    4. Zigbee iobroker Error while opening serialport
      klausiy123 last edited by klausiy123
      Hallo
      Mein cc26x2 mag, warum auch immer, nicht mehr. Vielleicht kann mir jemand helfen. Vielen Dank im voraus.
      2022-11-22 16:46:21.405 - info: host.orangepiplus2e "system.adapter.zigbee.0" enabled
      2022-11-22 16:46:22.201 - info: host.orangepiplus2e instance system.adapter.zigbee.0 started with pid 1538
      2022-11-22 16:46:34.269 - info: zigbee.0 (1538) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
      2022-11-22 16:46:34.577 - info: zigbee.0 (1538) delete old Backup files. keep only last 10
      2022-11-22 16:46:34.584 - info: zigbee.0 (1538) Starting Zigbee npm ...
      2022-11-22 16:46:36.030 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
      2022-11-22 16:46:56.485 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2022-11-22 16:46:56.488 - error: zigbee.0 (1538) Failed to start Zigbee
      2022-11-22 16:46:56.490 - error: zigbee.0 (1538) Error herdsman start
      2022-11-22 16:47:06.502 - info: zigbee.0 (1538) Try to reconnect. 1 attempts left
      2022-11-22 16:47:06.506 - info: zigbee.0 (1538) Starting Zigbee npm ...
      2022-11-22 16:47:06.561 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
      2022-11-22 16:47:07.170 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2022-11-22 16:47:07.174 - error: zigbee.0 (1538) Failed to start Zigbee
      2022-11-22 16:47:07.175 - error: zigbee.0 (1538) Error herdsman start
        arteck Developer Most Active @klausiy123 last edited by
        @klausiy123 zieh den coordinator ab und steck den wieder rein
          klausiy123 @arteck last edited by
          @arteck besten Dank, das war wohl der Fehler, auch wenn ich nicht verstehe warum das nach Jahren erstmals auftrat und das Teil nie bewegt wurde.
            Galli2k last edited by
            Hallo zusammen, auch ich bin verzweifelt den Zigbee adapter mit dem CC1352p-2 coordinator zum laufen zu bringen.
            Hier mal einiges was ich so gemacht hab. Ich hoffe jemand kann mir Helfen. Danke
            PS: ioBroker läuft auf ein LXC in Proxmox
            2022-12-07 18:50:59.448 - info: backitup.0 (385) [iobroker] backup was activated at 02:40 every 1 day(s)
            2022-12-07 18:56:16.554 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
            2022-12-07 18:59:17.572 - info: host.ioBroker "system.adapter.zigbee.0" enabled
            2022-12-07 18:59:17.587 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 416
            2022-12-07 18:59:18.664 - info: zigbee.0 (416) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
            2022-12-07 18:59:18.704 - info: zigbee.0 (416) Starting Zigbee npm ...
            2022-12-07 18:59:18.916 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
            2022-12-07 18:59:18.953 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
            2022-12-07 18:59:18.954 - error: zigbee.0 (416) Failed to start Zigbee
            2022-12-07 18:59:18.954 - error: zigbee.0 (416) Error herdsman start
            2022-12-07 18:59:21.505 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
            2022-12-07 18:59:21.555 - error: zigbee.0 (416) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            2022-12-07 18:59:28.956 - info: zigbee.0 (416) Try to reconnect. 1 attempts left
            2022-12-07 18:59:28.957 - info: zigbee.0 (416) Starting Zigbee npm ...
