    3. Einsteigerfragen
    4. Installation
    5. keine Updates bei IOB mehr möglich
      Thomas Braun Most Active @ralle last edited by
      @ralle sagte in keine Updates bei IOB mehr möglich:
      wieder auf Node 18? Hatte auf 20 upgedatet da der link in den ersten Posts erwähnt wurde....
      Nein, mit
      iob nodejs-update
      kommst du auf die gerade empfohlene Version.
        ralle @Thomas Braun last edited by
        @thomas-braun said in keine Updates bei IOB mehr möglich:
        iob diag
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         20:49:05 up 31 min,  2 users,  load average: 0.40, 2.03, 2.77
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-11-06 20:49:05 CET
                   Universal time: Mon 2023-11-06 19:49:05 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        116M        6.6G        1.0M        1.1G        7.6G
        Swap:            99M          0B         99M
        Total:          7.9G        116M        6.7G
                 7812 M total memory
                  116 M used memory
                  133 M active memory
                  747 M inactive memory
                 6573 M free memory
                  234 M buffer memory
                  887 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       15G   11G  3.3G  77% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
        [Mon Nov  6 20:17:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:65:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d0e90a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Nov  6 20:17:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Nov  6 20:17:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Nov  6 20:17:17 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.9G    /var/
        1.5G    /var/log/journal/9de79e4d9feb4ead979df62e580afcd8
        1.5G    /var/log
        129M    /var/cache
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        162M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.6G    /opt/iobroker/iobroker-data/
        899M    /opt/iobroker/iobroker-data/history
        617M    /opt/iobroker/iobroker-data/files
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
        22M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
        npm ERR! extraneous: @types/ws@8.5.8 /opt/iobroker/node_modules/@types/ws
        npm ERR! invalid: iobroker.worx@2.3.4 /opt/iobroker/node_modules/iobroker.worx
        npm ERR! extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
        npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
        npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/duplexify
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/isarray
        npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder
        npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
        npm ERR! extraneous: @ampproject/remapping@2.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@ampproject/remapping
        npm ERR! extraneous: @babel/code-frame@7.22.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame
        npm ERR! extraneous: @babel/compat-data@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/compat-data
        npm ERR! extraneous: @babel/core@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core
        npm ERR! extraneous: @babel/generator@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/generator
        npm ERR! extraneous: @babel/helper-compilation-targets@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets
        npm ERR! extraneous: @babel/helper-environment-visitor@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-environment-visitor
        npm ERR! extraneous: @babel/helper-function-name@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-function-name
        npm ERR! extraneous: @babel/helper-hoist-variables@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-hoist-variables
        npm ERR! extraneous: @babel/helper-module-imports@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-imports
        npm ERR! extraneous: @babel/helper-module-transforms@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-transforms
        npm ERR! extraneous: @babel/helper-plugin-utils@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-plugin-utils
        npm ERR! extraneous: @babel/helper-simple-access@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-simple-access
        npm ERR! extraneous: @babel/helper-split-export-declaration@7.22.6 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-split-export-declaration
        npm ERR! extraneous: @babel/helper-string-parser@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-string-parser
        npm ERR! extraneous: @babel/helper-validator-identifier@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-identifier
        npm ERR! extraneous: @babel/helper-validator-option@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-option
        npm ERR! extraneous: @babel/helpers@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helpers
        npm ERR! extraneous: @babel/highlight@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight
        npm ERR! extraneous: @babel/parser@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/parser
        npm ERR! extraneous: @babel/plugin-syntax-async-generators@7.8.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-async-generators
        npm ERR! extraneous: @babel/plugin-syntax-bigint@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-bigint
        npm ERR! extraneous: @babel/plugin-syntax-class-properties@7.12.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-class-properties
        npm ERR! extraneous: @babel/plugin-syntax-import-meta@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-import-meta
        npm ERR! extraneous: @babel/plugin-syntax-json-strings@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-json-strings
        npm ERR! extraneous: @babel/plugin-syntax-logical-assignment-operators@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-logical-assignment-operators
        npm ERR! extraneous: @babel/plugin-syntax-nullish-coalescing-operator@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-nullish-coalescing-operator
        npm ERR! extraneous: @babel/plugin-syntax-numeric-separator@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-numeric-separator
        npm ERR! extraneous: @babel/plugin-syntax-object-rest-spread@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-object-rest-spread
        npm ERR! extraneous: @babel/plugin-syntax-optional-catch-binding@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-catch-binding
        npm ERR! extraneous: @babel/plugin-syntax-optional-chaining@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-chaining
        npm ERR! extraneous: @babel/plugin-syntax-top-level-await@7.14.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-top-level-await
        npm ERR! extraneous: @babel/plugin-syntax-typescript@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-typescript
        npm ERR! extraneous: @babel/template@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/template
        npm ERR! extraneous: @babel/traverse@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/traverse
        npm ERR! extraneous: @babel/types@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/types
        npm ERR! extraneous: @bcoe/v8-coverage@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/@bcoe/v8-coverage
        npm ERR! extraneous: @hapi/hoek@9.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/hoek
        npm ERR! extraneous: @hapi/topo@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/topo
        npm ERR! extraneous: @istanbuljs/load-nyc-config@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/load-nyc-config
        npm ERR! extraneous: @istanbuljs/schema@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/schema
        npm ERR! extraneous: @jest/console@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/console
        npm ERR! extraneous: @jest/core@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/core
        npm ERR! extraneous: @jest/environment@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/environment
        npm ERR! extraneous: @jest/fake-timers@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/fake-timers
        npm ERR! extraneous: @jest/globals@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/globals
        npm ERR! extraneous: @jest/reporters@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/reporters
