    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      Gismoh @Guest last edited by Gismoh
      @dp20eic
      Merci,
      dies hatte ich im Vorfeld auch bereits getan, allerdings mit "Hindernissen" 😉
      Schreibe nun mit, was passiert....
      -Adapter wurde deinstalliert,
      -ioBroker neugestartet
      beim Versuch ihn aus der Weboberfläche hinzuzufügen kommt folgende Fehlermeldung:
      $ iobroker add ble --host ioBrokerVM
      NPM version: 9.8.1
      Installing iobroker.ble@0.13.4... (System call)
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:2525) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T15_10_54_825Z-debug-0.log
      host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
      ERROR: Process exited with code 25
      Edit:
      Habe danach
      curl -sL http://iobroker.net/fix.sh | bash -
      und
      sudo -H -u iobroker npm cache verify
      gemacht, danach erneut versucht den BLE Adapter zu installieren, aber gleicher Fehler.
      da_Woody crunchip 2 Replies Last reply Reply Quote 0
      • da_Woody
        da_Woody @Gismoh last edited by
        @gismoh bin kein Profi, aber wenn ich dein post so lese.
        Du hast iob installiert, dann ble. Da hat noch alles geklappt. Danach das Backup eingespielt und locker flockig den Port 8081 verbogen.
        Ob das so gut gehen kann?
          crunchip Forum Testing Most Active @Gismoh last edited by
          @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
          hci0: urb 000000003977ddce failed to resubmit (2)
          Sieht aber irgendwie so aus als wenn da etwas nicht stimmt, unabhängig von deinem npm Problem
            Ist mir gerade eingefallen, schau mal bei meinem issue
            https://github.com/AlCalzone/ioBroker.ble/issues/801
            crunchip77 created this issue in AlCalzone/ioBroker.ble
            closed upgrade 0.13.3 auf 0.13.4 npm ERR #801
              Gismoh @da_Woody last edited by Gismoh
              @da_woody
              Dachte Backitup, ist das "Mittel der Wahl"?
              Habe allerdings nun das erste mal damit ein Backup widerhergestellt.
              Um noch mal zu sehen, das ich mir das nicht eingebildet hatte, das vor dem einspielen des Backups ioBroker ersteinmal "Normal" lief, die VM wieder vom früheren Zeitpunkt widerhergestellt.
              = Weboberfläche wieder mit :8081 aufrufbar, und ble ist grün und hat Geräte gefunden und aktualisiert die Werte.
              Nachtrag: Hab das Backup einspielen bereits zwei mal durch gemacht, jeweils mit einem neuen Backup. Aber das Ergebnis war jeweils dasselbe.
              crunchip da_Woody 2 Replies Last reply Reply Quote 0
                @gismoh dann deinstalliere doch mal den ble jetzt und spiel anschliessend dein backup zurück
                  Gismoh @crunchip last edited by
                  @crunchip
                  merci, werde ich dann heute später machen, muss nun ersteinmal vom Rechner weg - sonst holt die GG noch das Nudelholz 🤕
                  • da_Woody
                    jo, auf einem nackten system.
                    offensichtlich knallt dir da was rein. warum sollte die oberfläche nachher nicht mehr über :8081 erreichbar sein?
                    das war, was mich nochmal nachlesen hat lassen...
                    crunchip 1 Reply Last reply Reply Quote 1
                      crunchip Forum Testing Most Active @da_Woody last edited by
                      @da_woody sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                      Möglich das der admin nicht gestartet war
                        Gismoh @crunchip last edited by Gismoh
                        @crunchip @da_Woody
                        Admin war zuerst nicht gestartet, das stimmt, hatte ich aber über die Console nachgeholt.
                        Aber auch danach war er unter :8081 nicht erreichbar. Erst nachdem ich über die Console einen "admin.1" installiert hatte, war dieser dann über :8091 erreichbar.
                        Spiele gerade erneut ein Restore mit dem Backitup Adapter ein, habe diesmal alle Instanzen außer "admin" und "backitup" auf der Zielmaschine vorher deinstalliert.
                        Mal sehen 😉
                          gebunden vllt an die IP?
                            @crunchip
                            würde mich wundern, denn vor der Backup Einspielung hatte es ja mit 8081 geklappt - sonst hatte ich ja nichts geändert.
                            Oder wird im iobroker selber die IP noch "bestimmt" ?
                              @gismoh klar, aber was ist denn in der alten Installation eingestellt, sprich deinem backup? diese Einstellungen spielst du ja durch dein backup ein
                                @crunchip
                                wo wird denn im ioBroker die eigene IP gesetzt? Habe dort nichts gefunden.
                                  crunchip Forum Testing Most Active @Gismoh last edited by crunchip
                                  @gismoh in der admin Instanz...IP- Adresse
                                  sollte eigentlich auf 0.0.0.0 stehen
                                  G 2 Replies Last reply Reply Quote 1
                                    ioBroker wurde mit dem frischen Backup gefüttert, nun mit :8081 kein Zugriff.
                                    Dann update & upgrade abgesetzt, danach noch den fix.
                                    Kein Zugriff aufs Interface.
                                      Gismoh @Gismoh last edited by
                                      iobroker list instances
                                      liefert:
                                      root@ioBrokerVM:~# iobroker list instances
                                      + system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
                                        system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
                                      + system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
                                        system.adapter.ble.0                    : ble                   : ioBrokerVM                               - disabled
                                        system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
                                        system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
                                        system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
                                        system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
                                        system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
                                        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
                                        system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
                                        system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
                                        system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
                                        system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
                                        system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
                                        system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
                                        system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
                                        system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
                                        system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
                                        system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
                                        system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
                                        system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
                                        system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
                                        system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
                                        system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
                                        system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
                                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                        system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                        system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
                                        system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
                                        system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
                                        system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
                                        system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
                                        system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
                                        system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                        system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                        system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
                                        system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                        system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
                                        system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
                                        system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
                                        system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
                                        system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
                                      + instance is alive
                                        Gismoh @Gismoh last edited by Gismoh
                                        Ah, mit https:// komme ich drauf 😉
                                        vorher war ohne .... argh (schäm)
                                        Mal sehen, was nun die anderen Adapter sagen.
                                          sehe bereits, das einige adapter laufen, aber manche auch nicht (habe noch nicht alle ausprobiert).
                                          ble ist z.B. rot:
                                          verbunden mit host = rot
                                          lebenszeichen = rot
                                          Verbunden mit gerät oder dienst = grün.
                                          Komme nicht in die Einstellungen des Adapters rein, es wird 404, File Index_m.html not found angezeigt.
                                          bei VIS, ebenso 404.
                                          Werde nun mal die Konfiguration über Backitup einspielen, mal sehen ob es daran liegt. (mache aber vorher eine Sicherung der VM)
                                            @crunchip
                                            Leider auch keine Änderung, außer das ich nun ohne zweiten admin adapter reinkomme (mit https) ansonsten keine Änderung .
                                            24232
