    4. Test Adapter Linux Control v1.x.x
    • Negalein
      @Scrounger
      kannst du zu meinem Issue irgendwas sagen?
      Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
      Er sagt irgendwas von invalid Characters. Aber welche?
      linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
      linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
      linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
      linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
      linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
      linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
      linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
      linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
      linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
      linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
      linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
      linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
      linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
      linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
      linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
      linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
      Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
      Aber warum? Ich hab nichts verändert an der Konfig.
      Was kann ich machen?
      • wendy2702
        wendy2702 @Negalein last edited by
        Das hakt ja schon hier:
        Gibt es den View noch?
        Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
        Wie sieht der aus?
        Gibt es das Device/laufwerk noch?
        • Negalein
          Negalein Global Moderator @wendy2702 last edited by Negalein
          @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
          Nein, hat es auch nie gegeben.
          10.0.1.201 = Proxmox
          10.0.1.202:8082/vis/index.html#080_System = ioB und die View heißt 080_System
          Gibt es das Device/laufwerk noch?>
          root@proxmox:~# ls -l /dev/disk/by-id/
          total 0
          lrwxrwxrwx 1 root root  9 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390 -> ../../sda
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part1 -> ../../sda1
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part2 -> ../../sda2
          lrwxrwxrwx 1 root root 10 Nov  6 05:06 ata-SanDisk_SDSSDH3_1T00_221348800390-part3 -> ../../sda3
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-root -> ../../dm-1
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-swap -> ../../dm-0
          lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-name-pve-vm--100--disk--0 -> ../../dm-6
          lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-name-pve-vm--101--disk--0 -> ../../dm-7
          lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-name-pve-vm--102--disk--0 -> ../../dm-8
          lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-name-pve-vm--103--disk--0 -> ../../dm-9
          lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-name-pve-vm--104--disk--0 -> ../../dm-10
          lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-name-pve-vm--105--disk--1 -> ../../dm-12
          lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--106--disk--0 -> ../../dm-11
          lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--107--disk--0 -> ../../dm-13
          lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxM3dxrDM3dBYhNgI8mpPV3YmfHk75VT2CZ -> ../../dm-8
          lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMEohxnWLY2pMegm2B06LWZhhOb4JtDLdQ -> ../../dm-6
          lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMOiAaJ18km9GOxKBboaWrAGtoGCssq5sm -> ../../dm-12
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMUldB8S2CZaYIN2ywWiLNCdTYvUJEz4ot -> ../../dm-0
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMdti3rBZdxZYTN3oDHliWCdLGGomqi2xj -> ../../dm-1
          lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMfdz28y3obse8csoHkDgVo2rTfBy8uJfJ -> ../../dm-9
          lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMiOEhJ1hibDoUrRctAkyzN2exdG1ZcgxU -> ../../dm-13
          lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMljq2p7vA13bd3yyKg19GNtsJ0RmMBuBi -> ../../dm-7
          lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMqu8b9ffqSwzJpJJH3V1dSl2uQhw8p3UP -> ../../dm-11
          lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMzv1OgYTuzbVrrzPLozpFivIdBr4F5xQv -> ../../dm-10
          lrwxrwxrwx 1 root root 10 Nov  6 05:06 lvm-pv-uuid-gELFXe-CNIv-TyOf-EVPI-b8LY-bEn2-Pct9zA -> ../../sda3
          lrwxrwxrwx 1 root root  9 Sep  7 13:58 wwn-0x5001b448b72fa263 -> ../../sda
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part1 -> ../../sda1
          lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part2 -> ../../sda2
          lrwxrwxrwx 1 root root 10 Nov  6 05:06 wwn-0x5001b448b72fa263-part3 -> ../../sda3
          7.2-7
          Meister Mopper crunchip wendy2702 3 Replies Last reply Reply Quote 0
          • Meister Mopper
            Meister Mopper @Negalein last edited by
            @negalein sagte in Test Adapter Linux Control v1.x.x:
            7.2-7
            Ich fahre die 8.x und habe mit dem Adapter keine Pobleme. Aber vielleicht gibt es ja jemanden, der mit 7.2-7 auch keine Probleme hat, dann könnte man das Problem mglw. eingrenzen.
            • Negalein
              Negalein Global Moderator @Meister Mopper last edited by
              @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
              komisch ist, dass vor JS-Controller 5 keine Probleme waren.
              Muss mir mal das Tut für das Update auf 8.x anschaun.
              Auf den ersten Blick sieht es sehr umfangreich aus. 😞
              • Meister Mopper
                Meister Mopper @Negalein last edited by Meister Mopper
                Es war nicht kompliziert und ich habe meine komplette HA-Umgebung binnen ca. einer Stunde auf 8.x gehoben. Läuft hier auch sehr stabil, keinerlei Ausfälle oder Störungen.