        npm ERR! extraneous: @jest/source-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/source-map
        npm ERR! extraneous: @jest/test-result@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-result
        npm ERR! extraneous: @jest/test-sequencer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-sequencer
        npm ERR! extraneous: @jest/transform@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/transform
        npm ERR! extraneous: @jest/types@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/types
        npm ERR! extraneous: @jridgewell/gen-mapping@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/gen-mapping
        npm ERR! extraneous: @jridgewell/resolve-uri@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/resolve-uri
        npm ERR! extraneous: @jridgewell/set-array@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/set-array
        npm ERR! extraneous: @jridgewell/sourcemap-codec@1.4.15 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/sourcemap-codec
        npm ERR! extraneous: @jridgewell/trace-mapping@0.3.20 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/trace-mapping
        npm ERR! extraneous: @sideway/address@4.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/address
        npm ERR! extraneous: @sideway/formula@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/formula
        npm ERR! extraneous: @sideway/pinpoint@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/pinpoint
        npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/commons
        npm ERR! extraneous: @sinonjs/fake-timers@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/fake-timers
        npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@tootallnate/once
        npm ERR! extraneous: @types/babel__core@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__core
        npm ERR! extraneous: @types/babel__generator@7.6.6 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__generator
        npm ERR! extraneous: @types/babel__template@7.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__template
        npm ERR! extraneous: @types/babel__traverse@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__traverse
        npm ERR! extraneous: @types/crypto-js@3.1.47 /opt/iobroker/node_modules/aws-crt/node_modules/@types/crypto-js
        npm ERR! extraneous: @types/graceful-fs@4.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/@types/graceful-fs
        npm ERR! extraneous: @types/istanbul-lib-coverage@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-coverage
        npm ERR! extraneous: @types/istanbul-lib-report@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-report
        npm ERR! extraneous: @types/istanbul-reports@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-reports
        npm ERR! extraneous: @types/jest@27.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/jest
        npm ERR! extraneous: @types/prettier@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/@types/prettier
        npm ERR! extraneous: @types/puppeteer@5.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/puppeteer
        npm ERR! extraneous: @types/stack-utils@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/stack-utils
        npm ERR! extraneous: @types/uuid@3.4.12 /opt/iobroker/node_modules/aws-crt/node_modules/@types/uuid
        npm ERR! extraneous: @types/yargs-parser@21.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs-parser
        npm ERR! extraneous: @types/yargs@16.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs
        npm ERR! extraneous: @types/yauzl@2.10.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yauzl
        npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/abab
        npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals
        npm ERR! extraneous: acorn-walk@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-walk
        npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/aws-crt/node_modules/acorn
        npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/agent-base
        npm ERR! extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes
        npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex
        npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles
        npm ERR! extraneous: ansi@0.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/ansi
        npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/anymatch
        npm ERR! extraneous: are-we-there-yet@1.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet
        npm ERR! extraneous: argparse@1.0.10 /opt/iobroker/node_modules/aws-crt/node_modules/argparse
        npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/arr-union
        npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/asynckit
        npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays
        npm ERR! extraneous: aws-sdk@2.1488.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk
        npm ERR! extraneous: babel-jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest
        npm ERR! extraneous: babel-plugin-istanbul@6.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul
        npm ERR! extraneous: babel-plugin-jest-hoist@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-jest-hoist
        npm ERR! extraneous: babel-preset-current-node-syntax@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-current-node-syntax
        npm ERR! extraneous: babel-preset-jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-jest
        npm ERR! extraneous: big-integer@1.6.51 /opt/iobroker/node_modules/aws-crt/node_modules/big-integer
        npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/binary
        npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/bluebird
        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/braces
        npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime
        npm ERR! extraneous: browserslist@4.22.1 /opt/iobroker/node_modules/aws-crt/node_modules/browserslist
        npm ERR! extraneous: bs-logger@0.2.6 /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger
        npm ERR! extraneous: bser@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/bser
        npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32
        npm ERR! extraneous: buffer-indexof-polyfill@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill
        npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims
        npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/buffers
        npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/call-bind
        npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/callsites
        npm ERR! extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/camelcase
        npm ERR! extraneous: caniuse-lite@1.0.30001561 /opt/iobroker/node_modules/aws-crt/node_modules/caniuse-lite
        npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/chainsaw
        npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/chalk
        npm ERR! extraneous: char-regex@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/char-regex
        npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/chownr
        npm ERR! extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/ci-info
        npm ERR! extraneous: cjs-module-lexer@1.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/cjs-module-lexer
        npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cliui
        npm ERR! extraneous: clone-deep@0.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep
        npm ERR! extraneous: cmake-js@6.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js
        npm ERR! extraneous: co@4.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/co
        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at
        npm ERR! extraneous: collect-v8-coverage@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage
        npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/color-convert
        npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/color-name
        npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/combined-stream
        npm ERR! extraneous: commander@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/commander
        npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map
        npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn
        npm ERR! extraneous: cssom@0.4.4 /opt/iobroker/node_modules/aws-crt/node_modules/cssom
        npm ERR! extraneous: cssstyle@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle
