    3. Einsteigerfragen
    4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
      crunchip Forum Testing Most Active @Gismoh last edited by
      @gismoh na im log nachsehen, da wird jeder adapter neu gebaut nach dem erfolgreichen restore
        Gismoh @crunchip last edited by
        @crunchip
        Delete adapter "ble"
        host.ioBrokerVM Counted 1 instances of ble
        host.ioBrokerVM Counted 1 meta of ble
        host.ioBrokerVM Counted 1 adapter for ble
        host.ioBrokerVM Counted 35 devices of ble
        host.ioBrokerVM Counted 37 channels of ble
        host.ioBrokerVM Counted 91 states of ble
        host.ioBrokerVM Counted 14 states of system.adapter.ble
        host.ioBrokerVM Counted 92 states (io.ble.*) from states
        host.ioBrokerVM Counted 13 states (system.adapter.ble.*) from states
        host.ioBrokerVM object ble deleted
        host.ioBrokerVM object ble.admin deleted
        host.ioBrokerVM Deleting 180 object(s).
        host.ioBrokerVM Deleting 105 state(s).
        Error deleting adapter ble from disk: Cannot find module 'iobroker.ble/io-package.json'
        Require stack:
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupInstall.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupUpgrade.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        You might have to delete it yourself!
        root@ioBrokerVM:~# iob add ble --debug
        NPM version: 9.8.1
        Installing iobroker.ble@0.13.4... (System call)
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/@abandonware/noble
        npm ERR! command failed
        npm ERR! command sh -c node-gyp-build
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@7.1.2
        npm ERR! gyp info using node@18.18.2 | linux | x64
        npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        npm ERR! (node:3048) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@abandonware/noble/build/config.gypi',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@abandonware/noble',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! Traceback (most recent call last):
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
        npm ERR!     sys.exit(gyp.script_main())
        npm ERR!              ^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
        npm ERR!     return main(sys.argv[1:])
        npm ERR!            ^^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
        npm ERR!     return gyp_main(args)
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
        npm ERR!     [generator, flat_list, targets, data] = Load(
        npm ERR!                                             ^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
        npm ERR!     result = gyp.input.Load(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
        npm ERR!     LoadTargetBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
        npm ERR!     build_file_data = LoadOneBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
        npm ERR!     build_file_contents = open(build_file_path, "rU").read()
        npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
        npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
        npm ERR! gyp ERR! configure error
        npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
        npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
        npm ERR! gyp ERR! node -v v18.18.2
        npm ERR! gyp ERR! node-gyp -v v7.1.2
        npm ERR! gyp ERR! not ok
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T23_56_22_185Z-debug-0.log
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
        root@ioBrokerVM:~#
        crunchip 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Gismoh last edited by crunchip
          @gismoh sag ich doch, das ist genau der Fehler den ich oben im git issue gezeigt hab
          ich habe nun in
          die folgenden Zeile von
          build_file_contents = open(build_file_path, 'rU').read()
          in
          build_file_contents = open(build_file_path, 'r').read()
          geändert.
          siehe nodejs/node-gyp#2219 (comment)
          BriceKrispies created this issue in nodejs/node-gyp
          closed ValueError: invalid mode: 'rU' while trying to load binding.gyp (Python 3.9 compatibility issue) #2219
          G 2 Replies Last reply Reply Quote 1
            @crunchip
            Okay, besten Dank!
            DOrt hatte ich bereits drübergeschaut, aber denke um dies anzugehen benötige ich meinen Freund - denke für mich als Laie ist dies nicht verständlich genug.
              @crunchip
              okay, danke für deine Erklärung, dann versuche ich mich dann doch mal dran 😉
                @gismoh
                du musst die Zeile
                mit nano aufrufen und das U in der entsprechenden Zeile entfernen
                abspeichern, fertig
                sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                dabei musst du ein stück nach unten blättern
                G Thomas Braun 2 Replies Last reply Reply Quote 1
                  @crunchip
                  Besten Dank für deine unermüdliche Hilfe!
                  muss allerdings erst schauen, wo die Datei bei mir ist, zumindest konnte ich die Datei mit "sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py" nicht finden, bzw. es wurde mir eine leere Datei angezeigt.
                    @gismoh dann installier mal zuerst die v0.13.3
                    iob add ble@0.13.3
                      @crunchip
                      NPM version: 9.8.1
                      Installing iobroker.ble@0.13.3... (System call)
                      npm ERR! code 1
                      npm ERR! (node:3259) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                      npm ERR!                                             ^^^^^
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T00_24_15_069Z-debug-0.log
                      host.ioBrokerVM Cannot install iobroker.ble@0.13.3: 1
                        @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                        npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                        die Datei muss es geben
                          @gismoh ok, bei mir ging die 0.13.3 damals, vllt auch weil sie vorher schon lief und das Problem bei einem upgrade auf die 0.13.4 entstand
                          G 3 Replies Last reply Reply Quote 0
                            @crunchip
                            Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                              @crunchip
                              ich verstehe auch "Logisch" nicht, das der ble vorher lief, nach Backup einspieleung nicht mehr. Kann ja auch nicht sein, das dadurch ganze ordner gelöscht wurden, denn andere Adapter laufen ja auch nach der Einspielung.
