    4. Windows 11 Info Bereich
      Bernd 1337 @Bernd 1337 last edited by Homoran
      @bernd-1337 schau dir mal mein Heizungs script an links wo umschalten steht ist der text der an telegram gesedet wird kann man dort einfügen das er den text über die ip sendet
        <variables>
          <variable id="Nngn$qGMi,a]t/|lc#?{">StateNum</variable>
          <variable type="timeout" id="WarteBissel">WarteBissel</variable>
        </variables>
        <block type="variables_set" id="Lf+.@w0i]IS/gNw{qa6L" x="838" y="112">
          <field name="VAR" id="Nngn$qGMi,a]t/|lc#?{">StateNum</field>
            <block type="math_number" id="KhrGvql?l=E@bi|rli_W">
              <field name="NUM">0</field>
            <block type="on_ext" id="K2#.V[BShz?wc5YaB:Xa">
              <field name="ACK_CONDITION">true</field>
              <value name="OID0">
                <shadow type="field_oid" id="EA2571m53SBZ4{-;6dlz">
                  <field name="oid">shelly.0.SHSW-25#3494547971EC#1.Relay0.Power</field>
                <block type="controls_if" id="6t9~,p6FidwN}]u?M4">
                  <mutation elseif="3"></mutation>
                    <block type="logic_compare" id="JCl5xO7ojDQn^44RiSp,">
                      <field name="OP">EQ</field>
                        <block type="variables_get" id="4$$P9HQ)MNUl{s1VE~F">
                        <block type="math_number" id="lf,FcwXo:E?[h.(=yGt6">
                    <block type="comment" id="ICp_/aW:$%cn-o0HvrQa">
                      <field name="COMMENT">Modus: Aus</field>
                  <value name="IF1">
                    <block type="logic_compare" id="3%|GqQPly)yBIN7#y,">
                        <block type="variables_get" id=".8{U{s3*3e1!sJOo/9D6">
                        <block type="math_number" id="hUec!BZSA.:|G(3=(+Lt">
                          <field name="NUM">1</field>
                  <statement name="DO1">
                    <block type="comment" id="nL6yYs(6sGU5H3e2Taxz">
                      <field name="COMMENT">Modus: Kerze</field>
                        <block type="controls_if" id="hc2nU}%;|[~nj~seBYjg">
                            <block type="logic_compare" id="A1fx8o=lFa]#g%7~,~E4">
                              <field name="OP">LT</field>
                                <block type="on_source" id="Ny*R^VVpN|F0/%U*AE};">
                                <block type="math_number" id="]G,eb/;~2DcnH{V*Rbma">
                                  <field name="NUM">100</field>
                            <block type="variables_set" id="}Zh9j34tYu[ebF)N,40,">
                                <block type="math_number" id="R+m@ZqFHMr@%_^w+^qOO">
                                  <field name="NUM">2</field>
                  <value name="IF2">
                    <block type="logic_compare" id=";hAF2.irdRUutWpZo;:d">
                        <block type="variables_get" id="FGT{I74}dY~WfC/PnVD/">
                        <block type="math_number" id="w7)Z{X|{3^6~AC1y+3{N">
                  <statement name="DO2">
                    <block type="comment" id="d;NS!%[1{?/P=8pO+WY0">
                      <field name="COMMENT">Modus: Aktiv</field>
                  <value name="IF3">
                    <block type="logic_compare" id="%Yw%3*w]I{fN|^S.ZS]=">
                        <block type="variables_get" id="-4j4^KiH7d:mHrXl#mT?">
                        <block type="math_number" id="$bd2xwJ/X1l.Kr.6[ut">
                          <field name="NUM">3</field>
                  <statement name="DO3">
                    <block type="comment" id="gQznu+9U)WyeA|SO.(">
                      <field name="COMMENT">Modus: Abkühlen</field>
                        <block type="controls_if" id="@bq3#zrqBgf#5h#5Z#hS">
                            <block type="logic_compare" id=".6qUKEJ|K/,*0Tqh7X+">
                                <block type="on_source" id="mL5[!HcyBnf9f?r^0">
                                <block type="math_number" id="0T2Sp8CcWbAThN_U-1mX">
                                  <field name="NUM">20</field>
                            <block type="variables_set" id="^Lqch?=mdtATs]!,HV.N">
                                <block type="math_number" id="sGO17n(^Qa?N)XGA@voq">
                <block type="on_ext" id="OtwKLd|WDL35?6l#wMO^">
                  <value name="OID0">
                    <shadow type="field_oid" id="GQOm_-9Y(R8AMX;(QMD?">
                      <field name="oid">mqtt.0.HeizungsWasser.Sensor.temperature</field>
                    <block type="controls_if" id="f|L;-tv#*;ER)[p#V,nP">
                        <block type="logic_operation" id="*:ES_JmGY(:w{)//L(">
                          <field name="OP">AND</field>
                            <block type="logic_compare" id=":eot3H)-S7/~J4}[62x{">
                                <block type="variables_get" id="z%+gjj@TqUv8b9r%Ign,">
                                <block type="math_number" id="7iVpE*zF@kH.cZFsa{~)">
                            <block type="logic_compare" id=":{L1=rg,|!e^]3zvz}s]">