                Wenn du ein Backup des node hast, kannst du das ja zurückpfeifen.
                • Negalein
                  ich werde da zeitnah einen eigenen Thread erstellen (darf dich dann verlinken 😉 ). Ein paar Fragen/Problemchen stehen schon auf der Liste.
                  Wird hier sonst zu OT.
                    crunchip Forum Testing Most Active @Negalein last edited by
                    @negalein proxmox root und sudo? 🤔
                    • Negalein
                      Negalein Global Moderator @crunchip last edited by
                      @crunchip sagte in Test Adapter Linux Control v1.x.x:
                      habs gerade gesehn.
                      aber auch ohne sudo spinnt er rum.
                      • wendy2702
                        Gibt es dieses Object?
                        Eventuell auch ohne das „io“ am Anfang.
                        Du hast nach „by-Id“ abgefragt. Gibt es bei dir eventuell „x2….“ ?
                        Negalein 2 Replies Last reply Reply Quote 0
                        • Negalein
                          nein
                          total 0
                          • David G.
                            Evtl stehe ich grad voll am Schlauch.
                            Gibt's einen Menüpunkt im Adapter wo ich eigene globale Befehle hinterlegen kann die für jeden Host ausgeführt werden?
                            Irgendwie doof, ein und den selben Befehl x mal unter "Meine Befehle" für jeden Rechner anzulegen.
                            • Negalein
                              kannst du dir denken, was ich noch machen könnte?
                              läuft jetzt, nachdem ich ihn in den letzten Wochen bestimmt 20x neu installiert habe.
                              • Meister Mopper
                                Meister Mopper @David G. last edited by
                                @david-g
                                Ist das nicht geradezu ein Thema für github?
                                • David G.
                                  David G. @Meister Mopper last edited by
                                  @meister-mopper
                                  Falls deine Antwort in etwa:
                                  Nein, das geht aktuell nicht.
                                  ist, dann ja.
                                  Frage aber erstmal, bevor ich da was auf mache.
                                  • Meister Mopper
                                    @david-g sagte in Test Adapter Linux Control v1.x.x:
                                    Ist das jetzt Aggression, oder solte ich reagiern?
                                    • David G.
                                      David G. @Meister Mopper last edited by David G.
                                      @meister-mopper
                                      Ne, garnicht. Kein Funken Aggression.
                                      Wollte wirklich einfach vorher fragen.
                                      Hatte schon einige Adapter wo mir mobil nicht alles angezeigt wird (arbeite ausschließlich mobil(Auch wenn es in letzter Zeit nicht mehr vorgekommen ist.)).
                                      Auf git schreibe ich, wenn ich ein Issue hab oder ein Feature Request. Nicht bei einer Frage zum Adapter.
                                      https://github.com/Scrounger/ioBroker.linux-control/issues/59
                                      ipod86 created this issue in Scrounger/ioBroker.linux-control
                                      open [Feature Request] Eigene globale Befehle #59
                                      • David G.
                                        Habe jetzt mal ein paar Rechner im Adapter konfiguriert.
                                        2 Problemchsn habe ich.
                                        Auf einem Rechner kann ich kein Upgrade über
                                        linux-control.0.localhost.control.aptUpgrade
                                        anstoßen. Apt-update klappt.
                                        Es kommt als response:
                                        sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                                        Ich versuche mittels
                                        awk '{u=$2+$4; t=$2+$4+$5; if (NR==1){u1=u; t1=t;} else printf "%.2f\n", ($2+$4-u1) * 100 / (t-t1); }' \
                                        <(grep 'cpu ' /proc/stat) <(sleep 1;grep 'cpu ' /proc/stat)
                                        die aktuelle CPU-Auslastung auszulesen. In der Konsole klappt es auch. Der DP der von Linux control wird immer mit einer 0 befüllt.
                                        Im Log kommt:
                                        	[userCommandExecute] localhost (192.168.99.33:22, id: Cpu_Auslastung, description: ): response error: awk: cannot open /dev/fd/63 (No such file or directory), stack: ResponseError: [userCommandExecute] localhost (192.168.99.33:22, id: Cpu_Auslastung, description: ): awk: cannot open /dev/fd/63 (No such file or directory) at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:886:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21)
                                        • da_Woody
                                          da_Woody @David G. last edited by
                                          @david-g Upgrade groß geschrieben?
                                          • David G.
                                            David G. @da_Woody last edited by
                                            @da_woody
                                            Läuft ja über den DP vom Adapter.
                                            Was der da im Hintergrund sendet weiß ich nicht.
                                            Grizzelbee 1 Reply Last reply Reply Quote 0
                                            1.0k
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            165251