        npm ERR! extraneous: cwd@0.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/cwd
        npm ERR! extraneous: data-urls@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/data-urls
        npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/decamelize
        npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/decimal.js
        npm ERR! extraneous: dedent@0.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/dedent
        npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend
        npm ERR! extraneous: deepmerge@4.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/deepmerge
        npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property
        npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/delayed-stream
        npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/delegates
        npm ERR! extraneous: detect-newline@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/detect-newline
        npm ERR! extraneous: diff-sequences@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/diff-sequences
        npm ERR! extraneous: domexception@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/domexception
        npm ERR! extraneous: duplexer2@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2
        npm ERR! extraneous: electron-to-chromium@1.4.576 /opt/iobroker/node_modules/aws-crt/node_modules/electron-to-chromium
        npm ERR! extraneous: emittery@0.8.1 /opt/iobroker/node_modules/aws-crt/node_modules/emittery
        npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex
        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/error-ex
        npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/escalade
        npm ERR! extraneous: escape-string-regexp@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp
        npm ERR! extraneous: escodegen@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/escodegen
        npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/esprima
        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/estraverse
        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/esutils
        npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/events
        npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/execa
        npm ERR! extraneous: exit@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/exit
        npm ERR! extraneous: expand-tilde@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde
        npm ERR! extraneous: expect-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/expect-puppeteer
        npm ERR! extraneous: expect@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/expect
        npm ERR! extraneous: extract-zip@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip
        npm ERR! extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify
        npm ERR! extraneous: fb-watchman@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/fb-watchman
        npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer
        npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/fill-range
        npm ERR! extraneous: find-file-up@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/find-file-up
        npm ERR! extraneous: find-pkg@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/find-pkg
        npm ERR! extraneous: find-process@1.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/find-process
        npm ERR! extraneous: find-up@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/find-up
        npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/for-each
        npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/for-in
        npm ERR! extraneous: for-own@0.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/for-own
        npm ERR! extraneous: form-data@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/form-data
        npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants
        npm ERR! extraneous: fs-exists-sync@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-exists-sync
        npm ERR! extraneous: fs-extra@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-extra
        npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass
        npm ERR! extraneous: fstream@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/fstream
        npm ERR! extraneous: function-bind@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/function-bind
        npm ERR! extraneous: gauge@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/gauge
        npm ERR! extraneous: gensync@1.0.0-beta.2 /opt/iobroker/node_modules/aws-crt/node_modules/gensync
        npm ERR! extraneous: get-caller-file@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file
        npm ERR! extraneous: get-intrinsic@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic
        npm ERR! extraneous: get-package-type@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type
        npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/get-stream
        npm ERR! extraneous: global-modules@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/global-modules
        npm ERR! extraneous: global-prefix@0.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/global-prefix
        npm ERR! extraneous: globals@11.12.0 /opt/iobroker/node_modules/aws-crt/node_modules/globals
        npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/gopd
        npm ERR! extraneous: graceful-fs@4.2.11 /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs
        npm ERR! extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/has-flag
        npm ERR! extraneous: has-property-descriptors@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors
        npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-proto
        npm ERR! extraneous: has-symbols@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/has-symbols
        npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag
        npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-unicode
        npm ERR! extraneous: hasown@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/hasown
        npm ERR! extraneous: homedir-polyfill@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/homedir-polyfill
        npm ERR! extraneous: html-encoding-sniffer@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/html-encoding-sniffer
        npm ERR! extraneous: html-escaper@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/html-escaper
        npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/http-proxy-agent
        npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/https-proxy-agent
        npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/human-signals
        npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite
        npm ERR! extraneous: import-local@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/import-local
        npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash
        npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/ini
        npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/invert-kv
        npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments
        npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-arrayish
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer
        npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/is-callable
        npm ERR! extraneous: is-core-module@2.13.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module
        npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable
        npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point
        npm ERR! extraneous: is-generator-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-fn
        npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function
        npm ERR! extraneous: is-iojs@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-iojs
        npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-number
        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/is-plain-object
        npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-potential-custom-element-name
        npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-stream
        npm ERR! extraneous: is-typed-array@1.1.12 /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array
        npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray
        npm ERR! extraneous: is-windows@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-windows
        npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/isexe
        npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/isobject
        npm ERR! extraneous: istanbul-lib-coverage@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage
        npm ERR! extraneous: istanbul-lib-instrument@5.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument
        npm ERR! extraneous: istanbul-lib-report@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report
        npm ERR! extraneous: istanbul-lib-source-maps@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps
        npm ERR! extraneous: istanbul-reports@3.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports
        npm ERR! extraneous: jest-changed-files@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files
        npm ERR! extraneous: jest-circus@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-circus
        npm ERR! extraneous: jest-cli@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli
        npm ERR! extraneous: jest-config@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-config
        npm ERR! extraneous: jest-dev-server@5.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/jest-dev-server
        npm ERR! extraneous: jest-diff@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-diff
        npm ERR! extraneous: jest-docblock@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-docblock
        npm ERR! extraneous: jest-each@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-each
        npm ERR! extraneous: jest-environment-jsdom@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-jsdom
        npm ERR! extraneous: jest-environment-node@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-node
        npm ERR! extraneous: jest-environment-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-puppeteer
        npm ERR! extraneous: jest-get-type@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-get-type
        npm ERR! extraneous: jest-haste-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map
        npm ERR! extraneous: jest-jasmine2@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-jasmine2
        npm ERR! extraneous: jest-leak-detector@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-leak-detector
        npm ERR! extraneous: jest-matcher-utils@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils
        npm ERR! extraneous: jest-message-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util
        npm ERR! extraneous: jest-mock@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock
        npm ERR! extraneous: jest-pnp-resolver@1.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/jest-pnp-resolver
        npm ERR! extraneous: jest-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-puppeteer
        npm ERR! extraneous: jest-regex-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util
        npm ERR! extraneous: jest-resolve-dependencies@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies
        npm ERR! extraneous: jest-resolve@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve
        npm ERR! extraneous: jest-runner@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner
        npm ERR! extraneous: jest-runtime@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime
        npm ERR! extraneous: jest-serializer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-serializer
        npm ERR! extraneous: jest-snapshot@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot
        npm ERR! extraneous: jest-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-util
        npm ERR! extraneous: jest-validate@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate
        npm ERR! extraneous: jest-watcher@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher
        npm ERR! extraneous: jest-worker@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker
        npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest
        npm ERR! extraneous: jmespath@0.16.0 /opt/iobroker/node_modules/aws-crt/node_modules/jmespath
        npm ERR! extraneous: joi@17.11.0 /opt/iobroker/node_modules/aws-crt/node_modules/joi
        npm ERR! extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens
        npm ERR! extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml
        npm ERR! extraneous: jsdom@16.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom
        npm ERR! extraneous: jsesc@2.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/jsesc
        npm ERR! extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors
        npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/json5
        npm ERR! extraneous: jsonc-parser@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser
        npm ERR! extraneous: jsonfile@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsonfile
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/kind-of
        npm ERR! extraneous: kleur@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/kleur
        npm ERR! extraneous: lazy-cache@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/lazy-cache
        npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/lcid
        npm ERR! extraneous: leven@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/leven
        npm ERR! extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns
        npm ERR! extraneous: listenercount@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/listenercount
        npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/locate-path
        npm ERR! extraneous: lodash.memoize@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.memoize
        npm ERR! extraneous: lodash.pad@4.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.pad
        npm ERR! extraneous: lodash.padend@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padend
        npm ERR! extraneous: lodash.padstart@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padstart
        npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/aws-crt/node_modules/lodash
        npm ERR! extraneous: lru-cache@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/lru-cache
        npm ERR! extraneous: lunr@2.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/lunr
        npm ERR! extraneous: make-dir@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir
        npm ERR! extraneous: make-error@1.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/make-error
        npm ERR! extraneous: makeerror@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/makeerror
        npm ERR! extraneous: marked@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/marked
        npm ERR! extraneous: memory-stream@0.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream
        npm ERR! extraneous: merge-deep@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/merge-deep
        npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/merge-stream
        npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/micromatch
        npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime-db
        npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/aws-crt/node_modules/mime-types
        npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime
        npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/mimic-fn
        npm ERR! extraneous: minipass@3.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/minipass
        npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib
        npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object
        npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp-classic
        npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp
        npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/natural-compare
        npm ERR! extraneous: node-int64@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/node-int64
        npm ERR! extraneous: node-releases@2.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/node-releases
        npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/normalize-path
        npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/npm-run-path
        npm ERR! extraneous: npmlog@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/npmlog
        npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/number-is-nan
        npm ERR! extraneous: nwsapi@2.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/nwsapi
        npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/onetime
        npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/os-homedir
        npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/os-locale
        npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-limit
        npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-locate
        npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-try
        npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-json
        npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-passwd
        npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/parse5
        npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/path-exists
        npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-key
        npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/path-parse
        npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pend
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/picocolors
        npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/picomatch
        npm ERR! extraneous: pirates@4.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/pirates
        npm ERR! extraneous: pkg-dir@4.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pkg-dir
        npm ERR! extraneous: pretty-format@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format
        npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/progress
        npm ERR! extraneous: prompts@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/prompts
        npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/proxy-from-env
        npm ERR! extraneous: psl@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/psl
        npm ERR! extraneous: punycode@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/punycode
        npm ERR! extraneous: puppeteer@3.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer
        npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystring
        npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystringify
        npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/rc
        npm ERR! extraneous: react-is@17.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/react-is
        npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/require-directory
        npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/requires-port
        npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-cwd
        npm ERR! extraneous: resolve-dir@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-dir
        npm ERR! extraneous: resolve-from@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-from
        npm ERR! extraneous: resolve.exports@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve.exports
        npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/aws-crt/node_modules/resolve
        npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/rimraf
        npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs
        npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/safer-buffer
        npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/sax
        npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/saxes
        npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/semver
        npm ERR! extraneous: set-function-length@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/set-function-length
        npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/setimmediate
        npm ERR! extraneous: shallow-clone@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone
        npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-command
        npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-regex
        npm ERR! extraneous: shiki@0.10.1 /opt/iobroker/node_modules/aws-crt/node_modules/shiki
        npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/signal-exit
        npm ERR! extraneous: sisteransi@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/sisteransi
        npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/slash
        npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/aws-crt/node_modules/source-map-support
        npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/source-map
        npm ERR! extraneous: spawnd@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/spawnd
        npm ERR! extraneous: splitargs@0.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/splitargs
        npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/sprintf-js
        npm ERR! extraneous: stack-utils@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/stack-utils
        npm ERR! extraneous: string-length@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/string-length
        npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/string-width
        npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-ansi
        npm ERR! extraneous: strip-bom@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-bom
        npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-final-newline
        npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-json-comments
        npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-color
        npm ERR! extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-hyperlinks
        npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-preserve-symlinks-flag
        npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/symbol-tree
        npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs
        npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream
        npm ERR! extraneous: tar@6.1.11 /opt/iobroker/node_modules/aws-crt/node_modules/tar
        npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/terminal-link
        npm ERR! extraneous: test-exclude@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/test-exclude
        npm ERR! extraneous: throat@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/throat
        npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/through
        npm ERR! extraneous: tmpl@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/tmpl
        npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/to-fast-properties
        npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/to-regex-range
        npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie
        npm ERR! extraneous: tr46@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/tr46
        npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/traverse
        npm ERR! extraneous: tree-kill@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/tree-kill
        npm ERR! extraneous: ts-jest@27.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest
        npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/type-detect
        npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/aws-crt/node_modules/type-fest
        npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray-to-buffer
        npm ERR! extraneous: typedoc-plugin-merge-modules@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc-plugin-merge-modules
        npm ERR! extraneous: typedoc@0.22.18 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/typescript
        npm ERR! extraneous: unbzip2-stream@1.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream
        npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/universalify
        npm ERR! extraneous: unzipper@0.8.14 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper
        npm ERR! extraneous: update-browserslist-db@1.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/update-browserslist-db
        npm ERR! extraneous: url-join@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/url-join
        npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/aws-crt/node_modules/url-parse
        npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/aws-crt/node_modules/url
        npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-crt/node_modules/util
        npm ERR! extraneous: uuid@8.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/uuid
        npm ERR! extraneous: v8-to-istanbul@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul
        npm ERR! extraneous: vscode-oniguruma@1.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-oniguruma
        npm ERR! extraneous: vscode-textmate@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-textmate
        npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-hr-time
        npm ERR! extraneous: w3c-xmlserializer@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-xmlserializer
        npm ERR! extraneous: wait-on@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on
        npm ERR! extraneous: wait-port@0.2.14 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port