                                <block type="on_source" id="+o:kLG3|[G/zOQA{@*V">
                                <block type="get_value" id="DqXK^aSt(YszonMp(9Q#">
                                  <field name="OID">Heizung.0.Ein</field>
                        <block type="variables_set" id="@1(if5NGK9EG:Dil(4Cd">
                            <block type="math_number" id="G?{p(eR}BhC7|!lN4l[H">
                            <block type="procedures_callnoreturn" id="%|#*~aAq96]Uv-JS7TqJ">
                              <mutation name="Heizung Umschalten"></mutation>
                      <value name="IF1">
                        <block type="logic_operation" id="Vr@lX;*Pc4]J2@-gu:W">
                            <block type="logic_compare" id="j{)~Jj9Y^oxHCV{kv=uy">
                                <block type="variables_get" id="A)mtm?a!vB7%tbufxyg">
                                <block type="math_number" id="]PxP{~|II!{NVfe%Cd">
                            <block type="logic_compare" id="(r{RhyGx7bV(jg2G(sE+">
                              <field name="OP">GT</field>
                                <block type="on_source" id="n](6.WEo[c:[4t!oc}~@">
                                <block type="get_value" id="}+,ko4-p~+jF;Ly|Z8">
                                  <field name="OID">Heizung.0.Aus</field>
                        <block type="variables_set" id="4^w`_tzL*$RzyAS%[U})">
                            <block type="math_number" id="+qT3-uNK}y=QED[]AT~H">
                            <block type="procedures_callnoreturn" id="N3@(j3a2?cU5b]N!vK%v">
        <block type="procedures_defnoreturn" id=".F]sXJcTp=@W3(Y(=EeK" x="-312" y="213">
          <field name="NAME">Heizung Umschalten</field>
          <statement name="STACK">
            <block type="request" id=";cmmm{:YO0yNze=#lDOT">
              <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
              <field name="WITH_STATEMENT">FALSE</field>
              <field name="LOG"></field>
              <value name="URL">
                <shadow type="text" id="E@lHsR]E-y+Rc@,Vincw">
                  <field name="TEXT">http://192.168.1.5/control?cmd=gpio,14,1</field>
                <block type="timeouts_settimeout" id="0+Nf.N=vWpAxzI;KPUfH">
                  <field name="NAME">WarteBissel</field>
                  <field name="DELAY">6</field>
                    <block type="request" id="%aA0/#=TLCMJ(5fu/)`P">
                      <value name="URL">
                        <shadow type="text" id="bb9#YKR)@Rx9jjdXvBp%">
                          <field name="TEXT">http://192.168.1.5/control?cmd=gpio,14,0</field>
                    <block type="telegram" id="3LY~@xt2e.([#Bj/078u">
                      <field name="ESCAPING">FALSE</field>
                      <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                      <value name="MESSAGE">
                        <shadow type="text" id="}1#aA@4Kf(;cC!,6h!4z">
                          <field name="TEXT">Heizung wurde Ausgeschaltet !</field>
                        <block type="logic_ternary" id="f}9^C%JV786Jh}ZmKErJ">
                          <value name="IF">
                            <block type="logic_compare" id="KHYb(LnPd=HL|U!{1zoO">
                                <block type="variables_get" id="cwD(ukIy)S1Dv{tI_V18">
                                <block type="math_number" id="xcofx23G.^hn$mt+^:`d">
                          <value name="THEN">
                            <block type="text_join" id="QbL0O8/z;~l!n2st|G}5">
                              <value name="ADD0">
                                <block type="text" id="`NF)FWl95`{6h8Yq;G3v">
                                  <field name="TEXT">Heizung wurde Eingeschaltet mit einer Temperatur von ! </field>
                              <value name="ADD1">
                                <block type="text_newline" id="A-QG:Ig4YObizhB~]da(">
                                  <field name="Type">\n</field>
                              <value name="ADD2">
                                <block type="get_value" id="seYhIcXy9|4kQxrn{1{)">
                                  <field name="OID">mqtt.0.HeizungsWasser.Sensor.temperature</field>
                          <value name="ELSE">
                            <block type="text_join" id="vxzalkvdQv(0g:RZzH,4">
                              <value name="ADD0">
                                <block type="text" id="i#mQW*k:Jk%qt`Eu)Vvj">
                                  <field name="TEXT">Heizung wurde Ausgeschaltet mit einer Temperatur von ! </field>
                              <value name="ADD1">
                                <block type="text_newline" id="A]K{Qi$do2-4F,kmkLEZ">
                              <value name="ADD2">
                                <block type="get_value" id="Y8;|lZ0`~Pq33,[rY(V:">
      • Codierknecht
        Codierknecht Developer Most Active @Bernd 1337 last edited by Codierknecht
        @bernd-1337
        Das geht mit dem Script deutlich einfacher.
