    4. Fehler beim Adapter installieren Code25
      Thomas Braun Most Active @yamaha1220 last edited by
      @yamaha1220 sagte in Fehler beim Adapter installieren Code25:
      /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log
      Dann schau da rein.
      Die Meldung selber kenne ich nicht.
      Y 1 Reply Last reply Reply Quote 0
      • Y
        yamaha1220 @Thomas Braun last edited by
        @thomas-braun das kam jetzt raus
        schenk@pi32:/opt/iobroker $ schenk@pi32:~ $ cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! Unable to subscribe to meta namespace "meta." changes: Error PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
        npm ERR!         throw e;
        npm ERR!         ^
        npm ERR!
        npm ERR! ReplyError: Error scan NOT SUPPORTED
        npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
        npm ERR! Emitted 'error' event on ScanStream instance at:
        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
        npm ERR!   command: {
        npm ERR!     name: 'scan',
        npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
        npm ERR!   }
        npm ERR! }
        npm ERR!
        npm ERR! Node.js v18.18.2
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T14_06_35_334Z-debug-0.log
        • Y
          @thomas-braun said in Fehler beim Adapter installieren Code25:
          so direkt eingeben?
            cat /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log
            oder
            less /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log
            Y 2 Replies Last reply Reply Quote 0
            • Y
              @thomas-braun passiert nichts
              schenk@pi32:~ $ cat /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log
              cat: /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log: No such file or directory
              schenk@pi32:~ $ less /home/iobroker/.npm/_logs/2023-11-07T14_02_04_163Z-debug-0.log
              schenk@pi32:~ $
              • Y
                @thomas-braun habe jetzt alles befolgt
                  @yamaha1220
                  Fällt mir nichts mehr zu ein.
                  Y 3 Replies Last reply Reply Quote 0
                  • Y
                    @thomas-braun hmm. Habe alles so aufgespielt wie in deiner Anleitung und alles befolgt echt komisch das er den js-controller nicht installiert also eine älter version
                      Homoran Global Moderator Administrators @yamaha1220 last edited by
                      logs/2023-11-07T**14_06**35_334Z-debug-0.log
                      • Y
                        @thomas-braun hängt der fehler in der version ?
                        • Y
                          yamaha1220 @Homoran last edited by
                          @homoran bedeutet jetzt was?
                            die in deinem output angegebene Datei ist nicht die, die du nicht findest
                            • Y
                              @homoran ok und was soll ich jetzt machen?
                              • Y
                                @thomas-braun das steht bei hosts
                                Typ: js-controller
                                Titel: JS controller
                                OS: linux
                                Verfügbar: 5.0.12
                                Installiert: 3.1.6
                                Ereignisse: ↦33 / ↦16
                                • Y
                                  @homoran hast du eine idee was ich jetzt machen könnte?
                                    @yamaha1220
                                    Du hockst ja noch auf dem ollen js-controller. Kein Wunder das damit nichts mehr funktioniert.
                                    • Y
                                      @thomas-braun das ist nach dem backup gewesen was soll ich jetzt machen? beim backup hat er es übernommen
                                        Hä? Wer hat was in welcher Version übernommen?
                                        Du hast ein Backup in den js-controller@5 bekommen? Verwunderlich.
                                        • Y
                                          @thomas-braun ich habe alles neu aufgesetzt wie in deiner anleitung.
                                          und da denke ich das der js-controller bestimmt eine andere version hat und nach meinem backup wieder ein schlechteres js-controller version oder nicht?
                                          • Y
                                            @thomas-braun was soll ich jetzt machen ? nochmal neu aufsetzen?
                                            10053