        npm ERR! extraneous: walker@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/walker
        npm ERR! extraneous: webidl-conversions@6.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/webidl-conversions
        npm ERR! extraneous: whatwg-encoding@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-encoding
        npm ERR! extraneous: whatwg-mimetype@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-mimetype
        npm ERR! extraneous: whatwg-url@8.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-url
        npm ERR! extraneous: which-typed-array@1.1.13 /opt/iobroker/node_modules/aws-crt/node_modules/which-typed-array
        npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/which
        npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/window-size
        npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wrap-ansi
        npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/write-file-atomic
        npm ERR! extraneous: xml-name-validator@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml-name-validator
        npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml2js
        npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/xmlbuilder
        npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/xmlchars
        npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/y18n
        npm ERR! extraneous: yallist@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yallist
        npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/aws-crt/node_modules/yargs-parser
        npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/yargs
        npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/yauzl
        npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/ansi-styles
        npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/chalk
        npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-convert
        npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-name
        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/escape-string-regexp
        npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/has-flag
        npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/supports-color
        npm ERR! extraneous: convert-source-map@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/convert-source-map
        npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/semver
        npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets/node_modules/semver
        npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/ansi-styles
        npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/chalk
        npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-convert
        npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-name
        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/escape-string-regexp
        npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/has-flag
        npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/supports-color
        npm ERR! extraneous: acorn@7.4.1 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals/node_modules/acorn
        npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/buffer
        npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/uuid
        npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/ansi-regex
        npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/axios
        npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/camelcase
        npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/chownr
        npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/cliui
        npm ERR! extraneous: fs-minipass@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/fs-minipass
        npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/is-fullwidth-code-point
        npm ERR! extraneous: minipass@2.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minipass
        npm ERR! extraneous: minizlib@1.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minizlib
        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/mkdirp
        npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/string-width
        npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/strip-ansi
        npm ERR! extraneous: tar@4.4.19 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/tar
        npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/wrap-ansi
        npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/y18n
        npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/yargs
        npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn/node_modules/which
        npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle/node_modules/cssom
        npm ERR! extraneous: webidl-conversions@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/domexception/node_modules/webidl-conversions
        npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip/node_modules/get-stream
        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/mkdirp
        npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/rimraf
        npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument/node_modules/semver
        npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/cliui
        npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/yargs
        npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/lru-cache
        npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/semver
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/yallist
        npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate/node_modules/camelcase
        npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker/node_modules/supports-color
        npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom/node_modules/ws
        npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/lru-cache
        npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/semver
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/yallist
        npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/isarray
        npm ERR! extraneous: readable-stream@1.0.34 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/string_decoder
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minipass/node_modules/yallist
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib/node_modules/yallist
        npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object/node_modules/for-in
        npm ERR! extraneous: ansi-styles@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format/node_modules/ansi-styles
        npm ERR! extraneous: agent-base@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/agent-base
        npm ERR! extraneous: https-proxy-agent@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/https-proxy-agent
        npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/ws
        npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/rc/node_modules/strip-json-comments
        npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs/node_modules/tslib
        npm ERR! extraneous: kind-of@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/kind-of
        npm ERR! extraneous: lazy-cache@0.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/lazy-cache
        npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs/node_modules/chownr
        npm ERR! extraneous: readable-stream@3.6.2 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream/node_modules/readable-stream
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar/node_modules/yallist
        npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie/node_modules/universalify
        npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/lru-cache
        npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/semver
        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/yallist
        npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/brace-expansion
        npm ERR! extraneous: glob@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/glob
        npm ERR! extraneous: minimatch@5.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/minimatch
        npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream/node_modules/buffer
        npm ERR! extraneous: bluebird@3.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/bluebird
        npm ERR! extraneous: process-nextick-args@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/process-nextick-args
        npm ERR! extraneous: readable-stream@2.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/string_decoder
        npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/url/node_modules/punycode
        npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul/node_modules/source-map
        npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on/node_modules/axios
        npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/ansi-styles
        npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/chalk
        npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-convert
        npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-name
        npm ERR! extraneous: commander@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/commander
        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/escape-string-regexp
        npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/has-flag
        npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/supports-color
        npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yargs/node_modules/yargs-parser
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-06T19_49_13_303Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.4
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-06T19_49_44_467Z-debug-0.log
        Adapters from github:   7
        Adapter State
          system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.bidirectional-counter.0  : bidirectional-counter : raspberrypi                              - disabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
          system.adapter.deyeidc.1                : deyeidc               : raspberrypi                              -  enabled, port: 8899
          system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              - disabled
          system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.material.0               : material              : raspberrypi                              -  enabled
          system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
          system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
          system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.tuya.1                   : tuya                  : raspberrypi                              - disabled
          system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
        Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "landroid"     : 1.0.3    , installed 1.0.3
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.4.5    , installed 6.4.5
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "telegram-menu": 0.7.1    , installed 0.7.1
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vaillant"     : 0.1.2    , installed 0.2.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.1.4    , installed 6.1.4
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        33316
        States:         26083
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13873      531/cupsd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12106      556/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13872      531/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12108      556/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12011      394/avahi-daemon: r
        udp        0      0 0.0.0.0:35226           0.0.0.0:*                           108        12013      394/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13910      560/cups-browsed
        udp6       0      0 :::5353                 :::*                                108        12012      394/avahi-daemon: r
        udp6       0      0 fe80::74d7:97e8:dd2:546 :::*                                0          15272      404/NetworkManager
        udp6       0      0 :::58181                :::*                                108        12014      394/avahi-daemon: r
        2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.deyeidc.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:34.282  - info: host.raspberrypi instance system.adapter.ws.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:35.104  - info: tuya.0 (3860) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-06 20:40:34.301  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:34.302  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:35.495  - info: tuya.0 (3860) terminating
        2023-11-06 20:40:35.496  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
        2023-11-06 20:40:35.497  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
        2023-11-06 20:40:35.497  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGTERM
        2023-11-06 20:40:35.497  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
        2023-11-06 20:40:35.498  - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGTERM
        2023-11-06 20:40:35.498  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
        2023-11-06 20:40:35.498  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
        2023-11-06 20:40:35.498  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
        2023-11-06 20:40:35.499  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
        2023-11-06 20:40:35.499  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
        2023-11-06 20:40:35.499  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
        2023-11-06 20:40:35.499  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
        2023-11-06 20:40:35.500  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:35.734  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2023-11-06 20:40:35.905  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-06 20:40:35.906  - info: host.raspberrypi All instances are stopped.
        2023-11-06 20:40:36.030  - info: host.raspberrypi terminated
        iob diag has finished.
        Press any key for a summary
                                v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        MEMORY:
        Mem:            7.8G        115M        6.6G        1.0M        1.1G        7.6G
        Swap:            99M          0B         99M
        Total:          7.9G        115M        6.7G
        Active iob-Instances:   1
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.12.0
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects:                33316
        States:                 26083
        Size of iob-Database:
        22M     /opt/iobroker/iobroker-data/objects.jsonl
        7.2M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Thomas Braun Most Active @ralle last edited by Thomas Braun
          @ralle sagte in keine Updates bei IOB mehr möglich:
          iobroker.worx
          Der ist krumm installiert.
          iob upgrade worx@2.3.4
          Und
          iob start
          sagt?
            ralle @Thomas Braun last edited by
            iob start hab ich gemacht, iob kann ich aufrufen.
            • Works ist krumm Installier, was kann ich tun? deinstallieren und neu Installieren?
            was ist mit den npm Fehlern in dem Infofenster?
              Die kommen vielleicht von den 'invalid' gekennzeichneten Adaptern.
                wo siehst du die "invalid" adapter.... seh nix
                  Homoran Global Moderator Administrators @ralle last edited by
                  npm ERR! invalid: iobroker.worx@2.3.4 /opt/iobroker/node_modules/iobroker.worx
                  z.b.
                    ralle @Homoran last edited by
                    hast du dafür auch etwas parat um die npm error zu beseitigen
                      @ralle
                      Hatte ich schon geschrieben:
                      Und dann mal schauen:
                      cd /opt/iobroker
                      npm prune
                      npm ls
                        @thomas-braun said in keine Updates bei IOB mehr möglich:
                        Die Konsole steht seit 7 Minuten
                        pi@raspberrypi:~ $ iob upgrade worx@2.3.4
                        Would you like to reinstall version 2.3.4 of worx now? [(y)es, (n)o]: y
                        Update worx from @2.3.4 to @2.3.4
                        NPM version: 9.8.1
                        Installing iobroker.worx@2.3.4... (System call)
                        passiert nichts mehr........
                          @ralle zweite session öffnen und wenn es noch geht mit top nachsehen
                            Doch. Irgendwas muss da irgendwann passieren. Nicht immer so ungeduldig sein mit den kleinen Kistchen.
                              @homoran hab ich auf und top gestartet, für mich jetzt böhmische Dörfer
                                und dewegen zeigst du nichts davon?