            2022-12-07 18:59:28.964 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
            2022-12-07 18:59:29.047 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
            2022-12-07 18:59:29.048 - error: zigbee.0 (416) Failed to start Zigbee
            2022-12-07 18:59:29.048 - error: zigbee.0 (416) Error herdsman start
            2022-12-07 18:59:32.398 - info: admin.0 (343) <== Disconnect system.user.admin from ::ffff:192.168.178.68
            root@ioBroker:~# ls -l /dev
            total 0
            crw--w---- 1 root   tty     136, 0 Dec  7 18:50 console
            lrwxrwxrwx 1 root   root        11 Dec  7 18:50 core -> /proc/kcore
            lrwxrwxrwx 1 root   root        13 Dec  7 18:50 fd -> /proc/self/fd
            crw-rw-rw- 1 nobody nogroup   1, 7 Dec  7 12:41 full
            lrwxrwxrwx 1 root   root        12 Dec  7 18:50 initctl -> /run/initctl
            lrwxrwxrwx 1 root   root        28 Dec  7 18:50 log -> /run/systemd/journal/dev-log
            drwxrwxrwt 2 nobody nogroup     40 Dec  7 18:50 mqueue
            crw-rw-rw- 1 nobody nogroup   1, 3 Dec  7 12:41 null
            crw-rw-rw- 1 root   root      5, 2 Dec  7 19:20 ptmx
            drwxr-xr-x 2 root   root         0 Dec  7 18:50 pts
            crw-rw-rw- 1 nobody nogroup   1, 8 Dec  7 12:41 random
            drwxr-xr-x 3 root   root        60 Dec  7 18:50 serial
            drwxrwxrwt 2 root   root        40 Dec  7 18:50 shm
            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stderr -> /proc/self/fd/2
            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdin -> /proc/self/fd/0
            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdout -> /proc/self/fd/1
            crw-rw-rw- 1 nobody nogroup   5, 0 Dec  7 12:41 tty
            crw------- 1 root   tty     136, 1 Dec  7 19:20 tty1
            crw--w---- 1 root   tty     136, 2 Dec  7 18:50 tty2
            crw-rw-rw- 1 nobody nogroup 166, 0 Dec  7 12:41 ttyACM0
            crw-rw-rw- 1 nobody nogroup 188, 0 Dec  7 12:41 ttyUSB0
            crw-rw-rw- 1 nobody nogroup   1, 9 Dec  7 12:41 urandom
            crw-rw-rw- 1 nobody nogroup   1, 5 Dec  7 12:41 zero
            Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
            Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
            Bus 001 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
            Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
            Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
            root@Intel:~# ls /dev/serial/by-id/
            usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03
            root@Intel:~#
            root@Intel:~# ls -l /dev/serial/by-id
            total 0
            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 -> ../../ttyUSB0
            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 -> ../../ttyACM0
            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03 -> ../../ttyACM1
            root@Intel:~#
              GNU nano 5.4        100.conf
            arch: amd64
            cores: 2
            features: nesting=1
            hostname: ioBroker
            memory: 4096
            net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=1A:BA:1E:27:F0:F7,ip=dhcp,ip6=dhcp,type=veth
            ostype: ubuntu
            rootfs: local-lvm:vm-100-disk-0,size=16G
            swap: 512
            unprivileged: 1
            lxc.cgroup2.devices.allow: c 189:* rwm
            lxc.mount.entry: usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 none bind,optional,create=file
            lxc.cgroup2.devices.allow: c 166:* rwm
            lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=file
            lxc.mount.entry: usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 none bind,optional,create=file
            lxc.cgroup2.devices.allow: c 188:* rwm
            lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
            • Asgothian
              Asgothian Developer @Galli2k last edited by
              @galli2k Du hast ein Problem damit das die Berechtigungen zum zugriff auf die serielle Schnittstelle nicht ausreicht. Das ist ein Problem des LXC Setups - da musst du suchen.
              Mehr kann ich dazu nicht sagen - ich setze das nicht ein.
              A
                Galli2k @Asgothian last edited by
                @asgothian Falls es jemanden helfen sollte:
                Ich hatte vorher beim Anlegen des Lxc im Netzwerk DHCP gewählt.
                Nun habe ich einen neuen Container mit einer statische IP angelegt und alles läuft wunderbar.
                  arteck Developer Most Active @Galli2k last edited by
                  @galli2k sagte in Zigbee iobroker Error while opening serialport:
                  da muss noch mehr gewesen sein .. DHCP hat nix mit USB belegun gzu tun.
                    woupi last edited by
                    leider muss ich dieses Thema nochmal hervorholen.
                    Ich habe heute einen Sonoff Zigbee Stick bekommen.
                    Ich habe ihn in den NUC gesteckt und in Proxmox zur VM iobroker durch gereicht.
                    ls -la /dev/serial/by-id/ ergibt
                    total 0
                    drwxr-xr-x 2 root root 80 Nov  7 17:44 .
                    drwxr-xr-x 4 root root 80 Nov  7 17:44 ..
                    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-1a86_USB_Serial-if00-port0 -> ../../t        tyUSB1
                    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl        us_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0 -> ../../ttyUSB0
                    Eingegeben unter COM-Anschluss im Adapter habe ich
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0
                    Hier der komplette log
                    zigbee.0
                    2023-11-07 19:16:24.684	error	Error herdsman start
                    zigbee.0
                    2023-11-07 19:16:24.684	error	Failed to start Zigbee
                    zigbee.0
                    2023-11-07 19:16:24.684	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0
                    2023-11-07 19:16:24.604	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    2023-11-07 19:16:24.596	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-11-07 19:16:24.596	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    2023-11-07 19:16:14.595	error	Error herdsman start
                    zigbee.0
                    2023-11-07 19:16:14.594	error	Failed to start Zigbee
                    zigbee.0
                    2023-11-07 19:16:14.594	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    2023-11-07 19:16:14.532	error	Re-commissioning your network will require re-pairing of all devices!
