    4. BackItUp Update hängt
      myssv @Thomas Braun last edited by
      @thomas-braun sagte in BackItUp Update hängt:
      iob update
      Ich habe den Server vorher einmal neu gestartet. Scheinbar auch ohne Erfolg.
      Volker@ioBroker:~$ iob update
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Volker@ioBroker:~$
        myssv last edited by
        Ich habe jetzt nach dem Neustart das Update im Backend noch einmal gestartet und nun lief es durch
        $ iobroker upgrade backitup@2.8.7
        Update backitup from @2.8.1 to @2.8.7
        Installing iobroker.backitup@2.8.7... (System call)
        88 packages are looking for funding run `npm fund` for details
        Update "system.adapter.backitup.0"
        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        Process exited with code 0
          @thomas-braun Danke für Deine Mühen!
            marios774 last edited by
            Bei mir lief das Update durch. Dann kam aber die Fehlerneldung:
            startInstance system.adapter.backitup.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=6.0.0"!
            admin: 6.12.0
            Node.js: v18.17.1(18.18.2)
            NPM: 9.6.7(9.8.1)
            Auch die Installation einer älteren Version haben nichts gebracht.
              Thomas Braun Most Active @marios774 last edited by Thomas Braun
              @marios774
              iob stop
              iob fix
              iob nodejs-update
              iob upload all
              • Duffy
                Duffy @Thomas Braun last edited by
        iob stop        iob fix        iob nodejs-update        iob upload all
                Kann man das node.js Update immer so machen? Es gibt hier so viele Beschreibungen zu das ich mir da jetzt etwas unsicher bin 🙂
                  Thomas Braun Most Active @Duffy last edited by
                  @duffy
                  Seit kurzen gibt es den Befehl dazu. Siehe auch die Ankündigungen hier im Forum.
                  • Duffy
                    Duffy @Thomas Braun last edited by Duffy
                    Wenn man am letzten Wochenende den IOB neu installiert hatte muss man dann trotzdem jetzt noch mal
                    fix iob
                    ausführen oder hat das die IOB Version dann schon drin das man jetzt
                    iob nodejs-update
                    ausführen kann?
                      Thomas Braun Most Active @Duffy last edited by Thomas Braun
                      @duffy
                      Nein, der
                      iob fix
                      ist nur erforderlich, wenn das Kommando 'iobroker nodejs-update' noch nicht geladen wurde (bei Alt-Installationen, Neuinstallationen kommen direkt damit an). Jetzt steht das natürlich direkt zur Verfügung.
                      Probier es halt einfach aus. Wenn es nicht vorhanden ist:
                      iob fix
                      • Duffy
                        Ich komme jetzt gerade nicht an meinen IOB aber woran sollte ich den erkennen ob es verfügbar ist?
                        Gibt es da auch einen Befehl für?
                        Glaub der Groschen ist gefallen, wenn
                        iob nodejs-update
                        funktioniert ist kein
                        fix iob
                        nötig.
                        Werde mir das heute Abend mal anschauen. Danke dir.
                        Gruß Duffy
                          @duffy
                          iob fix
                          nicht fix iob...
                          Duffy 2 Replies Last reply Reply Quote 0
                          • Duffy
                            Ja, danke, war ein Kopierfehler trotzdem danke für den Hinweis, sonst wäre ich vielleicht wieder mal auf dem Schlauch gestanden.
                            • Duffy
                              Habe es gerade überprüft. Ich konnte
                              iob nodejs-update
                              ausführen. Dann wurde mir vorgeschlagen um das System up to Date zu halten
                              sudo apt update && sudo apt full-upgrade
                              auszuführen.
                              Dabei kam am Ende die Meldung mit der ich nichts anfangen kann (letzter Satz):
                              pi@raspberrypi:~ $ sudo apt update && sudo apt full-upgrade
                              Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                              Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                              Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
                              Get:5 https://repos.influxdata.com/debian stable InRelease [6,901 B]
                              Get:6 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
                              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Get:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [90.9 kB]
                              Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [93.2 kB]
                              Get:10 http://deb.debian.org/debian bookworm-updates/main armhf Packages [6,648 B]
                              Get:11 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6,672 B]
                              Get:12 http://deb.debian.org/debian bookworm-updates/main Translation-en [5,204 B]
                              Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [346 kB]
                              Get:14 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [338 kB]
                              Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [7,173 B]
                              Get:16 https://packages.grafana.com/oss/deb stable/main arm64 Packages [126 kB]
                              Fetched 1,157 kB in 3s (427 kB/s)
                              Reading package lists... Done
                              ^Cilding dependency tree... 50%
                              Ist
                              was gutes?? 😧
                              VG Duffy
                              Thomas Braun ? Homoran 3 Replies Last reply Reply Quote 0
                                @duffy sagte in BackItUp Update hängt:
                                was gutes??
                                Was normales.
                                Dauert hat gglfs. etwas.
                                  A Former User @Duffy last edited by A Former User
                                  Moin,
                                  der war noch nicht fertig!
                                  Da steht eigentlich Building, Du hast aber irgendwie ein ^C gemacht also Control C == Abbruch der Aktion, die gerade auf der Kommandozeile ausgeführt wurde.
                                  Also nochmal ausführen und dann nicht immer herumfummeln, halte mal die Finger still und warte!
                                  VG
                                  Bernd
                                    Homoran Global Moderator Administrators @Duffy last edited by
                                    Ist
                                    was gutes??
                                    das ist ein Zeichen dass du zu ungeduldig warst und mitten im Prozess mit ctrl-c abgebrochen hast
                                    • Duffy
                                      Duffy @Homoran last edited by
                                      Hmm, eigentlich war ich an etwas anderem dran auf einem 2. Bildschirm aber vielleicht bin ich wirklich drauf gekommen.
                                      Aber sagt mal ist
                                      das gleiche wie
                                      Sudo apt update
                                      und
                                      Sudo apt upgrade
                                      Wenn nein wo ist der Unterschied?
                                        Der Unterschied besteht darin, das ein apt full-upgrade die Abhängigkeiten anders auflöst. Das macht u. U. auch ein Downgrade, was ein simples apt upgrade nicht macht.
                                        Meist wird allerdings da gleiche gemacht, weil in der Regel kein Downgrade sondern eher ein Upgrade von Paketen vorgesehen ist.
                                        • Duffy
                                          Heisst das man sollte lieber immer
                                          verwenden?
                                          Was ihr alles wisst, ihr seid der Hammer 👍
                                            @duffy
                                            Ja, full-upgrade ist zu bevorzugen.
                                            8719
