier.
                              maik150 last edited by
                              Ich habe einen Pi2 mit Raspbian Stretch und bei mir startet der iobroker auch nicht automatisch.
                              der befehl
                              funktioniert nicht, da kommt folgendes
                              Unit iobroker.service could not be found.
                              habe dann
                              in die
                              /etc/sudoers
                              eingefügt, brachte aber keinen erfolg
                              meine Datei /etc/init.d/iobroker.sh sieht auch etwas anders aus
                              #!/bin/bash
                              ### BEGIN INIT INFO
                              ### END INIT INFO
                              NODECMD=@@node
                              RETVAL=0
                              IOBROKERUSER=@@user
                              start() {
                                          RETVAL=$?
                              stop() {
                                          RETVAL=$?
                              case "$1" in
                                  start)
                                    start
                                  stop)
                                    stop
                                  restart)
                                    stop
                                    start
                                    exit 1
                              esac
                              exit $RETVAL
                              Kann mir da einer weiterhelfen?
                              • BuZZy
                                Wenn dein System noch frisch ist und du noch nichts weiter konfiguriert hast, würde ich die Speicherkarte mit Raspbian Jessie neu beschreiben und dann nochmal iobroker frisch installieren.
                                Image Raspbian Jessie Lite gibt's hier:
                                https://downloads.raspberrypi.org/raspb … e-lite.zip
                                  Weil auf Jessie läuft iobroker stabiler als auf Strech?
                                  • BuZZy
                                    Hat bei mir mit Jessie sofort alles auf Anhieb geklappt und seit Installation nicht ein einziges mal Probleme gehabt. 😉
                                      Die npm dateien sind aber heute geändert worden.
                                      Müsste jetzt auch wieder mit stretch gehen.
                                      Gruß Rainer
                                        @Homoran:
                                        Gruß Rainer `
                                        und was muss ich dafür tun? 😄
                                        • Dutchman
                                          Neu drüber installieren
                                          Send from mobile device
                                            @Dutchman:
                                            Neu drüber installieren `
                                            "sudo iobroker update" reicht da nicht?
                                            1.2k
                                            81.1k
                                            47
                                            19618
