    4. js-controller Update mit npm ERR
      Alex e @Thomas Braun last edited by
      erstmal danke für die schnelle Antwort.
      iob diag sagt:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       18:49:41 up  2:58,  2 users,  load average: 0.15, 0.12, 0.09
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2023-11-04 18:49:42 CET
                 Universal time: Sat 2023-11-04 17:49:42 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        496M        2.6G         16M        712M        3.2G
      Swap:           99M          0B         99M
      Total:         3.9G        496M        2.7G
               3838 M total memory
                496 M used memory
                414 M active memory
                640 M inactive memory
               2630 M free memory
                116 M buffer memory
                596 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
      * lightdm.service       loaded failed failed Light Display Manager
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  5.0G   23G  19% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M  4.0K  384M   1% /run/user/1000
      [Sat Nov  4 15:50:57 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:43:C8:EB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Nov  4 15:50:58 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Nov  4 15:50:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sat Nov  4 15:51:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET                SOURCE         FSTYPE          OPTIONS
      /                     /dev/mmcblk0p2 ext4            rw,noatime
      |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      439M    /var/
      207M    /var/cache
      194M    /var/cache/apt
      135M    /var/cache/apt/archives
      125M    /var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      281M    /opt/iobroker/iobroker-data/
      159M    /opt/iobroker/iobroker-data/files
      68M     /opt/iobroker/iobroker-data/backup-objects
      63M     /opt/iobroker/iobroker-data/files/javascript.admin
      44M     /opt/iobroker/iobroker-data/History
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.998ec878.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.19f19876.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.09585381.chunk.js.map
      5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  2.2.9
      admin:          4.0.9
      javascript:     7.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.daswetter.0             : daswetter             -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.flot.0                  : flot                  -  enabled
      + system.adapter.fullybrowser.0          : fullybrowser          -  enabled
        system.adapter.habpanel.0              : habpanel              -  enabled
      + system.adapter.history.0               : history               -  enabled
        system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
        system.adapter.info.0                  : info                  - disabled
      + system.adapter.iot.0                   : iot                   -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
      + system.adapter.knx.0                   : knx                   -  enabled, bind: 192.168.2.111
      + system.adapter.onkyo.0                 : onkyo                 -  enabled
        system.adapter.openweathermap.0        : openweathermap        -  enabled
      + system.adapter.samsung_tizen.0         : samsung_tizen         -  enabled, port: 8002
      + system.adapter.vis-inventwo.0          : vis-inventwo          -  enabled
        system.adapter.vis-metro.0             : vis-metro             -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      default    : http://download.iobroker.net/sources-dist.json
      latest     : http://download.iobroker.net/sources-dist-latest.json
      Active repo: default
      Installed ioBroker-Instances
      Used repository: default
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 6.12.0   , installed 4.0.9 [Updateable]
      Adapter    "backitup"      : 2.8.7    , installed 2.8.1 [Updateable]
      Adapter    "daswetter"     : 3.1.10   , installed 3.1.10
      Adapter    "discovery"     : 3.1.0    , installed 3.1.0
      Adapter    "flot"          : 1.12.0   , installed 1.12.0
      Adapter    "fullybrowser"  : 2.2.0    , installed 2.0.1 [Updateable]
      Adapter    "habpanel"      : 0.5.0    , installed 0.4.1 [Updateable]
      Adapter    "history"       : 3.0.1    , installed 1.9.10 [Updateable]
      Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
      Adapter    "info"          : 2.0.0    , installed 2.0.0
      Adapter    "iot"           : 1.14.5   , installed 1.5.3 [Updateable]
      Adapter    "javascript"    : 7.1.4    , installed 7.1.4
      Controller "js-controller" : 5.0.12   , installed 2.2.9 [Updateable]
      Adapter    "knx"           : 2.0.22   , installed 2.0.22
      Adapter    "onkyo"         : 2.1.2    , installed 2.1.2
      Adapter    "openweathermap": 0.3.9    , installed 0.1.0 [Updateable]
      Adapter    "paw"           : 0.3.2    , installed 0.3.2
      Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
      Adapter    "socketio"      : 6.5.5    , installed 6.5.5
      Adapter    "vis"           : 1.4.16   , installed 1.2.4 [Updateable]
      Adapter    "vis-inventwo"  : 3.3.3    , installed 2.5.11 [Updateable]
      Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
      Adapter    "web"           : 6.1.2    , installed 3.0.7 [Updateable]
      Objects and States
      Objects:        1612
      States:         1742
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15997      501/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17787      383/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       60542      10427/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       60541      10427/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59085      10445/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       61614      10537/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15999      501/sshd
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          16725      499/xrdp-sesman
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17786      383/cupsd
      tcp6       0      0 :::3389                 :::*                    LISTEN      110        16851      519/xrdp
      udp        0      0 0.0.0.0:56208           0.0.0.0:*                           108        15073      350/avahi-daemon: r
      udp        0      0 192.168.2.111:44520     0.0.0.0:*                           1001       59379      10569/io.knx.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18854      426/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17882      457/cups-browsed
      udp        0      0 192.168.2.111:35038     0.0.0.0:*                           1001       61658      10569/io.knx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15071      350/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          18989      426/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15072      350/avahi-daemon: r
      udp6       0      0 :::36198                :::*                                108        15074      350/avahi-daemon: r
      2023-11-04 18:30:01.031  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Schlafzimmer aufgerufen
      2023-11-04 18:30:01.517  - info: daswetter.0 (10753) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2
      2023-11-04 18:30:01.958  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:30:02.234  - info: daswetter.0 (10753) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-11-04 18:30:02.751  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-11-04 18:34:59.925  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:35:00.924  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Bad aufgerufen
      2023-11-04 18:35:00.996  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Schlafzimmer aufgerufen
      2023-11-04 18:35:01.923  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:39:59.888  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:40:00.884  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Bad aufgerufen
      2023-11-04 18:40:00.956  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Schlafzimmer aufgerufen
      2023-11-04 18:40:01.885  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:44:59.846  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:45:00.042  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 11057
      2023-11-04 18:45:00.845  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Bad aufgerufen
      2023-11-04 18:45:00.920  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Schlafzimmer aufgerufen
      2023-11-04 18:45:01.446  - info: daswetter.0 (11057) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2
      2023-11-04 18:45:01.844  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:45:02.120  - info: daswetter.0 (11057) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-11-04 18:45:02.638  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-11-04 18:49:59.808  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      2023-11-04 18:50:00.807  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Bad aufgerufen
      2023-11-04 18:50:00.878  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Schlafzimmer aufgerufen
      2023-11-04 18:50:01.805  - info: javascript.0 (10516) script.js.Smart_Home.Heizung_State_Machine.Heizung_mit_Alexa2: aktuell halten aus Wohnzimmer aufgerufen
      iob diag has finished.
      iob update
      iobroker upgrade
      iob stop
      iob upgrade self
      iob start
      führt zu:
      iob update
      pi@raspberrypi:~ $ iob update
      update done
      Adapter    "accuweather"   : 1.3.1
      Adapter    "acme"          : 0.1.0
      Adapter    "adb"           : 0.0.7
      Adapter    "adguard"       : 0.0.8
      Adapter    "aio"           : 0.1.1