                    zigbee.0
                    2023-11-07 19:16:14.532	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                    zigbee.0
                    2023-11-07 19:16:14.532	error	Please update configuration to prevent further issues.
                    zigbee.0
                    2023-11-07 19:16:14.532	error	- Channel List: configured=11, adapter=11
                    zigbee.0
                    2023-11-07 19:16:14.532	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                    zigbee.0
                    2023-11-07 19:16:14.531	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                    zigbee.0
                    2023-11-07 19:16:14.531	error	- PAN ID: configured=6258, adapter=6258
                    zigbee.0
                    2023-11-07 19:16:14.531	error	Configuration is not consistent with adapter state/backup!
                    zigbee.0
                    2023-11-07 19:16:14.261	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    2023-11-07 19:16:14.159	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-11-07 19:16:14.097	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                    zigbee.0
                    2023-11-07 19:15:37.122	info	terminating
                    zigbee.0
                    2023-11-07 19:15:36.683	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    2023-11-07 19:15:36.683	info	terminating
                    zigbee.0
                    2023-11-07 19:15:36.674	warn	Failed to stop zigbee during startup
                    zigbee.0
                    2023-11-07 19:15:36.625	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2023-11-07 19:15:36.622	info	cleaned everything up...
                    zigbee.0
                    2023-11-07 19:15:36.621	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    2023-11-07 19:09:56.448	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                    zigbee.0
                    2023-11-07 19:09:56.370	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    2023-11-07 18:28:27.996	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                    zigbee.0
                    2023-11-07 18:28:27.938	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    2023-11-07 18:26:08.388	error	Error herdsman start
                    zigbee.0
                    2023-11-07 18:26:08.388	error	Failed to start Zigbee
                    zigbee.0
                    2023-11-07 18:26:08.388	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0
                    2023-11-07 18:26:08.293	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    2023-11-07 18:26:08.278	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-11-07 18:26:08.277	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    2023-11-07 18:25:58.275	error	Error herdsman start
                    zigbee.0
                    2023-11-07 18:25:58.275	error	Failed to start Zigbee
                    zigbee.0
                    2023-11-07 18:25:58.275	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    2023-11-07 18:25:58.233	error	Re-commissioning your network will require re-pairing of all devices!
                    zigbee.0
                    2023-11-07 18:25:58.233	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                    zigbee.0
                    2023-11-07 18:25:58.233	error	Please update configuration to prevent further issues.
                    zigbee.0
                    2023-11-07 18:25:58.233	error	- Channel List: configured=11, adapter=11
                    zigbee.0
                    2023-11-07 18:25:58.232	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                    zigbee.0
                    2023-11-07 18:25:58.232	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                    zigbee.0
                    2023-11-07 18:25:58.232	error	- PAN ID: configured=6258, adapter=6258
                    zigbee.0
                    2023-11-07 18:25:58.232	error	Configuration is not consistent with adapter state/backup!
                    zigbee.0
                    2023-11-07 18:25:57.935	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    2023-11-07 18:25:57.803	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-11-07 18:25:57.758	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                    zigbee.0
                    2023-11-07 18:25:54.553	info	Terminated (NO_ERROR): Without reason
                    zigbee.0
                    2023-11-07 18:25:54.552	info	terminating
                    zigbee.0
                    2023-11-07 18:25:54.122	error	Error herdsman start
                    zigbee.0
                    2023-11-07 18:25:54.122	error	Failed to start Zigbee
                    zigbee.0
                    2023-11-07 18:25:54.121	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    2023-11-07 18:25:54.075	error	Re-commissioning your network will require re-pairing of all devices!
                    zigbee.0
                    2023-11-07 18:25:54.075	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                    zigbee.0
                    2023-11-07 18:25:54.075	error	Please update configuration to prevent further issues.
                    zigbee.0
                    2023-11-07 18:25:54.074	error	- Channel List: configured=11, adapter=11
                    zigbee.0
                    2023-11-07 18:25:54.074	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                    zigbee.0
                    2023-11-07 18:25:54.074	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                    zigbee.0
                    2023-11-07 18:25:54.074	error	- PAN ID: configured=6258, adapter=6258
                    zigbee.0
                    2023-11-07 18:25:54.074	error	Configuration is not consistent with adapter state/backup!
                    zigbee.0
                    2023-11-07 18:25:54.052	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2023-11-07 18:25:54.049	info	cleaned everything up...
                    zigbee.0
                    2023-11-07 18:25:53.725	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    2023-11-07 18:25:53.628	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-11-07 18:25:53.582	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                    zigbee.0
                    2023-11-07 18:25:21.806	info	terminating
                    zigbee.0
                    2023-11-07 18:25:21.336	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    zigbee.0
                    2023-11-07 18:25:21.335	info	terminating
                    zigbee.0
                    2023-11-07 18:25:21.335	warn	Failed to stop zigbee during startup
                    zigbee.0
                    2023-11-07 18:25:21.309	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2023-11-07 18:25:21.306	info	cleaned everything up...
                    zigbee.0
                    2023-11-07 18:25:21.299	error	Cannot read properties of undefined (reading 'getClients')
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    Wenn ich es richtig verstanden habe, stimmt etwas nicht mit dem Adapterstatus/Backup überein.