                                Gismoh @crunchip last edited by Gismoh
                                @crunchip
                                hmmm, vielleicht sollte ich nochmal das prozedre durchspielen, aber diesmal vor dem Backup das ble von der bestehenden Installation löschen - damit er diesen nicht mit sichert und einspielt - also den von der frischen Installation evtl. einfach behält? (hoffe das Backup löscht den dann nicht - weil nicht im Restore des Backups vorhanden.)
                                  nochmal,
                                  neu gebaut werden, aufgrund der Einstellungen aus deinem Backup und der neuen iobroker/nodejs Umgebung
                                    @gismoh kannst du machen, ble wird nicht gelöscht, der bleibt bestehen
                                    ich bin jetzt aber mal weg, viel Erfolg noch
                                      @crunchip
                                      dann werde ich mich mal ransetzen, wird aber vermutlich dauern, da ich vorher noch ein Karten-Kopie mache usw.
                                      Besten Dank an dich und dir eine schöne Nachtruhe!
                                        Gismoh @Gismoh last edited by
                                        Scheinbar ist das Backup einspielen von ioBroker (ohne Influx) doch schneller, als ich so gelesen habe.
                                        CPU und Netz-Auslastung sind nach 12 Minuten wieder quasi im Ruhezustand.
                                        Warte aber nun sicherheitshalber noch weiter ab.
                                          einfach eine Konsole deiner Wahl aufmachen und das aktuelle log anschauen
                                          iob logs --watch
                                            @crunchip
                                            merci, den Befehl kannte ich noch nicht 😉
                                            hier ein Auszug, scheint wirklich, das er nach 12 Minuten nichts mehr gemacht hatte:
                                            2023-11-08 11:45:41.207  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                                            2023-11-08 11:45:42.267  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                            2023-11-08 11:45:43.267  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                                            2023-11-08 11:45:43.268  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                            2023-11-08 11:45:44.908  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:45:44.909  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                            2023-11-08 11:45:49.371  - info: vis.0 (6542) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-08 11:45:49.603  - info: vis.0 (6542) vis license is OK.
                                            2023-11-08 11:45:49.792  - error: vis.0 (6542) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-11-08 11:45:49.793  - error: vis.0 (6542) unhandled promise rejection: Not exists
                                            2023-11-08 11:45:49.793  - error: vis.0 (6542) Error: Not exists
                                                at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                                                at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                                                at process.processImmediate (node:internal/timers:478:21)
                                            2023-11-08 11:45:49.794  - error: vis.0 (6542) Not exists
                                            2023-11-08 11:45:50.298  - info: vis.0 (6542) terminating
                                            2023-11-08 11:45:50.299  - warn: vis.0 (6542) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_45_45_224Z-debug-0.log
                                            2023-11-08 11:45:50.965  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                            2023-11-08 11:45:51.981  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                            2023-11-08 11:45:52.982  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
                                            2023-11-08 11:45:52.982  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
                                            2023-11-08 11:45:54.660  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:45:54.661  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
                                            2023-11-08 11:46:01.177  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s
                                            2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:
                                            2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install: 150 packages are looking for funding
                                            2023-11-08 11:46:01.178  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                                            2023-11-08 11:46:01.205  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
                                            2023-11-08 11:46:01.278  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                            2023-11-08 11:46:01.285  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                            2023-11-08 11:46:01.290  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                            2023-11-08 11:46:01.293  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                            2023-11-08 11:46:01.297  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                            2023-11-08 11:46:01.301  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                            2023-11-08 11:46:01.305  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                            2023-11-08 11:46:01.309  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                            2023-11-08 11:46:01.313  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                            2023-11-08 11:46:01.329  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                            2023-11-08 11:46:01.333  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                            2023-11-08 11:46:01.679  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                            2023-11-08 11:46:01.683  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                            2023-11-08 11:46:01.686  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                            2023-11-08 11:46:01.693  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                            2023-11-08 11:46:01.696  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                            2023-11-08 11:46:01.699  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                            2023-11-08 11:46:01.748  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                            2023-11-08 11:46:01.875  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                            2023-11-08 11:46:02.022  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                            2023-11-08 11:46:02.170  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                            2023-11-08 11:46:02.346  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                            2023-11-08 11:46:02.520  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                            2023-11-08 11:46:02.705  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                            2023-11-08 11:46:02.739  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                            2023-11-08 11:46:02.776  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                            2023-11-08 11:46:02.808  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                            2023-11-08 11:46:02.844  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                            2023-11-08 11:46:02.897  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                            2023-11-08 11:46:02.932  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                            2023-11-08 11:46:02.967  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                            2023-11-08 11:46:03.003  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                            2023-11-08 11:46:03.008  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                            2023-11-08 11:46:03.029  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                            2023-11-08 11:46:03.033  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                            2023-11-08 11:46:03.040  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                            2023-11-08 11:46:03.046  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                            2023-11-08 11:46:03.050  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                            