      Adapter    "airconwithme"  : 0.0.4
      Adapter    "airzone"       : 2.0.3
      Adapter    "alarm"         : 3.4.0
      Adapter    "alexa-shoppinglist": 0.1.5
      Adapter    "alexa-timer-vis": 0.2.0
      Adapter    "alexa2"        : 3.25.5
      Adapter    "alias-manager" : 1.2.6
      Adapter    "alpha-ess"     : 1.1.1
      Adapter    "alpha2"        : 1.0.0
      Adapter    "amazon-dash"   : 1.2.0
      Adapter    "anelhut"       : 1.0.15
      Adapter    "apcups"        : 1.0.15
      Adapter    "apg-info"      : 0.0.7
      Adapter    "apple-find-me" : 0.0.14
      Adapter    "artnet"        : 1.2.2
      Adapter    "asterisk"      : 1.0.6
      Adapter    "asuswrt"       : 1.0.1
      Adapter    "atlas-scientific-ezo-i2c": 2.3.0
      Adapter    "awattar"       : 1.0.6
      Adapter    "awtrix-light"  : 0.8.0
      Adapter    "b-control-em"  : 0.3.1
      Adapter    "beckhoff"      : 1.5.2
      Adapter    "benchmark"     : 1.1.4
      Adapter    "benq"          : 0.2.5
      Adapter    "bestway"       : 0.0.4
      Adapter    "bidirectional-counter": 2.1.0
      Adapter    "birthdays"     : 2.3.1
      Adapter    "ble"           : 0.13.4
      Adapter    "blebox"        : 2.1.0
      Adapter    "bluelink"      : 2.3.6
      Adapter    "bmw"           : 2.5.7
      Adapter    "bosch-ebike"   : 0.0.3
      Adapter    "bosesoundtouch": 0.10.3
      Adapter    "botslab360"    : 0.0.2
      Adapter    "botvac"        : 2.0.1
      Adapter    "bring"         : 1.8.4
      Adapter    "broadlink2"    : 2.1.5
      Adapter    "bsblan"        : 0.3.1
      Adapter    "bshb"          : 0.2.4
      Adapter    "bwt"           : 0.0.5
      Adapter    "bydbatt"       : 1.1.0
      Adapter    "bydhvs"        : 1.4.0
      Adapter    "canbus"        : 1.3.1
      Adapter    "cec2"          : 0.1.1
      Adapter    "chromecast"    : 3.0.3
      Adapter    "cleveron"      : 0.0.5
      Adapter    "cloud"         : 4.4.1
      Adapter    "cloudflare"    : 1.1.1
      Adapter    "comfoair"      : 1.1.8
      Adapter    "contactid"     : 1.0.2
      Adapter    "coronavirus-statistics": 0.8.7
      Adapter    "countdown"     : 2.2.0
      Adapter    "cul"           : 2.2.0
      Adapter    "daikin"        : 1.4.2
      Adapter    "daikin-cloud"  : 0.3.0
      Adapter    "deconz"        : 1.3.21
      Adapter    "denon"         : 1.15.4
      Adapter    "device-reminder": 3.0.0
      Adapter    "device-watcher": 2.9.4
      Adapter    "devices"       : 1.1.5
      Adapter    "deyeidc"       : 0.0.11
      Adapter    "digitalstrom"  : 2.3.0
      Adapter    "discord"       : 2.1.2
      Adapter    "discovergy"    : 0.5.8
      Adapter    "divera247"     : 0.2.0
      Adapter    "doorbird"      : 1.3.0
      Adapter    "doorio"        : 2.1.4
      Adapter    "drag-indicator": 2.1.0
      Adapter    "ds18b20"       : 2.0.4
      Adapter    "dwd"           : 2.8.5
      Adapter    "dysonairpurifier": 2.5.9
      Adapter    "e3dc-rscp"     : 1.2.3
      Adapter    "easee"         : 1.0.10
      Adapter    "ebus"          : 3.2.2
      Adapter    "echarts"       : 1.5.1
      Adapter    "ecovacs-deebot": 1.4.13
      Adapter    "egigeozone"    : 0.1.2
      Adapter    "ekey"          : 1.2.3
      Adapter    "elero-usb-transmitter": 0.5.2
      Adapter    "email"         : 1.2.0
      Adapter    "emby"          : 1.0.2
      Adapter    "ems-esp"       : 2.5.1
      Adapter    "energymanager" : 1.4.2
      Adapter    "enet"          : 1.0.1
      Adapter    "envertech-pv"  : 1.0.2
      Adapter    "epson_ecotank_et_2750": 0.0.12
      Adapter    "epson_stylus_px830": 0.2.1
      Adapter    "epson_xp540"   : 1.0.6
      Adapter    "eusec"         : 1.1.2
      Adapter    "evcc"          : 0.0.10
      Adapter    "eventlist"     : 1.2.3
      Adapter    "exchangerates" : 0.0.14
      Adapter    "fahrplan"      : 1.2.3
      Adapter    "fakeroku"      : 0.2.2
      Adapter    "fb-checkpresence": 1.2.2
      Adapter    "feiertage"     : 1.1.4
      Adapter    "fhem"          : 2.0.5
      Adapter    "fiat"          : 0.0.8
      Adapter    "firetv"        : 2.0.2
      Adapter    "fitbit-fitness": 0.4.10
      Adapter    "followthesun"  : 0.4.2
      Adapter    "foobar2000"    : 2.0.4
      Adapter    "ford"          : 0.0.14
      Adapter    "frigate"       : 0.2.6
      Adapter    "fritzbox"      : 0.5.0
      Adapter    "fritzdect"     : 2.3.1
      Adapter    "froeling"      : 0.0.8
      Adapter    "fronius"       : 2.0.2
      Adapter    "fronius-solarweb": 0.0.3
      Adapter    "fronius-wattpilot": 4.6.2
      Adapter    "frontier_silicon": 0.1.1
      Adapter    "fuelpricemonitor": 0.3.6
      Adapter    "fullcalendar"  : 1.2.0
      Adapter    "g-homa"        : 0.5.3
      Adapter    "garmin"        : 0.0.3
      Adapter    "geofency"      : 1.2.4
      Adapter    "gigaset-elements": 0.3.0
      Adapter    "go-e"          : 1.0.27
      Adapter    "govee-local"   : 0.1.2
      Adapter    "growatt"       : 3.2.1
      Adapter    "gruenbeck"     : 0.0.42
      Adapter    "gsmsms"        : 0.0.4
      Adapter    "haassohn"      : 1.0.9
      Adapter    "haier"         : 1.0.4
      Adapter    "ham"           : 5.3.1
      Adapter    "ham-wemo"      : 3.0.2
      Adapter    "harmony"       : 1.2.2
      Adapter    "hass"          : 1.4.0
      Adapter    "hausbus_de"    : 1.2.12
      Adapter    "heatingcontrol": 2.11.1
      Adapter    "heizoel"       : 1.0.3
      Adapter    "heizungssteuerung": 1.7.0
      Adapter    "hekr"          : 0.0.6
      Adapter    "helios"        : 0.0.3
      Adapter    "heos"          : 2.1.0
      Adapter    "heytech"       : 1.0.6
      Adapter    "hid-community" : 0.3.0
      Adapter    "hikvision-alarmserver": 0.1.0
      Adapter    "hm-rega"       : 3.0.47
      Adapter    "hm-rpc"        : 1.15.19
      Adapter    "hmip"          : 1.20.0
      Adapter    "homeconnect"   : 1.1.1
      Adapter    "homee"         : 1.2.0
      Adapter    "homekit-controller": 0.5.8
      Adapter    "homenet"       : 0.0.2
      Adapter    "homepilot"     : 1.1.6
      Adapter    "hoover"        : 0.0.7
      Adapter    "hp-ilo"        : 1.0.6
      Adapter    "hs100"         : 2.2.0
      Adapter    "hue"           : 3.10.1
      Adapter    "hue-extended"  : 2.0.0
      Adapter    "huum-sauna"    : 0.4.4
      Adapter    "i2c"           : 1.2.1
      Adapter    "ical"          : 1.13.3
      Adapter    "iceroad"       : 1.2.1
      Adapter    "ico-cloud"     : 1.1.0
      Adapter    "icons-addictive-flavour-png": 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0
      Adapter    "icons-icons8"  : 0.0.1
      Adapter    "icons-material-png": 0.1.0
      Adapter    "icons-material-svg": 0.1.0
      Adapter    "icons-mfd-svg" : 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2
      Adapter    "icons-ultimate-png": 1.0.1
      Adapter    "ikettle2"      : 1.0.1
      Adapter    "imap"          : 0.1.1
      Adapter    "imow"          : 0.0.2
      Adapter    "influxdb"      : 3.2.0
      Adapter    "innogy-smarthome": 1.2.6
      Adapter    "innoxel"       : 0.3.1
      Adapter    "intex"         : 0.1.5
      Adapter    "iqontrol"      : 2.3.0
      Adapter    "iwg-vpn"       : 2.0.5
      Adapter    "janitza-gridvis": 3.1.3
      Adapter    "jarvis"        : 3.1.8
      Adapter    "jeelink"       : 1.2.3
      Adapter    "judoisoft"     : 1.1.0
      Adapter    "kecontact"     : 2.0.2
      Adapter    "klf200"        : 1.1.2
      Adapter    "km200"         : 2.0.3
      Adapter    "knmi-weather"  : 1.0.2
      Adapter    "kodi"          : 3.0.0
      Adapter    "kostal-piko-ba": 3.0.7
      Adapter    "lametric"      : 2.4.1
      Adapter    "landroid"      : 1.0.3
      Adapter    "lcn"           : 1.1.1
      Adapter    "legrand-ecocompteur": 1.0.0
      Adapter    "letrika_comgw" : 0.0.6
      Adapter    "lg-ess-home"   : 0.2.3
      Adapter    "lg-thinq"      : 0.1.4
      Adapter    "lgtv"          : 2.1.1
      Adapter    "lgtv-rs"       : 0.1.1
      Adapter    "lgtv11"        : 1.0.5
      Adapter    "libre"         : 0.0.4
      Adapter    "lifx"          : 1.0.3
      Adapter    "lightcontrol"  : 0.4.0
      Adapter    "lightify"      : 0.2.16
      Adapter    "link"          : 0.5.12
      Adapter    "link2home"     : 0.0.1
      Adapter    "linkeddevices" : 1.5.5
      Adapter    "linktap"       : 0.3.0
      Adapter    "linux-control" : 1.1.5
      Adapter    "logparser"     : 2.2.0
      Adapter    "loqed"         : 0.3.1
      Adapter    "lovelace"      : 3.0.1
      Adapter    "lowpass-filter": 2.2.1
      Adapter    "loxone"        : 3.0.1
      Adapter    "luftdaten"     : 3.0.0
      Adapter    "lupusec"       : 1.3.6
      Adapter    "luxtronik1"    : 0.3.5
      Adapter    "material"      : 1.3.1
      Adapter    "matrix-org"    : 1.0.0
      Adapter    "maveo"         : 0.0.5
      Adapter    "maxcube"       : 1.0.4
      Adapter    "maxcul"        : 1.3.1
      Adapter    "mbus"          : 2.4.0
      Adapter    "mclighting"    : 0.1.2
      Adapter    "meater"        : 1.0.2
      Adapter    "mediola-gateway": 1.0.1
      Adapter    "megad"         : 1.2.1
      Adapter    "megadd"        : 0.2.0
      Adapter    "megaesp"       : 0.1.0
      Adapter    "melcloud"      : 1.3.5
      Adapter    "mercedesme"    : 0.1.1
      Adapter    "mercury"       : 0.1.6
      Adapter    "meross"        : 1.15.1
      Adapter    "meteoalarm"    : 2.3.7
      Adapter    "micronova"     : 0.0.2
      Adapter    "midea"         : 0.0.7
      Adapter    "miele"         : 0.1.5
      Adapter    "mielecloudservice": 6.5.4
      Adapter    "mihome"        : 1.4.0
      Adapter    "mihome-cloud"  : 0.1.0
      Adapter    "mihome-lamp"   : 1.1.0
      Adapter    "mihome-plug"   : 0.2.1
      Adapter    "mihome-vacuum" : 4.0.0
      Adapter    "mikrotik"      : 1.1.1
      Adapter    "milight"       : 0.4.0
      Adapter    "milight-smart-light": 1.2.2
      Adapter    "minuvis"       : 2.3.3