        Lösche unten die angelegten Trigger (die mit dem on() und lege einen eigenen an:
        on({id:'0_userdata.0.dein.datenpunkt', change:"ne"}, async function (obj) {
            let val = obj.state.val; // holt den Wert aus dem geänderten DP
            sendNotification('Nachricht vom ioBroker', 'Im DP steht  ' + val + ' als Wert!');
          Bernd 1337 @Codierknecht last edited by
          @codierknecht dann haut er error raus
          • Codierknecht
            @bernd-1337
            Welchen?`
            Wenn's denn unbedingt Blockly sein soll:
            Ohne Fehlerbehandlung. Leerzeichen im Text müssen URL-codiert werden (%20)
              Bernd 1337 @Codierknecht last edited by Homoran
              @codierknecht
              const axios = require('axios');
              axios.defaults.timeout = 500;
              const address = 'http://192.168.1.2:8090';
              async function sendNotification(title, body) {
                  try {
                      await axios.head(address);
                  } catch (error) {
                      if (error.code === 'ECONNABORTED') {
                          log('Target host:port not reachable');
                          return false;
                  let url = address + '/toastMessage';
                  url += '?title=' + encodeURI(title);
                  url += '&body=' + encodeURI(body);
                  try {
                      await axios.get(url);
                  } catch (error) {
                      log(error);
                      return false;
                  return true;
              on({id:'0_userdata.0.example_state', change:"ne"}, async function (obj) {
                @codierknecht haut jetzt alles raus was ich neu zugefügt habe soll ja nur das raus hauen was ich in den datenpunkt schreibe Screenshot_4.png
                  @codierknecht okay das funzt das schon mal gut
                  • Codierknecht
                    @bernd-1337
                    Dann statt
                    eben
                    sendNotification('', val);
                    Blockly:
                      @codierknecht okay das verstehe ich schon bisschen besser habe mal als test eingefügt in mein Pumpen scriptScreenshot_5.png
                      • Codierknecht
                        @bernd-1337 sagte in Windows 11 Info Bereich:
                        Schön - dann musst das nur noch Deinem Antivirus beibringen.
                        Ohne Dir zu nahe treten zu wollen:
                        Von dem was wir hier in den letzten Stunden gemacht haben hast Du noch immer keinen blassen Schimmer, oder?
                        Wenn Du einen ioBroker dauerhaft stabil und sicher betreiben willst, solltest Du das dringend nachholen.
                        Ohne zumindest rudimentäre Kenntnisse von JavaScript wirst Du auf Dauer wenig Freude haben. Beim kleinsten Problem bist Du auf fremde Hilfe angewiesen. Und was Dir dann da so angeboten wird, kannst in keinster Weise einschätzen.
                        • Codierknecht
                          @codierknecht okay das verstehe ich schon bisschen besser habe mal als test eingefügt in mein Pumpen script!
                          Da muss dann "Wurde%20eingeschaltet" rein!
                            @codierknecht wie meinst du das
                              @codierknecht jo hab Gecheckt was du meinst auf jedenfall funzt alles jetzt bestens muss ich nur rausfinden wie ich das avg beibringe das er den port durch lässt aber das Krieg ich schon hin ich sage auf jedenfall Herzlich danke an dich das du dir die zeit genommen hast um mir dumpfbacke es zu erklären aber wie gesagt ich habe 0 plan von dem ganzen
                              • Codierknecht
                                Codierknecht Developer Most Active last edited by
                                Nachtrag: Das Tool habe ich zwischenzeitlich geändert, so dass jetzt auch schon beim ersten Start auf den Port gehorcht wird.
                                  @codierknecht okay Klingt gut werd mir update laden
                                    @codierknecht was noch fehlt man könnte wenn es geht einbauen das sich das tool automatisch beim ersten start in sämtliche firewalls rein schreibt so das es nicht mehr so blockt wie bei mir den bei mir blockt er immer noch obwohl ich in avg nen eintrag gemacht habe muss avg immer aus machen wenn ich die meldung sehen will
                                    • Codierknecht
                                      Das wäre das allererste was ein Virus-Programmierer in seinen Code reinschreiben würde.
                                      Dann könnte man dass Konzept "Firewall" gleich wieder beerdigen.
                                      Homoran B 2 Replies Last reply Reply Quote 1
                                        Homoran Global Moderator Administrators @Codierknecht last edited by
                                        @codierknecht sagte in Windows 11 Info Bereich:
                                        incl. user vs. admin(root)
                                          @codierknecht das stimmt wohl aber du kennst doch wenn man ein Programm startet das diese anfrage kommt zur Ausnahme hinzufügen öffentlich Privat das meinte ich
                                          • Codierknecht
                                            @bernd-1337
                                            Dazu müsste ich ein Setup schreiben, das dann mit Adminrechten gestartet werden muss.
                                            Sei mir nicht böse, aber da übersteigt dann der Aufwand den Nutzen.
                                            Es gibt mit Sicherheit eine Möglichkeit, Deiner AVG-Firewall beizubringen den Port zu öffnen.
                                            Nur so am Rande: Ich nutze seit Jahren keine spezielle "Antivirus-Software". Schon gar keine kostenlose.
                                            Das was Windows an Bordmitteln liefert, ist bei umsichtigem Handeln völlig ausreichend.
                                            5944
