    4. BackItUp Update hängt
      myssv last edited by
      Nach einer gefühlten Ewigkeit ging es dann im Backend auch weiter:
      $ iobroker upgrade backitup@2.8.7
      Update backitup from @2.8.1 to @2.8.7
      Installing iobroker.backitup@2.8.7... (System call)
      upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      Process exited with code 0
      Aber er zeigt bei den Adaptern immer noch an, dass es ein Update gibt.
        Thomas Braun Most Active @myssv last edited by
        @myssv
        iob update
        sagt?
          myssv @Thomas Braun last edited by
          @thomas-braun sagte in BackItUp Update hängt:
          iob update
          Ich habe den Server vorher einmal neu gestartet. Scheinbar auch ohne Erfolg.
          Volker@ioBroker:~$ iob update
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Volker@ioBroker:~$
            Ich habe jetzt nach dem Neustart das Update im Backend noch einmal gestartet und nun lief es durch
            88 packages are looking for funding run `npm fund` for details
            Update "system.adapter.backitup.0"
              @thomas-braun Danke für Deine Mühen!
                marios774 last edited by
                Bei mir lief das Update durch. Dann kam aber die Fehlerneldung:
                startInstance system.adapter.backitup.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=6.0.0"!
                admin: 6.12.0
                Node.js: v18.17.1(18.18.2)
                NPM: 9.6.7(9.8.1)
                Auch die Installation einer älteren Version haben nichts gebracht.
                  Thomas Braun Most Active @marios774 last edited by Thomas Braun
                  @marios774
                  iob stop
                  iob fix
                  iob nodejs-update
                  iob upload all
                  • Duffy
                    Duffy @Thomas Braun last edited by
        iob stop        iob fix        iob nodejs-update        iob upload all
                    Kann man das node.js Update immer so machen? Es gibt hier so viele Beschreibungen zu das ich mir da jetzt etwas unsicher bin 🙂
                      Thomas Braun Most Active @Duffy last edited by
                      @duffy
                      Seit kurzen gibt es den Befehl dazu. Siehe auch die Ankündigungen hier im Forum.
                      • Duffy
                        Duffy @Thomas Braun last edited by Duffy
                        Wenn man am letzten Wochenende den IOB neu installiert hatte muss man dann trotzdem jetzt noch mal
                        fix iob
                        ausführen oder hat das die IOB Version dann schon drin das man jetzt
                        iob nodejs-update
                        ausführen kann?
                          Thomas Braun Most Active @Duffy last edited by Thomas Braun
                          @duffy
                          Nein, der
                          iob fix
                          ist nur erforderlich, wenn das Kommando 'iobroker nodejs-update' noch nicht geladen wurde (bei Alt-Installationen, Neuinstallationen kommen direkt damit an). Jetzt steht das natürlich direkt zur Verfügung.
                          Probier es halt einfach aus. Wenn es nicht vorhanden ist:
                          iob fix
                          • Duffy
                            Ich komme jetzt gerade nicht an meinen IOB aber woran sollte ich den erkennen ob es verfügbar ist?
                            Gibt es da auch einen Befehl für?
                            Glaub der Groschen ist gefallen, wenn
                            iob nodejs-update
                            funktioniert ist kein
                            fix iob
                            nötig.
                            Werde mir das heute Abend mal anschauen. Danke dir.
                            Gruß Duffy
                              @duffy
                              iob fix
                              nicht fix iob...
                              Duffy 2 Replies Last reply Reply Quote 0
                              • Duffy
                                Ja, danke, war ein Kopierfehler trotzdem danke für den Hinweis, sonst wäre ich vielleicht wieder mal auf dem Schlauch gestanden.
                                • Duffy
                                  Habe es gerade überprüft. Ich konnte
                                  iob nodejs-update
                                  ausführen. Dann wurde mir vorgeschlagen um das System up to Date zu halten
                                  sudo apt update && sudo apt full-upgrade
                                  auszuführen.
                                  Dabei kam am Ende die Meldung mit der ich nichts anfangen kann (letzter Satz):
                                  pi@raspberrypi:~ $ sudo apt update && sudo apt full-upgrade
                                  Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                                  Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                                  Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
                                  Get:5 https://repos.influxdata.com/debian stable InRelease [6,901 B]
                                  Get:6 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
                                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Get:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [90.9 kB]
                                  Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [93.2 kB]
                                  Get:10 http://deb.debian.org/debian bookworm-updates/main armhf Packages [6,648 B]
                                  Get:11 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6,672 B]
                                  Get:12 http://deb.debian.org/debian bookworm-updates/main Translation-en [5,204 B]
                                  Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [346 kB]
                                  Get:14 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [338 kB]
                                  Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [7,173 B]
                                  Get:16 https://packages.grafana.com/oss/deb stable/main arm64 Packages [126 kB]
                                  Fetched 1,157 kB in 3s (427 kB/s)
                                  Reading package lists... Done
                                  ^Cilding dependency tree... 50%
                                  Ist
                                  was gutes?? 😧
                                  VG Duffy
                                  Thomas Braun ? Homoran 3 Replies Last reply Reply Quote 0
                                    @duffy sagte in BackItUp Update hängt:
                                    was gutes??
                                    Was normales.
                                    Dauert hat gglfs. etwas.
                                      A Former User @Duffy last edited by A Former User
                                      Moin,
                                      der war noch nicht fertig!
                                      Da steht eigentlich Building, Du hast aber irgendwie ein ^C gemacht also Control C == Abbruch der Aktion, die gerade auf der Kommandozeile ausgeführt wurde.
                                      Also nochmal ausführen und dann nicht immer herumfummeln, halte mal die Finger still und warte!
                                      VG
                                      Bernd
                                        Homoran Global Moderator Administrators @Duffy last edited by
                                        Ist
                                        was gutes??
                                        das ist ein Zeichen dass du zu ungeduldig warst und mitten im Prozess mit ctrl-c abgebrochen hast
                                        • Duffy
                                          Duffy @Homoran last edited by
                                          Hmm, eigentlich war ich an etwas anderem dran auf einem 2. Bildschirm aber vielleicht bin ich wirklich drauf gekommen.
                                          Aber sagt mal ist
                                          das gleiche wie
                                          Sudo apt update
                                          und
                                          Sudo apt upgrade
                                          Wenn nein wo ist der Unterschied?
                                            Der Unterschied besteht darin, das ein apt full-upgrade die Abhängigkeiten anders auflöst. Das macht u. U. auch ein Downgrade, was ein simples apt upgrade nicht macht.
                                            Meist wird allerdings da gleiche gemacht, weil in der Regel kein Downgrade sondern eher ein Upgrade von Paketen vorgesehen ist.
                                            7971