      Adapter    "mobile"        : 1.0.1
      Adapter    "modbus"        : 5.0.11
      Adapter    "moma"          : 1.2.9
      Adapter    "mpd"           : 1.1.1
      Adapter    "mqtt"          : 4.1.1
      Adapter    "mqtt-client"   : 1.6.5
      Adapter    "musiccast"     : 1.1.3
      Adapter    "mydlink"       : 1.3.4
      Adapter    "myenergi"      : 0.0.3
      Adapter    "mysensors"     : 3.0.0
      Adapter    "mystrom"       : 0.0.14
      Adapter    "myvbus"        : 0.2.5
      Adapter    "nanoleaf-lightpanels": 1.4.0
      Adapter    "net-tools"     : 0.2.0
      Adapter    "netatmo"       : 3.1.0
      Adapter    "netatmo-crawler": 0.8.1
      Adapter    "netatmo-energy": 2.6.1
      Adapter    "nibeuplink"    : 1.3.0
      Adapter    "nina"          : 0.0.25
      Adapter    "nissan"        : 0.0.12
      Adapter    "niu"           : 0.0.3
      Adapter    "node-red"      : 4.0.3
      Adapter    "notification-manager": 0.1.2
      Adapter    "nsclient"      : 0.1.2
      Adapter    "nuki"          : 1.6.0
      Adapter    "nuki-extended" : 2.6.5
      Adapter    "nut"           : 1.6.0
      Adapter    "ocpp"          : 0.12.5
      Adapter    "octoprint"     : 4.0.0
      Adapter    "odl"           : 3.0.1
      Adapter    "oekofen-json"  : 1.0.5
      Adapter    "oilfox"        : 4.2.0
      Adapter    "omnicomm-lls"  : 0.0.7
      Adapter    "onvif"         : 1.0.5
      Adapter    "opendtu"       : 1.0.0
      Adapter    "openhab"       : 1.1.0
      Adapter    "openknx"       : 0.5.3
      Adapter    "openligadb"    : 1.2.4
      Adapter    "operating-hours": 1.0.4
      Adapter    "opi"           : 0.1.2
      Adapter    "oppoplayer"    : 0.2.4
      Adapter    "owfs"          : 0.7.0
      Adapter    "owntracks"     : 1.0.5
      Adapter    "panasonic-comfort-cloud": 2.2.4
      Adapter    "panasonic-viera": 2.0.0
      Adapter    "parcel"        : 0.0.27
      Adapter    "parser"        : 1.3.2
      Adapter    "pegelalarm"    : 1.3.1
      Adapter    "ph803w"        : 1.1.1
      Adapter    "phantomjs"     : 1.1.3
      Adapter    "philips-air"   : 1.0.3
      Adapter    "philips-tv"    : 0.5.3
      Adapter    "pi-hole"       : 1.3.6
      Adapter    "piface"        : 1.0.0
      Adapter    "pimatic"       : 0.3.2
      Adapter    "ping"          : 1.6.2
      Adapter    "pixelit"       : 1.1.2
      Adapter    "places"        : 1.1.2
      Adapter    "plenticore"    : 2.2.0
      Adapter    "plex"          : 1.1.3
      Adapter    "plexconnect"   : 0.0.7
      Adapter    "pollenflug"    : 1.0.6
      Adapter    "porsche"       : 0.0.3
      Adapter    "powerfox2"     : 0.0.12
      Adapter    "procon-ip"     : 1.4.0
      Adapter    "proxmox"       : 2.2.1
      Adapter    "proxy"         : 1.3.2
      Adapter    "psa"           : 0.0.11
      Adapter    "puppeteer"     : 0.2.7
      Adapter    "pushbullet"    : 1.0.1
      Adapter    "pushover"      : 3.0.3
      Adapter    "pushsafer"     : 1.0.3
      Adapter    "pvforecast"    : 2.8.1
      Adapter    "pvoutputorg"   : 1.8.9
      Adapter    "pylontech"     : 0.0.6
      Adapter    "radar2"        : 2.0.8
      Adapter    "radiohead"     : 1.3.0
      Adapter    "rct"           : 1.2.2
      Adapter    "renault"       : 0.0.15
      Adapter    "residents"     : 0.1.1
      Adapter    "resol"         : 1.3.0
      Adapter    "rest-api"      : 1.1.0
      Adapter    "rflink"        : 2.1.6
      Adapter    "rickshaw"      : 1.0.0
      Adapter    "ring"          : 3.2.2
      Adapter    "robonect"      : 1.3.4
      Adapter    "roborock"      : 0.4.4
      Adapter    "roomba"        : 1.2.2
      Adapter    "rpi2"          : 1.3.2
      Adapter    "rssfeed"       : 2.6.1
      Adapter    "s7"            : 1.3.15
      Adapter    "sainlogic"     : 0.10.5
      Adapter    "samsung"       : 0.5.11
      Adapter    "sanext"        : 0.0.5
      Adapter    "sayit"         : 3.0.5
      Adapter    "sbfspot"       : 4.1.6
      Adapter    "scenes"        : 2.3.9
      Adapter    "scheduler"     : 1.1.9
      Adapter    "schoolfree"    : 1.1.2
      Adapter    "schwoerer-ventcube": 1.4.2
      Adapter    "seko"          : 0.0.1
      Adapter    "selverf"       : 0.6.3
      Adapter    "semp"          : 1.3.4
      Adapter    "seq"           : 0.3.0
      Adapter    "shelly"        : 6.4.5
      Adapter    "shuttercontrol": 1.6.2
      Adapter    "sia"           : 1.0.4
      Adapter    "siegenia"      : 1.1.1
      Adapter    "signal-cmb"    : 0.3.0
      Adapter    "signifylights" : 0.3.0
      Adapter    "sma-em"        : 1.0.0
      Adapter    "smappee"       : 0.2.6
      Adapter    "smart-eq"      : 0.0.4
      Adapter    "smartcontrol"  : 2.0.1
      Adapter    "smartgarden"   : 2.0.0
      Adapter    "smartmeter"    : 3.3.4
      Adapter    "smartthings"   : 0.0.4
      Adapter    "snips"         : 1.5.1
      Adapter    "snmp"          : 3.1.0
      Adapter    "solarlog"      : 2.2.8
      Adapter    "solarmanpv"    : 0.5.1
      Adapter    "solarviewdatareader": 1.0.7
      Adapter    "solarwetter"   : 1.1.5
      Adapter    "solax"         : 0.7.7
      Adapter    "sonnen"        : 1.16.0
      Adapter    "sonoff"        : 2.5.3
      Adapter    "sonos"         : 2.3.1
      Adapter    "sony-bravia"   : 1.0.9
      Adapter    "spotify-premium": 1.2.2
      Adapter    "sprinklecontrol": 0.2.13
      Adapter    "sql"           : 2.2.0
      Adapter    "squeezeboxrpc" : 1.3.9
      Adapter    "starline"      : 1.1.3
      Adapter    "statistics"    : 2.3.0
      Adapter    "stiebel-isg"   : 1.7.7
      Adapter    "sureflap"      : 1.2.1
      Adapter    "swiss-weather-api": 2.0.3
      Adapter    "synochat"      : 1.3.1
      Adapter    "synology"      : 3.0.1
      Adapter    "systeminfo"    : 1.1.0
      Adapter    "tado"          : 0.4.11
      Adapter    "tahoma"        : 0.10.2
      Adapter    "tankerkoenig"  : 3.3.7
      Adapter    "tapo"          : 0.0.8
      Adapter    "telegram"      : 1.16.0
      Adapter    "telegram-menu" : 0.7.1
      Adapter    "terminal"      : 1.0.0
      Adapter    "tesla-motors"  : 1.3.2
      Adapter    "text2command"  : 3.0.2
      Adapter    "tibberlink"    : 1.4.1
      Adapter    "tinker"        : 1.2.0
      Adapter    "tinymqttbroker": 0.0.8
      Adapter    "toyota"        : 0.0.3
      Adapter    "tr-064"        : 4.2.18
      Adapter    "traccar"       : 1.1.3
      Adapter    "tradfri"       : 3.1.3
      Adapter    "trashschedule" : 2.2.0
      Adapter    "trivum"        : 0.0.5
      Adapter    "tronity"       : 1.1.1
      Adapter    "tunnelbroker-endpoint-updater": 0.0.1
      Adapter    "tuya"          : 3.14.2
      Adapter    "tvprogram"     : 1.1.2
      Adapter    "tvspielfilm"   : 2.0.5
      Adapter    "twinkly"       : 1.0.14
      Adapter    "unifi"         : 0.6.6
      Adapter    "upnp"          : 1.0.21
      Adapter    "uv-protect"    : 0.4.2
      Adapter    "vaillant"      : 0.1.2
      Adapter    "valloxmv"      : 1.2.0
      Adapter    "valuetrackerovertime": 1.0.1
      Adapter    "vcard"         : 0.0.9
      Adapter    "vds2465-server": 0.1.10
      Adapter    "velux"         : 0.0.7
      Adapter    "vesync"        : 0.0.3
      Adapter    "viessmann"     : 1.4.5
      Adapter    "viessmannapi"  : 2.3.0
      Adapter    "virtualpowermeter": 1.4.6
      Adapter    "vis-bars"      : 0.1.4
      Adapter    "vis-canvas-gauges": 1.0.1
      Adapter    "vis-colorpicker": 2.0.3
      Adapter    "vis-fancyswitch": 1.1.0
      Adapter    "vis-google-fonts": 1.0.4
      Adapter    "vis-history"   : 1.0.0
      Adapter    "vis-hqwidgets" : 1.4.0
      Adapter    "vis-icontwo"   : 0.96.0
      Adapter    "vis-jqui-mfd"  : 1.0.12
      Adapter    "vis-justgage"  : 1.0.2
      Adapter    "vis-keyboard"  : 0.0.2
      Adapter    "vis-lcars"     : 1.1.1
      Adapter    "vis-map"       : 1.0.4
      Adapter    "vis-material-advanced": 1.7.4
      Adapter    "vis-players"   : 0.1.6
      Adapter    "vis-plumb"     : 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2
      Adapter    "vis-timeandweather": 1.2.2
      Adapter    "vis-weather"   : 2.5.6
      Adapter    "voltoplus"     : 0.1.3
      Adapter    "volumio"       : 0.1.2
      Adapter    "volvo"         : 0.1.0
      Adapter    "vr200"         : 1.0.0
      Adapter    "vw-connect"    : 0.0.67
      Adapter    "wallpanel"     : 0.3.11
      Adapter    "warp"          : 1.2.2
      Adapter    "weatherflow_udp": 0.1.3
      Adapter    "weatherunderground": 3.6.0
      Adapter    "webui"         : 0.12.3
      Adapter    "webuntis"      : 0.3.4
      Adapter    "weishaupt-wem" : 0.0.15
      Adapter    "whatsapp-cmb"  : 0.2.3
      Adapter    "wiegand-tcpip" : 0.4.6
      Adapter    "wiffi-wz"      : 2.2.1
      Adapter    "wifilight"     : 1.1.4
      Adapter    "windows-control": 0.1.5
      Adapter    "wiobrowser"    : 2.0.2
      Adapter    "wireguard"     : 1.6.1
      Adapter    "wireless-mbus" : 0.9.1
      Adapter    "withings"      : 0.0.13
      Adapter    "wlanthermo-nano": 0.2.1
      Adapter    "wled"          : 0.7.1
      Adapter    "wmswebcontrol" : 0.0.5
      Adapter    "wolf"          : 1.7.0
      Adapter    "wolf-smartset" : 1.1.1
      Adapter    "worx"          : 2.3.2
      Adapter    "ws"            : 2.5.5
      Adapter    "xbox"          : 1.1.0
      Adapter    "xs1"           : 1.0.2
      Adapter    "xterm"         : 1.1.0
      Adapter    "yahka"         : 1.0.3
      Adapter    "yahoo-stock-market": 0.0.5
      Adapter    "yamaha"        : 0.5.3
      Adapter    "yeelight-2"    : 1.2.1
      Adapter    "youtube"       : 4.3.0
      Adapter    "yr"            : 5.3.0
      Adapter    "zehnder-cloud" : 0.0.7
      Adapter    "zigbee"        : 1.8.23
      Adapter    "zigbee2mqtt"   : 2.13.3
      Adapter    "zont"          : 0.5.4
      Adapter    "zwave2"        : 3.1.0
      iobroker upgrade
      pi@raspberrypi:~ $ iobroker upgrade
      Adapter "accuweather"    is not installed.
