    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Rolladenlevel Wert fehlerhaft CCU Homematic / IoBroker
    • KennyNinetySix
      KennyNinetySix @Homoran last edited by Homoran
      @homoran Es betrifft 2 HmiPW-DRBL4 die ich im Einsatz habe. Bei beiden sind diese Werte "fehlerhaft" Anbei die Passage aus dem Log:
      2023-11-06 20:47:59.009 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:0","VALUES"]
      2023-11-06 20:47:59.193 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:1","VALUES"]
      2023-11-06 20:47:59.277 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:2","VALUES"]
      2023-11-06 20:47:59.384 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:3","VALUES"]
      2023-11-06 20:47:59.488 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:4","VALUES"]
      2023-11-06 20:47:59.652 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:5","VALUES"]
      2023-11-06 20:47:59.739 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:6","VALUES"]
      2023-11-06 20:47:59.877 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:7","VALUES"]
      2023-11-06 20:47:59.984 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:8","VALUES"]
      2023-11-06 20:48:00.090 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:9","VALUES"]
      2023-11-06 20:48:00.191 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:10","VALUES"]
      2023-11-06 20:48:00.294 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:11","VALUES"]
      2023-11-06 20:48:00.417 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:12","VALUES"]
      2023-11-06 20:48:00.517 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:13","VALUES"]
      2023-11-06 20:48:00.606 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:14","VALUES"]
      2023-11-06 20:48:00.710 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:15","VALUES"]
      2023-11-06 20:48:00.814 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:16","VALUES"]
      2023-11-06 20:48:00.915 - info: hm-rpc.1 (6559) xmlrpc -> getParamsetDescription ["00165F29899020:17","VALUES"]
        Homoran Global Moderator Administrators @KennyNinetySix last edited by
        @kenny-miller sagte in Rolladenlevel Wert fehlerhaft CCU Homematic / IoBroker:
        Bei beiden
        haben die ein Icon in den Objekte n?
        KennyNinetySix 1 Reply Last reply Reply Quote 0
        • KennyNinetySix
          @homoran Was genau meinst du damit ?
            zeig mal
            • die seite Objekte mit den Geräten
            • die Konfiguration von HM rega
            wo läuft dein iobroker?
            • KennyNinetySix
              KennyNinetySix @Homoran last edited by KennyNinetySix
              @homoran IoBroker läuft auf einem Raspberry
                @kenny-miller ok, icon ist da, Konfiguration sieht plausibel aus.
                was ist mit der letzten Frage?
                bitte unbedingt lesen:
                • KennyNinetySix
                  @homoran steht ganz oben in der ersten zeile.
                      Guten Tag, leider fehlt mir ein Wert des Rolladenaktors. Gibt es eine Möglichkeit diese irgendwie zu
                      da steht nix
                      • KennyNinetySix
                        @homoran "@homoran IoBroker läuft auf einem Raspberry " ist ein Pi4*
                          läuft auf einem Raspberry"
                          ohne schnickschnack drumherum?
                          zeig mal die 2. Seite der Konfiguration von hm-rpc
                          • KennyNinetySix
                            @homoran Yes, ist nur Iobroker drauf
                              @kenny-miller das ist rega
                              • KennyNinetySix
                                  das hast du aber nachträglich editiert ohne Kennzeichnung! Genau wie jetzt wieder!
                                  lass das!
                                    @kenny-miller .4 ist der iobroker?
                                    • KennyNinetySix
                                      @homoran Yes
                                        @kenny-miller Dann fällt mir nichts mehr ein außer ccu (welche) neustarten.
                                        seit wann sind die Geräte angelernt?
                                        Seit wann zeigt es die Level nicht mehr an?
                                        KennyNinetySix 2 Replies Last reply Reply Quote 0
                                        • KennyNinetySix
                                          @homoran Neustart inkl neuaufsetzen wurde bereits gemacht. Hat nichts gebracht. Es hat noch nie funktioniert bei beiden aktoren nicht. Die Geräte sind auf dieser CCU nun seit 4 Monaten angelernt.
                                          • KennyNinetySix
                                            @homoran said in Rolladenlevel Wert fehlerhaft CCU Homematic / IoBroker:
                                            CCU3
                                            1901