                                  hast recht nach 14 minuten gehts weiter
                                    Natürlich...
                                    npm muss sich ja durch die ganzen Fehler quälen.
                                      so jetzt noch einmal iob diag....
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Model           : Raspberry Pi 4 Model B Rev 1.5
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : armhf
                                      Systemuptime and Load:
                                       21:57:29 up  1:40,  2 users,  load average: 0.47, 3.05, 3.34
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Mon 2023-11-06 21:57:29 CET
                                                 Universal time: Mon 2023-11-06 20:57:29 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      pi
                                      /home/pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                      *** X-Server-Setup ***
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            7.8G        116M        6.0G        1.0M        1.7G        7.6G
                                      Swap:            99M          0B         99M
                                      Total:          7.9G        116M        6.1G
                                               7812 M total memory
                                                116 M used memory
                                                164 M active memory
                                               1269 M inactive memory
                                               6039 M free memory
                                                244 M buffer memory
                                               1411 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FAILED SERVICES ***
                                        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                      * iobroker.service loaded failed failed ioBroker Server
                                      LOAD   = Reflects whether the unit definition was properly loaded.
                                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                      SUB    = The low-level unit activation state, values depend on unit type.
                                      1 loaded units listed.
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       15G  8.4G  5.3G  62% /
                                      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                                      tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                                      [Mon Nov  6 20:17:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:65:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d0e90a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Mon Nov  6 20:17:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Mon Nov  6 20:17:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Mon Nov  6 20:17:17 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      TARGET  SOURCE         FSTYPE OPTIONS
                                      /       /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      1.9G    /var/
                                      1.5G    /var/log/journal/9de79e4d9feb4ead979df62e580afcd8
                                      1.5G    /var/log
                                      129M    /var/cache
                                      Archived and active journals take up 1.4G in the file system.
                                      /opt/iobroker/backups:
                                      162M    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      1.6G    /opt/iobroker/iobroker-data/
                                      899M    /opt/iobroker/iobroker-data/history
                                      617M    /opt/iobroker/iobroker-data/files
                                      88M     /opt/iobroker/iobroker-data/files/echarts.admin
                                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                                      USB-Devices by-id:
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Installed: 18.18.2-1nodesource1
                                        Candidate: 18.18.2-1nodesource1
                                        Version table:
                                       *** 18.18.2-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                           12.22.12~dfsg-1~deb11u4 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      No problems detected
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        33253
                                      States:         26032
                                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Pending Updates: 0
                                      2023-11-06 21:16:45.859  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]: Error: DB closed
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Object.onceWrapper (node:events:632:26)
                                      2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:517:28)
                                      2023-11-06 21:16:45.862  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                                      2023-11-06 21:16:45.862  - error: host.raspberrypi Caught by controller[0]:     at TCP.<anonymous> (node:net:350:12)
                                      2023-11-06 21:16:45.862  - warn: host.raspberrypi instance system.adapter.shelly.0 terminated due to SIGTERM
                                      2023-11-06 21:16:45.862  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code null ()
                                      2023-11-06 21:16:45.862  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGTERM
                                      2023-11-06 21:16:45.862  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
                                      2023-11-06 21:16:45.863  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
                                      2023-11-06 21:16:45.863  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
                                      2023-11-06 21:16:45.863  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
                                      2023-11-06 21:16:45.863  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                                      2023-11-06 21:16:45.899  - info: host.raspberrypi instance system.adapter.ws.0 terminated with code 0 (NO_ERROR)
                                      2023-11-06 21:16:45.899  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
                                      2023-11-06 21:16:45.899  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
                                      2023-11-06 21:16:46.055  - info: tuya.0 (7182) terminating
                                      2023-11-06 21:16:46.065  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                      2023-11-06 21:16:46.297  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-11-06 21:16:46.297  - info: host.raspberrypi All instances are stopped.
                                      2023-11-06 21:16:46.552  - info: host.raspberrypi terminated
                                      NPM Fehler sind nach dem Update von Works weg......
                                      Copy text starting here:
                                                              v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               armhf
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Mem:            7.8G        115M        6.0G        1.0M        1.7G        7.6G
                                      Swap:            99M          0B         99M
                                      Total:          7.9G        115M        6.1G
                                                              admin                   6.12.0
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                33253
                                      States:                 26032
                                      26M     /opt/iobroker/iobroker-data/objects.jsonl
                                        iob fix
                                        iob start
                                          iob start
                                          Soo, IOB startet gerade. Vielen Vielen dank an dich / euch für eure Mühe die ihr euch gemacht habt.
                                          DANKE!!
                                            @ralle
                                            Dann zeig jetzt nochmal
                                            iob diag
                                            mit laufendem ioBroker
                                            1.2k
                                            3763