      Adapter "acme"           is not installed.
      Adapter "adb"            is not installed.
      Adapter "adguard"        is not installed.
      Invalid version of js-controler. Required >=3.3.22
      Adapter "aio"            is not installed.
      Adapter "airconwithme"   is not installed.
      Adapter "airzone"        is not installed.
      Adapter "alarm"          is not installed.
      Adapter "alexa-shoppinglist" is not installed.
      Adapter "alexa-timer-vis" is not installed.
      Adapter "alexa2"         is not installed.
      Adapter "alias-manager"  is not installed.
      Adapter "alpha-ess"      is not installed.
      Adapter "alpha2"         is not installed.
      Adapter "amazon-dash"    is not installed.
      Adapter "anelhut"        is not installed.
      Adapter "apcups"         is not installed.
      Adapter "apg-info"       is not installed.
      Adapter "apple-find-me"  is not installed.
      Adapter "artnet"         is not installed.
      Adapter "asterisk"       is not installed.
      Adapter "asuswrt"        is not installed.
      Adapter "atlas-scientific-ezo-i2c" is not installed.
      Adapter "awattar"        is not installed.
      Adapter "awtrix-light"   is not installed.
      Adapter "b-control-em"   is not installed.
      Invalid version of js-controler. Required >=4.0.0
      Adapter "beckhoff"       is not installed.
      Adapter "benchmark"      is not installed.
      Adapter "benq"           is not installed.
      Adapter "bestway"        is not installed.
      Adapter "bidirectional-counter" is not installed.
      Adapter "birthdays"      is not installed.
      Adapter "ble"            is not installed.
      Adapter "blebox"         is not installed.
      Adapter "bluelink"       is not installed.
      Adapter "bmw"            is not installed.
      Adapter "bosch-ebike"    is not installed.
      Adapter "bosesoundtouch" is not installed.
      Adapter "botslab360"     is not installed.
      Adapter "botvac"         is not installed.
      Adapter "bring"          is not installed.
      Adapter "broadlink2"     is not installed.
      Adapter "bsblan"         is not installed.
      Adapter "bshb"           is not installed.
      Adapter "bwt"            is not installed.
      Adapter "bydbatt"        is not installed.
      Adapter "bydhvs"         is not installed.
      Adapter "canbus"         is not installed.
      Adapter "cec2"           is not installed.
      Adapter "chromecast"     is not installed.
      Adapter "cleveron"       is not installed.
      Adapter "cloud"          is not installed.
      Adapter "cloudflare"     is not installed.
      Adapter "comfoair"       is not installed.
      Adapter "contactid"      is not installed.
      Adapter "coronavirus-statistics" is not installed.
      Adapter "countdown"      is not installed.
      Adapter "cul"            is not installed.
      Adapter "daikin"         is not installed.
      Adapter "daikin-cloud"   is not installed.
      Adapter "daswetter"      is up to date.
      Adapter "deconz"         is not installed.
      Adapter "denon"          is not installed.
      Adapter "device-reminder" is not installed.
      Adapter "device-watcher" is not installed.
      Adapter "devices"        is not installed.
      Adapter "deyeidc"        is not installed.
      Adapter "digitalstrom"   is not installed.
      Adapter "discord"        is not installed.
      Adapter "discovergy"     is not installed.
      Adapter "discovery"      is up to date.
      Adapter "divera247"      is not installed.
      Adapter "doorbird"       is not installed.
      Adapter "doorio"         is not installed.
      Adapter "drag-indicator" is not installed.
      Adapter "ds18b20"        is not installed.
      Adapter "dwd"            is not installed.
      Adapter "dysonairpurifier" is not installed.
      Adapter "e3dc-rscp"      is not installed.
      Adapter "easee"          is not installed.
      Adapter "ebus"           is not installed.
      Adapter "echarts"        is not installed.
      Adapter "ecovacs-deebot" is not installed.
      Adapter "egigeozone"     is not installed.
      Adapter "ekey"           is not installed.
      Adapter "elero-usb-transmitter" is not installed.
      Adapter "email"          is not installed.
      Adapter "emby"           is not installed.
      Adapter "ems-esp"        is not installed.
      Adapter "energymanager"  is not installed.
      Adapter "enet"           is not installed.
      Adapter "envertech-pv"   is not installed.
      Adapter "epson_ecotank_et_2750" is not installed.
      Adapter "epson_stylus_px830" is not installed.
      Adapter "epson_xp540"    is not installed.
      Adapter "eusec"          is not installed.
      Adapter "evcc"           is not installed.
      Adapter "eventlist"      is not installed.
      Adapter "exchangerates"  is not installed.
      Adapter "fahrplan"       is not installed.
      Adapter "fakeroku"       is not installed.
      Adapter "fb-checkpresence" is not installed.
      Adapter "feiertage"      is not installed.
      Adapter "fhem"           is not installed.
      Adapter "fiat"           is not installed.
      Adapter "firetv"         is not installed.
      Adapter "fitbit-fitness" is not installed.
      Adapter "flot"           is up to date.
      Adapter "followthesun"   is not installed.
      Adapter "foobar2000"     is not installed.
      Adapter "ford"           is not installed.
      Adapter "frigate"        is not installed.
      Adapter "fritzbox"       is not installed.
      Adapter "fritzdect"      is not installed.
      Adapter "froeling"       is not installed.
      Adapter "fronius"        is not installed.
      Adapter "fronius-solarweb" is not installed.
      Adapter "fronius-wattpilot" is not installed.
      Adapter "frontier_silicon" is not installed.
      Adapter "fuelpricemonitor" is not installed.
      Adapter "fullcalendar"   is not installed.
      Invalid version of js-controler. Required >=3.0.0
      Adapter "g-homa"         is not installed.
      Adapter "garmin"         is not installed.
      Adapter "geofency"       is not installed.
      Adapter "gigaset-elements" is not installed.
      Adapter "go-e"           is not installed.
      Adapter "govee-local"    is not installed.
      Adapter "growatt"        is not installed.
      Adapter "gruenbeck"      is not installed.
      Adapter "gsmsms"         is not installed.
      Adapter "haassohn"       is not installed.
      Invalid version of "web"
      Adapter "haier"          is not installed.
      Adapter "ham"            is not installed.
      Adapter "ham-wemo"       is not installed.
      Adapter "harmony"        is not installed.
      Adapter "hass"           is not installed.
      Adapter "hausbus_de"     is not installed.
      Adapter "heatingcontrol" is not installed.
      Adapter "heizoel"        is not installed.
      Adapter "heizungssteuerung" is not installed.
      Adapter "hekr"           is not installed.
      Adapter "helios"         is not installed.
      Adapter "heos"           is not installed.
      Adapter "heytech"        is not installed.
      Adapter "hid-community"  is not installed.
      Adapter "hikvision-alarmserver" is not installed.
      Invalid version of js-controler. Required >=3.3.0
      Adapter "hm-rega"        is not installed.
      Adapter "hm-rpc"         is not installed.
      Adapter "hmip"           is not installed.
      Adapter "homeconnect"    is not installed.
      Adapter "homee"          is not installed.
      Adapter "homekit-controller" is not installed.
      Adapter "homenet"        is not installed.
      Adapter "homepilot"      is not installed.
      Adapter "hoover"         is not installed.
      Adapter "hp-ilo"         is not installed.
      Adapter "hs100"          is not installed.
      Adapter "hue"            is not installed.
      Adapter "hue-extended"   is not installed.
      Adapter "huum-sauna"     is not installed.
      Adapter "i2c"            is not installed.
      Adapter "ical"           is not installed.
      Adapter "iceroad"        is not installed.
      Adapter "ico-cloud"      is not installed.
      Adapter "icons-addictive-flavour-png" is not installed.
      Adapter "icons-fatcow-hosting" is not installed.
      Adapter "icons-icons8"   is not installed.
      Adapter "icons-material-png" is not installed.
      Adapter "icons-material-svg" is not installed.
      Adapter "icons-mfd-png"  is up to date.
      Adapter "icons-mfd-svg"  is not installed.
      Adapter "icons-open-icon-library-png" is not installed.
      Adapter "icons-ultimate-png" is not installed.
      Adapter "ikettle2"       is not installed.
      Adapter "imap"           is not installed.
      Adapter "imow"           is not installed.
      Adapter "influxdb"       is not installed.
      Adapter "info"           is up to date.
      Adapter "innogy-smarthome" is not installed.
      Adapter "innoxel"        is not installed.
      Adapter "intex"          is not installed.
      Adapter "iqontrol"       is not installed.
      Adapter "iwg-vpn"        is not installed.
      Adapter "janitza-gridvis" is not installed.
      Adapter "jarvis"         is not installed.
      Adapter "javascript"     is up to date.
      Adapter "jeelink"        is not installed.
      Adapter "judoisoft"      is not installed.
      Adapter "kecontact"      is not installed.
      Adapter "klf200"         is not installed.