2023-11-08 11:46:03.056  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                            2023-11-08 11:46:03.061  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                            2023-11-08 11:46:03.066  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                            2023-11-08 11:46:03.071  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                            2023-11-08 11:46:03.079  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                            2023-11-08 11:46:03.085  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                            2023-11-08 11:46:03.089  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                            2023-11-08 11:46:03.100  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                            2023-11-08 11:46:03.107  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                            2023-11-08 11:46:03.124  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                            2023-11-08 11:46:03.135  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                            2023-11-08 11:46:03.139  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                            2023-11-08 11:46:03.143  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                            2023-11-08 11:46:03.147  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                            2023-11-08 11:46:03.328  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                                            2023-11-08 11:46:04.395  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                            2023-11-08 11:46:05.396  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
                                            2023-11-08 11:46:05.396  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
                                            2023-11-08 11:46:07.069  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:46:07.070  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
                                            2023-11-08 11:46:17.160  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
                                            2023-11-08 11:46:17.184  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
                                            2023-11-08 11:46:17.263  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                            2023-11-08 11:46:17.270  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                            2023-11-08 11:46:17.274  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                            2023-11-08 11:46:17.281  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                            2023-11-08 11:46:17.285  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                            2023-11-08 11:46:17.288  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                            2023-11-08 11:46:17.291  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                            2023-11-08 11:46:17.294  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                            2023-11-08 11:46:17.298  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                            2023-11-08 11:46:17.301  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                            2023-11-08 11:46:17.304  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                            2023-11-08 11:46:17.307  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                                            2023-11-08 11:46:17.310  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                                            2023-11-08 11:46:17.313  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                                            2023-11-08 11:46:17.434  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                                            2023-11-08 11:46:18.498  - info: host.ioBrokerVM iobroker npm-install: exit 0
                                            2023-11-08 11:46:19.499  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                                            2023-11-08 11:46:19.499  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                                            2023-11-08 11:46:21.160  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:46:21.161  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                            2023-11-08 11:46:25.314  - info: vis.0 (6854) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-08 11:46:25.483  - info: vis.0 (6854) vis license is OK.
                                            2023-11-08 11:46:25.699  - error: vis.0 (6854) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-11-08 11:46:25.699  - error: vis.0 (6854) unhandled promise rejection: Not exists
                                            2023-11-08 11:46:25.700  - error: vis.0 (6854) Error: Not exists
                                            2023-11-08 11:46:25.700  - error: vis.0 (6854) Not exists
                                            2023-11-08 11:46:26.207  - info: vis.0 (6854) terminating
                                            2023-11-08 11:46:26.208  - warn: vis.0 (6854) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2023-11-08 11:46:26.909  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_21_469Z-debug-0.loghost.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                            2023-11-08 11:46:27.929  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                            2023-11-08 11:46:28.929  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                                            2023-11-08 11:46:28.929  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                            2023-11-08 11:46:30.593  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:46:30.594  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                            2023-11-08 11:46:34.599  - info: vis.0 (6963) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-08 11:46:34.921  - info: vis.0 (6963) vis license is OK.
                                            2023-11-08 11:46:35.089  - error: vis.0 (6963) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-11-08 11:46:35.089  - error: vis.0 (6963) unhandled promise rejection: Not exists
                                            2023-11-08 11:46:35.090  - error: vis.0 (6963) Error: Not exists
                                            2023-11-08 11:46:35.090  - error: vis.0 (6963) Not exists
                                            2023-11-08 11:46:35.593  - info: vis.0 (6963) terminating
                                            2023-11-08 11:46:35.594  - warn: vis.0 (6963) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_30_898Z-debug-0.log
                                            2023-11-08 11:46:36.231  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                            2023-11-08 11:46:37.248  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                            2023-11-08 11:46:38.248  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                                            2023-11-08 11:46:38.249  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                                            2023-11-08 11:46:39.906  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                                            2023-11-08 11:46:39.908  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                                            2023-11-08 11:46:43.890  - info: vis.0 (7072) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                                            2023-11-08 11:46:44.072  - info: vis.0 (7072) vis license is OK.
                                            2023-11-08 11:46:44.242  - error: vis.0 (7072) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-11-08 11:46:44.242  - error: vis.0 (7072) unhandled promise rejection: Not exists
                                            2023-11-08 11:46:44.243  - error: vis.0 (7072) Error: Not exists
                                            2023-11-08 11:46:44.243  - error: vis.0 (7072) Not exists
                                            2023-11-08 11:46:44.747  - info: vis.0 (7072) terminating
                                            2023-11-08 11:46:44.747  - warn: vis.0 (7072) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2023-11-08 11:46:45.412  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T10_46_40_207Z-debug-0.log
                                            2023-11-08 11:46:45.413  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                                            2023-11-08 11:46:46.434  - info: host.ioBrokerVM iobroker npm-install: exit 25
                                            2023-11-08 11:46:47.435  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                            24252