                    Ich habe allerdings keine Ahnung was und auch nicht wo ich etwas ändern kann.
                    Ich würde mich freuen, wenn einem unwissenden etwas unter die Arme gegriffen werden könnte.
                    Vielen Dank und VG
                      Thomas Braun Most Active @woupi last edited by
                      @woupi
                      Die Werte müssen übereinstimmen.
                        woupi @Thomas Braun last edited by
                        @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                        00124b002b48282c
                        Super, vielen Dank. Ich habe mich nicht getraut das einzutragen, jetzt habe ich es einfach rein kopiert und siehe da funktioniert.
                        Nochmal vielen Dank
                        • tiobb
                          tiobb last edited by
                          Hallo, ich hänge mich hier mal rein. Mein Zigbee will auch einfach nicht laufen, habe schon einiges ausprobiert was hier so geschrieben wurde, leider ohne Erfolg. Ich hoffe ihr könnt mir helfen. Wie ihr wisst, bin ich ein absoluter Anfänger, wenn möglich für ganz ganz doofe erklären.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Fri Nov  3 17:54:35 2023 from 192.168.178.45
                          pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
                          insgesamt 0
                          drwxr-xr-x 2 root root 60 Nov 13 14:01 .
                          drwxr-xr-x 4 root root 80 Nov 13 14:01 ..
                          lrwxrwxrwx 1 root root 13 Nov 13 14:01 usb-Texas_Instruments_TI_CC2531_USB_CDC__
                          Opera Momentaufnahme_2023-11-13_151230_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151201_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151139_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151104_192.168.178.76.png
                            Thomas Braun Most Active @tiobb last edited by
                            @tiobb
                            Der Geräte-Link ist ja auch offensichtlich falsch.
                            In den Einstellungen muss
                            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC__
                            eingetragen werden. Wobei mir der Dateiname auch irgendwie abgeschnitten aussieht.
                            tiobb 1 Reply Last reply Reply Quote 0
                            • tiobb
                              tiobb @Thomas Braun last edited by tiobb
                              Wenn ich das als code eingebe wird der Eintrag beschnitten.
                              insgesamt 0
                              lrwxrwxrwx 1 root root 13 Nov 13 14:01 usb-Texas_Instruments_TI_CC2531_USB_CDC__ _0X00124B001CDD4A3A-if00 -> ../../ttyACM0
                                Thomas Braun Most Active @tiobb last edited by Thomas Braun
                                @tiobb sagte in Zigbee iobroker Error while opening serialport:
                                Der Eintrag im Adapter muss also
                                /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
                                lauten. Am besten kopieren. Der vollständige Link steht aber als Service auch in der Ausgabe von
                                iob diag
                                fertig zum kopieren drin.
                                • tiobb
                                  Ok danke, jetzt scheint es zu funktionieren, bin der Meinung ich hatte das schon genauso in den Einstellungen stehen, aber wahrscheinlich irre ich mich.
                                    In deinen Screenshots definitiv nicht.
                                    • tiobb
                                      Ich hatte ja schon einiges probiert, aber egal, jetzt scheint es zu funktionieren, zumindest ist alles grün. Für meine Sensoren und den Bewegungsmelder von Aqara brauche ich erstmal neue Batterien ☺
                                        Greenhorn last edited by
                                        Ich hänge mich hier mal an mit meinem Problem:
                                        Versuche auch den Sonoff Zigbee 3.0 USB Dongle Plus am Raspi 4B zum Laufen zu bringen, aber leider ohne Erfolg 😞
                                        Bekomme die Meldung "You need save and run adapter before pairing!"
                                        Als Port habe ich den genauen Pfad angegeben:
                                        dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                                        Die erweiterte und die Pan-ID habe ich geändert, schon tausendmal neu gestartet, nix ändert sich. Bin mit meinem Latein nach Stunden am Ende und würde mich freuen, hier Hilfe zu bekommen...
                                        Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @Greenhorn last edited by
                                          @greenhorn
                                          Genaues Log vom Adapter-Start?
                                          • Meister Mopper
                                            Meister Mopper @Greenhorn last edited by
                                            @greenhorn sagte in Zigbee iobroker Error while opening serialport:
                                            Und zeig mal das Ergebnis ls -lAh /dev/serial/by-id
                                            231
                                            42351