      Adapter "km200"          is not installed.
      Adapter "knmi-weather"   is not installed.
      Adapter "knx"            is up to date.
      Adapter "kodi"           is not installed.
      Adapter "kostal-piko-ba" is not installed.
      Adapter "lametric"       is not installed.
      Adapter "landroid"       is not installed.
      Adapter "lcn"            is not installed.
      Adapter "legrand-ecocompteur" is not installed.
      Adapter "letrika_comgw"  is not installed.
      Adapter "lg-ess-home"    is not installed.
      Adapter "lg-thinq"       is not installed.
      Adapter "lgtv"           is not installed.
      Adapter "lgtv-rs"        is not installed.
      Adapter "lgtv11"         is not installed.
      Adapter "libre"          is not installed.
      Adapter "lifx"           is not installed.
      Adapter "lightcontrol"   is not installed.
      Adapter "lightify"       is not installed.
      Adapter "link"           is not installed.
      Adapter "link2home"      is not installed.
      Adapter "linkeddevices"  is not installed.
      Adapter "linktap"        is not installed.
      Adapter "linux-control"  is not installed.
      Adapter "logparser"      is not installed.
      Adapter "loqed"          is not installed.
      Adapter "lovelace"       is not installed.
      Adapter "lowpass-filter" is not installed.
      Adapter "loxone"         is not installed.
      Adapter "luftdaten"      is not installed.
      Adapter "lupusec"        is not installed.
      Adapter "luxtronik1"     is not installed.
      Adapter "material"       is not installed.
      Adapter "matrix-org"     is not installed.
      Adapter "maveo"          is not installed.
      Adapter "maxcube"        is not installed.
      Adapter "maxcul"         is not installed.
      Adapter "mbus"           is not installed.
      Adapter "mclighting"     is not installed.
      Adapter "meater"         is not installed.
      Adapter "mediola-gateway" is not installed.
      Adapter "megad"          is not installed.
      Adapter "megadd"         is not installed.
      Adapter "megaesp"        is not installed.
      Adapter "melcloud"       is not installed.
      Adapter "mercedesme"     is not installed.
      Adapter "mercury"        is not installed.
      Adapter "meross"         is not installed.
      Adapter "meteoalarm"     is not installed.
      Adapter "micronova"      is not installed.
      Adapter "midea"          is not installed.
      Adapter "miele"          is not installed.
      Adapter "mielecloudservice" is not installed.
      Adapter "mihome"         is not installed.
      Adapter "mihome-cloud"   is not installed.
      Adapter "mihome-lamp"    is not installed.
      Adapter "mihome-plug"    is not installed.
      Adapter "mihome-vacuum"  is not installed.
      Adapter "mikrotik"       is not installed.
      Adapter "milight"        is not installed.
      Adapter "milight-smart-light" is not installed.
      Adapter "minuvis"        is not installed.
      Adapter "mobile"         is not installed.
      Adapter "modbus"         is not installed.
      Adapter "moma"           is not installed.
      Adapter "mpd"            is not installed.
      Adapter "mqtt"           is not installed.
      Adapter "mqtt-client"    is not installed.
      Adapter "musiccast"      is not installed.
      Adapter "mydlink"        is not installed.
      Adapter "myenergi"       is not installed.
      Adapter "mysensors"      is not installed.
      Adapter "mystrom"        is not installed.
      Adapter "myvbus"         is not installed.
      Adapter "nanoleaf-lightpanels" is not installed.
      Adapter "net-tools"      is not installed.
      Adapter "netatmo"        is not installed.
      Adapter "netatmo-crawler" is not installed.
      Adapter "netatmo-energy" is not installed.
      Adapter "nibeuplink"     is not installed.
      Adapter "nina"           is not installed.
      Adapter "nissan"         is not installed.
      Adapter "niu"            is not installed.
      Adapter "node-red"       is not installed.
      Adapter "notification-manager" is not installed.
      Adapter "nsclient"       is not installed.
      Adapter "nuki"           is not installed.
      Adapter "nuki-extended"  is not installed.
      Adapter "nut"            is not installed.
      Adapter "ocpp"           is not installed.
      Adapter "octoprint"      is not installed.
      Adapter "odl"            is not installed.
      Adapter "oekofen-json"   is not installed.
      Adapter "oilfox"         is not installed.
      Adapter "omnicomm-lls"   is not installed.
      Adapter "onkyo"          is up to date.
      Adapter "onvif"          is not installed.
      Adapter "opendtu"        is not installed.
      Adapter "openhab"        is not installed.
      Adapter "openknx"        is not installed.
      Adapter "openligadb"     is not installed.
      Adapter "operating-hours" is not installed.
      Adapter "opi"            is not installed.
      Adapter "oppoplayer"     is not installed.
      Adapter "owfs"           is not installed.
      Adapter "owntracks"      is not installed.
      Adapter "panasonic-comfort-cloud" is not installed.
      Adapter "panasonic-viera" is not installed.
      Adapter "parcel"         is not installed.
      Adapter "parser"         is not installed.
      Adapter "paw"            is up to date.
      Adapter "pegelalarm"     is not installed.
      Adapter "ph803w"         is not installed.
      Adapter "phantomjs"      is not installed.
      Adapter "philips-air"    is not installed.
      Adapter "philips-tv"     is not installed.
      Adapter "pi-hole"        is not installed.
      Adapter "piface"         is not installed.
      Adapter "pimatic"        is not installed.
      Adapter "ping"           is not installed.
      Adapter "pixelit"        is not installed.
      Adapter "places"         is not installed.
      Adapter "plenticore"     is not installed.
      Adapter "plex"           is not installed.
      Adapter "plexconnect"    is not installed.
      Adapter "pollenflug"     is not installed.
      Adapter "porsche"        is not installed.
      Adapter "powerfox2"      is not installed.
      Adapter "procon-ip"      is not installed.
      Adapter "proxmox"        is not installed.
      Adapter "proxy"          is not installed.
      Adapter "psa"            is not installed.
      Adapter "puppeteer"      is not installed.
      Adapter "pushbullet"     is not installed.
      Adapter "pushover"       is not installed.
      Adapter "pushsafer"      is not installed.
      Adapter "pvforecast"     is not installed.
      Adapter "pvoutputorg"    is not installed.
      Adapter "pylontech"      is not installed.
      Adapter "radar2"         is not installed.
      Adapter "radiohead"      is not installed.
      Adapter "rct"            is not installed.
      Adapter "renault"        is not installed.
      Adapter "residents"      is not installed.
      Adapter "resol"          is not installed.
      Adapter "rest-api"       is not installed.
      Adapter "rflink"         is not installed.
      Adapter "rickshaw"       is not installed.
      Adapter "ring"           is not installed.
      Adapter "robonect"       is not installed.
      Adapter "roborock"       is not installed.
      Adapter "roomba"         is not installed.
      Adapter "rpi2"           is not installed.
      Adapter "rssfeed"        is not installed.
      Adapter "s7"             is not installed.
      Adapter "sainlogic"      is not installed.
      Adapter "samsung"        is not installed.
      Adapter "sanext"         is not installed.
      Adapter "sayit"          is not installed.
      Adapter "sbfspot"        is not installed.
      Adapter "scenes"         is not installed.
      Adapter "scheduler"      is not installed.
      Adapter "schoolfree"     is not installed.
      Adapter "schwoerer-ventcube" is not installed.
      Adapter "seko"           is not installed.
      Adapter "selverf"        is not installed.
      Adapter "semp"           is not installed.
      Adapter "seq"            is not installed.
      Adapter "shelly"         is not installed.
      Adapter "shuttercontrol" is not installed.
      Adapter "sia"            is not installed.
      Adapter "siegenia"       is not installed.
      Adapter "signal-cmb"     is not installed.
      Adapter "signifylights"  is not installed.
      Adapter "simple-api"     is up to date.
      Adapter "sma-em"         is not installed.
      Adapter "smappee"        is not installed.
      Adapter "smart-eq"       is not installed.
      Adapter "smartcontrol"   is not installed.
      Adapter "smartgarden"    is not installed.
      Adapter "smartmeter"     is not installed.
      Adapter "smartthings"    is not installed.
      Adapter "snips"          is not installed.
      Adapter "snmp"           is not installed.
      Adapter "socketio"       is up to date.
      Adapter "solarlog"       is not installed.
      Adapter "solarmanpv"     is not installed.
      Adapter "solarviewdatareader" is not installed.
      Adapter "solarwetter"    is not installed.
      Adapter "solax"          is not installed.
      Adapter "sonnen"         is not installed.
      Adapter "sonoff"         is not installed.
      Adapter "sonos"          is not installed.
      Adapter "sony-bravia"    is not installed.
      Adapter "spotify-premium" is not installed.
      Adapter "sprinklecontrol" is not installed.
      Adapter "sql"            is not installed.
      Adapter "squeezeboxrpc"  is not installed.
      Adapter "starline"       is not installed.
      Adapter "statistics"     is not installed.
      Adapter "stiebel-isg"    is not installed.
      Adapter "sureflap"       is not installed.
      Adapter "swiss-weather-api" is not installed.
      Adapter "synochat"       is not installed.
      Adapter "synology"       is not installed.
      Adapter "systeminfo"     is not installed.
      Adapter "tado"           is not installed.
      Adapter "tahoma"         is not installed.
      Adapter "tankerkoenig"   is not installed.
      Adapter "tapo"           is not installed.
      Adapter "telegram"       is not installed.
      Adapter "telegram-menu"  is not installed.
      Adapter "terminal"       is not installed.
      Adapter "tesla-motors"   is not installed.
      Adapter "text2command"   is not installed.
      Adapter "tibberlink"     is not installed.
      Adapter "tinker"         is not installed.
      Adapter "tinymqttbroker" is not installed.
      Adapter "toyota"         is not installed.
      Adapter "tr-064"         is not installed.
      Adapter "traccar"        is not installed.
      Adapter "tradfri"        is not installed.
      Adapter "trashschedule"  is not installed.
      Adapter "trivum"         is not installed.
      Adapter "tronity"        is not installed.
      Adapter "tunnelbroker-endpoint-updater" is not installed.
      Adapter "tuya"           is not installed.
      Adapter "tvprogram"      is not installed.
      Adapter "tvspielfilm"    is not installed.
      Adapter "twinkly"        is not installed.
      Adapter "unifi"          is not installed.
      Adapter "upnp"           is not installed.
      Adapter "uv-protect"     is not installed.
      Adapter "vaillant"       is not installed.
      Adapter "valloxmv"       is not installed.
      Adapter "valuetrackerovertime" is not installed.
      Adapter "vcard"          is not installed.
      Adapter "vds2465-server" is not installed.
      Adapter "velux"          is not installed.
      Adapter "vesync"         is not installed.
      Adapter "viessmann"      is not installed.
      Adapter "viessmannapi"   is not installed.
      Adapter "virtualpowermeter" is not installed.
      Adapter "vis-bars"       is not installed.
      Adapter "vis-canvas-gauges" is not installed.
      Adapter "vis-colorpicker" is not installed.
      Adapter "vis-fancyswitch" is not installed.
      Adapter "vis-google-fonts" is not installed.
      Adapter "vis-history"    is not installed.
      Adapter "vis-hqwidgets"  is not installed.
      Adapter "vis-icontwo"    is not installed.
      Invalid version of js-controler. Required >=3.1.0
      Adapter "vis-jqui-mfd"   is not installed.
      Adapter "vis-justgage"   is not installed.
      Adapter "vis-keyboard"   is not installed.
      Adapter "vis-lcars"      is not installed.
      Adapter "vis-map"        is not installed.
      Adapter "vis-material-advanced" is not installed.
      Adapter "vis-metro"      is up to date.
      Adapter "vis-players"    is not installed.
      Adapter "vis-plumb"      is not installed.
      Adapter "vis-rgraph"     is not installed.
      Adapter "vis-timeandweather" is not installed.
      Adapter "vis-weather"    is not installed.
      Adapter "voltoplus"      is not installed.
      Adapter "volumio"        is not installed.
      Adapter "volvo"          is not installed.
      Adapter "vr200"          is not installed.
      Adapter "vw-connect"     is not installed.
      Adapter "wallpanel"      is not installed.
      Adapter "warp"           is not installed.
      Adapter "weatherflow_udp" is not installed.
      Adapter "weatherunderground" is not installed.
      Adapter "webui"          is not installed.
      Adapter "webuntis"       is not installed.
      Adapter "weishaupt-wem"  is not installed.
      Adapter "whatsapp-cmb"   is not installed.
      Adapter "wiegand-tcpip"  is not installed.
      Adapter "wiffi-wz"       is not installed.
      Adapter "wifilight"      is not installed.
      Adapter "windows-control" is not installed.
      Adapter "wiobrowser"     is not installed.
      Adapter "wireguard"      is not installed.
      Adapter "wireless-mbus"  is not installed.
      Adapter "withings"       is not installed.
      Adapter "wlanthermo-nano" is not installed.
      Adapter "wled"           is not installed.
      Adapter "wmswebcontrol"  is not installed.
      Adapter "wolf"           is not installed.
      Adapter "wolf-smartset"  is not installed.
      Adapter "worx"           is not installed.
      Adapter "ws"             is not installed.
      Adapter "xbox"           is not installed.
      Adapter "xs1"            is not installed.
      Adapter "xterm"          is not installed.
      Adapter "yahka"          is not installed.
      Adapter "yahoo-stock-market" is not installed.
      Adapter "yamaha"         is not installed.
      Adapter "yeelight-2"     is not installed.
      Adapter "youtube"        is not installed.
      Adapter "yr"             is not installed.
      Adapter "zehnder-cloud"  is not installed.
      Adapter "zigbee"         is not installed.
      Adapter "zigbee2mqtt"    is not installed.
      Adapter "zont"           is not installed.
      Adapter "zwave2"         is not installed.
      iob upgrade self
      pi@raspberrypi:~ $ iobroker stop
      pi@raspberrypi:~ $ iobroker upgrade self
      Update js-controller from @2.2.9 to @5.0.12
      NPM version: 9.8.1
      npm install iobroker.js-controller@5.0.12 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
       Objects 127.0.0.1:36550 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
       States 127.0.0.1:49422 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
       Objects 127.0.0.1:36550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
       States 127.0.0.1:49422 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
       Objects 127.0.0.1:36550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
       Objects 127.0.0.1:36550 Error from InMemDB: Error: scan NOT SUPPORTED
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
      npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
      npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
      npm ERR!         throw e;
      npm ERR!         ^
      npm ERR!
      npm ERR! ReplyError: Error scan NOT SUPPORTED
      npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      npm ERR! Emitted 'error' event on ScanStream instance at:
      npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
      npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
      npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
      npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
      npm ERR!   command: {
      npm ERR!     name: 'scan',
      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR!   }
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v18.18.2
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-04T17_59_20_355Z-debug-0.log
      Starting node restart.js
      pi@raspberrypi:~ $ iobroker start
        Thomas Braun Most Active @Alex e last edited by
        @alex-e sagte in js-controller Update mit npm ERR:
        3.3.22
        Schrittweise die Versionen hochziehen.
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
        iob update
        iob upgrade admin
        iob update
        sudo -H -u iobroker npm install iobroker.js-controller@4.0.0
        iob update
        iob upgrade
        iob stop
        iob upgrade self
        iob start
          ich komme zumindest etwas weiter 🙂 Vielen Dank nochmal!
          cd /opt/iobroker
          iob update
          iob upgrade admin
          iob update
          hat geklappt:
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
          added 92 packages, removed 32 packages, and changed 52 packages in 2m
          125 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi:/opt/iobroker $ iob update
          Used repository: stable
          hash changed or no sources cached => force download of new sources
          Cannot get any information of "_repoInfo". Ignored.
          update done
          Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
          pi@raspberrypi:/opt/iobroker $ iob upgrade admin
          This upgrade of "admin" will at least introduce the following changes:
          -> 6.12.0:
          fixed issue when updating news in backend
          validate json config against the schema
          update socket-client to improve performance
          -> 6.11.0:
          jsonConfig type number now stores values as number instead of string
          objects browser number value input behavior change to allow leading minus
          Added component `interfaces` to the JSON config
          Implemented Backend to GUI communication
          -> 6.10.9:
          Improvement of the public accessibility check
          -> 6.10.8:
          update adapter-react-v5 to fix issues with object browser
          -> 6.10.7:
          Corrected adapter termination if the alias has no target
          -> 6.10.6:
          Added possibility to show the icon on JSON config tabs
          on upgrade all, not yet started commands can now be aborted
          Added security check if the server is available from the internet without protection
          Corrected navigation after the settings closing
          -> 6.10.5:
          JSON config component `port` does no longer mark port as occupied if it is only occupied on another host
          register news as notifications
          if upgrade all is stopped on error, activate close button
          Export/import objects with its values
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade admin from @4.0.9 to @6.12.0 now? [(y)es, (n)o]: y
          Update admin from @4.0.9 to @6.12.0
          host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
          NPM version: 9.8.1
          npm install iobroker.admin@6.12.0 --loglevel error --prefix "/opt/iobroker" (System call)
          Update "system.adapter.admin.0"
          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map application/json
          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map application/json
          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js application/javascript
          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map application/json
          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js application/javascript
          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.map custom/static/js/main.681927cc.js.map application/json
          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.json application/json
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          Adapter "admin" updated
          host.raspberrypi Adapter "system.adapter.admin.0" is started
          update done
          Adapter    "admin"         : 6.12.0   , installed 6.12.0
          bei
          ging es dann nicht mehr weiter:
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.0
          npm ERR! code ETARGET
          npm ERR! notarget No matching version found for iobroker.js-controller@4.0.0.
          npm ERR! notarget In most cases you or one of your dependencies are requesting
          npm ERR! notarget a package version that doesn't exist.
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-04T19_40_51_419Z-debug-0.log
          Starten lässt sich der iobroker noch, jetzt ist der js-controller 3.3.22
          mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
          • mcm1957
            mcm1957 @Alex e last edited by mcm1957
            @alex-e
            vom jscontroller 4.x.x ist minimal 4.0.3 und maximal 4.0.24 (letzte 4er stable) verfügbar
            4.0.0 wurde nicht released.
              @alex-e
              Ich weiß die Versionsnummern nicht für 4xx
              iob stop
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
              iob update
              iob upgrade
              iob upgrade self
              iob start
              • mcm1957
                mcm1957 @Thomas Braun last edited by mcm1957
                Du weißt mal was nicht ? 🙂
                Hoffe du wirst nicht krank 🙂 🙂 🙂
                  Thomas Braun Most Active @mcm1957 last edited by
                  @mcm57 sagte in js-controller Update mit npm ERR:
                  Ich fühl mich auch schon ganz komisch...
                  Aber Versionsnummern 'von ollem Kram' merk ich mir nicht...
                    Vielen Dank nochmal für eure Hilfe, und sorry, dass ich nicht so schnell reagieren kann wie ihr. Ich kann gerade nicht so viel Zeit mit iob verbringen wie ich gerne würde.
                    Ich bin mal bis zum Upgrade auf 4.0.24 vorgegangen. Damit sollte der Tizen Adapter ja noch funktionieren.
                    Bis ich auf 5.x upgrade kann ich ja noch nach einer Alternative suchen. Evtl. schaffe ich es ja, mich da einzuarbeiten.
                    Zur Vollständigkeit: So sah das ganze aus:
                    Durchgeführt habe ich:
                    iob stop
                    cd /opt/iobroker
                    iob update
                    iob upgrade
                    Heraus kam:
                    pi@raspberrypi:~ $ iob stop
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                    added 37 packages, removed 18 packages, and changed 48 packages in 48s
                    127 packages are looking for funding
                    Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                    Adapter    "fullybrowser" : 2.2.0    , installed 2.0.1  [Updatable]
                    Adapter    "habpanel"     : 0.5.0    , installed 0.4.1  [Updatable]
                    Adapter    "history"      : 3.0.1    , installed 1.9.10 [Updatable]
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "iot"          : 1.14.5   , installed 1.5.3  [Updatable]
                    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                    Adapter    "openweathermap": 0.3.9   , installed 0.1.0  [Updatable]
                    Adapter    "vis"          : 1.4.16   , installed 1.2.4  [Updatable]
                    Adapter    "vis-inventwo" : 3.3.3    , installed 2.5.11 [Updatable]
                    Adapter    "web"          : 6.1.4    , installed 3.0.7  [Updatable]
                    This upgrade of "web" will at least introduce the following changes:
                    -> 6.1.4:
                    upgrade socketio and ws dependencies to fix vis subscribe problem
                    -> 6.1.3:
                    upgraded socketio and ws dependencies to correct the error by unsubscribing on client disconnect
                    -> 6.1.2:
                    -> 6.1.1:
                    added missing node16 requirement
                    -> 6.1.0:
                    Added the subscribing on the specific instance messages
                    -> 6.0.3:
                    Updated packages
                    Implemented the possibility to view folder content
                    -> 6.0.1:
                    Removed letsencrypt handling from web adapter
                    Would you like to upgrade web from @3.0.7 to @6.1.4 now? [(y)es, (n)o]: y
                    Update web from @3.0.7 to @6.1.4
                    host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                    NPM version: 9.8.1
                    Installing iobroker.web@6.1.4... (System call)
                    added 7 packages, removed 4 packages, and changed 4 packages in 11s
                    upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                    upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                    upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                    upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                    upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                    upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                    upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                    upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                    upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                    upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                    upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                    upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                    upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                    upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                    upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                    upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                    upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                    upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                    upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                    upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                    upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                    upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                    upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                    upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                    upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                    upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                    upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                    upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                    upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                    upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                    upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                    upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                    upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                    upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                    upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                    Update "system.adapter.web.0"
                    upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                    upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                    upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                    upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                    upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                    upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                    upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                    upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                    upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                    upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                    upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                    upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                    upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                    upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                    upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                    upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                    upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                    upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                    upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                    upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                    upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                    upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                    upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                    upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                    upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                    upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                    upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                    upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                    upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                    upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                    host.raspberrypi Adapter "system.adapter.web.0" is started
                    This upgrade of "vis-inventwo" will at least introduce the following changes:
                    -> 3.3.3:
                    Fixed issue with border color and view in popup
                    -> 3.3.2:
                    Bugfix
                    -> 3.3.1:
                    Bugfix
                    -> 3.3.0:
                    New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                    -> 3.2.8:
                    JSON-Table: Added text align für headrow, Radiobutton-List: Added Multi-Row/-Column schema (for more details go to the changelog on Github)
                    -> 3.2.7:
                    Fixed issue that popup not closing on datapoint value
                    -> 3.2.6:
                    JSON-Table: Color background per line depending on a value [#280], JSON-Table: Default sort of a column [#286], Universal- & Multi-Widget ViewInPopUp: View scrolling [#344], Universal- & Multi-Widget HTTP: Link can be opened in same or new tab [#363], FIXED: JSON-Table now also works if there is only a single object in the data point instead of an array with objects [#319], FIXED: JSON-Table: 10-digit timestamp didn't work [#376]
                    Would you like to upgrade vis-inventwo from @2.5.11 to @3.3.3 now? [(y)es, (n)o]: y
                    Update vis-inventwo from @2.5.11 to @3.3.3
                    NPM version: 9.8.1
                    Installing iobroker.vis-inventwo@3.3.3... (System call)
                    changed 1 package in 10s
                    Adapter "system.adapter.vis.0" restarted.
                    Adapter "system.adapter.web.0" restarted.
                    Update "system.adapter.vis-inventwo.0"
                    upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                    upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                    upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                    upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                    upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                    upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                    upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                    upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                    upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                    upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                    upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                    upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                    upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                    upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                    upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                    upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                    upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                    upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                    upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/htmlupload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/pngupload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                    upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                    This upgrade of "vis" will at least introduce the following changes:
                    -> 1.4.16:
                    Corrected connection with "only port" URLs
                    -> 1.4.15:
                    Better check of the offline license
                    -> 1.4.14:
                    Corrected GUI bug
                    -> 1.4.13:
                    The group attributes will be replaced recursively
                    -> 1.4.12:
                    Fixed bug with the export of specific widgets
                    -> 1.4.11:
                    Removed ES6 commands to be supported by older browsers
                    Fixed problem with update of grouped widgets
                    Added web manifest to be able to handle vis as the web app
                    -> 1.4.8:
                    Added support for js-controller 4.x
                    Would you like to upgrade vis from @1.2.4 to @1.4.16 now? [(y)es, (n)o]: y
                    Update vis from @1.2.4 to @1.4.16
                    NPM version: 9.8.1
                    Installing iobroker.vis@1.4.16... (System call)
                    added 2 packages, and changed 1 package in 21s
                    upload [439] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                    upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/navigation.png icon/navigation.png image/png
                    upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/img/vis.png img/vis.png image/png
                    upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/misc.png js/fm/icon/mine/24/misc.png image/png
                    upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/img/shape_align_left.png lib/img/shape_align_left.png image/png
                    upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_HTMLnavigation.png widgets/basic/img/Prev_HTMLnavigation.png image/png
                    upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/img/Prev_MeterGauge.png widgets/jqplot/img/Prev_MeterGauge.png image/png
                    upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_80.png widgets/metro/img/light_light_dim_80.png image/png
                    upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
                    upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                    upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                    upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Nav.png widgets/vis-inventwo/img/0_Nav.png image/png
                    upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Check.gif widgets/vis-inventwo/img/Check.gif image/gif
                    upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider2.gif widgets/vis-inventwo/img/Slider2.gif image/gif
                    upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png image/png
                    upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01.png widgets/vis-inventwo/img/clock_analog/01.png image/png
                    upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/min.png widgets/vis-inventwo/img/clock_analog/02/min.png image/png
                    upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/sek.png widgets/vis-inventwo/img/clock_analog/02/sek.png image/png
                    upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/std.png widgets/vis-inventwo/img/clock_analog/02/std.png image/png
                    upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02.png widgets/vis-inventwo/img/clock_analog/02.png image/png
                    upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/min.png widgets/vis-inventwo/img/clock_analog/03/min.png image/png
                    upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/sek.png widgets/vis-inventwo/img/clock_analog/03/sek.png image/png
                    upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                    upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03.png widgets/vis-inventwo/img/clock_analog/03.png image/png
                    upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/min.png widgets/vis-inventwo/img/clock_analog/04/min.png image/png
                    upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/sek.png widgets/vis-inventwo/img/clock_analog/04/sek.png image/png
                    upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/std.png widgets/vis-inventwo/img/clock_analog/04/std.png image/png
                    upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04.png widgets/vis-inventwo/img/clock_analog/04.png image/png
                    upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/min.png widgets/vis-inventwo/img/clock_analog/05/min.png image/png
                    upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/sek.png widgets/vis-inventwo/img/clock_analog/05/sek.png image/png
                    upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/std.png widgets/vis-inventwo/img/clock_analog/05/std.png image/png
                    upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05.png widgets/vis-inventwo/img/clock_analog/05.png image/png
                    upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                    upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/iro.min.js widgets/vis-inventwo/js/iro.min.js application/javascript
                    upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/vis-inventwo.js widgets/vis-inventwo/js/vis-inventwo.js application/javascript
                    upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo.html widgets/vis-inventwo.html text/htmlUpdate "system.adapter.vis.0"
                    upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                    upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                    This upgrade of "openweathermap" will at least introduce the following changes:
                    -> 0.3.9:
                    updated build process
                    -> 0.3.8:
                    update packages
                    -> 0.3.6:
                    Installation from GitHub does not possible anymore
                    -> 0.3.4:
                    Updated packages
                    -> 0.3.3:
                    Updated widget for vis 2.0
                    -> 0.3.0:
                    Added new widget for vis2.0
                    -> 0.2.5:
                    Make sure all forecast data are processed correctly
                    Would you like to upgrade openweathermap from @0.1.0 to @0.3.9 now? [(y)es, (n)o]: y
                    Update openweathermap from @0.1.0 to @0.3.9
                    NPM version: 9.8.1
                    Installing iobroker.openweathermap@0.3.9... (System call)
                    added 2 packages, and changed 1 package in 9s
                    Update "system.adapter.openweathermap.0"
                    upload [14] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [13] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [12] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [11] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [10] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [9] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [8] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [7] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [6] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [5] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [4] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/htmlupload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                    upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/jsonConfig.json jsonConfig.json application/json
                    upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                    upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                    This upgrade of "iot" will at least introduce the following changes:
                    -> 1.14.5:
                    Corrected names of enums in GUI
                    -> 1.14.3:
                    Fixed processing for lights with CT and RGB in Alisa
                    -> 1.14.2:
                    Updated GUI packages
                    -> 1.14.1:
                    Downgraded axios version to 0.27.2
                    -> 1.14.0:
                    Added netatmo support
                    -> 1.13.0:
                    Add support vor Custom Skill v2
                    -> 1.12.5:
                    Small changes on configuration GUI
                    Would you like to upgrade iot from @1.5.3 to @1.14.5 now? [(y)es, (n)o]: y
                    Update iot from @1.5.3 to @1.14.5
                    host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
                    NPM version: 9.8.1
                    Installing iobroker.iot@1.14.5... (System call)
                    added 49 packages, removed 56 packages, and changed 70 packages in 2m
                    132 packages are looking for funding
                    Update "system.adapter.iot.0"
                    upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                    upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
                    upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
                    upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
                    upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
                    upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
                    upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
                    upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
                    upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
                    upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
                    upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                    host.raspberrypi Adapter "system.adapter.iot.0" is started
                    This upgrade of "history" will at least introduce the following changes:
                    -> 3.0.1:
                    activated the round option when averaging
                    -> 3.0.0:
                    fix history2db.js with controller v5
                    Minimal node.sj version is 16
                    Added support for `count` aggregate type on getHistory
                    -> 2.2.6:
                    Fix getHistory when aggregations were used in some cases
                    -> 2.2.5:
                    -> 2.2.4:
                    Update for future js-controller versions
                    -> 2.2.3:
                    Fix error in history2db converter script
                    -> 2.2.1:
                    Fix crash cases reported by Sentry
                    Would you like to upgrade history from @1.9.10 to @3.0.1 now? [(y)es, (n)o]: y
                    Update history from @1.9.10 to @3.0.1
                    NPM version: 9.8.1
                    Installing iobroker.history@3.0.1... (System call)
                    removed 1 package, and changed 2 packages in 11s
                    Update "system.adapter.history.0"
                    upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                    upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                    This upgrade of "habpanel" will introduce the following changes:
                    -> 0.5.0:
                    added on support for new websockets
                    -> 0.4.3:
                    The compatibility to socket.io 3.0.13 provided
                    Would you like to upgrade habpanel from @0.4.1 to @0.5.0 now? [(y)es, (n)o]: y
                    Update habpanel from @0.4.1 to @0.5.0
                    NPM version: 9.8.1
                    Installing iobroker.habpanel@0.5.0... (System call)
                    added 2 packages, and changed 2 packages in 23s
                    upload [1750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/app.js app/app.js application/javascript
                    upload [1700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/knob/knob.tpl.html app/widgets/knob/knob.tpl.html text/html
                    upload [1650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/it.json assets/i18n/admin/it.json application/json
                    upload [1600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/main/en.po assets/i18n/main/en.po null
                    upload [1550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/ar.json assets/i18n/widgets/ar.json application/json
                    upload [1500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/sv.po assets/i18n/widgets/sv.po null
                    upload [1450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/battery-90.png assets/icons/eclipse-smarthome-classic/battery-90.png image/png
                    upload [1400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/boy_4.png assets/icons/eclipse-smarthome-classic/boy_4.png image/png
                    upload [1350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/cistern-30.png assets/icons/eclipse-smarthome-classic/cistern-30.png image/png
                    upload [1300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/dimmablelight-40.png assets/icons/eclipse-smarthome-classic/dimmablelight-40.png image/png
                    upload [1250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/fire-on.svg assets/icons/eclipse-smarthome-classic/fire-on.svg image/svg+xml
                    upload [1200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/garagedoor.svg assets/icons/eclipse-smarthome-classic/garagedoor.svg image/svg+xml
                    upload [1150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/humidity-100.svg assets/icons/eclipse-smarthome-classic/humidity-100.svg image/svg+xml
                    upload [1100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/man_3.svg assets/icons/eclipse-smarthome-classic/man_3.svg image/svg+xml
                    upload [1050] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_2_2.svg assets/icons/eclipse-smarthome-classic/parents_2_2.svg image/svg+xml
                    upload [1000] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_6_3.svg assets/icons/eclipse-smarthome-classic/parents_6_3.svg image/svg+xml
                    upload [950] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/qualityofservice.svg assets/icons/eclipse-smarthome-classic/qualityofservice.svg image/svg+xml
                    upload [900] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/sewerage-20.svg assets/icons/eclipse-smarthome-classic/sewerage-20.svg image/svg+xml
                    upload [850] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/slider-30.svg assets/icons/eclipse-smarthome-classic/slider-30.svg image/svg+xml
                    upload [800] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/switch-off.svg assets/icons/eclipse-smarthome-classic/switch-off.svg image/svg+xml
                    upload [750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/wind.svg assets/icons/eclipse-smarthome-classic/wind.svg image/svg+xml
                    upload [700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/cs-mixer.svg assets/icons/freepik-gadgets/cs-mixer.svg image/svg+xml
                    upload [650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/synthesizer.svg assets/icons/freepik-gadgets/synthesizer.svg image/svg+xml
                    upload [600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/bookshelf.svg assets/icons/freepik-household/bookshelf.svg image/svg+xml
                    upload [550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/door.svg assets/icons/freepik-household/door.svg image/svg+xml
                    upload [500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/mixer-2.svg assets/icons/freepik-household/mixer-2.svg image/svg+xml
                    upload [450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/sofa-17.svg assets/icons/freepik-household/sofa-17.svg image/svg+xml
                    upload [400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/window-6.svg assets/icons/freepik-household/window-6.svg image/svg+xml
                    upload [350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/bedroom-stairs-tool.svg assets/icons/freepik-housethings/bedroom-stairs-tool.svg image/svg+xml
                    upload [300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/door-design.svg assets/icons/freepik-housethings/door-design.svg image/svg+xml
                    upload [250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/house-building.svg assets/icons/freepik-housethings/house-building.svg image/svg+xml
                    upload [200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/livingroom-lamp.svg assets/icons/freepik-housethings/livingroom-lamp.svg image/svg+xml
                    upload [150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/shower-bathroom-tool.svg assets/icons/freepik-housethings/shower-bathroom-tool.svg image/svg+xml
                    upload [100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/yard-fountain.svg assets/icons/freepik-housethings/yard-fountain.svg image/svg+xml
                    upload [90] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/air-conditioning-indoor.svg assets/icons/smarthome-set/air-conditioning-indoor.svg image/svg+xml
                    upload [80] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/eye.svg assets/icons/smarthome-set/eye.svg image/svg+xml
                    upload [70] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/plug.svg assets/icons/smarthome-set/plug.svg image/svg+xml
                    upload [60] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/socket-i.svg assets/icons/smarthome-set/socket-i.svg image/svg+xml
                    upload [50] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set.list.json assets/icons/smarthome-set.list.json application/json
                    upload [40] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/styles/themes/default.css assets/styles/themes/default.css text/css
                    upload [30] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/styles/themes/translucent/translucent.min.css assets/styles/themes/translucent/translucent.min.css text/css
                    upload [20] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.ttf fonts/roboto/Roboto-Regular.ttf font/ttf
                    upload [19] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.woff fonts/roboto/Roboto-Regular.woff font/woff
                    upload [18] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.woff2 fonts/roboto/Roboto-Regular.woff2 font/woff2
                    upload [17] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/index.html index.html text/html
                    upload [16] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/manifest.json manifest.json application/json
                    upload [15] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/service-worker.js service-worker.js application/javascript
                    upload [14] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/tile.png tile.png image/png
                    upload [13] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/closebrackets.js vendor/cm/addon/edit/closebrackets.js application/javascript
                    upload [12] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/closetag.js vendor/cm/addon/edit/closetag.js application/javascript
                    upload [11] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/matchbrackets.js vendor/cm/addon/edit/matchbrackets.js application/javascript
                    upload [10] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/matchtags.js vendor/cm/addon/edit/matchtags.js application/javascript
                    upload [9] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/xml.js vendor/cm/addon/edit/xml.js application/javascript
                    upload [8] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/fold/xml-fold.js vendor/cm/addon/fold/xml-fold.js application/javascript
                    upload [7] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/mode/overlay.js vendor/cm/addon/mode/overlay.js application/javascript
                    upload [6] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/lib/codemirror.css vendor/cm/lib/codemirror.css text/css
                    upload [5] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/lib/codemirror.js vendor/cm/lib/codemirror.js application/javascript
                    upload [4] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/mode/javascript/javascript.js vendor/cm/mode/javascript/javascript.js application/javascript
                    upload [3] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/mode/xml/xml.js vendor/cm/mode/xml/xml.js application/javascript
                    upload [2] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/theme/rubyblue.css vendor/cm/theme/rubyblue.css text/css
                    upload [1] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/styles.min.css vendor/styles.min.css text/css
                    upload [0] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/vendor.js vendor/vendor.js application/javascript
                    Update "system.adapter.habpanel.0"
                    upload [0] habpanel.admin /opt/iobroker/node_modules/iobroker.habpanel/admin/habpanel.png habpanel.png image/png
                    This upgrade of "fullybrowser" will at least introduce the following changes:
                    -> 2.2.0:
                    intrvall corr
                    -> 2.1.6:
                    add name of devie to admin
                    -> 2.1.2:
                    encodeuri for psw
                    -> 2.1.1:
                    js-controller 4.x
                    Would you like to upgrade fullybrowser from @2.0.1 to @2.2.0 now? [(y)es, (n)o]: y
                    Update fullybrowser from @2.0.1 to @2.2.0
                    NPM version: 9.8.1
                    Installing iobroker.fullybrowser@2.2.0... (System call)
                    removed 2 packages, and changed 3 packages in 9s
                    Update "system.adapter.fullybrowser.0"
                    upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
                    upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
                    upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
                    This upgrade of "backitup" will introduce the following changes:
                    -> 2.8.7:
                    fix restore in docker v9
                    -> 2.8.6:
                    Fix node-red restore
                    dependencies updated
                    -> 2.8.5:
                    Fix mount errors
                    -> 2.8.4:
                    Fix mysql Backup
                    Fix pgsql Backup
                    Fix InfluxDB Backup
                    -> 2.8.3:
                    Wake on LAN Advanced Settings added
                    -> 2.8.2:
                    Fix redis backup
                    Would you like to upgrade backitup from @2.8.1 to @2.8.7 now? [(y)es, (n)o]: y
                    Update backitup from @2.8.1 to @2.8.7
                    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                    NPM version: 9.8.1
                    Installing iobroker.backitup@2.8.7... (System call)
                    Update "system.adapter.backitup.0"
                    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                    host.raspberrypi Adapter "system.adapter.backitup.0" is started
                    pi@raspberrypi:/opt/iobroker $ iob start
                      Der funktioniert als git-Version wohl wieder mit js-controller5.
                      • mcm1957
                        @alex-e said in js-controller Update mit npm ERR:
                        https://github.com/iobroker-community-adapters/ioBroker.samsung_tizen#100-alpha1-2023-09-24
                        Mit ioBroker.smsung_tizen von aus der community sollte js-controller 5 kein Problem haben - oder umgekehrt. Zumindest hab ich nix negatives erfahren.
                        Release in Repos fehlt noch - steht aber auf der (ellenlangen) Liste 🙂
                          Alex e @mcm1957 last edited by
                          @mcm57 @Thomas-Braun
                          Vielen Dank auch noch für den Tipp mit dem Tizen Adapter.
                          Ich habe mein System jetzt (um zu testen ob das Backup funktioniert) aus dem Backup neu aufgsetzt und dann den Tizen Adapter aus Github neu installiert.
                          Bisher funktioniert alles wunderbar.
                          • mcm1957
                            @mcm57 @Thomas-Braun .
                            Warum installierst du von Github?
                            Installationen von Github sollten NUR auf Aufforderung des DEV und iA. zur Fehleranalyse oder dem Test eines Hot-Fixes erfolgen. Für die normale Benutzung - insbesondere auf produktiven Systemen - wird von einer GITHUB Installation dringend abgeraten.
                            Der Adapter ist längst normal im Repo verfügbar:
                            1.0.0 (2023-09-30)
                            (mcm1957) An official release has been created
                            1567
